Tankless Water Heater Installation: Steps, Costs, and What to Expect
Replacing a storage water heater with a tankless model involves more than finding room on a wall. The plumbing connections move, a gas unit may need different venting or a larger fuel supply, and a whole-home electric model can place a substantial new load on the service panel. Those details often determine the final price more than the heater itself.
For the right household, the conversion can still make sense. A properly sized tankless system provides hot water without holding 40 or 50 gallons in reserve, and its compact footprint can reclaim useful space in a utility room or garage. This guide explains what to review before installation, how the work is typically completed, what common U.S. projects cost, and what to expect once the system is operating.
What Should You Know Before Installing a Tankless Water Heater?
Begin with the house, not the product catalog. The installer needs to know the coldest incoming-water temperature, the fixtures that may run together, the available gas or electrical capacity, and where venting and drainage can go. A model that performs well in one home may deliver disappointing flow in another if those conditions are different. If outage resilience is part of the plan, assess whether a portable power station is compatible with a gas model’s electrical controls.
Choose the Right Tankless Water Heater
Natural gas and propane models generally offer enough heating capacity for higher simultaneous flow, which can suit a home with several bathrooms. They require a correctly sized fuel supply, combustion air, and an approved exhaust route. Condensing models also produce acidic condensate that must be drained according to the manufacturer’s instructions and local code.
Electric tankless heaters are compact and need no combustion vent. Point-of-use models can serve a remote sink or a small, limited load, while whole-home models require much more electrical capacity. The lower equipment price of an electric unit can be offset if the project calls for new branch circuits, a larger panel, or a service upgrade.
Size a Tankless Water Heater for Your Household
Tankless systems are sized by flow rate, measured in gallons per minute (GPM), and temperature rise. Temperature rise is the difference between the incoming cold-water temperature and the desired outlet temperature. Colder groundwater requires the heater to add more heat, so the same unit may deliver fewer gallons per minute in a northern winter than it does in a warm climate.
List the hot-water fixtures that may operate at the same time. A 2.0 GPM shower and a 1.5 GPM faucet create a combined demand of 3.5 GPM. Then compare that demand with the manufacturer’s flow table at the temperature rise your home requires. The largest advertised GPM figure is usually based on a relatively small temperature rise and may not represent winter performance at your address.
Electrical Requirements and Backup-Power Compatibility
Have the service panel evaluated before ordering a whole-home electric model. Depending on its output, the heater may require several dedicated 40-amp double-pole breakers, heavy-gauge wiring, and enough unused service capacity to carry the new load. In some homes, that leads to a 200-amp service upgrade; in others, the existing panel is adequate. A load calculation should settle the question before installation begins.
Gas tankless heaters use fuel to heat the water, but most current models still require a 120V receptacle for electronic ignition, controls, freeze protection, and an exhaust fan. As a result, a gas unit will usually stop producing hot water when utility power fails.
For compatible models, the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) can provide backup electricity for essential components, helping maintain hot water during blackouts. Check the heater’s running wattage, startup surge, and plug configuration before connecting backup power.
1.3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2.2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 3. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
Permits and Professional Installation Requirements
Permit requirements are set locally, and the work may fall under plumbing, mechanical, fuel-gas, electrical, or building rules. A tank-to-tankless conversion often touches more than one trade, particularly when it includes a new gas line, exterior vent penetration, dedicated circuit, or panel work.
A qualified installer should verify gas-pipe capacity, vent clearances, combustion-air provisions, pressure relief, condensate disposal, electrical protection, and access for future service. The completed job may also require an inspection before the permit is closed.
How to Install a Tankless Water Heater
A straightforward tankless-to-tankless replacement may reuse much of the existing infrastructure. Converting from a storage tank is more involved because the water connections, vent, gas demand, electrical supply, and mounting location may all change. Coordinate any planned home backup power with the installer before circuits and equipment locations are finalized.
