Are Heat Pump Water Heaters Worth It? Savings by Household Size, Pros and Cons, and 2026 Incentives
A heat pump water heater can cut energy use, but its higher purchase price may give some homeowners pause. In 2026, buyers must also account for a change in federal tax credits that many older guides have yet to reflect. For a household replacing an electric tank, the savings can make the upgrade worthwhile. ENERGY STAR estimates a payback of about three years for a family of four. This guide covers household savings, key drawbacks, payback factors, available incentives, and backup power options.
Are heat pump water heaters worth it: the short answer by household size
For most households replacing a standard electric water heater, a heat pump water heater (HPWH) is worth considering. It uses heat from the surrounding air rather than relying mainly on an electric resistance element. This can reduce electricity use and lower bills.
ENERGY STAR estimates that a certified model can save a household of four about 550 dollars per year. Its published estimate puts the payback period at about three years under its stated assumptions.
Savings vary with household size, hot water use, electricity rates, and installation costs. Smaller households may need more time to recover the extra upfront cost.
Table: ENERGY STAR savings by household size (vs. a standard electric water heater)
Household size
Annual kWh saved
Annual savings (ENERGY STAR, at 14.6 cents/kWh)
Payback on extra cost
Lifetime savings
2 people
1,880
$270
5.5 years
$2,050
3 people
2,820
$410
3.7 years
$3,830
4 people
3,760
$550
2.7 years
$5,610
Source: ENERGY STAR. Payback estimates depend on its stated assumptions and may differ from your actual costs.
ENERGY STAR also reports that certified heat pump water heaters use at least 70% less energy on average than standard electric water heaters. This refers to energy use, not a guaranteed reduction in your total utility bill.
A heat pump model may be less attractive for a one- or two-person household with low hot water use. Homes replacing a gas water heater also need a separate cost comparison, since the published savings above use a standard electric tank as the baseline.
Because it moves heat instead of making it with an element, the way heat pump water heaters save energy also explains why savings grow with every gallon you use.
The household table shows when the numbers work. However, the pros and cons below show what else you sign up for, from room cooling to slower recovery.
Heat pump water heater pros and cons
Heat pump water heaters can reduce electricity use, but they work differently from conventional tanks. They need enough surrounding air, can cool the room where they sit, and may heat water more slowly in their most efficient mode.
Table: Pros and cons of heat pump water heaters
Pros
Cons
Lower electricity use than standard electric tanks
Higher upfront purchase cost
Potentially lower annual energy bills
Slower recovery in heat pump-only mode
Reduced energy use over the unit's lifetime
Needs adequate air space and suitable temperatures
Can work with a home's solar power system
May cool the surrounding room
Some models offer different operating modes
Often needs a suitable electrical circuit and condensate drainage
The actual payback depends on the household, local energy rates, installation needs, and operating conditions. A cold installation space may also cause the unit to rely more often on its backup electric element.
A heat pump tank is one of several energy saving appliances for every home, and it tends to pay back fastest in households that use the most hot water.
Once the decision to buy is made, some households take a second step and plan for hot water during outages and for using their own solar power, which is a separate project with its own budget.
The strengths and weaknesses of heat pump water heatersThe strengths and weaknesses of heat pump water heaters
Already chose a heat pump water heater? Planning outage hot water and solar use with EcoFlow TITAN Plus
A heat pump water heater needs electricity to operate, so it will usually stop heating during a grid outage unless a suitable backup system powers its circuit. Rooftop solar can also supply electricity during the day, depending on the home's setup.
If you have already chosen a heat pump water heater, a home battery may be worth considering for outage backup or solar storage. However, a battery is not required to benefit from the water heater's energy savings. Assess the two investments separately.
Four steps to plan for backup power
  1. Calculate the water heater's costs first. Compare its purchase price, installation cost, and expected annual operating costs with those of your current system. Do not include battery savings in the water heater's payback calculation.
  2. Check the heater's electrical specifications. Read the nameplate and product manual for voltage, compressor draw, and backup resistance-element wattage. Many full-size models use a 208–240V supply and a 30A breaker, while some models operate at 120V. Requirements vary by model.
