What Is SEER? A Homeowner's Guide to Heat Pump SEER Ratings
You're comparing two heat pumps, and the contractor's quote lists one at 15.2 SEER2 and another at 23 SEER2. The second costs several thousand dollars more. Is the higher rating worth the extra money? SEER tells you how efficiently a system cools your home, but the number alone won't settle that question. You'll also need to consider your climate, electricity rates, heating needs, and installation. Here's how to read the ratings, understand the federal minimums, and figure out what a heat pump's 240V electrical requirements mean if you want backup power during an outage.
What Is SEER? The Short Definition and What It Measures
SEER stands for Seasonal Energy Efficiency Ratio. It measures how much cooling an air conditioner or heat pump delivers for the electricity it uses over a typical cooling season. A higher rating means the system provides more cooling per unit of electricity. In practical terms, the rating compares seasonal cooling output in British thermal units (BTUs) with the electricity consumed in watt-hours. Trane describes SEER2 as a seasonal average measured across outdoor temperatures from 65°F to 104°F. For a heat pump, SEER2 covers cooling efficiency only. You'll need another rating, HSPF2, to compare heating efficiency.
What Is SEER? The Short Definition and What It MeasuresWhat Is SEER? The Short Definition and What It Measures
SEER at a glance
  • What it means: Seasonal Energy Efficiency Ratio.
  • What it measures: Cooling output compared with electricity use over a season.
  • Which systems carry the rating: Central air conditioners, air-source heat pumps, and ductless mini-splits.
  • How to read it: Higher SEER or SEER2 ratings indicate better seasonal cooling efficiency.
The rating comes from standardized testing, so your actual electric bill may look different. Leaky ducts, poor sizing, thermostat settings, local weather, and installation quality all affect energy use. A high-rated system installed in a home with major duct leaks won't deliver its full potential. That makes proper sizing an important part of the decision. A contractor's load calculation should account for your home's size, insulation, windows, climate, and other factors before you settle on a system.
SEER vs. SEER2 and the federal minimums
On January 1, 2023, new federal efficiency standards took effect, introducing SEER2, EER2, and HSPF2 ratings. The updated testing procedure puts more resistance on the equipment's indoor blower to better reflect the conditions of a real home's ductwork.
Why SEER2 Replaced SEER
The U.S. Department of Energy (DOE) explains that SEER2 uses a different test method from the original SEER metric. The numbers are related, but they're not directly comparable. Don't assume a specific SEER rating converts to the same number under SEER2, or use a simple conversion formula to compare equipment. When reviewing contractor quotes, compare SEER2 with SEER2 and the older SEER ratings with other older SEER ratings.
Federal heat pump and air conditioner minimums
The minimum efficiency rating depends on the equipment type and, for certain central air conditioners, where the system will be installed.
Equipment (residential)
National minimum (manufactured on or after Jan 1, 2023)
Southeast and Southwest (installed on or after Jan 1, 2023)
Split-system heat pump
14.3 SEER2, 7.5 HSPF2
Same as national (regional rules don't apply to heat pumps)
Single-package heat pump
13.4 SEER2, 6.7 HSPF2
Same as national
Split-system central AC, under 45,000 Btu/h
13.4 SEER2
14.3 SEER2
Split-system central AC, 45,000 Btu/h or more
13.4 SEER2
13.8 SEER2
Single-package central AC
13.4 SEER2
13.4 SEER2 (Southwest also sets an EER2 minimum)
DOE rules for central AC vary by region. The Southwest includes Arizona, California, Nevada, and New Mexico; the Southeast covers the states and territories defined by DOE; all other areas fall under the North. Southwest split AC units must also meet an EER2 minimum. Northern standards depend on manufacture date, while southern split AC standards depend on installation date.
For a new split heat pump anywhere in the U.S., the minimum heat pump SEER2 rating is 14.3, with a minimum HSPF2 of 7.5. Homeowners may also compare heat pumps with gas furnaces using this guide to heat pump vs. furnace costs and efficiency. A higher SEER2 rating can lower electricity use, but most central heat pumps still need 240V power, which matters when choosing backup power for outages.
A Heat Pump Is a 240V Load: What That Means for Backup Power
Most residential central heat pumps use dedicated 240V circuits rather than standard 120V outlets. For example, Lennox specifies 208/230V single-phase, 60Hz power for its SL25XPV-024, SL25XPV-036, SL25XPV-048, and SL25XPV-060 outdoor units. While refrigerators, lights, and routers typically use 120V, heat pumps, central AC units, and some other appliances require higher-voltage circuits. A higher SEER2 rating lowers seasonal energy use but doesn't change the unit's specified voltage or startup requirements. Check the outdoor unit and air handler nameplates, especially if the system has electric backup heat strips.
EcoFlow TITAN Classic vs. EcoFlow TITAN Plus
The EcoFlow TITAN Classic powers essential 120V circuits but cannot run 240V heat pumps, central AC, or other 240V appliances. The EcoFlow TITAN Plus supports selected 120V and 240V circuits within its power limits. EcoFlow TITAN Plus can start a 3-ton central AC while powering about 1kW of essential loads in its specified test scenario. Before choosing either system, have a qualified electrician check your equipment's nameplates and confirm compatibility. Both pair with the EcoFlow Smart Home Panel 10 in the appropriate configuration and require professional installation.