Step 1: Remove the Existing Unit and Prepare the Installation Area
The installer shuts off the water and the applicable gas or electrical supply. A storage tank must cool and drain before it can be disconnected and removed. If the old unit is gas-fired, the existing vent is evaluated rather than automatically reused; tank-style venting is not necessarily suitable for a tankless heater.
Next, the installer confirms the mounting location and service clearances. The wall must support the unit and provide access to the inlet screen, isolation valves, controls, and heat exchanger. A code-approved backing surface or fire-rated board may be installed where required. The crew also plans the routes for water, gas, wiring, venting, condensate, and the pressure-relief discharge.
Step 2: Mount the Unit and Connect the Water Lines
The heater is fastened securely to wall framing or another approved support. The plumber then routes the cold-water supply to the inlet and connects the hot-water outlet to the home’s distribution piping. Pipe size and layout should preserve adequate flow without creating unnecessary pressure loss.
Isolation service valves are commonly installed on both water connections. They allow the heat exchanger to be flushed and descaled without shutting off water to the entire house. A pressure-relief valve and discharge pipe are added as required by the model instructions and local code.
Some systems also need a thermal expansion tank, particularly when a check valve or pressure-reducing valve creates a closed plumbing system. A drain pan may be required for an indoor installation where leakage could damage the building. These items depend on the plumbing configuration and local rules rather than on the word “tankless” alone.
Step 3: Complete Electrical, Gas, and Venting Work as Required
The remaining connections depend on the fuel type:
  • Gas models: The installer calculates the fuel demand of the heater and other appliances, then checks the meter, regulator, pipe diameter, pipe length, and fittings. An existing 1/2-inch line may need to be replaced with a 3/4-inch line, but that is not automatic; some models are designed for compatible 1/2-inch installations under specified conditions. The technician also installs the manufacturer-approved intake and exhaust system or confirms that an outdoor model meets location requirements.
  • Electric models: An electrician installs the breaker configuration, conductor size, disconnecting means, and grounding required for that unit. Whole-home models may need several dedicated circuits, so the work should be based on the nameplate and installation manual rather than a generic wattage rule.
For a condensing gas heater, the contractor also routes the condensate drain and installs a neutralizer if the manufacturer or local plumbing rules require one. In cold climates, exterior terminations must be positioned to reduce the chance that snow, ice, or recirculated exhaust will obstruct airflow.
Step 4: Commission the Unit and Test Its Operation
After the connections are complete, the installer opens the water supply, purges air from the piping, and checks every new joint for leaks. A gas system also receives the required fuel-pressure and leak testing. The unit is then powered on and configured for the home’s fuel type, elevation, recirculation arrangement, and other applicable settings.
Many households use 120°F as the initial outlet setting. The installer should confirm the temperature at a fixture rather than relying only on the display, then run enough hot-water outlets to verify stable heating and flow. Testing should also cover ignition, venting, condensate drainage, error codes, and any recirculation controls included in the project.
Commissioning is the point at which sizing or supply problems become visible. If temperature drops sharply when a second fixture opens, the installer should determine whether the cause is unit capacity, a flow restriction, gas pressure, an electrical issue, or a control setting before closing the job.
EcoFlow DELTA Pro Ultra X Whole-Home Backup PowerEcoFlow DELTA Pro Ultra X Whole-Home Backup Power
How Much to Install a Tankless Water Heater
The Home Depot’s published cost guide gives a tankless installation range of $2,400 to $5,400, although a simple replacement may cost less and an infrastructure-heavy conversion can cost considerably more. Regional labor rates, equipment capacity, fuel type, access, permits, and utility upgrades all influence the final quote.
The figures below are illustrative budgeting allowances from this draft, not verified local quotes or the retailer’s category-by-category prices. A useful proposal separates the heater, standard installation labor, old-unit removal, permits, venting, gas or electrical upgrades, condensate work, and any wall repair. Comparing tankless water heater cost by fuel type helps identify which items belong in each quote.
