Tornado New Jersey Guide: Watches, Warnings, Recent Tornadoes, and How to Shelter
Tornadoes in New Jersey are less common than in the Plains, but they can happen in any season. The National Weather Service confirmed that an EF-1 tornado struck Chesterfield, Burlington County, on November 12, 2026, during a powerful storm system. Knowing where to get alerts matters when severe weather moves through. This guide explains the difference between a tornado watch and a warning, which NWS office covers your area, how to find local emergency alert sign-ups, and where to take shelter. It also covers simple ways to keep a weather radio and phone charged.
Tornado Watch vs. Warning in New Jersey
A tornado watch means conditions are favorable for tornadoes. A warning means a tornado has been reported or indicated by radar, and you should take cover immediately. Most of New Jersey falls under NWS Mount Holly, while NWS Upton covers the state's northeast corner.
Tornado Watch vs Warning in New JerseyTornado Watch vs Warning in New Jersey
What a watch and warning mean
The National Weather Service uses two alerts for different stages of tornado risk:
Alert
What it means
What to do
Tornado watch
Conditions could support tornado development
Stay alert, check updates, and review your shelter plan
Tornado warning
A tornado has been reported or indicated by radar
Take shelter immediately
The Storm Prediction Center issues tornado watches. Your local NWS office issues warnings when radar or reports indicate a tornado. A warning can cover only part of a county, so check the location and expiration time rather than assuming the entire state is under the same alert.
Which NWS office covers your New Jersey county?
The NWS office that serves your area depends on where you live:
  • NWS Mount Holly: Covers most of New Jersey.
  • NWS Upton: Covers northeastern New Jersey.
You can check local forecasts and warnings through NWS Mount Holly or NWS Upton. Look at the alert's issue time, affected counties, and expiration time. If a warning is active, don't spend time comparing updates before taking cover. Use NJOEM's Staying Informed guide and its county emergency management directory to find the alert systems offered in your community. Keep Wireless Emergency Alerts (WEA) enabled on a compatible phone, and check with your carrier if you are unsure whether your phone supports them. Use a weather radio and official forecasts as additional sources of information.
Pay attention to the weather around you as well. Learn how to spot tornado signs, including a rotating funnel, a loud roar, or flying debris. Don't wait to see a funnel before taking shelter if the NWS issues a warning. Warnings can leave little time to react. Choose your shelter spot and prepare your alert devices before storm season.
Prepare Your Shelter Spot: Power for Alerts and Light
Pick a basement or small interior room on the lowest floor of your home. Keep a charged phone, weather radio, flashlight, and backup power source nearby. If a tornado warning arrives, take cover first. Never delay sheltering to move or connect equipment.
Set up a small storm kit
Choose a spot away from windows, ideally in a basement or an interior room on the lowest floor. Keep these supplies together:
  • A battery-powered or hand-crank weather radio
  • A charged cell phone and charging cable
  • A flashlight or battery-powered lamp
  • Extra batteries and a power bank
  • Water, basic first-aid supplies, and essential medication
Check your radio and flashlight before storm season. Replace weak batteries and charge your backup equipment. Make sure everyone in the household knows where the kit is and how to get to the shelter area.
Keep a power station ready for alerts and lighting
A charged portable power station can keep a weather radio, phones, and a small lamp running if a storm knocks out electricity. The best time to set it up is before severe weather arrives. Keep it in your planned shelter area so you don't have to search for it during an alert. The EcoFlow DELTA 3 Classic has a 1,024Wh battery capacity. It can provide backup power for small devices such as phones, a weather radio, and an LED lamp. EcoFlow lists AC recharging from 0 to 80% in about 45 minutes.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
How long can it run a radio, lamp, and phones?
The following example assumes a combined 30W load from a weather radio, LED lamp, and phone charging.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Weather radio + LED lamp + phones (placeholders)
about 30W
about 29 hours
This is an estimate, not a guaranteed runtime. It uses 85% of the battery's rated capacity to account for power conversion losses. Estimated runtime (hours) = Usable battery energy (Wh) ÷ Load (W). Replace the 30W placeholder with the actual wattage of your devices before relying on the estimate. Check their labels or manuals, and remember that charging patterns affect total runtime. A power station is there to support your storm plan, not replace it. Take shelter as soon as a warning is issued. Do not delay taking shelter to connect equipment or carry it downstairs. For more backup-power planning, read our guide to keeping power on after a tornado.
