Wood Heater Installation Cost: Stove, Chimney, Labor, and Permits Explained
Wood heater installation cost is rarely just the price of the stove. The chimney or flue, floor protection, wall clearances, labor, and local permits can add substantially to the final bill. Before buying a heater, it's worth getting a clear picture of each expense. This guide breaks down the main installation costs, explains what to check before work begins, and covers the federal tax credit change for 2026. It also looks at backup power for wood stoves with electric blowers, including a practical option for keeping one running during an outage.
What Goes Into Wood Heater Installation Cost?
The total cost depends on five main items: the heater, chimney or flue, clearance work, installation labor, and permits. The venting system can make a big difference, especially if your home needs a new chimney rather than a liner for an existing masonry one. The EPA's February 2023 Burn Wise guide listed wood stove prices of $1,000 to $4,000 before installation. Use that historical range for appliance context. For a current project total, ask an installer to price the stove, venting, site work, labor, and permits separately.
What Goes Into Wood Heater Installation Cost?What Goes Into Wood Heater Installation Cost?
Wood heater installation cost breakdown
Line item
What drives the price
How to price it
Heater
Freestanding stove vs insert; EPA certification
Dealer quote
Chimney or flue
New class-rated chimney vs liner in existing masonry
Installer quote
Clearances and hearth
Floor protection, wall shields per the stove manual
Installer quote
Labor
Roof or wall penetration, height, access
Installer quote
Permit and inspection
Local building department
Your city or county
A new chimney can change the budget considerably. If your home already has a suitable masonry chimney, an installer may be able to use a liner instead. But don't assume an existing chimney is ready for a wood stove. It needs to be inspected and matched to the appliance. Ask for two or three itemized quotes before choosing an installer. Each quote should separate the stove, venting, materials, labor, and permit costs. That makes it easier to spot missing work and compare proposals. A wood heater is one of several ways to cut winter heating costs, but the upfront installation expense belongs in your budget too.
Does a Wood Heater Need Power During an Outage?
Most traditional wood stoves keep producing heat without electricity because the fire doesn't depend on the grid. However, models with electric blowers need power to circulate warm air. During an outage, the blower stops, but the fire keeps burning. Check the blower's wattage and operating requirements before choosing a backup power source, and estimate how long you need it to run.
What should you check before buying backup power?
Start with these details:
  • Blower wattage: Check the manufacturer's label rather than relying on a general estimate.
  • Run time: Decide how many hours you want the blower to operate during an outage.
  • Other small devices: Account for any lights or phone chargers you also plan to power.
  • Placement: Keep the power station outside the stove's high-heat zone and follow its operating and ventilation instructions.
A stove without electric accessories does not need a power station to produce heat. Pellet stoves vary by design. Models with powered augers, fans, igniters, or controls need electricity for those parts. Other models, such as the US Stove GW1949, use gravity feed and can operate without electricity. If you need to keep a powered pellet stove running during an outage, check the specific model's starting and running loads and follow its manual.
A portable option for a wood stove blower
If your wood stove has a plug-in blower, the EcoFlow DELTA 3 Classic can provide backup power for that accessory and a few small devices. It has a 1,024Wh LFP battery and 1,800W of pure sine wave AC output. The purpose here is specific: keep an approved blower running when the grid goes down. It doesn't power the wood stove itself or replace the heat produced by the fire.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For a rough runtime estimate, use the battery's usable capacity and the actual wattage of the blower. The examples below use an estimated 870Wh of usable energy, based on 85% of the rated capacity. They're illustrations, not guaranteed runtimes.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Example: plug-in stove blower
about 60W
about 14 hours
Example: blower, LED lamp, and phone charging
about 90W
about 9.7 hours
Replace the example wattages with the figures on your equipment labels before making a purchase decision. Actual runtime also varies with battery conditions, temperature, and power conversion losses. Place the EcoFlow DELTA 3 Classic well away from the stove and other hot surfaces. Follow the product manual for safe operation, and make sure the blower manufacturer permits the type of power source you're using.
Clearances, Chimneys, and Permits
The stove manual tells you how much space the appliance needs around walls and other combustible materials. Local building codes determine which permits and inspections apply. A qualified installer should account for both before work begins.
Follow the stove's clearance requirements
Every stove has its own installation requirements. The distance from walls, furniture, floors, and other combustible materials depends on the appliance's listing and installation instructions. Some setups may allow approved wall shields or floor protection, but you shouldn't assume those changes apply to every model. The U.S. Fire Administration recommends keeping anything that can burn at least three feet from heat sources. Follow your stove's specific clearance instructions as well, since its requirements may call for more space.
Have the chimney inspected and cleaned
Creosote buildup can cause chimney fires. The EPA recommends annual cleaning by a certified chimney sweep. Before installation, have a qualified installer check the flue, liner, and masonry for damage and confirm they're suitable for your stove. A faulty flue can also allow carbon monoxide into your home. Read about carbon monoxide risks in winter and install working smoke and CO alarms.
Check local permits before installation
Permit requirements vary by location. Contact your local building department to check which permits and inspections you need. Hire an installer familiar with local codes, and keep your permit records, inspection results, and installation paperwork for future reference.
Are there tax credits for wood heater installation in 2026?
The federal Energy Efficient Home Improvement Credit (25C) no longer applies to qualifying property placed in service after December 31, 2025. If you installed a biomass stove in 2025, consult the IRS instructions for Form 5695 for the placed-in-service date and equipment eligibility. Certain state and local incentives may still be available.
Are there tax credits for wood heater installation in 2026?Are there tax credits for wood heater installation in 2026?
Check for state and local incentives
The end of the federal credit doesn't necessarily mean every incentive has disappeared. Some states and local agencies may offer wood stove changeout programs or other support for replacing older heating equipment. Check with your state energy office or local air quality agency for current programs. Eligibility can depend on where you live, the stove you replace, the model you install, and the program's funding. Confirm the rules before buying equipment or scheduling installation.
Wood heater installation cost depends on more than the stove. Budget for the chimney or flue, floor and wall protection, labor, and local permits before committing to a model. Get itemized quotes, hire a qualified installer, and schedule annual chimney cleaning to keep the system in good condition. The federal 25C credit also ended for property placed in service after December 31, 2025, so check for any state or local incentives instead. If your stove has a plug-in blower, the EcoFlow DELTA 3 Classic can provide backup power for that accessory during an outage.
How much does it cost to install a wood heater?
The price depends on the stove, chimney or flue, clearance work, labor, and permits. The EPA's February 2023 Burn Wise guide listed $1,000 to $4,000 for a wood stove before installation. Get current itemized quotes for the full project.
Is a chimney the most expensive part of wood stove installation?
It can be one of the biggest expenses, particularly if your home needs a new chimney or extensive roof work. An existing masonry chimney may need a suitable liner instead. Have a qualified installer inspect it before estimating the work.
Do I need a permit to install a wood stove?
Permit requirements vary by location. Contact your city or county building department to find out which permits and inspections apply. Your installer should also be familiar with local building codes.
Is there a tax credit for wood stoves in 2026?
The federal 25C tax credit ended for property placed in service after December 31, 2025. See the IRS Form 5695 instructions for 2025 eligibility. Check your state energy office or local air quality agency for current local incentives.
Does a wood stove work during a power outage?
Most traditional wood stoves can continue producing heat without electricity. However, an electric blower won't run when the power goes out unless you connect it to a suitable backup power source. Check the blower's wattage and operating requirements before choosing one.
Home Solutions
