High Humidity in House: How to Find the Cause and Bring It Down
Foggy windows, musty closets, and sticky air are common signs of high indoor humidity. EPA recommends keeping indoor humidity below 60%, ideally between 30% and 50%. A dehumidifier does not fix a leak or a vented dryer exhausting into a garage. This guide shows how to measure humidity, find moisture sources, improve ventilation, size a dehumidifier, and plan safe backup power.
What Causes High Humidity in House Air?
Moisture comes from people, appliances, and the building itself. Cooking, showers, and drying clothes add water to the air. Leaks, wet basements, and poor venting let it build up.
Where the Moisture Comes From
The table pairs each common source with the first fix to try.
Source
Fix first
Showers and cooking
Run exhaust fans vented outdoors
Vented clothes dryer
Exhaust directly outdoors as the manufacturer directs
Wet basement
Grading, gutters, sump pump
Leaks
Repair pipes and roof
Most of these fixes are simple. A wet basement is the exception, because grading and drainage work often takes planning and a contractor.
What EPA Says About Moisture
  • Humidity near 60% is a problem on its own: EPA lists high humidity, at 60% relative humidity, among the common moisture problems in buildings.
  • Venting matters: A vented clothes dryer must exhaust outdoors according to its installation instructions. A garage is an indoor space. Ventless heat pump dryers collect moisture in a closed loop and do not need an outdoor exhaust duct.
  • Moisture control is mold control: In EPA's words, "controlling indoor moisture will control the growth of indoor mold." Removing every spore is virtually impossible, so water is the target.
Telltale Signs Around the Home
  • Condensation on windows: Fog or droplets on glass, walls, or pipes often point to damp air meeting a cool surface.
  • Musty odor: A stale smell in closets, basements, or laundry rooms suggests moisture is lingering.
  • Peeling paint and warped trim: Water vapor can lift paint and swell wood over time.
  • Sticky air: A clammy feel, even with the AC running, hints that the air holds more moisture than cooling can remove.
Measure Before Fixing
Guessing wastes time, so a reading comes first. A hygrometer is a cheap start, and fuller indoor air quality monitoring tracks CO and CO2 too. Basements and bathrooms often read higher than bedrooms, so it helps to check a few rooms.
Log readings over several days. A spike after showers is a reason to check bathroom exhaust. If readings stay high, investigate ongoing moisture sources, inadequate exhaust or dehumidification, plumbing leaks, and water intrusion. Humidity readings can show a pattern, but identifying the source takes inspection.
With the source handled, a dehumidifier can hold the level steady. That only helps while it has power, and storms have a way of taking it.
Keeping a Dehumidifier Running During Outages
Basement humidity can climb fast when storms knock out power. A dehumidifier is a steady, moderate load that cycles on and off. Backup size depends on its watts and how often it runs.
Start With the Source
The first job is still finding moisture sources and ventilation problems. Backup power keeps a dehumidifier running, but it does not remove the reason for the dampness. A leaking pipe or a blocked dryer vent will keep adding water either way.
Check Watts and Startup First
Every appliance has its own power needs. A few checks make the sizing math more honest.
  • Electrical ratings: Check the label and manual for voltage, rated input, and circuit requirements. Some labels list current rather than watts. When estimating runtime, use measured energy over a representative period.
  • Startup surge: Compressors can draw extra power for a moment when they start. A station's surge rating needs to cover it.
  • Duty cycle: Compressor-on time affects energy use. Include power used by any fan or controls between compressor cycles.
  • Target range: The humidistat should aim to hold levels below 60%, ideally in the 30% to 50% band EPA describes.
Matching a Power Station to the Job
EcoFlow portable power stations can operate indoors where the unit, outlets, and connections stay dry and cannot be reached by floodwater. Never operate or plug in equipment while standing in water. Have a qualified professional check equipment and circuits that got wet before using them. Include the dehumidifier and other loads you need at the same time when sizing backup.
One compatible 120V dehumidifier is the simplest case. The EcoFlow DELTA 3 Max stores 2,048Wh, which can cover many cycles because the compressor does not run all the time.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
Some outages run longer. Some basements also add a condensate pump to the dehumidifier. For those setups, the EcoFlow DELTA 3000 Gen4 adds 3,072Wh of capacity and a higher surge rating.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The EcoFlow US page listed Gen4 as shipping in early January 2027 when checked in mid-November 2026. Delivery timing can differ by address, so it is worth confirming before planning around it. It suits advance planning, not an outage or storm already underway.
How the Products Divide the Job
  • EcoFlow DELTA 3 Max: It fits one dehumidifier through shorter outages. Runtime stretches when the compressor cycles off often.
  • EcoFlow DELTA 3000 Gen4: It fits longer outages, or a dehumidifier running alongside a condensate pump. The extra capacity gives more room for both loads.
Runtime Estimates
The table gives example runtimes. The actual result depends on average measured power, startup demand, room conditions, and how the appliance cycles.
Load (example)
Watts used
EcoFlow DELTA 3 Max (1,741Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
Example: 300 W with the compressor on at 50% duty, excluding off-cycle draw
about 150W
about 12 hours
about 17 hours
Dehumidifier + condensate pump (example average)
about 190W
about 9.2 hours
about 14 hours
  • Method: For the first illustrative row, 300 W × 50% gives 150 W before off-cycle use. The 190 W in the second row is an assumed combined average.
