How Does a Heat Pump Work in Winter? Cold-Weather Physics, Defrost, and Backup Heat
How can a heat pump pull heat from air at 20°F and use it to warm a home? Even at that temperature, outdoor air contains heat energy. A heat pump uses refrigerant and a compressor to collect that energy and move it indoors. However, its heating capacity and efficiency change as temperatures fall. This guide explains the winter heating cycle, defrost and backup heat, cold-climate models, and how to estimate battery runtime during a power outage.
How a heat pump works in winter: the refrigerant cycle in four steps
A heat pump does not burn fuel to create heat. Instead, it moves heat from one place to another. In winter, a reversing valve switches the refrigerant flow so the system can collect heat outdoors and release it inside.
Heat naturally moves from warmer areas to colder ones. The refrigerant must be colder than the outdoor air to absorb its heat. The compressor then raises the refrigerant's pressure and temperature, allowing it to warm the home.
Step
Where
What happens
Part doing the work
1. Absorb
Outdoor coil (the evaporator in heating mode)
Refrigerant colder than the outdoor air picks up heat and turns to gas
Outdoor coil and fan
2. Compress
Outdoor unit
Pressurizing the gas raises its temperature
Compressor
3. Release
Indoor coil in the air handler or wall head
Hot refrigerant gives up heat to indoor air, which the blower sends through the home
Indoor coil and blower
4. Reset
Line back to the outdoor coil
Pressure and temperature drop so the refrigerant can absorb heat again
Expansion valve
The reversing valve changes the direction of refrigerant flow between heating and cooling. It also plays a role in the defrost cycle, which helps remove frost from the outdoor coil.
Ducted and ductless heat pumps use the same basic process. The main difference is how each system delivers heat indoors. Because it moves heat instead of burning fuel, the comparison of heat pumps and furnaces on efficiency often looks different in Georgia than it does in Minnesota.
The cycle works the same at 45°F and at 5°F, but the colder it gets, the less heat each kilowatt-hour moves, and two helpers, defrost and auxiliary heat, start to step in.
What changes when it gets cold: efficiency, balance point, defrost, and auxiliary heat
A heat pump must work harder as outdoor temperatures fall. It usually delivers less heat and uses more electricity per unit of heat produced. Defrost cycles and auxiliary heat can also increase electricity use during cold weather.
COP and heating capacity fall as temperatures drop
The coefficient of performance (COP) measures heat delivered compared with electricity used. A COP of 2 means the system delivers two units of heat for each unit of electricity consumed.
Cold-weather performance is model-specific. For example, Bosch says its IDS Ultra can maintain 100% heating capacity down to 5°F and initiate heating down to −13°F. Those manufacturer claims describe that model; they do not establish a COP or backup runtime for other heat pumps.
When comparing models, check the manufacturer's low-temperature performance data and test conditions rather than assuming every heat pump will behave the same way.
What is the balance point?
The balance point is the outdoor temperature at which a heat pump's heating capacity matches the home's heating demand. It varies with the equipment, insulation, home size, and system design.
Below this point, the heat pump may need auxiliary heat to maintain the thermostat setting. There is no single balance-point temperature that applies to every home.
Why does a heat pump defrost in winter?
The outdoor coil can become colder than the surrounding air. Moisture then freezes on its surface, restricting airflow and reducing heat transfer.
During defrost, the reversing valve changes the refrigerant flow to warm the outdoor coil and melts the frost. The process can temporarily interrupt normal heating, and the system may activate backup heat.
Defrost cycles vary by model and weather conditions. Steam rising from the outdoor unit during defrost is usually normal. However, persistent heavy ice or unusually frequent, prolonged defrost cycles may require a technician's attention.
Auxiliary heat vs. emergency heat
Auxiliary heat helps a heat pump meet demand when its output is not enough. Many all-electric systems use resistance heating strips for this purpose. These strips can deliver heat reliably, but they often consume much more electricity than the heat pump.
Emergency heat is a separate thermostat setting intended for situations where the heat pump has failed or needs repair. It may rely on the backup heating system alone.
Auxiliary heat is a normal part of many systems. Do not disable it without guidance from a qualified HVAC technician.
Comparing heating output and electricity in the same units makes COP easier to picture, and a quick BTU to kWh conversion for heating does that in one step.