  3. Estimate your hot water needs. Decide how much hot water you need during an outage and how long backup power must last. If the model supports heat pump-only operation, this mode may use much less power than its resistance element.
  4. Confirm circuit compatibility. Ask a licensed electrician to check the heater's starting and running loads, along with other backed-up appliances. The electrician should confirm whether the proposed battery and home connection can support the required circuits.
How does EcoFlow TITAN Plus fit into the plan?
EcoFlow TITAN Plus is an option to evaluate if you want home backup power or a way to store surplus solar energy. Its suitability depends on the water heater's electrical requirements and the demands of other appliances connected to the system.
The system's stated specifications include 7.2kW of battery-only output and up to 8,000W of solar input. With a compatible Smart Home Panel 10 setup, it can support a home energy configuration designed to limit exports to the grid. Check the current product specifications and installation requirements before making a decision.
A resistance element can place a substantial load on a battery. For example, a 4,500W element can use much of a 7.2kW output capacity, leaving less room for other appliances. The compressor, resistance element, and other household loads must all be considered.
EcoFlow TITAN 5000 Plus
Example backup runtime estimates
The following estimates use a 5,000Wh battery and assume 85% usable energy after conversion losses. They show estimated operating time while the stated load is running, not total elapsed time between hot water cycles.
Example load
Estimated runtime
2,750W electric heating load
About 1.5 hours
1,126W electric load
About 3.8 hours
Actual runtime depends on the load, battery condition, conversion losses, and other connected equipment. Heat pump-only operation may use less power than resistance heating, but check the specific model's rated draw. Expansion batteries can extend runtime, but they do not increase the system's output rating.
Storing surplus solar instead of exporting it pays off differently under each utility's rules, which is why net metering versus solar self-reliance is a question to settle before sizing a battery.
Back to the water heater itself: ENERGY STAR's payback assumes you're replacing an electric tank at its test price, and four things can move your own number a long way.
What changes the payback: your current fuel, your rates, and your hot water use
ENERGY STAR's estimated three-year payback assumes a household of four replacing a standard electric water heater. Your result may differ because of four main factors.
Your current water heater's fuel
The published savings estimates compare heat pump models with standard electric tanks. If you currently use gas, compare your existing heater's annual gas use and cost with the new model's expected electricity use and cost.
A switch from gas may also require electrical work, such as adding a suitable circuit or upgrading the panel. These costs can reduce financial benefit. A 120V model may offer another option, depending on its specifications and installation requirements.
Your electricity rate
Higher electricity rates increase the value of each kilowatt-hour saved. For example, saving 3,760kWh per year is worth about $550 at 14.6 cents per kWh or $650 at 17.3 cents per kWh.
These are illustrative figures, not guaranteed savings. Use the energy rate on your own bill and keep fixed monthly charges separate.
Your hot water usage
Households that use more hot water may recover the extra upfront cost sooner. ENERGY STAR estimates a 5.5-year payback for a two-person household, compared with about 2.7 years for a household of four under its stated assumptions.
The installation location
Heat pump water heaters generally operate less efficiently in colder spaces and may switch to backup electric heating more often. This can reduce savings in a cold garage or other unsuitable location.
How to calculate your payback
Use this simple formula:
Payback period = Extra cost after rebates ÷ Annual savings
For example, an extra cost of $1,503 divided by $550 in annual savings gives a payback of about 2.7 years. Your actual result depends on the purchase price, installation quote, available rebates, and energy costs.
A battery's return is a separate calculation, and the factors that decide whether home battery backup pays off have nothing to do with the water heater's payback.
The payback formula starts with "extra cost after rebates," and for 2026 installs, the list of rebates looks different than it did a year ago.
Knowing the efficiency of heat pump water heatersKnowing the efficiency of heat pump water heaters
Heat pump water heater incentives in 2026: what ended and what's left
Many older articles still mention a federal tax credit of up to 30% for qualifying heat pump water heaters. That information is out of date for new installations in 2026.
According to the IRS, the federal Energy Efficient Home Improvement Credit under Section 25C does not apply to property placed in service after December 31, 2025. Buyers should therefore base their 2026 calculations on energy savings and any incentives they can confirm are available.