  • Usable capacity: The estimates assume roughly 85% of rated capacity is usable after conversion losses.
  • Real numbers: Use a properly rated meter to record watt-hours over a representative period. Divide those watt-hours by the elapsed hours to get average watts, including any fan or control power between cycles. Ask a qualified professional to measure hardwired loads.
In a wet basement, sump pump battery backup matters as much as the dehumidifier.
Backup power only helps if the unit fits the space. Next comes sizing the dehumidifier itself.
How to Lower Humidity in Your House
Fix the source, then ventilate, then dehumidify. Air conditioning removes some moisture in summer. A dehumidifier handles basements and the shoulder seasons, when the AC runs less.
Dehumidifier running in damp basementDehumidifier running in damp basement
A Simple Order of Attack
  1. Fix the source: Repair leaks, clear gutters, and point downspouts away from the foundation. Dry any wet materials quickly.
  2. Ventilate: Run bathroom and kitchen fans during use and for a while after. Make sure they exhaust outdoors, not into an attic.
  3. Use the AC in summer: Cooling coils pull water from the air as a side effect. A unit that cycles properly does this better than one that short-cycles.
  4. Add a dehumidifier: Place it where moisture lingers, such as a basement or laundry room.
Ventilation in Tight Homes
Newer, well-sealed houses trap moisture more easily. Fresh air has fewer ways in, so exhaust fans and balanced ventilation matter more. Ventilation is one of the must-haves for an energy-efficient home that stays dry.
The Right Target
The ideal indoor humidity range is 30% to 50%. EPA sets the upper limit below 60%, if possible. Going much lower than 30% can leave the air uncomfortably dry, so more dehumidifying is not always better.
Sizing by Pints per Day
Dehumidifier size is usually measured in pints per 24 hours, according to ENERGY STAR. Its chart pairs capacity with room size and dampness. These ranges apply to rooms under 2,000 square feet.
  • Mildly to moderately damp: A musty smell shows up in humid weather. A unit rated for 20 to 30 pints per day fits.
  • Very damp: The space feels damp most of the time, with visible damp spots. A unit rated for 25 to 40 pints per day fits.
  • Wet: Walls or floors sweat, or water seeps in. A unit rated for 30 to 50 pints per day fits.
Rooms over 2,000 square feet step up to roughly 30+, 40+, and 50+ pints per day for the same three conditions. Check ENERGY STAR's chart for the full detail.
Running It Well
  • Handle the water: Empty the bucket often, or attach a drain hose or condensate pump. ENERGY STAR advises keeping hoses away from electrical cords and connections.
  • Close the space: Doors and windows to the room should stay shut while the unit runs. Otherwise it keeps pulling in outside air.
Finally, some problems are bigger than a dehumidifier can handle.
When to Call a Professional About Humidity
Call for help if humidity stays high after the fixes above. Visible mold over a large area, water stains, or rot need a pro. An energy audit can find air leaks and venting problems.
Inspector checking wall for moisture damageInspector checking wall for moisture damage
Signs the Job Is Too Big
  • Large mold growth: EPA says a moldy area under about 10 square feet can usually be handled by the homeowner. Growth beyond that, or heavy water damage, calls for professional help.
  • Water stains or rot: Dark stains, soft wood, or sagging drywall point to a leak that has been active for a while.
  • Suspected HVAC contamination: EPA advises against running the HVAC system if mold in it is known or suspected.
Who Can Help
  • HVAC technician: A technician can check AC sizing and run time. An oversized unit may cool the house quickly but remove little moisture.
  • Energy auditor: A home energy audit can find air leaks that pull in damp air.
  • Health professional: Anyone with health concerns should talk to one before starting mold cleanup.
Showers, cooking, vented dryers, leaks, and damp basements can all raise indoor humidity. EPA recommends staying below 60%, ideally between 30% and 50%. Find the moisture source, exhaust vented appliances outdoors, and size the dehumidifier in pints per day. For backup, evaluate an EcoFlow DELTA 3 Max or EcoFlow DELTA 3000 Gen4 using the measured average load and compressor startup demand. Use the station and connections in a dry, flood-safe location.
What humidity is too high in a house?
EPA recommends keeping indoor humidity below 60%, ideally between 30% and 50%. Readings above 60% raise the odds of mold, condensation, and musty smells. A hygrometer in the basement and main living areas shows where levels run highest.
What causes high humidity in a house?
Cooking, showers, clothes drying, and leaks all add moisture to indoor air. Damp basements and poor ventilation let it build up. Vented dryers should exhaust outdoors. Ventless heat pump dryers handle moisture without an outdoor exhaust duct. Run exhaust fans during and after showers and cooking.
How do I lower humidity fast?
Run exhaust fans vented outdoors, use the AC or a dehumidifier, and keep windows closed in humid weather. Fix leaks and dry wet materials right away. A dehumidifier works best in a closed room with doors and windows shut.
What size dehumidifier do I need?
Use ENERGY STAR's pints-per-day chart, which matches capacity to room size and dampness. A room under 2,000 square feet that is very damp calls for roughly 25 to 40 pints per day. Wet spaces and rooms over 2,000 square feet need more.
Can high humidity cause mold?
Yes. Sustained moisture can support mold growth on wood, paper, carpet, and other organic materials. EPA says controlling indoor moisture will control mold growth, so keeping humidity below 60% and fixing leaks quickly matter most.
Home Solutions
