How Many Watts Does a Coffee Maker Use?
Coffee makers don't all draw the same amount of power, and the gap between types is bigger than most people expect. A basic drip machine might pull around 600 watts, while a single-serve pod machine can spike past 1,300 watts just to heat water fast enough for one cup.
So, how many watts does a coffee maker use? The number on your own machine matters more than any average floating around online. Most machines fall somewhere between 550 and 1,500 watts, and the figure that actually counts is whatever your specific model has printed on its label.
That number becomes especially useful once you start thinking about running your coffee maker somewhere without a wall outlet. Knowing a coffee maker's wattage is really the first step toward brewing off a portable power station, whether that's on a camping trip, in an RV, or through a power outage at home. The EcoFlow DELTA 3 Classic is a good example of a unit built to handle that kind of everyday load.
Wattage by Coffee Maker Type: Drip, Pod, and Espresso
How many watts is a coffee maker uses changes more than you'd think. Coffee maker wattage swings quite a bit depending on how the machine actually brews. Here's how the three most common types compare while they're running:
Coffee Maker Type
Typical Wattage
Notes
Drip
550 to 1,200W
Scales with cup capacity; a 4-cup machine sits low, a 12-cup runs high
Single-serve pod
900 to 1,500W
Peaks briefly during the heating cycle, then drops
Espresso
Up to 1,500W or more
Pump and boiler often draw power at the same time
Coffee maker wattage also shifts with cup capacity. A small 4-cup drip machine typically sits at the low end of that range, while a 12-cup model with a warming plate runs closer to the top, since the plate keeps cycling on and off to hold the pot at temperature. These figures all reflect a machine actively brewing, not what it draws while quietly sitting on standby.
Why Keurig's Wattage Looks So High
Keurig and other pod machines often show up in searches with wattage numbers that look alarming next to a regular drip machine. The reason comes down to timing, not raw power.
Most of that draw happens during a short heating phase, when the machine pulls somewhere between 1,300 and 1,500 watts to bring water up to brewing temperature fast. That phase only lasts 45 to 90 seconds. Once brewing actually starts, draw drops to around 600 to 800 watts, and between cups, the machine idles at roughly 15 watts. So while how many watts does a Keurig use sounds like it should have one simple answer, it really depends on which second of the cycle you're asking about.
Because that high number only shows up in short bursts, the total energy used per cup stays fairly modest, even though the peak wattage looks intense on paper. That gap between peak and average is really the whole answer to how many watts does a Keurig use in everyday terms.
What a Cup of Coffee Actually Costs in Electricity
Wattage tells you how much power a coffee maker pulls at any given moment, but it doesn't tell the full story on its own. To actually estimate cost or runtime, time has to come into the equation too.
How Many Watts Does a Coffee Maker Use Per Hour?
A coffee maker's wattage is really just a snapshot of power drawn at a single moment. Electricity used over time is measured differently, in watt-hours (Wh) or kilowatt-hours (kWh), and that's the number that actually determines cost or how long a battery can keep the machine running.
The formula is simple: watts multiplied by hours used, divided by 1,000, gives you kWh. So a 900-watt coffee maker running for 10 minutes, or roughly 0.17 hours, works out to about 0.15 kWh. Multiply that by your local electricity rate and you've got a rough cost per pot. For a closer look at the math, this guide on how to calculate watts walks through a few more examples.
How Many Watts Does a Coffee Maker Use Per Cup?
Wattage alone doesn't answer this one either, since cost per cup depends just as much on how long the machine runs to brew it. Most coffee makers draw somewhere between 600 and 1,500 watts while actively brewing, but a machine that finishes a cup in 90 seconds uses far less total energy than one running at the same wattage for several minutes.
That's why two machines with similar wattage can still cost noticeably different amounts per cup. The real difference usually comes down to brew time, not the number printed on the label.
Sizing a Portable Power Station Around Your Coffee Maker
Once you know how many watts is a coffee maker actually pulling, sizing a power station to run it is more straightforward than it sounds.
Coffee makers are resistive loads, which means they draw a steady amount of power with no real startup surge, so a power station only needs to match or exceed the machine's running wattage rather than plan around some much higher peak.
That makes it easy to plan for, whether you're brewing while camping, running a coffee maker in an RV, or keeping the morning routine going through a power outage at home. Browse the full range of portable power stations to compare capacity and output, or take a look at the two options below.
EcoFlow DELTA 3 Classic, best for a standard drip machine or single-serve brewer.
The EcoFlow DELTA 3 Classic comfortably covers up to 1,800W continuous, with nothing to maintain between uses.
4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech,it supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and air conditioners. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. 30dB Whisper-Quiet Operation: Ultra-low noise ≤30dB at 600W.
EcoFlow DELTA 3 Plus, best for running a coffee maker alongside other devices.
If the coffee maker needs to share power with a phone charger, a small fridge, or anything else on the same trip, the EcoFlow DELTA 3 Plus offers more outlets and faster solar recharge, which matters more on repeat trips or during a longer outage.
1–5kWh expandable with DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, or DELTA Pro 3 Extra Battery via an Alternator Charger XT150 Output Cable. 1800W AC output, 2200W (surge 3600W) with X-Boost 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
How many watts coffee maker use boils down to three things: type, cup size, and whether there's a warming plate involved. Drip machines sit lowest, pod machines like Keurig spike briefly but recover fast, and espresso machines can run highest of all. What actually matters, whether you're watching an electricity bill or planning power for a trip, isn't the wattage number by itself, but how that number plays out over time. If you're setting up backup power for your coffee routine, the EcoFlow DELTA 3 Plus is a solid place to start.
Can a 1000W Inverter Run a Coffee Machine?
In most cases, yes, though it depends on the specific machine. A standard drip coffee maker pulling 600 to 900 watts runs comfortably on a 1,000-watt inverter. Larger machines, or ones with a high peak draw like some single-serve pod brewers, can push closer to that 1,000-watt ceiling and leave little headroom for anything else running at the same time.
How Many Watts Does a 12 Cup Coffee Maker Use?
A standard 12-cup drip coffee maker typically draws somewhere between 900 and 1,200 watts while brewing. The exact figure depends on the model and whether it includes a warming plate, since that adds ongoing draw even after the pot finishes brewing.
Can I Run a Coffee Maker on a Generator or Power Station?
Yes, coffee makers are one of the easier kitchen appliances to run on either one. Since they're resistive loads without a real startup surge, a generator or portable power station only needs to match the coffee maker's running wattage, not plan around a much higher spike. If the relationship between watts, volts, and amps is still a little fuzzy, this explainer on volts, amps, and watts breaks down how the three connect.
How Many Amps Does a Coffee Maker Draw?
On a standard 120-volt outlet, most coffee makers draw somewhere between 5 and 12.5 amps, depending on wattage. A 600-watt drip machine pulls about 5 amps, while a 1,500-watt espresso machine can approach 12.5 amps at its peak.
Save Bills
