Steam Deck Charger Wattage: What the 45W Power Supply Means for Charging
Valve ships every Steam Deck with a 45-watt USB-C Power Delivery charger. That number is the most the charger can supply. It isn't what flows into the battery every minute. Real charging speed depends on what the Deck asks for and whether you're playing while it's plugged in. This guide explains Steam Deck charger wattage in plain terms. It also covers how to pick a replacement or travel charger, why the cable matters, how much battery the Deck holds, and when a power station makes sense at camp or during an outage.
What Is the Steam Deck Charger Wattage?
Maybe your charger went missing, or you want a spare for your travel bag. Either way, start with the rating on the original. Valve's Steam Deck spec sheet lists a "45W USB Type-C PD3.0 power supply" for the LCD model. The Steam Deck tech specs page shows the same 45W supply for the OLED model.
Same Charger, Different Batteries
So if you're comparing steam deck charger watts between the two versions, there's nothing to compare. The steam deck power supply is rated at 45W on both. The battery size and the length of the charger cable are what differ.
Spec
Steam Deck LCD
Steam Deck OLED
Power supply
45W USB-C PD 3.0
45W USB-C PD 3.0
Battery
40Wh
50Wh
Valve's gameplay estimate
2 to 8 hours
3 to 12 hours
Charger cable
1.5m (about 5 feet)
2.5m (about 8 feet)
Rated Watts vs. Charging Watts
Does a 45W charger push 45 watts into the battery the whole time? It doesn't. Three different numbers tend to get mixed together.
  • Adapter rating: The most the charger can supply. For the Deck's charger, that's 45W.
  • Negotiated power: What the Deck and the charger agree on when you plug in.
  • Battery charging power: What's left for the battery after the system takes its share.
USB Power Delivery is built around that second number. It lets each device take only the power it needs, according to the USB-IF Power Delivery overview. That's why steam deck charging watts move up and down during a session.
Playing while you charge changes the third number. Part of the charger's output runs the game, so less of it reaches the battery and the battery fills more slowly. Charging also eases off as the battery gets close to full. If you put a meter on the cable, the steam deck watts you see will rarely sit at 45. A USB-C charger wattage guide can help you compare ratings across the rest of your gear.
The original charger works anywhere there's a standard outlet. That includes the AC outlet on a portable power station, which matters if you game at camp or through an outage.
Charging a Steam Deck at Camp or During an Outage
Picture a three-day weekend at a campsite with no hookups. Or picture a storm that knocks out power on your street for a couple of days. At home on a normal day, a lost charger is easy to solve with the right USB-C charger and cable. Long stretches away from a working outlet are a different problem, because you need stored energy and not just a charger.
Two Ways to Plug In
A portable power station gives you two ways to charge the Deck. Both leave the Deck in control of how much power it takes.
  • AC outlet: Plug the original 45W charger into the station, the same way you'd plug it into a wall.
  • USB-C port: Use a USB-C PD port that supplies at least 45W, with a good cable.
A bigger station doesn't raise the charge power the Deck accepts. One handheld is a light load, so station size only changes how many times you can refill it.
alt: Steam Deck charging directly from the EcoFlow DELTA 3 Classic's 100W USB-C PD port; the AC outlets are unused.
Check Watt-Hours Against Your Trip
How long will you be away from a wall outlet? For car camping, that's the question to answer first. Add up the watt-hours you'll use between chances to recharge the station, then compare that total to its capacity. For bigger setups, read more on portable power for gaming before you pack.
Illustrative scene: direct USB-C PD charging through the 100W port, with both plugs fully inserted.Illustrative scene: direct USB-C PD charging through the 100W port, with both plugs fully inserted.
If that kind of trip or outage is what you're planning for, a 1kWh station is a sensible size for one handheld plus a few small devices. EcoFlow DELTA 3 Classic is one example. You plug the Steam Deck's original 45W charger into its AC outlet, just as you would at home. It weighs about 27 pounds, so it belongs at a campsite or in a hall closet. It's too big to carry around like a battery pack. A station this size can refill a 40 to 50Wh handheld many times, with energy left over for phones and lights.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
What the Estimates Look Like
How many recharges is "many"? The table below works through an example. Every figure in it is an estimate, and the 20% charging loss is a placeholder for energy lost in the adapter and battery.
Example (estimate)
Steam Deck LCD
Steam Deck OLED
Battery size, per Valve
40Wh
50Wh
Energy per full charge with 20% loss
About 50Wh
About 63Wh
Usable energy in EcoFlow DELTA 3 Classic (about 85% of 1,024Wh)
About 870Wh
About 870Wh
Estimated full charges
About 17
About 13
The math is usable watt-hours divided by the energy each charge takes. Your real count will be lower if you play while charging or run other devices from the station. Any backup lasts for a limited period that depends on the battery capacity and the actual load.
