How Many Watts Does An Electric Furnace Use?
- How to Calculate Your Furnace's Energy Usage
- How Many Watts Does an Electric Furnace Use?
- What Factors Affect How Much Power My Electric Furnace Uses?
- How Much Does It Cost to Run an Electric Furnace?
- Should I Get a Gas or Electric Furnace?
- Manage Your Electric Furnace's Power Usage for Comfort and Savings
- FAQ About Electric Furnace Power Consumption
Got an electric furnace? Unlike gas systems, these simple heaters convert electricity straight to heat through heating elements, then blow that warmth throughout your home. Why care about your furnace's wattage? Simple—it's likely your home's biggest power drain in winter, hitting your wallet hardest when temperatures drop. Knowing exactly how much power your electric furnace draws helps you make sense of steep winter bills, prepare backup power options, and prevent electrical overloads in your home.
To determine how many watts your electric furnace uses, you can apply a simple formula:
Watts = Volts × Amps
For example, if you have a 60-amp electric furnace operating on a standard 240-volt circuit:
240 volts × 60 amps = 14,400 watts (or 14.4 kW)
To calculate daily consumption, multiply the wattage by the number of hours the furnace runs:
Daily: 14.4 kW × 8 hours = 115.2 kWh
Weekly: 115.2 kWh × 7 days = 806.4 kWh
Monthly: 115.2 kWh × 30 days = 3,456 kWh
Note: These numbers show worst-case scenarios. Your furnace won't actually use this much power all the time since it cycles on and off throughout the day.
After calculating your furnace's wattage using the volts × amps formula, you'll want to know what these numbers mean for real homes. Electric furnaces come in different sizes to match various heating needs, with each wattage level suited for specific house sizes and climates.
What Power Ranges Do Electric Furnaces Come In?
Electric furnaces come in a wide range of power ratings to accommodate different home sizes and heating needs. Most residential electric furnaces fall between 10,000 and 50,000 watts (10-50 kW), with the specific wattage depending on factors like your home's square footage, local climate, and insulation quality.
For typical family homes, you'll most commonly find units in the 18,000-20,000 watt (18-20 kW) range. This middle-of-the-road option provides sufficient heating capacity for average-sized homes in moderate climates. If you live in an extremely cold region or have a larger home, you might need a more powerful unit.
What Size Electric Furnace Does Your Home Need?
Choosing an electric furnace that's properly sized for your home makes all the difference in both comfort and energy bills.
| Furnace Size | BTU Rating | Typical Wattage | Best For |
| Small | 30,000-40,000 | 10,000-15,000 W | Apartments, small homes (up to 1,200 sq ft) |
| Medium | 50,000-60,000 | 15,000-25,000 W | Average homes (1,200-2,000 sq ft) |
| Large | 70,000+ | 25,000-50,000 W | Larger homes (2,000+ sq ft) or cold climates |
Small homes under 1,200 square feet need just 10,000-15,000 watts (30,000-40,000 BTUs) for efficient heating, while average homes between 1,200-2,000 square feet require medium furnaces delivering 15,000-25,000 watts (50,000-60,000 BTUs). Larger homes over 2,000 square feet or houses in cold climates demand more powerful furnaces in the 25,000-50,000 watt range (70,000+ BTUs) to maintain comfortable temperatures throughout all living spaces.
Those wattage numbers on your furnace—whether 10,000 or 50,000—only tell part of the story. Your actual electricity use depends on how your specific home and habits interact with the heating system. Several simple factors determine whether your furnace runs at full power or sips electricity more conservatively throughout the day. Knowing what drives your real energy consumption puts you in control of your winter heating bills.Understanding these energy factors is crucial, as many homeowners are surprised by unexpectedly high electric bills that could be avoided with better awareness and simple changes to their home systems.
Home Size
The size of your home directly affects how powerful your furnace needs to be. Heating professionals typically recommend between 30-60 BTUs of heating capacity per square foot of living space.
For example, a well-insulated 2,000-square-foot home in a moderate climate might need about 60,000 BTUs (around 17.5 kW), while the same size home in a colder region could require up to 120,000 BTUs (about 35 kW). Getting the right size matters—too small and your home stays cold, too large and you waste energy.
Furnace Efficiency Rating
Electric furnaces are already quite efficient, converting nearly all electricity into heat. Most modern units achieve efficiency ratings between 95% and 100%.
This means almost every dollar you spend on electricity for your furnace turns directly into heat for your home. When shopping for a new system, look for high-efficiency models to maximize your heating dollars.
