Furnace Repair Checklist for Winter: Homeowner Checks, Technician Tasks, and a Backup Power Plan
A reliable furnace needs more than a quick look before winter. Some maintenance tasks, such as checking the air filter and clearing vents, take just a few minutes. Others, including gas pressure testing, burner inspection, and heat exchanger checks, belong to a qualified HVAC technician. This furnace repair checklist for winter separates both responsibilities into one printable table, explains what an annual preventive maintenance visit should cover, and identifies warning signs that need immediate attention. It also includes one often-overlooked final step: planning backup power for a properly functioning furnace.
The Furnace Maintenance Checklist: Printable Table for Winter
Use this table as a seasonal reference and keep a copy near your furnace. Follow the manufacturer's instructions for homeowner maintenance, and leave gas, combustion, and electrical work to a qualified professional.
Item
Who
How often
Inspect, clean, or replace the air filter
Homeowner
Monthly during heating season
Test smoke and CO alarms; check batteries
Homeowner
Spring and fall, plus manufacturer guidance
Clear supply vents, return grilles, and surrounding space
Homeowner
Before winter and as needed
Visually inspect outdoor intake and exhaust openings
Homeowner
Before winter and after snowstorms
Check thermostat settings and batteries
Homeowner
At the start of the season
Inspect the condensate drain and trap
Technician (homeowner can look for leaks)
Annual tune-up
Check electrical connections and motor readings
Technician
Annual tune-up
Lubricate applicable moving parts
Technician
Annual tune-up
Inspect fuel connections, pressure, combustion, and heat exchanger
Technician
Annual tune-up
Verify safe startup and shutdown controls
Technician
Annual tune-up
Inspect the igniter and clean the flame sensor as needed
Technician
Annual tune-up
Plan backup power and confirm safe circuit connections
Homeowner plans; licensed electrician installs
Annually and after system changes
The distinction matters because homeowners can identify potential heating problems without attempting repairs; never open a burner compartment or adjust gas fittings during a DIY inspection. As part of your winter preparation, follow practical steps to winterize your home for safety, including sealing drafts, checking alarms, and organizing essential supplies before severe weather arrives.
Furnace PM Checklist: What a Technician Should Check on a Gas Furnace
Preventive maintenance, often shortened to PM, is the inspection and servicing performed to help a heating system operate safely and reliably. The CDC recommends having fuel-burning heating systems serviced annually by a qualified technician. A professional visit should involve more than switching the furnace on and confirming that warm air comes out.
Core Tasks From ENERGY STAR's Maintenance Checklist
ENERGY STAR's HVAC maintenance guidance includes several important checks:
  • Thermostat and controls: verify the thermostat calls for heat and the furnace starts, operates, and shuts down correctly.
  • Electrical connections: Inspect electrical connections and measure motor voltage and current where appropriate.
  • Moving parts: Lubricate components as specified in the manufacturer's maintenance instructions.
  • Condensate drainage: Check the drain and trap on applicable systems for blockages, leaks, or drainage issues.
  • Fuel connections and pressure: Inspect gas or oil connections and verify that operating pressures meet manufacturer specifications.
  • Burner combustion: Evaluate burner operation and combustion safety to identify potential performance or safety issues.
  • Heat exchanger: Inspect the heat exchanger for cracks, damage, or deterioration that could compromise safe operation.
Other Items Common on Technician PM Lists
Depending on the furnace type and its condition, the technician may perform additional checks to ensure safe operation, reliable heating, and proper ventilation.
  • Clean the flame sensor to support reliable flame detection and inspect the igniter for wear, damage, or starting problems.
  • Inspect the blower wheel for dust buildup and clean it when necessary to maintain proper airflow.
  • Check pressure-switch hoses and connections for blockages, cracks, or loose fittings that could affect furnace operation.
  • Inspect vent piping joints and outdoor termination points for damage, loose connections, or obstructions.
