How Many Amps Does a TV Use? Converting Watts to Amps and Planning Backup
A TV's current draw depends on its power use, supply voltage, and power factor. If you're asking how many amps a TV uses, screen size, picture mode, and brightness also affect its load. The input rating on the label can be higher than its measured draw during viewing. This guide uses an ENERGY STAR example to explain the calculation and its assumptions, distinguishes nameplate ratings from measurements, and shows how to budget a TV, cable box, and router for an outage.
Maybe you're adding a TV to a crowded power strip or checking whether a backup battery can carry it. For a single-phase AC load, current in amps = real power in watts ÷ (voltage × power factor). Dividing watts by 120V alone assumes a power factor of 1. That simplified calculation is an illustration, not a measurement of your TV's current.
For example, a 70W TV at 120V would draw about 0.58A if its power factor were 1. At a hypothetical power factor of 0.7, the same 70W load would draw about 0.83A. These are calculation examples, not measured ratings for a particular model. Screen size and picture settings can change the watts, while power factor also affects the current.
A Real 55-Inch Example
ENERGY STAR lists a certified 55-inch LG model (55QNED80AU*) at 70.3W of on-mode power and 0.4W in standby in its certified TV listing. Assuming 120V and a power factor of 1, 70.3W ÷ 120V gives about 0.59A. The listing does not provide the current or power factor, so 0.59A is a conditional calculation, not an official measured amperage. Check the AC input rating or measure current for your own TV.
Watts to Amps by TV Size
The table below illustrates watts-to-amps calculations at 120V, assuming a power factor of 1. The wattages are example loads, not a market survey. Actual current requires the relevant power factor or a current measurement.
TV on-mode watts (examples) | Calculated amps at 120V (PF = 1) |
25W (small TV) | About 0.2A |
70W (55-inch LED example) | About 0.6A |
150W (large screen, bright setting) | About 1.25A |
Whether you ask how many amps a TV takes, draws, or pulls, the answer depends on the particular model and operating conditions. Use its specified AC input current or a suitable meter; a watts-only example cannot establish the actual amperage of most TVs.
Why the Full AC Formula Matters
In Oracle’s single-phase AC power formula, real power equals voltage × current × power factor. Rearranging gives I = P ÷ (V × PF). Voltage and current here are RMS values, and PF is the ratio of real power to apparent power. When PF is below 1, the current is higher than P ÷ V; the size of the difference depends on PF.
For circuit or power-strip planning, check each device's AC input rating and the combined load against the equipment ratings, or measure actual AC current with a suitable meter. Do not rely on P ÷ V as a guaranteed current estimate when PF is unknown. For the watts used in battery-runtime estimates, compare smart, LED, and OLED TVs and measure your own setup.
The TV is rarely the only thing plugged in, though. If you want to watch the news through an outage, the cable box and router need power too, and their watts go on the same list.
Watching TV During a Power Outage
When the lights go out, the first thing most people want is information. U.S. electricity customers averaged 11 hours of interruptions in 2024, nearly twice the yearly average of the decade before, according to the EIA power interruption report.
To keep a TV on through hours like that, add up the TV, the cable or streaming box, and the router. Use measured watts if you can, and then size your backup to the hours you expect between recharges.
Add Up the Whole Setup
If you're working out how many amps for a TV and everything attached to it, start with watts for each device. A few checks keep the total honest:
Running watts: Measure the TV with the picture on, at the brightness you really use.
Standby watts: Note what each box draws when it's "off" but still plugged in.
Brightness changes: A daytime setting can draw more than a dim evening one.
The network gear: Count the modem and router if you stream or need Wi-Fi.
As a hypothetical example, a 70W TV, a 20W cable box, and a 15W router total 105W. At 120V and PF = 1, that would be about 0.88A; this is not a measured current for the setup. Four hours at a steady 105W uses about 420Wh, and eight hours uses about 840Wh. Use real watts and watt-hours to estimate battery runtime, and check current separately against the output ratings.
Keep a battery-powered weather radio around as well. The National Weather Service’s NOAA Weather Radio guidance explains that transmitters broadcast 24 hours a day, with watches, warnings, and advisories taking priority during severe weather.
A Portable Option for One TV
When a storm knocks out power, the TV is often how a household follows the news. A portable power station is one way to keep it on for a limited time. An EcoFlow portable power station has standard AC outlets, so a TV, streaming box, and router plug straight in. How long they run depends on the battery's capacity and your actual load.
Say your plan is one TV and a streaming box for a few hours each evening. That's a small load, and a station around 1kWh is sized for it. EcoFlow DELTA 3 Classic stores 1,024Wh and recharges from 0 to 80% in about 45 minutes on wall power, per EcoFlow.
When the Cable Box and Router Run Too
What if the cable box and router have to stay on, and it may be a full day before you can recharge? The load is still small, but the hours add up. A station with about 2kWh doubles the stored energy. EcoFlow DELTA 3 Max holds 2,048Wh and can recharge from solar panels, a car, or a wall outlet.
Which one fits depends on hours and load. The split looks like this:
EcoFlow DELTA 3 Classic: One TV and short viewing sessions.
EcoFlow DELTA 3 Max: TV, cable box, and router over longer gaps between recharges.