Thermostat Habits
How you set your thermostat dramatically affects power use. Each degree higher means more electricity consumed. Lowering your thermostat by just 1-2 degrees can cut energy use by 5-10%.
Smart thermostats can help by automatically adjusting temperatures based on your schedule—lowering heat when you're away or sleeping and raising it when you're home and active. These small adjustments add up to real savings over a heating season.
Home Insulation Quality
Even the best furnace wastes energy in an inadequately insulated home. Good insulation keeps warm air inside and cold air out. Attics, windows, doors, and exterior walls are usually weak areas.
Improving your insulation can reduce your heating needs by 20-30%. Simple fixes like weatherstripping around doors, caulking windows, and adding attic insulation often pay for themselves quickly through lower energy bills.
Furnace Age and Maintenance
Older furnaces use more electricity than newer models. Regular maintenance keeps your system running efficiently—dirty filters, clogged parts, and worn-out elements all force your furnace to burn more energy.
Simply replacing filters every 1-3 months (as recommended by manufacturers) can make a 5-15% efficiency improvement. Yearly professional maintenance inspections can catch issues before they lead to higher energy bills or costly repairs.
Local ClimateWhere you live significantly influences how many hours your furnace will run. Northern homes are in cold temperatures for 6-8 months, while homes in warmer southern climates get occasional heat use for 2-3 months.
The wider the temperature difference between inside and outside, the harder your furnace is working and the more electricity it will use. During extreme cold snaps, your system might be running almost continuously, significantly increasing your power consumption.
Those factors affecting your furnace's power consumption—home size, insulation quality, and thermostat settings—directly translate into dollars on your monthly bill. When winter arrives and your electric furnace kicks into regular operation, many homeowners notice their electricity costs climbing dramatically. This happens because these heating systems rank among your home's most power-hungry appliances, drawing thousands of watts whenever they run to maintain comfortable temperatures.
Break Down the Costs
The price tag for running your electric furnace depends mainly on three things: how powerful your furnace is, how long it runs each day, and what you pay for electricity in your area.
Let's look at a typical example using the national average electricity rate of about $0.15 per kilowatt-hour (kWh):
For a 10,000-watt (10 kW) electric furnace:
Running for 8 hours a day: $12 per day
Monthly cost (30 days): $360
Seasonal cost (4 months): $1,440
For a 20,000-watt (20 kW) electric furnace:
Running for 8 hours a day: $24 per day
Monthly cost (30 days): $720
Seasonal cost (4 months): $2,880
This explains why many homeowners experience "bill shock" during their first winter with an electric furnace. In colder regions where the furnace might run longer or more frequently, costs can climb even higher. For instance, if a 20 kW furnace needs to run for 12 hours a day in a particularly cold area, the monthly cost could reach $1,080, and the seasonal cost could soar to $4,320.
How This Compares to Other Heating Options
Electric furnaces typically cost more to operate than natural gas furnaces in most locations. While electric systems are nearly 100% efficient at converting electricity into heat, the fact that electricity tends to be higher priced than natural gas in most markets often makes gas heat the lower-cost solution in the end.This cost advantage represents just one aspect of natural gas as an energy choice, and weighing all its benefits and drawbacks is essential for consumers and policymakers alike.
The majority of homeowners with gas furnaces report winter heating costs of $150-300 per month, significantly less than comparable electric systems. However, the real difference is very wide based on local utility rates and climatic factors.
Control Your Costs
While electric furnaces are expensive to operate, you can take steps to manage these costs:
Invest in a programmable thermostat to reduce heating when you're away or sleeping
Improve insulation to keep the heat you're paying for inside your home
Consider supplemental heating options like heat pumps, which can be more efficient in milder conditions
Explore time-of-use electricity plans that might offer lower rates during certain hours
Those high operating costs of electric furnaces naturally lead many homeowners to explore alternatives. Gas furnaces present a different financial equation—typically costing more upfront but running more economically each month in most regions. This trade-off between installation expenses and monthly bills represents just one of several key differences between these heating systems. Your home's existing infrastructure, local energy rates, and personal preferences all play important roles in determining which option makes the most sense for your situation.
When an Electric Furnace Makes Sense
Electric furnaces offer several compelling advantages for homeowners:
Lower initial investment: You'll typically save $1,000-$2,500 on purchase and installation compared to gas systems since electric models don't require venting, gas lines, or complex safety components.
Safety benefits: Without combustion, electric furnaces eliminate worries about gas leaks, carbon monoxide, or explosion risks—a significant consideration for many families.