The November 12, 2026 Chesterfield Tornado
In its November 13, 2026 damage survey, NWS Mount Holly confirmed an EF-1 tornado that struck Chesterfield, Burlington County, on November 12. The tornado had estimated peak winds of 100 mph and traveled about 1.5 miles. It lasted roughly five minutes. These are preliminary NWS findings, subject to final review.
What the NWS damage survey found
The NWS reported these details for the Chesterfield tornado:
Survey detail
NWS finding
Location
Chesterfield, Burlington County, New Jersey
Date
November 12, 2026
Rating
EF-1
Estimated peak wind
100 mph
Path length
1.5 miles
Maximum width
100 yards
Estimated time
4:00 to 4:05 p.m. EST
Injuries
0
Fatalities
0
The same storm system also produced an EF-1 tornado near Newark, Delaware, according to NWS Mount Holly's updated damage survey. The Chesterfield survey gives a clear example of how a brief tornado can still produce damaging winds. Tornado damage depends on wind speed, the path of the storm, and the structures it crosses. Learn how tornadoes damage homes to understand why roofs, trees, windows, and exterior walls can be affected differently. The November 12 event is a past storm, not an active warning. For current conditions, check your local NWS office and your county's official emergency alerts.
Where to Shelter During a Tornado Warning
Go to the lowest floor of your home and put as many walls as possible between you and the outside. A basement is usually the best option. If you don't have one, use a small interior room such as a bathroom, closet, or hallway away from windows.
Where to Shelter During a Tornado WarningWhere to Shelter During a Tornado Warning
If you're at home
Follow these steps when a tornado warning covers your area:
  1. Go to the basement or lowest floor.
  2. Choose a small interior room away from windows and exterior walls.
  3. Stay under sturdy furniture if possible.
  4. Cover your head and neck with your arms, a mattress, or a thick blanket.
  5. Keep your phone and weather radio with you for updates.
Avoid rooms with large windows, exterior doors, or wide open spans. Don't go outside to watch the storm or try to record it.
If you're in a mobile home or vehicle
Mobile homes are not safe places to shelter during a tornado, even when they're tied down. Move to a sturdy nearby building before the storm arrives if you have time. If a warning is already in effect, follow local emergency instructions and don't risk driving through dangerous conditions.
Being in a vehicle during a tornado is also dangerous. If you can reach a sturdy building, get inside and take shelter. Don't try to outrun a tornado in traffic. Nighttime storms can be harder to spot, especially when visibility is low. Review these night tornado safety tips and keep your weather radio close enough to hear overnight alerts.
For tornado New Jersey alerts, remember the difference: a watch means stay ready, while a warning means take cover immediately. NWS Mount Holly confirmed that an EF-1 tornado with estimated 100 mph winds struck Chesterfield on November 12, 2026. Use NJOEM's county directory to find local emergency alerts, check which NWS office serves your county, and choose a shelter spot before the next storm. Keep a charged EcoFlow DELTA 3 Classic there for phone, radio, and light backup, but never delay taking cover to reach it.
Is there a tornado warning in New Jersey right now?
Check NWS Mount Holly or NWS Upton for current tornado warnings in your area. This guide doesn't show live alert status, so check the latest update and its expiration time. If a warning covers your location, move to your shelter immediately.
Did a tornado hit New Jersey in November 2026?
Yes. NWS Mount Holly's November 13, 2026 damage survey confirmed that an EF-1 tornado struck Chesterfield, Burlington County, on November 12. It had estimated peak winds of 100 mph, traveled about 1.5 miles, and caused no reported injuries or fatalities.
How do I get New Jersey emergency alerts?
Use NJOEM's Staying Informed guide and county emergency management directory to find official information sources and any alert sign-ups offered in your community. Keep Wireless Emergency Alerts enabled on a compatible phone, and check your local NWS office for tornado watches and warnings. Follow local emergency instructions immediately.
Where should I go during a tornado warning?
Go to your basement or a small interior room on the lowest floor, away from windows and exterior walls. Cover your head and neck with your arms, a mattress, or a thick blanket. Stay sheltered until local authorities or the National Weather Service say the danger has passed.
Which NWS office covers my New Jersey county?
NWS Mount Holly covers most of New Jersey, while NWS Upton serves the northeastern part of the state. Check Mount Holly's local forecasts or Upton's forecasts to find alerts for your area. The correct office matters because warnings are issued for specific locations and can have different expiration times.
Power Outages