Table: Incentive status for heat pump water heaters (checked October 14, 2026)
Incentive type
Status in 2026
Federal 25C tax credit
Not available for property placed in service after December 31, 2025
State-administered HEAR rebates
May be available to eligible households, depending on the state program
Utility rebates
Check with your electricity or gas provider for current offers
Energy bill savings
Continue to offer potential long-term value
State-administered Home Electrification and Appliance Rebates (HEAR) may help eligible households cover some of the cost of a heat pump water heater. Availability, income limits, application rules, and program timelines vary by state. Do not assume funding is open or that you qualify without checking the relevant state energy office.
Utility rebates may provide another source of support. Confirm the eligible equipment, installation requirements, application deadline, and funding status before including a rebate in your budget.
State programs are where most of the remaining federal money flows, and HEEHRA rebates for heat pump water heaters are run through state energy offices that set their own timelines.
Even with rebates lined up, a heat pump water heater only pays off if it's installed in a space where it can actually run in heat pump mode, so the last check is your home.
Is your home a good fit? A pre-purchase checklist
A heat pump water heater offers the greatest benefit when the installation space and electrical supply suit the model. Check these points before buying.
  • Room temperature: The U.S. Department of Energy recommends a location that stays between 40°F and 90°F year-round. Check your chosen model's operating range, as manufacturer specifications can differ.
  • Air space: ENERGY STAR recommends providing about 1,000 cubic feet of air space around the unit. Some models support ducting or other arrangements for smaller rooms. Follow the manufacturer's installation manual.
  • Height and clearance: Heat pump tanks can be taller than conventional tanks. Measure the available height and check the required clearance before ordering.
  • Condensate drainage: These systems remove moisture from the air and produce condensate. Check whether you have a suitable floor drain or need a condensate pump.
  • Electrical supply: Many full-size models require a 240V circuit, while some plug-in models use 120V. Confirm the specific requirements with a qualified electrician.
  • Cold-weather effects: A unit installed in heated living space can cool the surrounding area. In winter, your home's heating system may need to replace that heat.
  • Maintenance: Plan to clean the air filter as directed by the manufacturer. Regular maintenance helps keep the unit operating as intended.
Adding a heat pump tank changes your home's daily load, and knowing how many kWh a house uses per day gives your electrician a baseline for the new circuit and any backup plan.
Heat pump water heaters can be worth the extra upfront cost for households replacing standard electric tanks. ENERGY STAR estimates a payback of about three years for a household of four, although smaller households and homes switching from gas need their own calculations. Compare local energy rates, installation quotes, and available 2026 rebates before buying. The federal 25C credit has ended for equipment placed in service after 2025. If you also want outage backup or solar storage, ask a licensed electrician whether EcoFlow TITAN Plus suits your heater's electrical requirements.
Are heat pump water heaters worth it for a small household?
They can be, but the payback may take longer. ENERGY STAR estimates about 5.5 years for a two-person household, compared with roughly 2.7 years for a household of four. Your actual result depends on hot water use, electricity rates, and installation costs.
How much does a heat pump water heater save per year?
ENERGY STAR estimates annual savings of about $550 for a household of four compared with a standard electric water heater, using an electricity rate of 14.6 cents per kWh. Your savings will vary with local rates and household demand.
Is there still a federal tax credit for heat pump water heaters in 2026?
No. The federal Section 25C credit does not apply to equipment placed in service after December 31, 2025. Eligible households may still qualify for state-administered HEAR rebates or utility incentives, depending on local program rules and funding.
What are the main disadvantages of a heat pump water heater?
The main drawbacks include higher upfront costs, slower recovery in heat pump-only mode, space and temperature requirements, condensate drainage, and possible electrical upgrades. The unit can also cool the room around it, which may affect heating needs during winter.
Do I need a battery or solar to benefit from a heat pump water heater?
No. A heat pump water heater can reduce electricity use without solar panels or a battery. A system such as EcoFlow TITAN Plus is a separate investment to consider for outage backup or solar storage, with its own costs and payback period.
Save Bills