Runtime Estimates
How many hours does that work out to? The table below shows estimates, and your results will vary. The method is usable capacity (watt-hours × 0.85 for conversion losses) divided by the load in watts.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable, est.) | EcoFlow DELTA 3 Max (1,741Wh usable, est.) |
55-inch TV (ENERGY STAR example) | About 70W | About 12 hours | About 25 hours |
TV 70W + cable box 20W + router 15W | About 105W | About 8.3 hours | About 17 hours |
The cable-box and router wattages are assumptions for this example. Use your own devices' measured watts or label ratings to make a budget, and remember that actual runtime will vary.
A brighter picture or a bigger screen shortens these hours. A powered router also doesn't mean the internet is up, because your provider's network has to be working too. For a wider view of loads, see what power stations can run besides a TV.
Those estimates depend on real watts. That brings us back to the label on the TV.
Nameplate Amps vs Real TV Power Use
Have you looked at the back of your TV and seen a bigger number than you expected? The label, or the power supply, lists a maximum. Normal viewing usually sits well under it.
Why the Label Number Runs High
The nameplate AC input rating is useful when checking circuit and power-supply limits, but it is not a measurement of the watts used during viewing. Multiplying AC input amps by volts gives volt-amperes (VA), not necessarily real watts. For battery-runtime calculations, start from measured real power in watts; for current-limit checks, use the specified AC input current or a suitable measurement.
Where do you find the label? On most flat screens, it's a sticker on the back panel near the power cord. If your TV uses an external power brick, the brick carries its own rating, and the owner's manual usually lists the specs too.
What Changes the Real Number
Real draw moves with brightness and with what's on the screen. HDR and "vivid" modes draw more, and eco modes draw less.
ENERGY STAR builds this into its program. Its on-mode limits are tied to screen area, and certified models report on-mode power measured under a set test procedure, as the ENERGY STAR television criteria explain. A listed figure is a fair comparison point, but your settings can land above or below it.
Measure It Yourself
A plug-in watt meter settles the question in a few minutes. Plug the meter into the wall, plug the TV into the meter, and watch a normal show. Then try your brightest mode and write down both readings.
Give each test a few minutes, since the reading can swing between bright and dark scenes. Write down the highest steady number you see. Then turn the TV off with the remote and note the standby reading too, so your outage list has both numbers.
If the meter shows amps and watts side by side, the two won't always match the simple math. It's worth brushing up on calculating amps, volts, and watts so the readings make sense.
One number is left to check. It's what the TV draws when the screen is dark.
How Much Power Does a TV Use in Standby?
Does a TV that's "off" still use power? It does, but very little on newer models. ENERGY STAR caps standby-passive power at 0.5 watts for certified TVs, and the 55-inch example above measured 0.4 watts.
What Standby Looks Like in Amps
At 120V and PF = 1, a 0.5W load would calculate to about 0.0042A. That is a conditional example, not the measured standby current of a TV. For TVs capable of network connectivity, ENERGY STAR’s criteria set a separate standby-active limit of 1.0W. Measure current or use the relevant PF rather than inferring actual standby amps from watts alone.
What does that add up to over a year? Half a watt left on around the clock comes to about 4.4 kilowatt-hours. That's small next to viewing, which ENERGY STAR lists at 128 kWh a year for the 55-inch example.
Older TVs and Connected Boxes
Cable boxes and game consoles can draw more than the TV does in standby, so measure them along with the screen. Samsung TV power consumption shows how the figures vary within one brand.
If a box doesn't need to stay on overnight, a power strip with a switch cuts its standby draw completely. Check first, though, because some cable boxes take a while to restart and reload the channel guide.
So how many amps does a television use? Check the model's AC input rating or measure its current; watts alone do not give actual amps without voltage and power factor. For the 70.3W ENERGY STAR example, about 0.59A at 120V assumes PF = 1. ENERGY STAR certified TVs use 0.5W or less in standby-passive mode, with a separate limit for network-connected standby. Measure your real watts, then add the cable box and router to estimate outage runtime. EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max are two sizes to compare for that load.
How many amps does a 55-inch TV use?
A 70W example calculates to about 0.58A at 120V only if PF = 1. Screen size alone does not determine current. Check your model's specified AC input current or measure it; if calculating from real watts, use I = P ÷ (V × PF).
How many amps does a TV use on standby?
The current depends on voltage and PF as well as standby watts. ENERGY STAR limits certified TVs to 0.5W in standby-passive mode and 1.0W in network-connected standby-active mode. Dividing 0.5W by 120V gives about 0.0042A only under the PF = 1 assumption; it is not a measured standby-current specification.
Can a TV share a circuit?
A TV can share a circuit if the combined load stays within the circuit and connected equipment ratings. Check the TV's specified AC input current and count every other device on that circuit, including high-load heaters and kitchen appliances. Do not use the PF = 1 examples as a substitute for those current-limit checks.
How do I find my TV's watts?
Start with the label on the back or the owner's manual. The ENERGY STAR listing for your model is another source. For a number that matches your settings, use a plug-in watt meter.
Can a power station run a TV?
Yes, if the TV and other connected devices fit within the station's AC output power and current ratings. Estimate runtime from stored energy and the setup's measured real watts. Check current limits separately rather than treating the simplified watts-to-amps examples as actual device measurements.
