EM Heat vs Heat: What Each Thermostat Setting Does on a Heat Pump
If your thermostat shows HEAT, AUX, and EM HEAT, the difference between EM HEAT and HEAT comes down to which equipment runs. HEAT uses the heat pump. AUX means the thermostat has automatically called for backup heat. Electric strips may run with the compressor, while a dual-fuel system can switch to its furnace and turn the heat pump off. EM HEAT turns the heat pump off and runs only the backup, which might be electric resistance strips or a gas furnace. This guide compares the three settings, explains when emergency heat makes sense, shows how each one changes your electrical load, and covers when to call an HVAC technician.
EM Heat vs Heat: The Three Thermostat Settings
HEAT and AUX are both part of normal operation, and your system moves between them without any help from you. EM HEAT is different because it's a manual override that you have to switch on yourself. Most homes rarely need it.
Setting
What runs
Triggered by
Typical use
HEAT
Heat pump
You (normal mode)
Everyday heating
AUX (electric resistance backup)
Backup strips, which may run alongside the heat pump, depending on system settings
Thermostat, automatically
Defrost, cold snaps, big setpoint jumps
AUX (dual fuel)
Gas or oil furnace, with the heat pump turned off
Outdoor temperature below the switchover point, or the heat pump falling behind
EM HEAT
Backup only
You, manually
Heat pump failure or damage
What AUX Means on Your Display
Seeing AUX light up on a frosty morning usually means the system is doing its job. The thermostat calls for backup heat when its settings and conditions require it. An all-electric system may run the strips during defrost or when more heat is needed. A dual-fuel system can switch from the compressor to its furnace, then return to heat-pump operation when its controls allow.
That's the main point in the aux heat vs em heat question. AUX calls backup heat automatically. An electric system may run the strips and compressor together, while a dual-fuel thermostat can switch to its furnace. EM HEAT is a manual setting that keeps the heat pump off.
What if AUX seems to stay on all day, even in mild weather? That isn't normal, and it can point to a setup or equipment problem that quietly raises your bill. Note when it happens and what the weather is like, then share those details with an HVAC technician.
Why Labels and Triggers Vary
Not every thermostat uses the same words. Some say AUX, others say "Backup Heat" or "Emer," and the rules for when backup turns on depend on how your installer set things up. Your thermostat manual is the best guide to what your screen means.
Your backup type matters just as much as the label. In an all-electric home, backup heat is usually resistance strips inside the indoor air handler. In a dual-fuel home, the backup is a gas furnace instead. If you're not sure which one you have, your installer can tell you.
Thermostats also decide how often backup heat runs. The Building America Solution Center explains that heat pump thermostats with adaptive recovery let the heat pump handle the warm-up and limit costly electric resistance backup. ENERGY STAR's smart thermostat certification criteria also require certified models to report electric resistance heat use for heat pumps. If you want to go further, see how smart thermostats manage HVAC staging and schedules.
Knowing which equipment runs in each mode is only half the picture. The backup type also changes how much power each setting draws, and that matters a lot when you plan for outages.
How Your Electrical Load Changes by Mode
Electric resistance backup draws far more power than the heat pump does. A gas furnace backup draws much less, since the gas makes the heat and electricity mainly runs the blower and controls. So when you plan backup power, size it for the mode you'd actually use during an outage.
Outdoor heat pump and indoor EcoFlow TITAN 5000 shown separately. A licensed electrician must evaluate the backup circuit and panel.Outdoor heat pump and indoor EcoFlow TITAN 5000 shown separately. A licensed electrician must evaluate the backup circuit and panel.
What Each Mode Asks of Your Panel
The same system can put very different loads on your panel. Here's how it shifts between settings:
  • HEAT: The outdoor compressor, the indoor blower, and the controls. The compressor also needs extra power for a moment when it starts.
  • AUX with resistance strips: The strips, indoor blower, and controls, plus the compressor only when the system allows both heat sources to run together.
