Generator Wattage Calculator: How to Size Running Watts, Surge, and Hours
A generator wattage calculator works in three parts. Add the running watts of the devices you'll use at once. Check the extra demand from anything that could start at the same time. Then multiply average watts by hours of use to estimate energy. This guide walks through worked examples, compares sizing for fuel generators and battery power stations, and explains when you need a licensed electrician.
How to Use a Generator Wattage Calculator
List the devices you plan to power. Look for their running power and startup requirements. A label may show running watts or current without giving a startup figure. Check the exact model's manual or ask the manufacturer for missing startup data before doing the math.
Where to Find Your Numbers
  • Check the nameplate on the back of the appliance or inside the door.
  • Look in the owner's manual or on the maker's website.
  • See only amps for an AC device? Use its actual voltage. Volts × amps gives apparent power in volt-amps (VA). To estimate real watts, also multiply by the power factor, or use a manufacturer-provided watt rating.
  • Expect a bigger starting number from motors, like fridges, sump pumps, and window AC units.
  • Some LED drivers and switching power supplies also draw a brief inrush when turned on. Check startup requirements when they matter to the setup.
The Four-Step Math
Here's the whole method in one table. The example numbers are placeholders, so swap in your own.
Step
What to add
Example
1
Running watts of all loads together
Fridge 150 + lights 40 + router 15 = 205W
2
Add the extra startup draw of devices that can start together. If only one can start at a time, use the largest single extra draw.
The fridge is the only starting load in this example. It draws 1,150W at startup, or about 1,000W over its running load.
3
Estimated peak for this startup case
About 1,205W
4
Energy = average watts × hours
100W average for all three loads × 12 hours = 1,200Wh
When One Starting Surge Is Enough
If you can operate the motor loads at separate times, add the largest extra startup draw to their combined running watts. When two or more loads can start together, allow for the overlapping extra draw and check how long it lasts. Starting equipment one by one only controls that first startup.
For each device, subtract its running watts from its total starting watts to find the extra draw. This avoids counting its running power twice. Check the manufacturer's starting and running ratings.
Watts vs. Watt-Hours
Watts tell you how much power a device draws. Watt-hours measure energy used over time. As the U.S. Energy Information Administration explains, a 100W bulb running for 10 hours uses 1,000Wh.
You need both numbers. Peak watts tell you if the unit can start your gear. Watt-hours tell you how long it keeps going.
A Quick Worked Example
Say you want to keep a fridge, a few lights, and a Wi-Fi router going overnight. Here's how the numbers shake out.
  • Running watts: 150W fridge + 40W lights + 15W router = 205W.
  • Largest surge: The fridge needs about 1,000W extra to start.
  • Peak: 205W + 1,000W = about 1,205W.
  • Energy: Assume the fridge averages 45W across its on and off cycles. If the lights and router draw 55W throughout the example, the three loads average 100W. Over 12 hours, they use 1,200Wh.
These figures are placeholders. Replace them with the numbers from your own labels before you buy anything.
With those numbers, you can check them against a battery power station's limits.
Matching Your Numbers to a Power Station
Compare the running load with the power station's continuous output. Check the estimated startup peak against its permitted surge output and duration. Check each outlet and the usable battery capacity separately.
Output, Capacity, and Outlet Checks
  • Output and surge: The combined running load must stay within continuous output. The total peak during startup must fit within the specified surge limit for the required duration. These are separate limits.
  • Capacity: Allow enough usable battery energy for the expected watt-hours, conversion losses, and operating conditions.
  • Outlet: Check the required voltage, plug type, and individual receptacle rating.
EcoFlow power stations publish both numbers the calculator needs: output watts with surge, and capacity in watt-hours. That makes it easy to check your list against each model.
For lights and a router, the peak is small, so EcoFlow DELTA 3 Classic's 1,800W output is plenty and its 1,024Wh sets the hours.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
When refrigerator startup demand joins other 120V appliances, you may need a larger system. The EcoFlow DELTA 3000 Gen4 offers higher output and battery capacity.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How the products divide the job
Choosing between these two setups comes down to what is on your list and how long the grid stays down:
  • EcoFlow DELTA 3 Classic: Best suited for keeping Wi-Fi routers, modems, LED lamps, and phones running during short outages or work-from-home interruptions.
  • EcoFlow DELTA 3000 Gen4: Can support heavier compatible 120V essentials. Check the refrigerator's startup, the combined running draw, and the limits of each outlet before using it with lights, fans, or electronics.
  • 240V loads: A standard 120V outlet can't directly power a 240V load. Some equipment is hardwired. Other equipment, such as some 208/240V electric dryers, uses a dedicated receptacle. Have a licensed electrician design any connection to household wiring.
Comparing Estimated Runtime
Battery capacity doesn't translate directly into usable energy. Conversion losses and operating conditions affect the amount available to your appliances.
For these examples, we'll assume 85% usable battery capacity.
  • EcoFlow DELTA 3 Classic: 1,024Wh × 0.85 = approximately 870Wh.
  • EcoFlow DELTA 3000 Gen4: 3,072Wh × 0.85 = approximately 2,611Wh.
