How to Drive on Ice: Braking, Steering and Speed Control
Wet pavement and packed snow give tires more grip than ice, so an ordinary drive calls for more care once the surface freezes. Freezing rain or refrozen slush can create a nearly invisible layer of ice that leaves tires with little traction, making merging or crossing intersections hazardous. Careful speed control, braking, and steering can help you keep the car steady. Here’s how to prepare for the drive, spot black ice, and handle front- and rear-wheel skids.
What Should You Do Before Driving on Icy Roads?
Before getting behind the wheel, check current road advisories and make sure your vehicle is ready for the conditions ahead. Learning how to drive on icy roads starts with checking conditions before you leave.
Before setting out, also prepare for delays in case icy conditions lead to road closures. Pack warm layers, drinking water, and a way to keep your phone charged; a portable power station can provide backup power during a prolonged wait.
Check Road Conditions and Watch for Black Ice
A weather app will not always show isolated icy patches. Before you leave, check road conditions, plowing updates, and freezing rain reports on a state Department of Transportation (DOT) map such as Caltrans QuickMap, NY 511, or DriveTexas. Because black ice blends in with asphalt, pay particular attention near freezing. Air temperature alone cannot tell you whether pavement is ice-free. Bridges, overpasses, and shaded pavement deserve extra caution; cold air circulating above and below a bridge causes it to freeze earlier. Suspect ice when the pavement looks glossy, wet, or unusually dark, or when vehicles ahead stop kicking up spray.
Inspect Your Tires, Brakes, and Other Essential Components
Cold affects the way your vehicle responds on slick pavement: tires stiffen, and fluids and battery output also suffer. Check these items before you drive.
Tire tread and pressure: Once temperatures drop below 45°F, all-season tires lose flexibility. Winter tires stay pliable in freezing weather—look for the Three-Peak Mountain Snowflake symbol. Tread should measure at least 4/32 of an inch. Inflate the tires to the pressure on the driver-side door jamb, and remember that a 10°F temperature drop can lower pressure by about 1 psi.
Brakes and rotors: During the first few stops around your neighborhood, listen for grinding or squealing. On slick pavement, a sticking brake caliper or uneven braking force may pull the vehicle sharply to one side.
Wipers, washer fluid, and defrosters: Install fresh blades if the old ones are worn, consider winter beam blades, and use winter washer fluid rated for local minimum temperatures and suitable for your vehicle.
Battery and lights: A battery can lose 30% to 50% of its cranking power in cold weather. Clear snow and frost off every window, all exterior lights, and the backup camera before driving.
A portable power station can also be useful during unexpected winter delays, providing backup power for your phone and other essential electronics if you need to wait for road assistance or a road closure to clear. Explore power stations to find an option for your winter travel needs.
How Should You Control Your Speed, Brake, and Steer on Ice?
“How do I drive on ice?” is best answered by looking at three essentials: speed, braking, and steering. The following techniques explain how to manage each without demanding more grip than the tires have.
Maintain a Low Speed and Accelerate Gradually
Speed limits assume good road conditions, not glare ice. Stay well below the posted limit to give the tires more time to regain grip.
From a stop, ease onto the gas gently. Too much throttle can spin the drive wheels, leaving you with even less traction.
Keep a Safe Following Distance
You may need much more room to stop on glare ice than on dry asphalt. A three-second gap may work in good weather, but on ice, allow 8 to 10 seconds or more. To check your gap, pick a fixed landmark and count the seconds from when the vehicle ahead passes it until you reach it.
Brake Smoothly and Use ABS Correctly
Start slowing down well before intersections, off-ramps, and downhill stretches. Panic braking can lock the wheels and send the vehicle into a slide.
Braking System | How to Apply the Pedal on Ice | What to Expect |
Anti-Lock Braking System (ABS) (Standard on almost all modern vehicles) | Apply firm, steady pressure and hold the pedal down. Never pump the brakes. | Expect pulsing and buzzing at the pedal; ABS regulates pressure so you can continue steering. |
Non-ABS Brakes (Older vehicles or disabled ABS) | Apply threshold braking: press gently until the wheels are about to lock, ease off slightly if they slide, then press down again smoothly. | Rapid pumping can destabilize the car. Make smooth adjustments to keep the tires turning. |
Steer Gently and Avoid Sudden Maneuvers
Abrupt steering transfers weight and can make the tires lose what grip they have left. Hold the wheel with both hands at 9- and 3-o’clock positions, and make small, smooth corrections. Do not use cruise control on ice or slush. If the tires hit black ice, cruise control may add throttle to hold the set speed, causing the drive wheels to spin.
Navigate Curves and Hills Without Losing Traction
Set an appropriate speed before entering a curve or starting up a hill.
Taking curves: Do your braking before the turn, while the car is still straight. Let it coast through the curve; once the wheel is straight again, ease back onto the accelerator.
Climbing hills: Once on the slope, maintain the steady momentum you built at the bottom instead of accelerating. Stop only if traffic forces you to; getting started again on a slick hill is tough.
Descending hills: Shift into a lower gear before the descent and let engine braking keep your speed in check rather than relying solely on the brake pedal.
What Should You Do If Your Car Starts to Skid on Ice?
Black ice can surprise even a cautious driver. A slide is not the time to stomp on the brakes or yank the wheel. Stay calm so you can give the tires a chance to regain grip.