Extended lifespan: Electric furnaces generally last 20-30 years with proper care, often outlasting gas models by 5-10 years thanks to their simpler mechanical design and fewer moving parts.
Complete energy conversion: Electric systems convert virtually 100% of electricity directly into heat, achieving nearly perfect efficiency at the unit itself.
Flexible placement: Without needing gas connections, electric furnaces can be installed almost anywhere, making them ideal for homes without natural gas service or in areas where running gas lines would be prohibitively expensive.
When Gas Furnaces Have the Edge
Gas furnaces deliver important benefits that make them the preferred choice for many homeowners:
Lower operating costs: Despite higher upfront prices, gas furnaces typically cost 30-50% less to run monthly compared to electric models—savings that often recover the initial investment difference within a few years.
Better cold-weather performance: Gas systems produce more heat more quickly, making them better suited for regions with harsh winters or extreme temperature drops.
Potentially smaller carbon footprint: In areas where electricity comes primarily from coal power plants, efficient gas furnaces might actually produce fewer emissions than electric alternatives.
Faster home warming: Gas furnaces heat homes more rapidly than electric models, providing quicker comfort when temperatures suddenly drop—a noticeable difference during the coldest days.
Electric systems shine with their safety, simplicity, and lower installation costs—ideal for milder climates or homes without gas access. Gas furnaces excel with their superior heating performance and lower monthly operating costs, making them better suited for colder regions where their efficiency quickly offsets the higher upfront investment.
Your electricity furnace's power usage affects your monthly bill. Home size, furnace efficiency, thermostat settings, insulation quality, routine tune-ups, and your local climate all contribute to how much power your system draws in watts. Lower heating bills? Start with the simple steps - check out your furnace's power rating, plug the leaky spots, install a programmable thermostat, or schedule a professional tune-up. Even dropping the thermostat a single degree will make a significant difference in energy savings and keeping your home warm. If you're worried about losing heat during winter blackouts or want to save on your power bills, the EcoFlow Smart Home Panel 2 can help. This smart device connects to your heating system to keep it running when the power goes out and can also save you money by using electricity when rates are lowest. Smart management of your electric furnace today means lower bills tomorrow and a more comfortable home all winter long—the kind of simple change that keeps giving back season after season.
Q1: How long does an electric furnace last?
An electric furnace will last 20-30 years under proper maintenance, 5-10 years longer than an average gas furnace, as they possess fewer movable parts and less complex design.
Q2: How Much Does it Cost to Replace an Electric Furnace?
The replacement will cost between $2,000 and $7,000 along with installation. The price would be based on the unit's size, the efficiency rating, and whether there are any required electrical upgrades or not.
Q3: How long does it take an electric furnace to heat up?
Electric furnaces typically begin producing heat 1-3 minutes after they're lit, but 15-20 minutes can elapse before it's up to full power and heating the whole house.
Q4: How big of a furnace do I need for a 2000 sq ft house?
A 2,000 sq ft house will typically require an 18-25 kW furnace (60,000-85,000 BTUs) capacity, based on climate, insulation level, and ceiling height.
Q5: How much does it cost to run a 1500-watt heater for 30 days?
A 1,500-watt heater running 24 hours a day for 30 days would consume 1,080 kWh (1.5 kW × 24 hours × 30 days). At $0.15 per kWh, this would cost approximately $162 per month.
Q6: What size breaker does an electric furnace take?
Electric furnaces typically require 60-100 amp dedicated circuit breakers, depending on their wattage. A 20 kW furnace usually needs a 100-amp breaker on a 240-volt circuit.
Q7: Is it hard to switch from a gas furnace to an electric furnace?
Yes, switching from a gas furnace to an electric furnace can be difficult. Your home will need major electrical upgrades that most houses aren't set up for. You'll need to hire professionals to install new wiring, add circuit breakers, and possibly upgrade your electrical panel. This isn't something you can do yourself - it requires licensed electricians and HVAC technicians.
Q8: How can I keep my electric furnace running during power outages?
Power outages can leave you without heat when you need it most. The EcoFlow Smart Control Kit offers a simple solution for this problem. Unlike traditional generators that require professional installation, this whole-home backup system connects to your breaker panel through a power inlet box or transfer switch with a plug-and-play design. It can deliver up to 7200W and 240V output when paired with two DELTA Pro units, enough to power high-wattage appliances like your electric furnace. This provides a clean, quiet alternative to gas generators for maintaining essential heating during blackouts.
