CCA to Amp Hours: How to Convert Battery Ratings
You're standing in the battery aisle, and two labels stare back at you. One says 650 CCA. The other says 100Ah. They look like they measure the same thing, but they don't. Pick the wrong one and you get a battery that cranks your truck fine on a freezing morning, then dies after two hours of running a camp fridge. Here's what each rating actually means, how the CCA to amp hours math works, and why that answer is only ever a rough estimate.
What CCA and Amp Hours Actually Measure
Most battery labels lead to one big number, and shoppers assume bigger is better. Starting batteries and deep-cycle batteries are graded on two different tests, so that headline number means different things depending on which battery you're holding.
What Cold Cranking Amps Measure
Cold Cranking Amps (CCA) is a cold weather test, not a capacity rating. It measures the current a battery can deliver at 0°F for 30 seconds while staying above 1.2 volts per cell. On a 12-volt battery, that works out to 7.2 volts at the terminals.
The rating answers one narrow question. Can this battery turn over an engine on a freezing January morning?
Cold works against you twice here. The Department of Energy notes that battery performance drops in cold weather, and NHTSA adds that engines need more power to start when temperatures fall.
What Amp Hours Measure
Amp hours (Ah) measure staying power over a long, steady draw. The rating is normally calculated at a 20-hour discharge rate, so a 100Ah battery should supply 5 amps for 20 hours before it runs flat. That number says nothing about how hard the battery can push in a single burst. If the unit is new to you, what amp hours mean on a battery label breaks the rating down further.
Why Starting and Deep-Cycle Batteries Differ
The two ratings exist because the two batteries are built differently inside:
Starting batteries use many thin plates. The extra surface area delivers a big burst of current for a few seconds.
Deep-cycle batteries use fewer, thicker plates. They survive repeated deep discharges without breaking down as fast.
Each battery is rated around the job it was built for, which is why one label lists CCA and the other lists Ah.
With both ratings defined, converting between them comes down to one simple formula.
Converting CCA to Amp Hours
Say you're looking at a used battery, and the only number on the case is a CCA rating. You want a rough sense of how long it could run a tire inflator or a small cooler.
The Formula Most People Use
The common shortcut divides the CCA rating by 7.2:
Ah = CCA ÷ 7.2
The 7.2 comes from that same terminal voltage used in the cold cranking test. To convert CCA to amp hours on a 600 CCA battery, divide 600 by 7.2 and you land near 83Ah.
A Quick Reference Chart
Here is the CCA to amp hour conversion at four common ratings:
CCA Rating | Approximate Ah |
400 CCA | ~56 Ah |
600 CCA | ~83 Ah |
800 CCA | ~111 Ah |
1,000 CCA | ~139 Ah |
Treat every figure in that table as a ballpark number rather than a spec sheet number. The gap between the estimate and real capacity widens as a battery ages.
Running the Conversion in Reverse
Going from amp hours to CCA uses the same math flipped around:
CCA = Ah × 7.2
So to convert amp hours to CCA on a 100Ah battery, multiply by 7.2 for roughly 720 CCA. A battery voltage chart is worth keeping nearby, since voltage tells you the state of charge that both ratings assume.
That formula gets you close. It's also worth knowing that some equipment skips this guesswork entirely.
Skipping the Conversion With a Direct Capacity Rating
CCA and Ah both describe lead-acid battery behavior, and neither translates cleanly to modern gear. If you're sizing power for a camping trip, a job site, or a storm outage, an estimate built on an estimate is a shaky place to start.
A portable power station lists capacity directly in watt-hours (Wh), so there is nothing to convert. Divide the capacity by the wattage of whatever you're running, and you have your runtime.
Run a 60W fan from a 1,024Wh unit, and you get roughly 17 hours before efficiency losses. The Department of Energy describes storage capacity the same way, measured in kilowatt-hours rather than in amp hours.
A Mid-Size Option for Weekend Power
Most weekend power needs to sit well under 2kWh. If you mainly want to run a cooler, charge some tool batteries, and keep a few lights on without doing any conversion math, a mid-size unit covers it.
A Larger Option for Home Backup
Backing up a house is a different problem. If you need a refrigerator, a sump pump, and a furnace fan to keep running through a multi-day outage, you need both a bigger reserve and more output to draw from.
