New York Wildfire Guide: Current Fire Info, Smoke Safety, and Outage Prep
New York wildfires tend to be smaller than the large fires seen across the West, but dry weather can still keep Forest Rangers busy. Smoke can also travel well beyond the burn area, affecting nearby homes and communities. If you're following a New York wildfire, start with the Department of Environmental Conservation (DEC) and National Weather Service (NWS) updates. This guide covers where to find fire and evacuation information, how to manage indoor smoke, what to know about outdoor burning, and how to keep essential devices running during a power outage.
Where to Check New York Wildfire Information
The New York DEC reports wildfires handled by its Forest Rangers, while the NWS issues weather alerts that can signal elevated fire danger. County officials handle local emergency notices and evacuation orders. Check these sources directly for updates, especially when conditions are changing.
Where to Check New York Wildfire InformationWhere to Check New York Wildfire Information
Official fire reports and weather alerts
Use these resources to follow wildfire activity across New York:
  • New York DEC: Check DEC news releases and Forest Ranger reports for fire incidents, locations, acreage, and response updates.
  • National Weather Service: Check Red Flag Warnings and local fire weather forecasts. New York is served by several NWS offices, including Albany, Buffalo, Binghamton, and Upton.
  • AirNow: Check air quality conditions and smoke-related information in your area.
  • County emergency management: Follow your county's official alerts for evacuation notices, road closures, and local instructions.
The DEC reported that Forest Rangers extinguished 93 wildfires covering more than 224 acres during the first nine months of 2026. In a separate report covering October 29 through November 1, Rangers responded to seven wildland fires totaling 11.5 acres. Three were caused by debris burning. These figures come from the DEC's published updates, not a live incident map. Check the DEC's Forest Ranger updates for the latest reports. Always note the date and time of an update before sharing it.
Smoke advisories and evacuation orders aren't the same
A smoke advisory warns about air quality. It may recommend limiting outdoor activity or taking steps to reduce smoke indoors. An evacuation order is a direction from local authorities to leave an area. If your county issues an evacuation order, follow it immediately. Don't wait for smoke to reach your home or for another agency to repeat the notice. Keep a wildfire smoke safety guide handy, so you know how to respond when smoke affects your area. If officials say it's safe to remain indoors during smoky conditions, the next step is to protect indoor air and keep your alert devices powered.
Staying In During Smoke: Power for Alerts and an Air Cleaner
Smoke can enter a home through open windows, doors, and small gaps. Keep windows and doors closed when outdoor air quality is poor, and follow local health guidance. A properly sized portable air cleaner can help reduce indoor particles. If the power goes out, a compatible power station can keep that cleaner and essential communication devices running for a while.
Keep alerts and essential devices powered
Start with the devices you'll need to receive updates and contact family:
  • Cell phones and charging cables
  • A battery-powered or hand-crank weather radio
  • LED lights and spare batteries
  • A power bank for everyday phone charging
  • A portable power station for several small devices
Charge phones and radios before severe weather or fire danger becomes a concern. If you receive an evacuation notice, leave immediately. Don't stay behind to charge devices or collect backup equipment.
EcoFlow DELTA 3 Classic for phones and alerts
For basic communication backup, the EcoFlow DELTA 3 Classic has a 1,024Wh battery capacity. It can supply power to phones, a weather radio, and LED lights during an outage. It doesn't produce exhaust, so it can be used indoors according to the manufacturer's instructions.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Max for a portable air cleaner
If you already own a portable air cleaner and want to keep it running during an outage, the EcoFlow DELTA 3 Max offers a larger 2,048Wh battery capacity and 2,400W output, according to EcoFlow. Check the air cleaner's running wattage and startup requirements before connecting it. The power station supplies electricity; the air cleaner handles the filtration.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How the products divide the job
The EcoFlow DELTA 3 Classic is suited to phones, radios, and other alert devices. The EcoFlow DELTA 3 Max has more battery capacity for running a compatible portable air cleaner during an outage.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max (1,741Wh usable est.)