  • EM HEAT with resistance strips: The strips, blower, and controls, with the compressor off.
  • EM HEAT with a gas furnace: The furnace’s electrical components can include the blower, draft inducer, igniter, gas valve, and controls. The outdoor unit stays off.
Your installer can confirm which kind of backup you have and what each piece draws. Check the model manual and wiring diagram for manufacturer-stated input watts, or ask an electrician to measure the real load. Fixed wiring and any troubleshooting belong with licensed professionals.
Startup is easy to overlook. A compressor needs a short burst of extra power each time it kicks on, and that burst can trip a backup system that handles the running load just fine. Other circuits running at the same time, like the fridge or a well pump, add to the total too. A good backup plan sizes for that peak, not just the average.
Sizing Backup Power for the Mode You'd Use
Picture a winter ice storm that cuts power for most of a day. If your heat pump is working, it's the most realistic heating load to keep on backup. Before you plan around a battery, decide between whole-home versus essential-circuit backup based on your heating mode.
The EcoFlow TITAN 5000 is a 5kWh home battery with 7,200W of 120V/240V split-phase output. It backs up selected circuits through a Smart Home Panel 10 installed by a licensed electrician. It's a useful example for comparing heating modes, because each mode puts a different load on backup power.
In HEAT mode, a compatible heat pump circuit is the realistic backup target for the EcoFlow TITAN 5000. Resistance strips in AUX or EM HEAT can exceed what backup should carry, so your electrician decides which circuits make sense.
EcoFlow TITAN 5000
Estimated Runtime by Heating Mode
The figures below are estimates, not promises. They assume about 4,265Wh of usable energy, which is 85 percent of the EcoFlow TITAN 5000's 5,017.6Wh, divided by each example load. The watt figures are placeholders, so swap in your own equipment's stated input watts or your electrician's measurements.
Mode
What's running (example watts)
Example total load
Single EcoFlow TITAN 5000 (7,200W rated output)
HEAT
Heat pump compressor, outdoor fan, indoor blower, and controls (about 3,500W)
About 3,500W
Within rated output; about 1.2 hours of steady running. Size separately for compressor startup.
AUX with strips, heat pump allowed to run
10kW rated strip kit (10,000W) + heat pump, blower, and controls (about 3,500W)
About 13,500W
Over the 7,200W rated output; not a fit for this configuration
AUX with strips, heat pump off, or EM HEAT with strips
10kW rated strip kit (10,000W) + blower and controls (about 500W)
About 10,500W
AUX (dual fuel) or EM HEAT with gas furnace
Combined furnace electrical load, including model-dependent components such as the blower and draft inducer (600W assumed)
About 600W
Within rated output; about 7.1 hours
The strip figure is the kit's rated input, not the heat it delivers. For the same heat, strips draw more power than a working heat pump. Extra batteries add stored energy but not output, so they don't change the 7,200W limit. Real runtime will also differ as the heat pump cycles and other circuits share the battery, and backup lasts only a limited time.
Load planning only matters once you know when emergency heat belongs in the picture. So when is switching to it the right move?
When Should You Use Emergency Heat?
Use EM HEAT if the heat pump is damaged or not working. Then call a technician to find out why. It isn't a setting to leave on as a habit.
Signs It's Time to Switch
Knowing when to use emergency heat mostly comes down to whether the heat pump can still heat your home. Watch for these common signs:
  • The outdoor unit has visible damage, such as from a fallen limb or storm debris.
  • Ice is blocking the outdoor unit and won't clear on its own.
  • The heat pump runs but sends no warm air, while backup heat still works.
Some frost on the outdoor coil in winter is normal, and the defrost cycle should melt it. Watch for heat pump ice that won't clear after a defrost cycle, because that can point to a real problem.