For anyone still working with traditional lead-acid ratings, it helps to know exactly why the conversion isn't perfect.
Why the Conversion Isn't Exact
Dividing by 7.2 feels precise because it produces a specific number. That precision is misleading. The two ratings describe different behaviors of the same battery, so no single multiplier links them reliably.
The Test Windows Don't Match
CCA is measured over 30 seconds. Ah is measured over 20 hours. One test is a sprint and the other is a long walk, and no formula turns a sprint time into a marathon time. A battery that dumps 650 amps for half a minute may still fade quickly under a steady 5-amp load.
Chemistry Changes the Relationship
Lead-acid capacity drops noticeably as you draw harder, an effect described by Peukert's law. Lithium holds its capacity far more steadily under the same increase in load. The 7.2 divisor came from lead-acid testing, so it loses accuracy as you move away from that chemistry. A guide to battery chemistry is a useful background here.
Temperature Hits CCA Much Harder
Cold affects both ratings, but not equally. That is why the cranking test is run at 0°F rather than at room temperature. A battery tested at 75°F would post a friendlier number that tells you nothing about January.
Looking up cold cranking amps to amps turns up calculators, but there is nothing real to convert. CCA is already a current rating, and it's already stated in amps.
Even with all that imprecision, each rating still has a clear job where it matters most.
When Each Rating Actually Matters
Here's the practical version. Instead of asking which number is bigger, ask what the battery has to do for you.
When CCA Is the Number to Check
CCA matters most for starting batteries, especially in places with real winters like Minnesota or upstate New York. Check the rating on anything that has to fire up in the cold: a truck parked outside overnight, a boat or RV engine, a mower stored in an unheated barn, or any vehicle that has struggled to crank lately.
For more on how starting ratings are listed, car battery amp ratings explained covers what those labels mean in practice.
When Amp Hours Matter More
Amp hours matter for anything that runs for hours instead of seconds. That covers RV house batteries, trolling motors, and solar energy storage. A battery with high CCA and low Ah is built to start an engine. It is not built to run a fridge, a CPAP machine, or a string of work lights overnight.
Reading a Label Without Getting Fooled
Three habits will keep you out of trouble at the counter. Find out which test produced the headline number before you compare two batteries, and match the rating to the job rather than to the price tag.
The third habit is watching the units, since mAh and Ah differ by a factor of 1,000. The difference between mAh and Ah trips up plenty of shoppers.
Once you know which rating applies to your situation, the buying decision gets a lot simpler.
CCA measures short-burst starting power, and amp hours measure sustained capacity. The rough conversion between them (Ah = CCA ÷ 7.2) is useful for a quick estimate, but it is never exact. Use CCA to compare starting batteries and amp hours to compare deep-cycle batteries, instead of treating the two as interchangeable. If you'd rather skip math, the EcoFlow DELTA 3 Plus and DELTA Pro list capacity directly in watt-hours, which turns runtime into simple division. Match the rating to the job, and the right battery usually picks itself.
What is the formula to convert CCA to amp hours?
Divide the CCA rating by 7.2. A 600 CCA battery works out to roughly 83Ah. The 7.2 comes from the terminal voltage used in the cranking test. Treat the result as an estimate, since the two ratings measure different things.
Is a higher CCA rating always better?
Not always. Higher CCA helps in cold climates and does no harm in warm ones. But paying extra for CCA you don't need makes little sense when what you want is runtime. For a deep-cycle job, amp hours tell you more.
Can I use a starting battery's CCA rating to estimate its Ah?
You can, but expect a wide margin of error. A starting battery is built for short bursts, so the estimate overstates how long a steady load is. Use it as a sanity check, not a sizing tool.
Why does temperature affect CCA more than Ah?
Cold slows the chemical reaction inside the battery, which limits how much current it can release at once. Sustained low-draw capacity suffers too, but far less dramatically. That's why the test is run at 0°F.
Do lithium batteries use CCA ratings the same way lead-acid batteries do?
Usually not. Lithium batteries hold capacity better under heavy load, so the lead-acid assumptions behind CCA don't carry over. Many list watt-hours or continuous output instead, which maps more directly to real runtime. A closer look at amp-hour ratings covers more of this nuance.