EcoFlow TITAN 5000 Classic
•Certified Safety: UL9540, UL9540A, and UL1741 certified, with an IP20 rating for indoor use. • Essential 120V Output: 4kW for essential 120V loads such as a refrigerator, lights, and a Wi-Fi router. It is not designed for 240V appliances like central AC, a well pump, or an electric dryer. • Expandable Capacity: 5kWh base capacity, expandable up to 30kWh with additional TITAN batteries (sold separately). •Outage Backup: An entry-level indoor option for critical circuits during an outage. It has no grid-interactive or AC-coupled solar features. • Recharging: 3.2kW single-MPPT solar input, plus a NEMA TT-30R outlet.
For homes that need more output, the EcoFlow TITAN Plus adds 120V/240V support for selected household circuits, including compatible heavy loads within its power limits.
EcoFlow TITAN 5000 Plus
• Certified Safety: UL9540, UL9540A, and UL1741 certified, with 40160 tabless LFP cells and an IP20 rating for indoor installation. •Backup Output: 7.2kW from the battery alone, rising to up to 10kW only when compatible solar panels are connected and producing. •Heavy Loads: In EcoFlow's defined 240V test scenario, it can start a 3-ton central AC while running about 1kW of essential loads. Results depend on your AC unit, the circuits you back up, and available battery and solar power. •Expandable Capacity: 5kWh base capacity, expandable up to 30kWh with additional TITAN batteries (sold separately). • Home Connection: Backup of up to 10 selected circuits with 20ms auto-switchover requires Smart Home Panel 10, installed by a qualified electrician.
The EcoFlow TITAN Classic backs up essential 120V circuits but cannot run a 240V heat pump. The EcoFlow TITAN Plus supports selected 120V/240V circuits, with 7.2kW of battery output, subject to its capacity limits. Have an electrician confirm your heat pump’s compatibility before buying. The EcoFlow TITAN Plus also supports time-of-use savings only if your utility offers suitable rates; the EcoFlow TITAN Classic has no time-of-use savings role.
With compatible rooftop solar, EcoFlow TITAN Plus supports X-Fusion 2.0 AC coupling in no-export mode, and PV Boost can raise output to 10kW while solar is producing. Utility rules apply, and no-export operation earns no export credits. Knowing which appliances need 240V split-phase power helps you choose which circuits to back up. Next, let’s look at models shoppers consider when searching for the highest SEER heat pump.
Highest SEER Heat Pumps You Can Buy Today
Several major manufacturers list central heat pumps with SEER2 ratings in the low 20s. Some ductless mini-splits can rate higher. These are manufacturer-listed maximums for specific matched equipment combinations, not ratings every installation will achieve.
Brand and model
Type
SEER2 (as the maker states it)
HSPF2 (as the maker states it)
Carrier Infinity 25VNA4
Central variable-speed heat pump
Up to 23
Up to 10.5
Daikin DZ9VC
Up to 22.5
8.2 (stated with the "up to" SEER2 figure)
Daikin OTERRA Wall Mount
Ductless wall-mount heat pump
Up to 21
Up to 10.2
Lennox SL25XPV
Central variable-capacity heat pump
Up to 23
Up to 10.3
Mitsubishi Electric MUZ-HM (M-Series)
Ductless wall-mounted single-zone heat pump
20 SEER2
Not stated on page
The table is alphabetical, not a ranking. Ratings can change with the unit's size and the matched indoor coil or air handler. Before comparing quotes, confirm the exact combination in the AHRI Directory of Certified Product Performance or ask your contractor for the system's AHRI certificate. The highest rating on a product page isn't necessarily the best fit for your home. A properly sized system that matches your heating and cooling needs may be a better choice than chasing the largest number.
Heat Pump SEER Rating vs. HSPF2, EER2, and ENERGY STAR
A heat pump has more than one efficiency rating because it cools and heats your home under different conditions. SEER2 covers seasonal cooling, EER2 measures cooling efficiency at a specific hot outdoor temperature, and HSPF2 measures heating efficiency over a season.
What each rating tells you
  • SEER2: Seasonal cooling efficiency across a range of outdoor temperatures.
  • EER2: Cooling efficiency under a single test condition, with an outdoor temperature of 95°F.
  • HSPF2: Seasonal heating efficiency.
If you live in Minnesota or Maine, HSPF2 and cold-climate performance may matter more than a small increase in SEER2. In Phoenix, cooling efficiency and EER2 deserve more attention because the system regularly faces high outdoor temperatures.
ENERGY STAR efficiency levels
ENERGY STAR sets higher efficiency standards than federal minimums, helping homeowners identify heat pumps that use less energy. Its Version 6.2 specification, effective January 1, 2023, outlines the following requirements. The heat pump requirements remain in effect; the two central AC rows below are historical, as ENERGY STAR ended central air conditioner certification on February 2, 2026.
