How Is Electricity Made? The Science Behind the Grid
Flip a switch and the lights come on, but the actual process behind that is easy to take for granted. Almost all of it still comes down to a 19th-century discovery: spin a magnet inside a coil of wire and current flows out. What changes between a coal plant, a wind farm, and a nuclear reactor is just what's doing the spinning. This guide covers basic physics and how the US generation mix actually breaks down. It also gets into what storage changes once power exists and how it all travels from a plant to an outlet.
Basic Physics: Spinning a Magnet Inside a Coil of Wire
Electricity generation still runs on a principle Michael Faraday discovered in 1831. Moving a magnet inside a coil of wire induces an electric current in that wire. That's electromagnetic induction, and it's still the basis for most power generation today.
A generator scales that principle up. A stationary coil of wire, called the stator, surrounds a rotating electromagnetic shaft called the rotor. Spin the rotor, and current flows out through power lines.
What actually spins the rotor is the real variable between generation methods. Burning fuel, falling water, and moving air are all, mechanically, just different ways of spinning that same shaft.
Solar panels are the one common exception. There's no rotor, no coil, no spinning part at all. Photovoltaic cells convert sunlight directly into electricity through a different physical process entirely.
Fuel type changes what's driving the spin, but the electrical result out the other side is identical. A watt generated by a coal-fired steam turbine and a watt generated by a wind turbine are indistinguishable once they're on the grid. Induction doesn't care what pushes the rotor.
Nearly every generator on the grid also produces alternating current rather than direct current. AC is far easier to step up and down in voltage. That's a big part of why it became the long-distance power standard over a century ago, and it still is today.
Working through how you can create electricity goes deeper into that induction principle itself, including a few methods most people never think about.
With that mechanism established, the actual mix of what spins US turbines, and how much each source contributes, is worth breaking down.
The Generation Methods Behind the US Electricity Mix
Steam turbines still lead the US mix by a wide margin, but a few other mechanisms make up a meaningful share too.
Source | Share of 2022 US Generation |
Steam turbines (boilers, nuclear reactors) | 42.5% |
Combined-cycle systems (gas plus steam) | 33.8% |
Wind turbines | 10.3% |
Hydroelectric turbines | 6.0% |
Combustion gas turbines | 3.6% |
Solar photovoltaic (no turbine) | 3.3% |
Those figures come from the U.S. Energy Information Administration and reflect 2022, the most recent full-year breakdown EIA has published by generation method rather than just fuel type.
Steam turbines cover more than coal plants. That same mechanism, boiling water and spinning a turbine with the steam, also runs most nuclear power plants. A reactor is really just a tightly controlled heat source for making steam.
Combined-cycle plants capture extra efficiency by using the same fuel twice. A gas turbine spins first, then its leftover heat boils water for a second, steam-turbine pass.
Wind and hydro turbines work the same basic way as a coal-fired steam turbine, just with a different fluid doing the pushing. Moving air spins a wind turbine's blades directly, and falling water spins a hydroelectric turbine's blades. Neither one needs a combustion or boiling step first.
Wind and solar's combined share has grown steadily over the past decade. They still trail steam and combined-cycle generation by a wide margin in absolute terms, though. Neither one burns fuel or boils water. That's part of why EIA lists them as separate rows instead of folding them into steam turbines.
Total US generation has kept climbing in recent years too. Checking how US electricity generation hit a record puts these 2022 shares in a bigger, more current context.
Globally, the mix leans more heavily on fossil fuels than the US breakdown above suggests. The World Nuclear Association put fossil fuels at roughly 64.5% of worldwide generation as of 2017, with nuclear energy around 10.5% as of 2018. Treat those as dated snapshots rather than current numbers. The global mix has kept shifting in the years since.
Once electricity is actually made, what happens to it next depends on whether it's used the instant it's generated or stored for later. That's where a home's own setup starts to matter.
Once Electricity Is Made, Storage Decides What Happens Next
Generation and storage work the same way on a smaller, home-level scale. A source makes power, whether that's grid delivery or solar panels on a roof. A battery then decides whether that power gets used the instant it's made or held for later.
Without storage, a home is only ever using electricity the instant it's generated somewhere else on the grid. With storage, a home can hold power made at one time, like midday solar or off-peak rates. It can use that power at another time instead, including during an outage.
A home battery doesn't care whether the electricity filling it came from a coal plant three states away or a rooftop panel ten feet away. Once power reaches the battery, its origin stops mattering. What matters from that point on is capacity, output, and how quickly it can respond when the grid drops.