Project Type / Component
Average U.S. Cost Range
Key Cost Drivers
Electric Tankless (Installed)
$1,500 – $3,000
Unit wattage, distance from main breaker panel
Gas Tankless (Installed)
$2,500 – $4,800
Condensing vs. non-condensing model, vent run length
Tankless-to-Tankless Replacement
$1,800 – $3,200
Reusing existing gas lines, venting, and electrical
Tank-to-Tankless Conversion
$2,800 – $5,500+
New venting, gas pipe upsizing, panel upgrades
Permits & Inspection Fees
$100 – $450
Local city or county fee schedules
Typical Installed Costs for Gas and Electric Models
An electric tankless heater may cost about $500 to $1,200 for the equipment. Installation can remain relatively affordable when the panel has sufficient capacity, and the unit is close to it. Long wire runs, multiple new circuits, or a service upgrade change the economics quickly.
Gas units often cost about $1,000 to $2,200 before installation. Labor is generally higher because the job may include fuel-pipe calculations, a new vent system, combustion-air provisions, and condensate drainage. In a region with inexpensive natural gas, operating costs may be lower than those of an electric resistance model, but the result depends on local utility rates and household use.
Installation Costs for Replacement vs. Conversion
Replacing an existing tankless heater with a compatible model is usually the least disruptive job. Water lines, the electrical supply, and parts of the venting or gas system may already be in suitable locations. They still need inspection; “existing” does not automatically mean compatible with the new unit.
A tank-to-tankless conversion moves the job beyond a simple appliance swap. Water piping may need to be rerouted higher on the wall, a new vent penetration may be required, and the gas or electrical service may need more capacity. Removing a large tank from a basement, attic, or tight utility closet can also add labor. If you plan to replace a water heater with tankless equipment, request a site assessment before choosing the unit.
Additional Costs for Utility Upgrades, Venting, and Permits
Infrastructure work is often what pushes a project beyond the initial estimate. Depending on the route and local labor, gas-pipe upsizing may add roughly $400 to $1,000. A 100-amp-to-200-amp service upgrade may add $1,500 to $3,000, while a condensate neutralizer and drain can add about $150 to $300.
Those figures are broad allowances. The actual cost depends on pipe length, panel location, wall access, trenching, meter capacity, permit fees, and whether the utility must participate. Exterior finish work can also matter when new vent openings pass through brick, stucco, siding, or a roof.
What Should You Expect During and After Installation?
Most installations interrupt hot water for part of a day. A conversion may also require a brief whole-house water shutdown and access to the electrical panel, gas meter, attic, crawl space, or exterior wall. Clear the work area in advance and confirm whether the crew will remove the old heater and packaging.
Installation Time and How Long You’ll Be Without Hot Water
For scheduling, allow several hours for a straightforward job and ask the installer to confirm the expected water-shutoff period for your specific project. A same-location tankless replacement may be quicker, while a conversion involving panel work, long vent runs, or a gas-meter change can extend into a second day.
Ask whether the stated schedule includes inspection and final utility work. The physical installation may be finished even though a required meter change, inspection, or correction remains outstanding. If the household cannot go without hot water overnight, discuss that possibility before demolition starts.
Final Inspection and System Handover
The installer should show you the main water and fuel shutoffs, isolation valves, temperature control, inlet filter, pressure-relief discharge, condensate components, and error-code reference. Keep the model and serial numbers, warranty registration, permit record, and installer contact information in one place.
Where an inspection is required, the inspector may review electrical protection, pipe sizing, combustion air, vent clearances, relief piping, drainage, and mounting. In California, water heaters must be braced or anchored against earthquake movement. For a tankless unit, state guidance calls for secure attachment to the wall and piping installed according to the manufacturer’s instructions rather than the two wraparound straps commonly seen on a storage tank.