Heat matters at camp too. EcoFlow lists a charging temperature range of 32°F to 113°F for the station. The CPSC notebook computer tips warn against leaving a portable computer in places that may get very hot, such as a closed car in summer.
That covers long stays away from outlets. Everyday charging is simpler.
Choosing a Replacement or Travel Charger
Say the original charger got left in a hotel room, or you want a smaller one for flights. Whether you search for "steamdeck charger wattage" or "steam deck wattage charger," the advice is the same. Match the original: USB-C Power Delivery at 45W or more.
Steam Deck Replacement Travel ChargerSteam Deck Replacement Travel Charger
What to Look For
  • USB-C PD support: The listing should name USB Power Delivery, not just a USB-C plug.
  • 45W or more from one port: Multi-port chargers split their total, so check the single-port rating.
  • A cable rated for the actual load: A quality 3A/60W USB-C cable covers the Deck's 45W input, including when the PD charger is rated at 65W or 100W. For another device that actually needs more than 60W, choose an appropriately rated 5A, electronically marked cable. See USB-IF's cable power-rating guidance; the charger's maximum rating alone does not set the Deck's draw.
  • A known brand with a safety listing: Skip no-name chargers with no test mark.
The U.S. Fire Administration charging tips say to use the charger that came with a device or one from a reputable supplier. They also suggest devices certified by a nationally recognized testing laboratory, such as UL, and say to unplug a device that gets noticeably hot while charging.
Will a Bigger Charger Hurt the Deck?
A 65W or 100W laptop charger is fine as long as it supports USB-C PD. A higher rating won't force extra power into the Deck. The steam deck charge wattage is set by what the Deck negotiates, and the charger's label only sets the upper limit.
Going smaller is where you'll notice a difference. A low-watt phone charger may charge the Deck slowly, and it may not keep up while you play.
Don't Overlook the Cable
A weak cable can hold back a good charger. A standard 3A USB-C cable carries up to 60W, which covers the Deck. See these tips on durable fast USB-C cables before you buy a spare.
Once charging is sorted, battery life is the other half of the picture. It depends on more than the size of the battery.
How Long Does a Steam Deck Battery Last?
Ever wonder why one game drains the battery in two hours and another lasts all afternoon? Battery life depends on the game and your settings. Valve gives a range of 2 to 8 hours for the LCD model and 3 to 12 hours for the OLED model.
What Valve's Estimate Assumes
Valve bases the LCD estimate on games running at 30FPS with 50% brightness and 50% volume. Its spec sheet says different settings can drain the battery faster.
Settings That Stretch a Charge
Want more time between charges? Start with the three settings Valve names.
  • Frame rate: A 30FPS cap uses less power than an uncapped frame rate.
  • Brightness: A dimmer screen stretches a charge.
  • Volume: Lower speaker volume helps too.
Accessories can change power use as well. Before a long trip, look at popular Steam Deck upgrades and note which ones draw from the Deck's battery.
Steam Deck charger wattage is 45W over USB-C PD 3.0, per Valve, on both models. That's the most the charger can supply, and real charging speed changes with what you're playing and how full the battery is. For a replacement, choose a USB-C PD charger rated at 45W or more and pair it with a quality cable. If you're planning for camp or an outage, EcoFlow DELTA 3 Classic can power the original charger from its AC outlet.
How many watts is the Steam Deck charger?
The charger that comes in the box is rated at 45W and uses USB-C Power Delivery 3.0. Valve lists that same rating for the LCD and OLED models. It's the charger's maximum, so the Deck often draws less.
Can I use a 65W charger on a Steam Deck?
Yes, as long as it's a USB-C PD charger. The Deck and the charger agree on a power level, and the Deck takes only what it asks for.
Can I charge a Steam Deck with a phone charger?
You can in a pinch, but expect slow charging. A low-watt charger may fall behind if you play at the same time. For normal charging, use a USB-C PD charger rated at 45W or more.
How big is the Steam Deck battery?
Valve lists a 40Wh battery in the LCD model. The OLED model has a larger 50Wh battery, which is one reason its gameplay estimate is longer.
Can a power station charge a Steam Deck?
Yes. Plug the original charger into the station's AC outlet, or use a USB-C PD port rated at 45W or more. The Deck still charges at its own pace, so a larger station adds recharges and doesn't add speed.
Portable Power Stations