Ease Off the Accelerator and Avoid Sudden Braking
Take your foot off the gas if the car drifts or the steering stops responding. Unless a collision is imminent, stay off the brake. Freely rolling wheels give the tires a better chance to regain traction.
How to Handle Front-Wheel and Rear-Wheel Skids
Once you’ve eased off the pedals, check whether the front or rear tires are sliding, then steer smoothly:
Understeer (front tires lose grip): No matter which wheels drive the vehicle, a car that continues straight when you turn the wheel is understeering. Look toward the open lane instead of the guardrail or snowbank. Unwind the steering briefly to help the front tires recover grip, then gently guide the vehicle toward your intended path.
Oversteer (rear tires lose grip / fishtailing): When the rear swings right, steer smoothly right—into the skid. As the car comes back in line, counter-steer toward the middle of your lane so it does not slide the opposite way.
Regain Control Before Accelerating Again
Do not accelerate until the vehicle is lined up with your lane and the steering responds normally. At that point, ease back onto the gas and keep your speed low because another icy patch may be ahead.
What Other Winter Driving Safety Tips Should You Know?
Sound technique matters on icy roads, but planning and emergency supplies become equally important if a storm shuts down the highway. A winter car emergency kit checklist helps you organize supplies for warmth, visibility, food, water, and communication.
Know When to Avoid Driving in Severe Winter Weather
The question “how thick does ice need to be to drive on” concerns frozen lakes and other bodies of water, rather than icy pavement. No ice thickness guarantees safety; follow local authorities’ guidance and restrictions.
Staying home is sometimes the safest decision. Even with all-wheel drive and winter tires, it can be unsafe to drive during freezing rain advisories, ice storm warnings, or flash freezes. AWD and 4WD help with acceleration and hill climbing; neither reduces stopping distance nor adds cornering grip on ice. When local officials advise against travel, postpone the trip until road crews have treated the primary routes. Preparing your vehicle, supplies, and communication plan before conditions deteriorate is part of knowing how to prepare for a winter storm.
Keep a Winter Emergency Kit in Your Vehicle
Pack supplies that can keep you warm, visible, and able to communicate during a highway closure or while waiting by the side of the road:
Traction and extraction gear: Collapsible shovel, ice scraper and brush, and non-clumping kitty litter, sand, or traction mats.
Warmth and visibility: Wool or fleece blankets, insulated gloves, a knit hat, hand warmers, reflective vest, and flares or LED warning triangles.
First aid and food: First-aid kit, water kept in the cabin so it doesn’t freeze, and snacks such as protein bars or trail mix.
Power and communication: Jumper cables or a portable jump starter, plus a backup power source.
Cold weather can quickly deplete phone batteries during a long wait for roadside assistance, cutting off contact with family, AAA, or emergency responders. A standard 12-volt car outlet won’t keep up if the vehicle won’t start or you’d rather not idle the engine for hours. That makes a portable power station a practical addition to your winter kit. The EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) can keep your smartphones charged for communication and power emergency LED lanterns for basic lighting. If you need to power a laptop, a heated blanket, or several family devices during an overnight highway closure, the EcoFlow DELTA 3 Max Portable Power Station (2048Wh) offers a larger battery reserve. Both models run compatible devices in winter temperatures as low as 14°F.
Prepare for Unexpected Delays and Road Closures
Set out on a winter trip with the gas tank at least half full or an EV charged above 80%, since cold weather reduces range. Tell someone your route and expected arrival time. If you become stranded, stay inside your vehicle for shelter and to remain visible to rescuers. Before running the engine for heat, make sure snow is not blocking the tailpipe; otherwise, carbon monoxide could enter the cabin.
On ice, smooth control inputs, patience, and extra space are central to safe driving. Check conditions before you leave, stay below the speed limit, maintain an 8- to 10-second following gap, and steer gently. Keep a stocked winter emergency kit in the vehicle as well in case severe weather delays the trip.
Is It Better to Drive with Traction Control on or off in Snow?
For nearly all winter driving, keep traction control on. When it detects wheel spin, the system can cut engine power or brake an individual wheel to help the tire recover grip. You may switch it off briefly if you are stuck in deep snow or slush and need to rock the vehicle free, but turn it back on afterward.
Is It Okay to Drive with Traction Control off All the Time?
No. With traction control disabled, you lose a safety feature that helps limit wheel spin on wet pavement, black ice, and loose gravel. Keep it active for normal driving, and turn it off only to free a stuck vehicle or when driving on a closed off-road track.
What Gear Should You Use When Driving on Ice?
Use Drive (D) on ordinary level roads. For steep descents or slick intersections, select a lower gear such as L, 2, or 3 so you can use engine braking to slow the vehicle without relying entirely on the brakes. The opposite applies when pulling away on ice: avoid L and first gear. Select second gear or Snow/Winter mode if your vehicle has it; starting in a higher gear reduces torque and helps prevent wheel spin.
How Cold Is Too Cold to Drive a Car?
Extreme cold puts additional strain on even well-maintained vehicles. As temperatures drop, battery performance decreases, cold engine oil and other fluids increase friction, and tire pressure falls. Before driving in severe cold, check your battery, tires, coolant, and other essential systems. Use the engine oil grade recommended by your vehicle manufacturer for cold-weather conditions. If temperatures are expected to fall well below freezing, consult your owner’s manual for additional precautions, such as using an engine block heater if recommended. Postpone non-essential trips when road or weather conditions make driving unsafe.