Phones + radio + LED lamp (placeholders)
about 30W
about 29 hours
about 58 hours
Portable air cleaner on medium (placeholder 50W)
about 50W
about 17 hours
about 35 hours
These are estimates based on 85% of each battery's rated capacity. Actual runtime depends on the devices' power use and operating conditions. Estimated runtime (hours) = Usable battery capacity (Wh) ÷ Load (W). The wattages above are placeholders. Check the labels or manuals for your actual devices and use those figures to estimate runtime before choosing a power station. A power station supplies electricity; the air cleaner handles filtration. For more ways to reduce indoor smoke, read our guide to protecting your home from wildfire smoke.
Preventing Wildfires in New York
Many New York wildfires start with human activity. Debris burning is one source of preventable fires, especially when dry vegetation and wind allow flames or embers to spread. Check state and local rules before burning anything outdoors.
Know the statewide burn ban and local rules
New York has a seasonal statewide ban on residential brush burning from March 16 through May 14. The DEC may also issue additional restrictions when conditions call for them. Check the current DEC open burning rules before lighting a brush pile or starting an outdoor fire. A few basic precautions can help prevent accidental fires:
  • Don't burn brush during a ban or when local restrictions prohibit it.
  • Never leave a campfire unattended.
  • Keep water and a shovel nearby when fires are permitted.
  • Make sure a campfire is fully extinguished before leaving.
  • Avoid outdoor burning on dry, windy days.
The DEC's November 4, 2026 report, covering incidents from October 29 to November 1, attributed three of seven reported wildland fires to debris burning. That is a reminder to check the rules before burning yard waste. You can also review these everyday fire prevention habits to reduce common risks around your property.
Choosing an Air Cleaner for Wildfire Smoke
A portable air cleaner can help reduce fine particles indoors, but the unit needs enough capacity for the room. Check its clean air delivery rate (CADR), filter type, and recommended room size before buying. A power station can keep a compatible unit running during an outage, but it can't make an undersized air cleaner more effective.
Choosing an Air Cleaner for Wildfire SmokeChoosing an Air Cleaner for Wildfire Smoke
Use smoke CADR to size the unit
The EPA recommends choosing an air cleaner with a smoke CADR of at least two-thirds of the room's floor area in square feet. For example, a 300-square-foot room needs a smoke CADR of at least 200. If you plan to use the cleaner in a bedroom, check that its rating covers the room size and that it uses a filter suitable for fine particles. A few details matter when comparing models:
  • Smoke CADR: Look for a rating that meets the room-size recommendation.
  • Filter type: Check the manufacturer's filtration specifications and replacement schedule.
  • Room size: Match the cleaner to the room where you'll spend the most time.
  • Operating speed: Higher fan settings may draw more power and produce more noise.
  • Power use: Check the wattage on the label or in the manual before choosing backup equipment.
Keep doors and windows closed while the air cleaner runs, as long as it's safe to stay indoors and local guidance supports doing so. Follow public health advice if smoke levels rise or conditions change. Pair your indoor air plan with wildfire season home preparation, including a go-bag and a clear evacuation plan.
New York wildfire updates come from the DEC and NWS, while county officials provide local evacuation instructions. Check those sources for dated reports and current restrictions. During smoky conditions, follow health guidance, keep alerts available, and use a properly sized air cleaner if it's safe to stay indoors. The EcoFlow DELTA 3 Classic can power phones and radios, while the EcoFlow DELTA 3 Max can run a compatible air cleaner based on its measured wattage. Leave immediately when officials issue an evacuation order.
Are there wildfires in New York right now?
Check the New York DEC and National Weather Service for current fire reports and weather alerts. For local evacuation instructions, follow your county's emergency management office or sheriff's department. Always check the report date and time.
How many wildfires does New York have?
The DEC reported that Forest Rangers extinguished 93 wildfires covering more than 224 acres during the first nine months of 2026. The total changes throughout the year, so check the DEC's latest reports for updated figures.
What causes most wildfires in New York?
Human activity causes many wildfires in the state. Debris burning is one reported cause. The DEC's October 29 to November 1, 2026 update attributed three of seven wildland fires to debris burning.
What size air cleaner do I need for wildfire smoke?
The EPA recommends a smoke CADR of at least two-thirds of the room's area in square feet. For a 300-square-foot room, look for a smoke CADR of at least 200. Check the manufacturer's room-size guidance too.
Should I stay home during wildfire smoke?
Follow local health guidance and emergency alerts. If officials say it's safe to remain indoors, close windows and doors and use a properly sized air cleaner if available. Leave immediately if authorities issue an evacuation order.
Power Outages
