What Size Generator Do You Actually Need for 400 Amp Service?
You'll see one number everywhere when researching 400 amp service. Multiply 400 amps by 240 volts, and you get 96,000 watts, or 96kW. Some generator sellers present that as the size your home needs. That's not how generator sizing works. A 400 amp panel shows your home's maximum electrical capacity. It doesn't show how much power your household actually uses. Most homes never draw anywhere near 400 amps at once.
This guide explains why 96kW math can be misleading. You'll also see how electricians size generators based on actual loads. We'll cover load calculations, realistic generator sizes, and situations requiring more capacity.
The Myth: "400 Amps × 240V = 96kW Generator"
The basic math behind the 96kW number looks simple enough. Watts equal amps multiplied by total volts in your system. Which means:
400 amps × 240 volts = 96,000 watts = 96kW
The raw mathematical formula itself is not wrong at all. However, that number only measures your panel's maximum capacity. It is the absolute electrical ceiling for your household wiring. It does not reflect your typical everyday electrical demand. It does not even match your peak real-world usage.
Buying a generator based on that ceiling is a mistake. You will pay for huge capacity you never actually touch. Figuring out how much power a house uses gives you a far more realistic starting baseline. You avoid wasting thousands of dollars on unneeded equipment.
What Electricians Actually Say
Electricians don't size a generator from the service rating alone. They size it to the load it will serve. One licensed electrician made this point during a discussion about 400-amp service: match the generator to the demand, not the panel. Take a 45kW unit. At 240 volts, it produces 187.5 amps (45,000W ÷ 240V), less than half of a 400-amp service rating, and it still runs everything most homes need during an outage. The service rating never enters that calculation.
The same logic applies to breaker pairings. A 45kW generator on a 400-amp breaker is a common mismatch on residential job sites, and most pros recommend a 200-amp breaker for that unit. The home generator sizing steps walk through how to match equipment to actual demand.
Electrician calculating ampsElectrician calculating amps
Knowing what size generator for 400 amp service you really need starts with proper load planning. Here is the exact calculation process you should use instead.
How to Actually Calculate the Generator Size You Need
The right generator starts with your home's actual electrical load. Follow these steps to estimate your needs before choosing a generator for backup power.
Step 1: Make your full appliance list
Walk through your entire home with a notepad and pen. List every single device you want to run during an outage. Include heavy draws like central air conditioners, refrigerators, and water heaters. Do not forget everyday necessities like lighting circuits and routers.
Step 2: Add running and starting watts
Check the manufacturer labels on all your listed appliances. Record both continuous running watts and initial motor starting watts. Starting surges often determine your actual minimum required generator capacity. Add the single highest motor surge to total running watts.
Step 3: Add about 20% extra capacity
Once you've totaled your loads, add roughly 20% headroom. That gives your generator some breathing room when your actual demand changes during an outage. Extra capacity can also help if you add appliances later. It gives you more flexibility without pushing the generator to its limit.
Example:
One typical suburban home totaled 13,800 running watts during testing. Motor starting surges pushed the peak load to 19,700 watts.
19,700 watts × 1.20 = 23,640 watts
23,640 watts ÷ 1,000 = 23.64kW
So, the calculated requirement is about 23.6kW with 20% headroom. That's nowhere close to the 96kW figure tied to 400 amp service.
That calculation shows why generator sizing should start with your actual load. Once you know how much power your essential circuits need, you can compare backup options based on capacity and output instead of your home's 400 amp service rating.
A Smarter Alternative to Oversized Gas Generators: EcoFlow TITAN
That worked example points to a much more realistic demand than panel-rating math suggests. Instead of oversizing for entire electrical panels, battery backup systems let you support selected circuits with zero fuel, no exhaust, and indoor operation. For handling substantial household loads across up to 10 selected circuits via Smart Home Panel 10, the EcoFlow TITAN Plus provides the highest capacity tier.
EcoFlow TITAN 5000 Plus
For homeowners who need reliable split-phase capacity without maximum dual-MPPT solar charging, the standard EcoFlow TITAN provides an ideal match. It delivers dependable 7.2kW of 120V/240V power to run selected circuits and heavy loads during unexpected outages.