Why You Shouldn't Leave It On
Heat pump emergency heat on resistance strips gives up the efficiency that makes a heat pump worth owning. ENERGY STAR notes that a heat pump can deliver up to three times more heat than the electrical energy it uses. Resistance strips turn each unit of electricity into one unit of heat, so long stretches on strips can raise your bill quickly.
Cold weather alone isn't a reason to flip the em heat setting. If the heat pump needs help, the thermostat calls AUX on its own. Switch back to HEAT as soon as a technician clears the system for normal use.
While you wait for service, keep things simple. Check that the filter isn't clogged and that nothing is piled against the outdoor unit, but leave panels, wiring, and refrigerant work to the pro. Write down what you noticed, such as when the heat stopped and whether the outdoor fan was running, so the visit goes faster.
Cost is the other big factor in this choice. Here's what running EM HEAT can add to your bill.
What Emergency Heat Costs to Run
Cost depends on your backup type and your local rates. Resistance strips work like any electric heater. Energy use in kWh equals the heater's power in kW multiplied by its running hours, and cost is that kWh times your electricity rate. Gas backup burns gas for the heat and adds a small electrical load for the blower and controls.
Checking emergency heat running costs with the HVAC service panels closed.Checking emergency heat running costs with the HVAC service panels closed.
A Strip Heat Cost Example
Here's a simple example with labeled assumptions. A 10kW strip heater (a placeholder size) running for 4 hours uses 40kWh. At 18.16 cents per kWh, that's about $7.26 for those four hours. The rate comes from the EIA, which lists a U.S. average residential price of 18.16 cents per kWh for August 2026 (preliminary). Use the rate on your own bill, since prices vary by state and season.
Shorter runs scale the same way. Two hours on the same 10kW strips would use 20kWh, or about $3.63 at that average rate. The real cost depends on how many stages of strips turn on, how cold it is outside, and how often the system cycles.
That math is why strip heat costs about what an electric furnace does. Strip heat runs the way electric furnace wattage and cost figures suggest, since both turn electricity straight into heat.
How Gas Backup Compares
With gas backup, your gas bill rises instead. The furnace still needs electricity for parts such as the draft inducer motor, igniter, gas valve, blower, and control board, depending on the model. That load is usually far smaller than strip heat.
Whichever backup you have, a steady setpoint helps. Big thermostat jumps are a common AUX trigger, so small changes let the heat pump catch up on its own. If your thermostat reports backup heat use, check it now and then.
EM heat vs heat comes down to equipment: HEAT runs the heat pump, AUX calls for backup automatically, either adding electric heat or switching to the furnace as configured, and EM HEAT runs only the backup, which can cost far more if it's resistance strips. Use EM HEAT only when the heat pump fails, then call a technician. For outage heat, an EcoFlow TITAN 5000 with a Smart Home Panel 10, installed by a licensed electrician, can back up an evaluated heat pump circuit for a limited time.
What is the difference between EM heat and heat?
The emergency heat vs heat difference is about which equipment does the work. HEAT uses the heat pump, with backup stepping in only when needed. EM HEAT shuts the heat pump off completely, so all your warmth comes from the backup system.
Is AUX heat the same as EM heat?
No, though they often use the same backup equipment. AUX is called automatically. Depending on the equipment, backup heat either runs alongside the heat pump or takes over from it. EM HEAT is a setting you choose manually, and it keeps the heat pump off until you switch back.
When should I use emergency heat?
Switch to it when the heat pump is damaged, iced over and not clearing, or no longer producing warm air. After that, schedule a visit from an HVAC technician, and return to HEAT once the system is repaired.
Does emergency heat cost more?
It usually does when the backup is electric resistance strips, since they use far more electricity for the same heat. With a gas furnace as backup, the cost shifts to your gas bill, and the electrical load stays fairly small.
Should I switch to EM heat when it's very cold?
Not normally. A working heat pump calls for AUX on its own when it needs help, so you don't have to do anything. Save EM HEAT for times when the heat pump itself has a problem.
Home Solutions