  • Flush the condensate trap on applicable high-efficiency furnaces to remove buildup and help prevent drainage blockages.
  • Perform combustion testing and appropriate carbon monoxide checks to assess combustion performance and identify potential safety concerns.
Questions to Ask After the Visit
Before the technician leaves, ask a few key questions to understand your furnace’s condition, identify potential repairs, and prepare your heating system for winter.
  • Was the heat exchanger inspected, and were any concerns found?
  • Were combustion and safety checks completed?
  • Are any components showing signs of wear?
  • Does anything need repair before heavy winter use?
  • Can I receive written service findings and recommendations?
Before the appointment ends, ask the technician about the heat exchanger inspection, combustion and safety checks, worn components, and any repairs needed before winter. Request written service findings and recommendations, then consider ways to reduce home heating costs through proper insulation, thermostat adjustments, and regular furnace maintenance to improve comfort and manage energy use during colder weather.
The Last Item on the Checklist: Your Furnace's Outage Backup Power Plan (EcoFlow TITAN 5000 Classic)
A gas furnace still needs electricity to operate its blower, ignition system, and electronic controls. That means a furnace can be in excellent repair and still stop heating when the grid fails. Plan for backup power only after the furnace passes its maintenance and safety checks. Backup electricity is not a workaround for faulty equipment, and it does not replace professional repairs.
Furnace and Home Battery Backup Power System in WinterFurnace and Home Battery Backup Power System in Winter
Check
What to record or confirm
Where to find it
1. Electrical load
Furnace voltage and amps, plus lights, router, and phone charging
Furnace rating plate and device labels
2. Starting power
Whether startup demand fits the backup system's output
HVAC technician or electrician
3. Backup capacity
Available watt-hours and desired runtime
Backup system specifications
4. Gas supply
Natural gas availability or propane level
Utility or propane supplier
5. Transfer and wiring
Approved circuit connections and transfer equipment
Licensed electrician and local code requirements
For example, Carrier's Comfort 80 58SC0A/58SC1A product data lists a nominal electrical supply of 115 volts, 60 Hz, single-phase, with maximum unit amps varying by model. Your own furnace's rating plate and installation manual are the correct starting points for sizing.
Where EcoFlow TITAN 5000 Classic Fits
Once your furnace passes inspection, a suitable backup system can help keep it running during a power outage. EcoFlow TITAN 5000 Classic supports essential 120V loads, making it an option for compatible gas furnaces, lights, and communication devices. It requires compatible distribution equipment and professional installation by a licensed electrician. It is not designed to power 240V equipment, such as electric furnaces, central air conditioners, or heat pump outdoor units.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Estimate Runtime: A Worked Example
For example, a Carrier furnace rated at a maximum of 8.3A at 115V draws approximately 955W at that rating. A 5,000Wh battery with an assumed 85% usable capacity provides about 4,250Wh, equivalent to roughly 4.5 hours at continuous maximum draw. Actual runtime varies because the furnace cycles on and off, and additional devices use stored energy. Before winter, follow a pre-winter blackout drill with your electrician to confirm which circuits remain powered. Never operate a fuel-burning generator indoors or in a garage. Operate it outdoors at least 20 feet from the house, away from doors, windows, and vents, with exhaust directed away from your home and other buildings' entrances. Follow the manufacturer's instructions.
Seasonal Furnace Checks to Repeat Through the Winter
A fall tune-up does not cover every problem that can develop in January. Filters can collect dust as the furnace runs, and snow can block intake or exhaust openings on high-efficiency systems. Repeat these simple checks throughout the heating season.
Seasonal Furnace Checks to Repeat Through the WinterSeasonal Furnace Checks to Repeat Through the Winter
Filters and MERV Ratings
Inspect the air filter monthly during the heating season, and clean or replace it according to the manufacturer's instructions. A clogged filter can restrict airflow and make the system work harder. MERV ratings describe how effectively an air filter captures particles of different sizes. A higher rating is not automatically better for every furnace: a filter that restricts too much airflow may cause problems. Before upgrading to a higher-MERV filter, ask an HVAC professional what your system can accommodate.