EcoFlow TITAN 5000
If your backup needs focus solely on critical 120V appliances rather than 240V equipment, the EcoFlow TITAN Classic serves as an entry-level indoor alternative. It provides 4kW of dedicated 120V power to keep refrigerators, lights, and basic electronics running reliably.
EcoFlow TITAN 5000 Classic
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
What a Realistic Generator Size Looks Like
A 400-amp service doesn't mean you need a massive generator
  • Most homes get solid backup from 20kW to 30kW, nowhere near the full 96kW rating.
  • The right size comes from your actual load: the appliances you want running during an outage and what they draw together. Even with central air, an electric water heater, refrigerator, freezer, and lights on the list, few homes need anything close to 96kW.
Back up only essential circuits, and the required size drops
  • For most households, the essentials are enough: refrigeration, lighting, medical equipment, sump pumps, and selected HVAC circuits.
  • Every nonessential load you leave offline shrinks the generator you need to buy.
Know your panel before you lock in a size
  • Picking which circuits to back up gets easier once you know how your panel is organized. More circuits means more flexibility in what stays on.
  • That way you buy for your real needs, not for the number on the panel.
When You Might Actually Need Something Bigger
Some homes genuinely need more than 20kW or 30kW. The reason usually comes down to several large loads running together.
Larger homes may have multiple HVAC zones. They may also have well pumps, electric water heaters, pool equipment, and major appliances. Running several of these systems together can quickly increase your peak demand.
A larger generator may make sense if you want most systems available during an outage. Your actual load calculation should determine the final size.
An EV charger can add another significant load. A Level 2 home charger typically uses 240V power. Charging your vehicle alongside other major appliances can raise your total demand. That's why EV charging and home batteries should be part of your backup power planning.
You don't necessarily need to support every load simultaneously. You could delay EV charging during an outage. You could also turn off nonessential equipment to reduce your overall power needs.
When you need bigger ampsWhen you need bigger amps
Working With an Electrician on the Final Number
Paying a licensed electrician for a formal load calculation is always worth it. A professional calculates exact numbers for your specific property and appliances. That prevents costly guesswork based on simple panel rating shortcuts.
You also need a properly matched transfer switch installed. Connecting a generator safely requires a switch matched to your generator size rather than your panel rating. Learning how automatic transfer switches work makes planning your whole-home installation much easier. Professional installation keeps utility line workers safe during grid repairs.
A 400 amp service does not require a 96kW generator. That math shows up across generator marketing. Real-world sizing depends on your household’s actual running and starting watts. Most homes land between 20,000 and 30,000 watts for full coverage. Essentials-only backup often needs considerably less.
Calculate your actual load with a room-by-room appliance list. Skip multiplying your panel’s amp rating by voltage. Get a professional load calculation before you buy anything.
Once you know your actual essential load rather than sizing purely around your panel's maximum 400A rating, compare flexible battery backup solutions. These systems are built for targeted circuit coverage. EcoFlow TITAN, EcoFlow TITAN Plus, and EcoFlow TITAN Classic can back up up to 10 selected circuits through EcoFlow Smart Home Panel 10, installed by a qualified electrician. For 240V loads such as a well pump or central AC, choose TITAN or TITAN Plus, since TITAN Classic is 120V only. If your essential-circuit load is smaller, these systems can cover it without a large 20kW to 30kW fuel generator.
What size generator do I need for 400 amp service?
Most homes with 400-amp service only need a 20kW to 30kW generator. This easily runs multiple air conditioners and major appliances. Essentials-only backup setups can run smoothly on even smaller 7kW to 15kW units.
Does a 400 amp panel mean I need a 96kW generator?
No. The 96kW figure is only the theoretical maximum of the panel. No home draws that much power at the same time. Electricians size generators to the real load they will serve.
How do electricians actually size a generator for a home?
Electricians calculate the total continuous running watts of all target appliances. Then they add the single highest motor starting surge to that total. Finally, they factor in a safety margin for reliable operation.
What's a realistic generator size for a typical house?
For many homes, with 400 amp service 20,000 to 30,000 watts covers real-world needs. Prioritizing only essential circuits can drop that number lower. Focus on what you actually use during an outage.
Do I need a bigger generator if I have an EV charger?
Yes, in most cases. EV charging adds a meaningful load on top of your regular household draw, so it needs its own line item in your calculation.
Home Solutions
