Low Consumption Electric Stove Guide: Induction, Radiant, and Coil Compared, Plus Cooking on Limited Power
Imagine boiling a pot of water for pasta and wondering how much electricity your stove uses before dinner is ready. The answer depends on more than the burner's wattage. It also depends on how efficiently the cooktop transfers heat to your pan. Induction, radiant, and coil stoves handle this differently, affecting how much energy reaches your food. This guide compares their efficiency, explains ENERGY STAR-certified models, estimates the electricity used during a cooking session, and shows how a portable induction burner can work with battery backup when a regular outlet is unavailable.
Which Electric Stove Uses the Least Electricity? Coil, Radiant, and Induction Compared
Every electric stove converts electricity into heat, but not all that heat reaches the cookware. The difference between an energy efficient electric cooktop and a less efficient one is how effectively it transfers heat to the pan. Wattage indicates how quickly a burner draws power, while efficiency indicates how much of that energy goes toward cooking. ENERGY STAR, a program run by the U.S. Environmental Protection Agency, with support from the Department of Energy (DOE), reports approximately 85% efficiency for induction cooktops, compared with 75–80% for conventional electric resistance cooktops.
Portable induction cooktop heating a pot in a modern kitchenPortable induction cooktop heating a pot in a modern kitchen
Table: Electric cooktop types at a glance (efficiency from ENERGY STAR; federal class from DOE's 2024 rule)
Cooktop type
How it works
Approximate efficiency
What does it mean
Coil (open element)
An exposed metal element heats the pan
75–80%
Heat escapes into the surrounding air
Radiant (smooth glass)
An element heats the glass surface, then the pan
75–80%
The glass retains heat after cooking
Induction (smooth glass)
A magnetic field heats compatible cookware directly
About 85%
More energy reaches the pan
Gas (comparison only)
A flame heats the cookware
About 32%
More heat escapes around the pan
Induction generally offers the most efficient electric cooking method. It also responds quickly to temperature adjustments. However, it requires compatible magnetic cookware, and the cooktop's rated wattage still determines its maximum power demand. ENERGY STAR also notes that boiling water with induction can take nearly half the time compared with gas, radiant, or coil cooking in its example. Actual results depend on the cookware, quantity of water, and appliance.
How Much Energy One Cooking Session Takes
A simple calculation shows how cooktop efficiency affects electricity consumption. Heating two pounds of water from 60°F to 212°F requires approximately 304 Btu of heat. Since one kilowatt-hour equals 3,412 Btu, the water needs about 89 watt-hours of heat. For an idealized comparison:
  • Induction at 85% efficiency: 89 ÷ 0.85 = approximately 105 Wh.
  • Resistance cooking at 80% efficiency: 89 ÷ 0.80 = approximately 111 Wh.
  • Resistance cooking at 75% efficiency: 89 ÷ 0.75 = approximately 119 Wh.
These estimates exclude the energy required to heat the pot, evaporation, and burner cycling. The difference between one pot of water is modest, but repeated cooking sessions can add up. Knowing your cooktop's rated power is also useful, and this guide to electric stove wattage explains how burner wattage affects electricity demand. It helps you estimate energy use for everyday cooking.
Energy Efficient Electric Stoves and Cooktops to Know (ENERGY STAR Models and Portable Burners)
Choosing an energy-efficient electric stove involves more than comparing advertised features. ENERGY STAR publishes annual energy figures for certified residential cooking products, while manufacturers provide wattage ratings and operating details for portable burners.
ENERGY STAR certified ranges and cooktops (examples, checked October 14, 2026)
According to ENERGY STAR's residential electric cooking product criteria, eligible residential electric cooking products must meet an Integrated Annual Energy Consumption (IAEC) limit of 195 kWh per year. Electric ranges must also meet an oven low-power energy consumption limit of 7 kWh per year. The following examples are drawn from the ENERGY STAR certified residential electric cooking products catalog. Check each model's certification status and specifications against the catalog before publication.
