Boiler vs Water Heater: What Each One Does and How Combination Systems Work
A boiler and a water heater both heat water, so it's easy to confuse them. The difference comes down to what they heat. A boiler warms your home either by circulating heated water through radiators, baseboards, or radiant floor loops, or by sending steam through piping to radiators. A water heater supplies hot water to your faucets, shower, and appliances. Some homes use a combination system that handles both jobs. This guide explains how these systems work, what they need during a power outage, and what to consider when choosing or replacing one.
Boiler vs Water Heater: What's the Difference?
Boiler vs Water Heater: What's the Difference?Boiler vs Water Heater: What's the Difference?
A boiler heats your home, while a water heater supplies hot water for everyday use. They can work together, too. Some systems use a boiler to heat water in a separate storage tank. The main difference is how each appliance uses the heated water. Residential heating boilers come in both hot water and steam designs (as outlined in the ENERGY STAR Boilers Specification and manufacturer manuals such as the Weil-McLain EG Series Boiler Manual): a hot water boiler circulates heated water or another fluid through a closed heating loop, while a steam boiler sends steam through piping to radiators (typically returning condensate by gravity). By contrast, a water heater supplies potable water to fixtures such as kitchen sinks, bathroom faucets, and showers.
Feature
Boiler
Water heater
Combination system
Main job
Space heat (radiators, baseboards, radiant floors)
Hot water at taps
Both
Water/steam loop
Closed hot water loop or steam piping (with gravity condensate return)
Potable water
Separate loops via heat exchanger
Energy source
Gas, oil, propane, electric
Gas or electricity, including electric heat pump models (per the ENERGY STAR Residential Water Heaters Specification)
Usually gas or oil boiler
The DOE explains that tankless coil and indirect water heaters use a home's space-heating system to heat household water. An indirect water heater circulates heated fluid from the boiler or furnace through a heat exchanger inside a storage tank, keeping the household water separate from the heating loop. If you're considering a standalone electric option, compare potential heat pump water heater savings with your current system. Even gas- and oil-fired systems may need electricity for controls, ignition, and circulator pumps. That matters when the power goes out.
What Needs Power When the Grid Goes Down?
A gas or oil boiler often still needs electricity for components such as controls, an ignition system, and, depending on the configuration, circulator pumps or draft fans. Many gas water heaters also rely on electrical components. The exact requirements depend on the boiler type (hot water vs. steam), the model, and how the equipment is wired. During an outage, the goal is to verify the specific circuits and starting loads that keep your heating system operating. A hot water boiler typically requires power for its controls and circulator pumps, a gravity-return steam boiler may only need power for controls and ignition (without circulator pumps), and an electric boiler or electric tankless water heater requires a much larger electrical supply.
Electrical components to check
Before planning backup power, check the equipment manual and nameplate. Ask an electrician to verify the voltage, running wattage, and startup loads for each circuit based on your exact configuration. The following components may need power:
  • Boiler controls: The control board and safety limits (such as low-water cutoffs on steam boilers) manage the heating cycle and safety functions.
  • Ignition system: Gas and oil boilers may use an electronic ignition system to start the burner, though some older standing-pilot models operate without household electricity for ignition.
  • Circulator pumps or fans: Hot water boilers use circulator pumps to move heated water through radiators, baseboards, or floor loops, whereas gravity-return steam boilers do not use circulators (though some boilers use draft or power-vent fans).
  • Water heater controls: Some gas water heaters use electronic ignition and controls.
  • Electric heating elements: Electric boilers and electric water heaters draw power for their heating elements, so their loads need a separate assessment.
Using EcoFlow TITAN 5000 for boiler circuits
For a boiler system, backup power may need to support the controls, ignition, and circulator pumps. EcoFlow TITAN 5000 has a 5kWh base capacity and 7,200W of 120V/240V split-phase output. Through the Smart Home Panel 10 (SHP10), installed by a qualified, licensed electrician, it can back up selected circuits. The electrician must check the equipment loads and confirm which circuits are suitable.
EcoFlow TITAN 5000
Estimate how long backup power may last
The runtime depends on the total load connected to the battery. Boiler controls and circulator pumps often draw less power than electric heating elements, but the actual figures vary by equipment. The following examples assume a constant average load and use an estimated 4,265Wh of usable capacity calculated as an example from the EcoFlow TITAN 5000's 5,017.6Wh nominal capacity at an assumed 85% usable ratio to account for conversion losses, rather than a measured specification.
Load (example)
Watts used
EcoFlow TITAN 5000 (4,265Wh usable est.)
Boiler controls + one circulator (placeholder)
about 150W
about 28 hours
Boiler + two circulators + gas water heater controls (placeholder)
about 250W
about 17 hours
These are calculation examples, not guaranteed runtimes. Each figure divides the assumed usable capacity by the constant placeholder load: 4,265Wh ÷ watts used. Replace the placeholder wattages with the running and startup figures from your equipment labels. Actual runtime will vary as pumps or fans cycle on and off and as other backed-up circuits draw power. Electric boilers and electric tankless water heaters need a separate assessment, as their heating elements draw far more power than boiler controls or circulator pumps. Don't assume the system can support them without checking the full electrical load.
Choosing a Combination Water and Space Heating System
A combination system can supply heat to your home and hot water to your faucets using connected equipment. It can save space and may reduce installation and maintenance costs compared with separate appliances. The initial cost, however, is often higher.
Tankless coil, indirect tank, and all-in-one combi boiler options
A combination system can supply heat to your home and hot water to your faucets using connected or integrated equipment. Depending on the setup, there are three common configurations:
  • Tankless coil: A tankless coil system heats domestic water as it passes through a coil inside the boiler without a separate storage tank. Because the boiler heats the water on demand, output may be limited during high household hot water demand.