A remote lodge in Iceland shows both halves of that process on a tiny scale. Elliðaey, an island in the Westman Islands, has one building: a hunting lodge social media calls the loneliest house in the world. It has no grid connection, so for 60 to 70 years its power came from burning gasoline and propane on site.
In 2026, Reuters reported, the lodge switched generation methods. Two solar panels now make the electricity, with no turbine involved, and a 5kWh EcoFlow TITAN home battery system stores it. That stored power runs the stove, kettle, and lighting when solar power is unavailable. Communications equipment was mentioned as a potential additional use.
A typical home can apply the same generation-plus-storage principle without leaving the grid. The EcoFlow TITAN Plus takes up to 8kW of solar across two inputs, runs the home on that power first, then stores the surplus in a 5kWh battery that expands to 30kWh. With Smart Home Panel 10, installed by a qualified electrician, stored power runs up to 10 selected circuits.
Homes with a smaller array don't need two solar inputs. The standard EcoFlow TITAN keeps the 7.2kW of 120V/240V output and the expandable 5kWh base, and takes up to 4kW of solar through a single input, which suits a modest rooftop setup.
Some households only want the basics covered when the grid goes down. The EcoFlow TITAN Classic is the 120V entry model: 4kW for a refrigerator, lights, and Wi-Fi, with a 3.2kW solar input to recharge the battery. It is not built for 240V appliances.
Home batteries like these are also starting to work as more than backup for one house. Reading up on virtual power plants and home batteries covers that shift in more depth. Utilities are increasingly treating a neighborhood's worth of home storage as one shared grid resource.
Whether or not a home stores any of its own power, most electricity people use still travels a long way from where it's actually generated.
From Power Plant to Outlet: How Generated Electricity Reaches a Home
Power plants generate electricity at a relatively low voltage, then step it up dramatically for transmission. Higher voltage loses less energy over long distances. That's why the step-up happens before electricity ever leaves the plant.
Transmission lines carry that high-voltage electricity from generation sites toward populated areas. Substations along the way step the voltage back down for local distribution.
Distribution lines carry electricity the final stretch to individual homes and businesses. Voltage gets stepped down again at a transformer close to the property, low enough to be safe at an outlet.
This full path, plant, transmission, substation, distribution, outlet, is why a single generation source rarely serves just one neighborhood. The grid pools generation and distributes it broadly rather than routing one plant to one house.
Power plant steps voltage up for transmission
High-voltage transmission lines carry it toward populated areas
A substation steps voltage back down for local distribution
Distribution lines carry it the final stretch to a neighborhood
A transformer near the property steps it down again to outlet-safe voltage
This layered structure is also part of why a single storm or equipment failure rarely blacks out an entire region at once. A downed line usually knocks out a distribution segment or a substation, not the whole transmission backbone feeding it. That containment is what limits how far one failure spreads.
Following electricity transmission step by step lays out that full path in more detail, including what happens at each stage along the way.
Electricity generation still comes down to Faraday's 1831 principle in most cases: spinning a magnet inside a coil of wire. Solar is the one common exception that skips the turbine entirely. What changes across methods is what's doing the spinning and how power travels from plant to home. Increasingly, it's also whether the home stores any of what it uses. The EcoFlow TITAN Plus, EcoFlow TITAN, and EcoFlow TITAN Classic are all built around that same generation-plus-storage principle.
How is most electricity actually generated?
Most electricity still comes from spinning a magnet inside a coil of wire, the same principle Faraday discovered in 1831. What varies is what spins that shaft, whether it's steam, falling water, or moving air.
Do all power plants use turbines?
No. Solar photovoltaic panels skip the turbine and rotor entirely, converting sunlight directly into electricity through a different physical process. Almost every other generation method still relies on spinning a shaft.
How is solar power different from other electricity generation methods?
Solar panels have no moving parts and no coil of wire being spun. Every other common method, from coal to wind to nuclear, still comes down to spinning a rotor inside a stator.
How does electricity get from a power plant to a home?
It travels through a step-up transformer at the plant, then high-voltage transmission lines. A substation steps voltage back down from there, and distribution lines carry the final stretch to a home's own transformer.
Does storing electricity at home change how it was originally generated?
No. Storage only changes when power gets used, not how it was made. A battery like EcoFlow TITAN or EcoFlow TITAN Plus holds power generated earlier, whether from the grid or rooftop solar, for use later.