ENERGY STAR category
SEER2
EER2
HSPF2
Heat pump, split system
15.2 or higher
11.0 or higher
7.8 or higher
Heat pump, single package
15.2 or higher
10.0 or higher
7.2 or higher
Cold Climate heat pump, split, non-ducted
15.2 or higher
(not listed)
8.5 or higher
Cold Climate heat pump, split, ducted
15.2 or higher
(not listed)
8.1 or higher
Central AC, split system (historical; certification ended February 2, 2026)
15.2 or higher
12.0 or higher
n/a
Central AC, single package (historical; certification ended February 2, 2026)
15.2 or higher
11.5 or higher
n/a
ENERGY STAR's cold-climate heat pump criteria also include a coefficient of performance (COP) of at least 1.75 at 5°F and a heating capacity at 5°F that's at least 70% of its capacity at 47°F. COP compares the heat delivered with the energy used under a particular condition. Those cold-weather figures matter if you live somewhere with long stretches below freezing. A system's cooling rating won't tell you how well it heats your house on a bitter winter morning.
Is a higher-SEER heat pump worth it?
 Is a higher-SEER heat pump worth it? Is a higher-SEER heat pump worth it?
A higher-SEER2 heat pump generally costs more upfront and uses less electricity for the same amount of cooling under comparable conditions. Whether the price difference pays off depends on your home's cooling demand, local electricity rates, equipment, and how long you plan to stay. Before paying more for a higher rating, consider these factors:
  • Cooling season: Homes in hot states like Arizona and Texas may benefit more from a higher SEER2 rating because heat pumps run frequently during long summers. In cooler regions with shorter summers, the savings may be smaller.
  • Electricity rates: Check your utility's current rates and billing plan. Higher electricity prices can make efficiency improvements more valuable, depending on how much energy your system uses.
  • Home size and ductwork: Larger homes may need more cooling, while leaky ducts waste conditioned air. Proper sizing, good insulation, and sealed ducts improve efficiency. Compare heat pump and furnace costs and efficiency to understand which option better suits your heating needs.
  • Comfort and humidity: Variable-speed heat pumps adjust their output to maintain steadier temperatures. In humid climates, they can also help control indoor moisture, depending on the system and conditions.
  • Length of ownership: Staying in your home longer gives you more time to recover a higher upfront cost through lower energy bills. If you're moving soon, those savings may not offset the price difference.
Compare the cost difference with expected energy use
Ask your contractor to estimate each heat pump's annual electricity use, then multiply it by your utility's rate to compare running costs against the upfront price difference. Actual savings depend on your climate, thermostat settings, and installation quality. If you also need outage protection, check which appliances need 240V split-phase power before choosing a backup system. The federal Energy Efficient Home Improvement Credit covered qualifying improvements through December 31, 2025, so heat pumps installed in 2026 don't qualify under that credit. Check state and utility rebates, and consider a smart thermostat to help manage energy use.
SEER2 gives you a useful way to compare cooling efficiency, but it's only one part of a heat pump purchase. New split-system heat pumps must meet the federal minimum of 14.3 SEER2 and 7.5 HSPF2, while ENERGY STAR requires at least 15.2 SEER2 for qualifying split systems. Top central models reach the low 20s. Compare SEER2, HSPF2, and EER2 for your climate, confirm the exact equipment pairing through AHRI, and check your heat pump's electrical nameplate before planning outage coverage. EcoFlow TITAN Classic supports essential 120V circuits; EcoFlow TITAN Plus can support selected 120V/240V circuits within its limits. Both need the appropriate Smart Home Panel 10 and installation by a qualified electrician.
What is a good SEER rating for a heat pump?
For a new split-system heat pump, the federal minimum is 14.3 SEER2. Qualifying ENERGY STAR models must reach at least 15.2 SEER2, along with the required EER2 and HSPF2 ratings. In colder climates, pay close attention to heating efficiency as well.
What is the highest-SEER heat pump?
The central heat pumps listed by Carrier and Lennox reach up to 23 SEER2. Some ductless systems may rate higher. Check the exact model and matched equipment combination in the AHRI Directory before comparing ratings.
Is SEER2 the same as SEER?
No. SEER2 uses an updated test procedure that better reflects the resistance found in real duct systems. The DOE says the two metrics aren't directly comparable, so compare systems using the same rating method.
Can I still get a federal tax credit for a high-SEER heat pump in 2026?
The IRS states that the Energy Efficient Home Improvement Credit covered qualifying improvements made through December 31, 2025. A heat pump installed in 2026 doesn't qualify under that credit's stated period. Check state and local utility programs for other available incentives.
Can a home battery run my heat pump during an outage?
It depends on the heat pump's voltage, startup demand, running load, and the backup system's output and capacity. EcoFlow TITAN Classic provides 120V output and can't run a 240V heat pump. EcoFlow TITAN Plus supports 120V/240V loads within its limits, but a qualified electrician should confirm compatibility using your equipment's nameplate before installation.
Home Solutions