  • Indirect water heater: An indirect water heater pairs a boiler with a separate storage tank containing an internal heat exchanger. The boiler circulates heated fluid through the exchanger to warm the stored water while keeping potable household water separate from the heating loop.
  • All-in-one combi boiler: An integrated combination ("combi") boiler such as models in the Navien NCB-H Series combines space heating and on-demand domestic hot water in a single wall-hung or compact unit. Rather than using a storage tank, it heats domestic hot water instantaneously through a dedicated plate heat exchanger, keeping the closed space-heating circuit and potable domestic water separate (as categorized in U.S. Department of Energy appliance classifications such as the DOE Commercial Water Heaters Final Rule).
The right option depends on your home's hot water demand, boiler capacity, available space, and existing plumbing. Combination systems can save space and may reduce installation and maintenance costs compared with separate appliances, though upfront equipment costs are often higher. Sizing also involves calculations that differ from standalone appliances, so have a qualified plumbing and heating contractor assess your system before choosing one.
Check your home's heating setup
Your existing distribution system can affect the choice. Homes with radiators or baseboard heaters may already have a hydronic boiler loop. Homes with hydronic radiant floors also circulate heated water through tubing, so the boiler's capacity, zone controls, and circulator pump requirements matter if you're planning backup power for a hydronic floor system. Check the equipment manuals and nameplates for your boiler, controls, and pumps. By contrast, electric radiant floor systems use electric heating cables (such as Schluter-DITRA-HEAT-E-HK) rather than a boiler loop; if your home uses an electric cable system, read about radiant floor heating electricity use to estimate its heating load.
Cutting Hot Water and Heating Costs
Your boiler and water heater use energy in different ways. Check each system separately to find potential savings. Look at the boiler's efficiency rating and your water heater's energy rating. Insulation and thermostat settings also matter. Local gas and electricity prices can affect your monthly costs.
Cutting Hot Water and Heating CostsCutting Hot Water and Heating Costs
Compare efficiency ratings
Boilers are often rated with an Annual Fuel Utilization Efficiency (AFUE), which measures how efficiently a boiler converts fuel to heat over a typical heating season. Check the rating for the particular model rather than relying on an estimate. The rating for water heaters depends on the type of equipment, with the Uniform Energy Factor (UEF) serving as the standard way to compare water heater efficiency. For example, ENERGY STAR certification for U.S. residential gas instantaneous (tankless) water heaters requires a minimum UEF of 0.95 (subject to the applicable flow rate test conditions in Table 3 of the ENERGY STAR Residential Water Heaters Version 5.0 Specification). Always check the current certification criteria and product listing when comparing models.
Reduce heat loss and hot water use
A few practical changes can help lower energy use:
  • Insulate accessible hot water pipes: This can reduce heat loss as water travels from the heater to your fixtures.
  • Fix dripping hot-water faucets: A leak can waste both water and the energy used to heat it.
  • Review thermostat settings: Use settings recommended by your boiler manufacturer and HVAC contractor.
  • Choose efficient fixtures: Low-flow showerheads and faucets can reduce hot water demand.
  • Maintain the equipment: Follow the manufacturer's service schedule for the boiler, pumps, and water heater.
Your utility rate also matters. If your electricity plan has time-based pricing, a compatible storage system may help shift some electricity use away from more expensive periods. Read about hot water costs and energy storage before estimating potential savings. The result depends on your equipment, electricity rates, and how your home uses hot water.
The difference between a boiler and a water heater is what each appliance does. A boiler heats rooms by circulating hot water through a closed hydronic loop or sending steam through piping to radiators. A water heater heats potable water for household fixtures. Combination systems can use a tankless coil, an indirect water heater, or an integrated combi boiler with a separate heat exchanger for on-demand domestic hot water. Before replacing equipment, confirm whether you have a hot water or steam system and check its efficiency, capacity, and installation needs. A qualified contractor can size a combination system, and an electrician can verify the circuits and starting loads for your boiler's controls, ignition, and any pumps or fans to confirm backup power compatibility. EcoFlow TITAN 5000 can support selected circuits through a professionally installed SHP10, subject to the equipment's electrical requirements.
What is the difference between a boiler and a water heater?
A boiler heats your home either by circulating hot water through radiators, baseboards, or radiant floor loops, or by sending steam through piping to radiators. A water heater supplies hot water to faucets, showers, and appliances. Some combination systems use a boiler to heat domestic water, too.
Can a boiler heat water for showers?
Yes. A boiler can provide domestic hot water through a tankless coil, an external indirect water heater tank, or an all-in-one combi boiler with a built-in instantaneous plate heat exchanger (such as the Navien NCB-H Series). In both indirect tanks and plate-exchanger combi boilers, heat transfers to your domestic water while keeping potable water separate from the closed space-heating loop.
Does a gas boiler need electricity?
Most modern gas boilers need electricity to power controls, electronic ignition, and, depending on whether the unit is a hot water or steam model, circulator pumps or draft fans. Some older standing-pilot steam boilers require minimal or no household electricity. Check your equipment manual and wiring to verify the exact circuits and starting loads before planning backup power.
Is a combi boiler better?
A combi boiler is one system that can heat your home and provide domestic hot water, saving you space. It can also cost more up front than separate equipment. A qualified contractor should assess your home's heating and hot water demand before recommending one.
How long does a boiler last?
The longevity of boilers depends on the type of boiler, installation, maintenance, and operating conditions. Consult the manufacturer's maintenance schedule. Have the HVAC or heating professional check the condition if repairs are frequent or performance changes.
Home Solutions