Essential Maintenance Requirements
Mineral scale can collect inside the heat exchanger, especially where water is hard or the heater operates at a high temperature. Over time, that buildup can restrict flow and reduce heat transfer. Follow the maintenance interval in the unit’s manual; annual service is common, while some homes with hard water may need attention every six months. A tankless water heater maintenance plan should cover descaling, inlet-filter cleaning, and model-specific professional service.
Flushing should be completed using a manufacturer-approved descaling solution (or undiluted white vinegar, if permitted by your unit’s manual). The cold-water inlet screen also needs periodic cleaning because sediment can reduce flow and trigger performance errors. Gas models may require inspection of the burner, ignition components, vent terminations, and condensate neutralizer. Maintenance frequency depends on water quality, usage, installation conditions, and the manufacturer’s instructions. Keep service records, particularly when the warranty requires documented care.
Planning for Household Backup Power
A gas tankless water heater still relies on electricity for its controls, ignition, and fan. During an outage, households may also need to support refrigeration, a sump pump, communications, lighting, or other essential loads. Planning those circuits together provides a clearer picture of the required backup capacity than considering the water heater alone.
For broader household backup, the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power paired with the Smart Home Panel 3 can supply power to compatible essential circuits during outages. This integrated setup allows homeowners to prioritize a gas tankless water heater’s control circuit, kitchen appliances, and electronics. The Smart Home Panel 3 must be installed by a qualified electrician in accordance with local electrical codes and regulations.
1. 100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity. 2. Plug & play design, installed in 7 days. Save up to 80% on time and cost. 3. Smart & reliable when it matters most, 20ms auto switchover.
A successful tankless water heater installation begins with an accurate load and site assessment. The heater must deliver the required flow at the home’s winter temperature rise, while the plumbing, gas supply, electrical service, venting, and drainage must support the selected model.
Get written quotes that separate the equipment from infrastructure upgrades and permits. Once the work is complete, confirm the temperature, simultaneous-flow performance, shutoff locations, and maintenance procedure before the installer leaves. With correct sizing, professional commissioning, and regular descaling, a tankless system can provide dependable hot water without the space occupied by a storage tank. If outages are common in your area, include the electrical needs of a compatible gas model in the household backup-power plan as well.
Can I Install My Own Tankless Hot Water Heater?
Technically, yes, if your local municipality allows homeowner-pulled permits, though DIY installation is strongly discouraged for most people. Gas line sizing, high-voltage electrical wiring, and sealed exhaust venting carry serious safety risks if done improperly, and warranty conditions depend on the manufacturer and model. Navien, for example, requires installation by a qualified contractor for warranty coverage.
Can You Run Two Showers with a Tankless Water Heater?
Yes, provided your unit is sized with a high enough flow rate (GPM) for your region’s incoming groundwater temperature. A high-output gas tankless heater rated around 9.5 to 11.0 GPM (measured at lower temperature rises) can typically handle two simultaneous showers plus a kitchen faucet in moderate U.S. climates, though extreme northern winters require sizing carefully for steep temperature rises. Smaller electric point-of-use units, by contrast, usually struggle to keep up with more than one fixture at a time.
What's the Average Lifespan of a Tankless Hot Water Heater?
The U.S. Department of Energy states that tankless water heaters can last more than 20 years, compared with 10 to 15 years for most storage water heaters. Actual service life depends on maintenance, water quality, and operating conditions. Because tankless systems don’t store standing water in a steel tank that corrodes over time, replacing individual sensors or valves down the road is straightforward and extends service life even further.
What Is the Downside of a Tankless Hot Water Heater?
The biggest drawbacks are the higher upfront equipment and installation costs, particularly when converting from a tank model that requires new venting, larger gas pipes, or electrical panel upgrades. Hot water can also take time to reach distant taps, depending on the piping layout. A separate issue, the “cold-water sandwich,” is a brief cold-water interruption between hot-water draws after frequent on/off operation. Model-specific buffer tanks and correctly configured recirculation can help address these issues.
Home Backup