Use this formula:
Runtime (hours) = Usable Capacity (Wh) / Load (W)
The following figures are estimates, not guaranteed runtimes.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
Lights and router
About 55W
About 16 hours
About 47 hours
Sample fridge (38W average) + lights + router
About 93W
About 9.4 hours
About 28 hours
These are example loads. One ENERGY STAR-certified refrigerator lists 332 kWh per year, or about 38W averaged over 8,760 hours. Use your own appliance's measured or documented average for runtime and check its startup requirement separately.
Remember that refrigerator compressors cycle on and off. Actual runtime depends on usage, temperature, door openings, and other conditions.
Also, check the starting surge separately. A runtime calculation doesn't prove that a power station can start your refrigerator.
Many appliances fit different backup setups. See which appliances a power station can run before deciding whether you need a larger unit.
Next, let's look at the common mistakes people make when adding up their numbers.
Common Wattage Calculator Mistakes
Common mistakes include overlooking startup peaks that can overlap and using average watts to size peak output. Keep running power, startup demand, and energy use separate.
Refrigerator example: 150W running and 1,150W at startup.Refrigerator example: 150W running and 1,150W at startup.
Even a small math slip can push you toward the wrong unit. Watch out for these four traps when you run your numbers:
  • Double-counting or missing starting demand: Add the running watts of the loads you will use simultaneously. Add the extra startup draw of devices that may start together. If you can reliably stagger their starts, include only the largest single extra draw.
  • Confusing average watts with peak watts: A refrigerator's average over a full day includes time when the compressor is off. Use its actual running and startup requirements to size output. Use the average load over the planned period to estimate watt-hours.
  • Mixing generator and battery runtime: A fuel generator's runtime depends on the fuel available and consumption at the actual load. Use the manufacturer's runtime at comparable loads when available. For a battery, estimate runtime from usable watt-hours and average draw.
  • Overlooking 240V equipment: Check voltage and connection type. An electric dryer can use a dedicated 208/240V receptacle, while some central HVAC and well pumps are hardwired. Both EcoFlow models discussed here supply 120V AC in the U.S. A licensed electrician should review any connection to the home's circuits.
If you are planning backup power beyond a few key rooms, read how to size a generator for your house for whole-home planning.
Finally, keep safety rules front and center before you connect any backup power source.
Generator Safety and Connection Rules
Choosing the right generator size is only part of the process. You also need to connect and operate your equipment safely. Good math will not protect your family if the equipment is set up in the wrong spot or wired dangerously. Follow these non-negotiable rules every time the power goes out:
Generator safety and connection rulesGenerator safety and connection rules
  • Keep fuel generators outdoors. CPSC guidance calls for at least 20 feet from homes and other buildings, with exhaust directed away from windows, doors, and vents. Never run one in a home, basement, shed, or garage, even with the door open.
  • Never backfeed through a wall outlet: The U.S. Consumer Product Safety Commission (CPSC) warns that plugging a generator directly into a standard wall outlet, a dangerous shortcut known as backfeeding, creates an extreme electrocution hazard. It sends live voltage back out onto neighborhood utility lines, putting lineworkers and neighbors at risk while threatening to destroy your home's wiring and the generator itself.
  • Check power and energy separately. Watts multiplied by hours estimates energy use. To prevent electrical overload, check the equipment's continuous and startup limits and the ratings of the outlets and cords.
  • Use cords allowed by the generator and appliance manuals. CPSC generator guidance calls for an undamaged, heavy-duty outdoor-rated cord with a grounded plug and a rating at least equal to the connected loads.
The same steps apply to calculating power needs for any setup, whether you are preparing for hurricane season, winter storms, or weekend camping trips.
Start with the running watts for everything you will use at once. Add the extra startup draw for devices that may start together. Use average watts times hours to calculate energy. Follow the generator and appliance manuals, and have a licensed electrician handle any connection to household wiring.
The EcoFlow DELTA 3 Classic suits compatible lower-power loads such as routers, lamps, or phones. The EcoFlow DELTA 3000 Gen4 offers more output and stored energy for compatible 120V loads such as a refrigerator and other essentials. Check total draw, startup, outlet ratings, and runtime against the model you choose.
How do I calculate generator wattage?
Add the running watts of appliances you will use together. Check the extra starting draw of any devices that may start at the same time. The running load plus those overlapping extras estimates the peak.
Do I add all starting watts together?
Add the extra startup draws that can actually overlap. If you can ensure only one motor starts at a time, add the largest single extra draw to the running total. Check automatic cycling before assuming starts won't overlap.
What size generator runs a refrigerator?
Choose a generator that can handle your refrigerator's starting surge and the running loads of other connected appliances. Check the refrigerator's label or manual for its actual wattage requirements. Ratings vary between models.
How do I convert watts to watt-hours?
Multiply average watts by hours to estimate energy in watt-hours. A constant 100W load uses 1,000Wh in 10 hours. Allow extra battery capacity for conversion losses and operating conditions.
Can a power station replace a generator?
A power station can cover specific compatible loads for the hours it is sized to support. Check the running load against its continuous rating and the startup peak and duration against its surge limit. Also check the outlet ratings and usable energy. Consult a licensed electrician for backup connections to hardwired home circuits.
Portable Power Stations