Falling COP, defrost, and strip heat all change how much electricity a heat pump uses on a cold night, which is why a rated spec can't predict how long backup power will last.
A heat pump meter showing temperatureA heat pump meter showing temperature
Why Rated Specs Can't Predict Outage Backup Time in Cold Weather (and Where EcoFlow TITAN Plus Fits)
A heat pump's rated performance comes from specific test conditions. Actual winter electricity use can differ because of lower efficiency, defrost cycles, and auxiliary heat. These factors also affect how long a home battery can power the heating system during an outage.
Three factors matter:
  • Lower efficiency: The same amount of heat requires more electricity as COP falls.
  • Extra heating loads: Resistance strips can add a substantial load during cold weather.
  • Combined electrical demand: The compressor, fans, and auxiliary heat may run together. Their total running and starting power must be checked before connecting backup power.
Estimate battery runtime for winter heating
For a hypothetical heating demand of 20,400 Btu/h (about 5.98kW of heat), compare COP values of 3, 2, and 1. These are illustrative efficiency assumptions, not measured results for a specific heat pump.
Heat source for the same 20,400 Btu/h
COP used
Estimated electric load
EcoFlow TITAN Plus 5kWh base: 5,000 × 0.85 ÷ load
At 30kWh maximum: 30,000 × 0.85 ÷ load
Heat pump at COP 3 (illustrative)
3
about 1,990 W
about 2.1 hours
about 12.8 hours
Heat pump at COP 2 (illustrative)
2
about 2,990 W
about 1.4 hours
about 8.5 hours
Electric strip heat
1
about 5,980 W
about 0.7 hours
about 4.3 hours
These are illustrations, not runtime guarantees. They assume continuous heating at the stated output and 85% usable battery energy after conversion losses. They exclude other household loads, such as lights and refrigeration.
At the same heating demand, a COP of 2 requires 50% more electrical input than a COP of 3. Resistance heat at COP 1 requires still more. Actual system performance and backup runtime depend on equipment, conditions, and connected loads.
For a realistic estimate, review your electricity use during a cold week and check the heat pump and air handler nameplates. A licensed electrician can assess the circuit loads and confirm whether a battery system can support them.
Where does EcoFlow TITAN Plus fit?
EcoFlow TITAN Plus offers a 5 kWh base capacity, expandable to 30 kWh, with battery-only output of up to 7.2 kW. Its higher output of up to 10 kW requires compatible solar panels to be connected and producing power.
With the compatible Smart Home Panel 10 240V version, installed by a licensed electrician, it can back up selected household circuits. A compatible heat pump may be among them, but its starting power, voltage, and combined loads must be checked first.
Expansion batteries add stored energy and potential runtime, not output power. An electric resistance heating kit rated at 8 kW or more would exceed the system's 7.2 kW battery-only output on its own. EcoFlow's published test involving a 3-ton central air conditioner does not establish compatibility with every heat pump.
Battery storage can help keep selected circuits running during an outage. It cannot improve a heat pump's cold-weather efficiency. Size the system around actual winter electricity use rather than the heat pump's rated capacity alone.
EcoFlow TITAN 5000 Plus
Runtime always comes back to stored energy divided by load, and the factors behind how long home backup batteries last apply to heating circuits the same way they apply to a refrigerator.
Equipment matters as much as sizing, and cold-climate heat pumps are built to hold more of their output when the thermometer drops toward 5°F.
Cold-climate heat pumps: what the ENERGY STAR label and DOE challenge require
Not all heat pumps perform equally well in extreme cold. Cold-climate models are designed to retain more heating capacity as outdoor temperatures fall. ENERGY STAR certification and the U.S. Department of Energy's Cold Climate Heat Pump Technology Challenge provide two useful benchmarks.
Benchmark
COP at 5°F
Capacity at 5°F vs. 47°F
Status
ENERGY STAR Cold Climate (Version 6.2 Central AC and Heat Pump specification, effective Jan. 1, 2023; revised February 2, 2026)
1.75 or higher
70% or more
Current certification criteria (also shown on ENERGY STAR's live Key Product Criteria page, checked 2026-10-13)
DOE Cold Climate Heat Pump Technology Challenge
2.1 to 2.4 minimum
100%
Technology challenges target, not a label
These benchmarks serve different purposes. ENERGY STAR sets certification criteria, while the DOE challenge established more demanding technology targets for participating manufacturers.