Vent Pipes After Snowstorms
After heavy snowfall or drifting, look at the outdoor intake and exhaust openings. If snow blocks them, carefully clear the openings by hand without damaging or altering the pipes. Never climb into an unsafe area or dismantle venting. If a pipe is damaged or the furnace repeatedly shuts down, contact an HVAC professional.
CO Alarms
The CPSC recommends installing CO alarms on every level of your home and outside sleeping areas, with interconnected alarms providing added protection by triggering together. Test alarms according to the manufacturer's instructions and replace them as directed or when they reach the end of their service life; the CDC advises replacing CO detectors according to the manufacturer's guidance or every five years. Because carbon monoxide and carbon dioxide require different monitoring approaches, understanding the difference between carbon monoxide and carbon dioxide in indoor air can help you choose the appropriate monitoring devices and respond to potential hazards.
Furnace Repair Warning Signs: When Maintenance Isn't Enough
Maintenance helps catch wear before a breakdown, but some symptoms need immediate action rather than waiting for the next tune-up. A few indicate potential life-threatening hazards. The CDC reports that more than 400 Americans die annually from unintentional carbon monoxide poisoning unrelated to fires, with more than 100,000 emergency department visits and over 14,000 hospitalizations.
Warning Sign
What to do
CO alarm sounds, or household members develop headaches, dizziness, nausea, or confusion
Get everyone outside into fresh air and call 911 from a safe location.
Rotten-egg smell suggesting a gas leak
Leave immediately without operating switches or using a phone inside. Call the gas utility or emergency services from a safe place.
Persistent burning smell or visible smoke
Turn the furnace off only if it is safe to do so, leave if there is smoke or danger, and contact the appropriate emergency service or HVAC professional.
No heat, repeated failed ignition, or frequent short cycling
Stop repeated restart attempts and arrange professional diagnosis.
Loud banging, grinding, or persistent rattling
Turn the system off if safe and schedule a repair.
Never run a furnace with a suspected fault on backup power; have the equipment repaired and verified before using it again. During freezing weather, a heating failure can also put your plumbing at risk, so follow practical steps to prevent frozen pipes in winter while preparing safe alternative heating arrangements and protecting your household during an outage.
A furnace repair checklist for winter helps you separate routine homeowner checks from professional maintenance. Check filters, vents, alarms, and thermostat settings regularly, while a qualified technician inspects gas connections, burners, the heat exchanger, and wiring annually. Treat CO alarms and suspected gas leaks as emergencies. Print the checklist, schedule your seasonal tune-up, and complete the final backup power plan. For a compatible 120V gas furnace, consider EcoFlow TITAN 5000 Classic with Smart Home Panel 10 (120V version), professionally installed.
What should a furnace maintenance checklist include?
It should include filter checks, CO and smoke alarm testing, clear vents, thermostat checks, and an annual professional inspection of fuel connections, combustion, the heat exchanger, electrical connections, and controls.
How often should a furnace be inspected?
Have your heating system serviced by a qualified technician annually, following the CDC's recommendation and your furnace manufacturer's maintenance schedule.
What is a furnace PM checklist?
A furnace preventive maintenance checklist is the technician's service list. It typically covers combustion, burners, electrical connections, controls, condensate drainage, venting, and relevant safety checks.
Can I do furnace maintenance myself?
Yes. Homeowners can check filters, clear accessible vents, test alarms, and inspect thermostat settings. Leave gas fittings, burners, the heat exchanger, and internal electrical work to a qualified professional.
Should I plan backup power for my gas furnace?
Yes, particularly if winter outages are common in your area. Most modern gas furnaces need electricity to operate, but backup power should only be used with a healthy, compatible furnace and an approved electrical connection installed by a licensed electrician.
Home Solutions