ENERGY STAR also checks whether a heat pump's native controls can achieve the required performance under normal operating conditions. Its cold-climate testing extends to 5°F, but backup heating may still be useful at lower temperatures.
When choosing a system, check its published low-temperature capacity and operating limits. A model's performance at 5°F matters more for a cold winter climate than its headline rating alone.
When an Arctic outbreak pushes subzero air deep into the country, the reasons polar blasts reach the South also explain why heat pumps well south of the northern tier sometimes face cold-climate temperatures.
Even a cold-climate heat pump usually has a partner for the coldest hours, either electric strips or a furnace, and the two share the job in different ways.
Dual-fuel and backup heat: how a furnace and heat pump share the winter
Many homes use a heat pump alongside another heating source. An all-electric system may use resistance heating strips. A dual-fuel system pairs the heat pump with a gas or oil furnace.
In a dual-fuel setup, the furnace can take over when outdoor temperatures make heat pump operation less effective or when the system cannot meet the home's heating demand. The changeover point depends on equipment, local energy costs, and system controls.
A qualified HVAC contractor can set up the controls, so the two heating sources work together. If a home retains an older furnace or boiler, its thermostat settings may also affect when backup heat activates.
Remember that a gas furnace still needs electricity for its controls and blowers. Without backup power, it may not provide heat during a blackout, even when gas is available.
A furnace's igniter, controls, and blower all need power, which is why a home that has a gas furnace without electricity loses heat in an outage just like an all-electric one.
Backup heat covers the coldest hours, and the last piece is keeping the outdoor unit itself working through snow and ice.
A heat pump requiring fixingA heat pump requiring fixing
Keeping a heat pump running through snow and ice
A heat pump needs clear airflow around its outdoor unit. Snowdrifts, leaves, debris, roof runoff, and heavy ice can restrict airflow and reduce performance.
Follow these basic winter maintenance steps:
  • Keep snow and loose debris away from the outdoor unit.
  • Check for roof runoff that could drain onto the unit and freeze.
  • Inspect the area regularly for ice buildup.
  • Consider a suitable rain and snow shelter that does not block airflow.
  • Leave normal defrost cycles alone, but contact a technician if heavy ice persists or defrost cycles become unusually frequent or prolonged.
Do not chip or pry ice from the coil, as this can damage the equipment. Clear loose snow gently and seek professional help for substantial ice buildup. Follow the manufacturer's maintenance guidance, and do not switch off the heat pump just because temperatures fall below freezing.
Roof meltwater that drips and refreezes is one of the ways ice builds on outdoor equipment, and preventing ice dams along roof edges cuts down on that runoff.
A heat pump heats a home in winter by extracting heat from outdoor air and transferring it indoors. As temperatures fall, its heating capacity and efficiency may decline. Defrost cycles and auxiliary heat help maintain operation, but they can increase electricity use.
Check your model's cold-climate performance and base any backup-power estimate on actual winter consumption. For selected heating circuits, EcoFlow TITAN Plus paired with Smart Home Panel 10 may be an option if the electrical loads are compatible. Have a licensed electrician assess the system before installation.
How does a heat pump heat a house when it's cold outside?
It runs its cooling cycle in reverse. Cold refrigerant absorbs heat from outdoor air, the compressor raises its temperature, and the indoor coil transfers that heat into the home.
At what temperature does a heat pump stop working?
There is no universal cutoff. Operating limits depend on the model. Some traditional systems struggle in very low temperatures, while cold-climate models are designed to operate in colder conditions. Check the manufacturer's specifications.
Why is steam coming from my heat pump in winter?
Steam or water vapor often appears when the defrost cycle melts frost from the outdoor coil. This is usually normal. Persistent heavy ice or repeated, prolonged defrost cycles may indicate a problem.
Is a heat pump still efficient below freezing?
Yes. Many heat pumps remain efficient below freezing, but performance varies by model and outdoor conditions. Cold-climate models are designed for lower temperatures; check the manufacturer's published low-temperature capacity, COP, and operating limits for the specific equipment.
How long can a home battery run a heat pump in winter?
Runtime depends on battery capacity, the heat pump's actual electrical draw, defrost cycles, and auxiliary heat. Review your winter energy use and have an electrician check the system's starting and running loads before choosing a battery.
Home Solutions