Regulatory context: Separately, the U.S. Department of Energy's cooking products standards page explains federal energy conservation standards and their compliance dates. In State of Mississippi v. Department of Energy, decided August 11, 2026, the U.S. Court of Appeals for the Fifth Circuit issued its ruling, setting aside the challenged 2024 rule and remanding the matter to DOE for further proceedings. ENERGY STAR certification criteria and DOE's federal standards are separate programs, so they should not be presented as interchangeable.
Model
Product Type
Cooktop
Annual energy
Bertazzoni PRO244IFEMXB
Freestanding range
Induction
186 kWh
Bertazzoni MAS365INMXV
Freestanding range
Induction
187 kWh
Samsung NSI6D*99 series
Slide-in range
Induction
189 kWh
LG CBIS3618*E
Built-in cooktop
Induction
189 kWh
Frigidaire FCFE3083A*
Slide-in range
Radiant
195 kWh
GE - JB256*M***
Freestanding range
Coil
195 kWh
The examples range from 186 to 195 kWh per year under the applicable test procedure. That nine-kWh difference illustrates why certification figures should not be treated as a precise prediction of your household bill. Your cooking frequency, settings, and appliance use will affect actual consumption.
Portable 120V single burners
A portable induction cooktop is worth considering if you need one cooking zone, live in a rental, or want a flexible backup option.
Model
Maximum rated power
Manufacturer-listed features
Duxtop 9100MC
1,800 W
15 power levels from 200 W to 1,800 W; 120V, 15A outlet; magnetic cookware at least 5 inches across
NuWave PIC Gold Pro
1,500 W
Temperature settings from 100°F to 575°F in 5°F increments; induction-ready cookware
A plug-in induction burner is not automatically a low-consumption appliance because its electricity use depends on the selected power level and cooking time. However, it lets you heat one pot without running a full-size range. Since a full-size stove also includes an oven, understanding how much electricity an oven uses per hour helps you distinguish oven energy use from cooktop consumption when comparing your household's electricity needs. A 120V single-burner setup can also be useful during a power outage when paired with a compatible portable power station.
Simple Cooking on a Small Amount of Power: EcoFlow DELTA 3 Max With a Portable Induction Burner
A portable power station can run a compatible single-burner induction cooktop during a power outage or where a wall outlet isn't available. The EcoFlow DELTA 3 Max provides short-term power for one suitable countertop burner. It isn't designed to run a fixed 240V electric range through its standard AC outlets, and it doesn't change the cooktop's own energy efficiency.
Step 1: Check the burner fits the unit.
EcoFlow rates the DELTA 3 Max at 2,400W of AC output at 120V and 60Hz, making it compatible with the listed 1,800W Duxtop 9100MC and 1,500W NuWave PIC Gold Pro within its rated output. Before connecting a burner, check its power requirements and the manufacturer's instructions. X-Boost does not provide additional rated output; it lowers voltage, so performance varies by appliance. The DELTA 3 Max's 120V AC output cannot directly power the 240V full-size range and built-in cooktops in the comparison table.
Step 2: Calculate Session Energy and Estimate Runtime
The EcoFlow DELTA 3 Max has a stated capacity of 2,048Wh. Assuming 85% is usable after conversion losses, the estimated available energy is 1,741Wh. At continuous full power, this could run a 1,500W NuWave burner for about 1.2 hours or an 1,800W Duxtop burner for about one hour. A 15-minute session at 1,500W uses approximately 375Wh, allowing around 4.6 sessions per charge under these assumptions. Actual runtime depends on the burner's power setting, heating cycles, battery condition, and other connected loads.
Step 3: Plan the recharge and keep it simple.
EcoFlow lists four charging methods for the DELTA 3 Max and states that wall or generator charging can reach 80% in 68 minutes under specified conditions. During an outage, focus on simple one-pot meals that require boiling, simmering, or reheating rather than running multiple appliances.
If you use a fuel-powered generator to recharge the battery, operate it outdoors at least 20 feet from the home, windows, doors, and vents, following the generator manufacturer's placement and operating instructions. Direct the generator's exhaust away from the home and all windows, doors, and vents. Never operate a fuel-powered generator inside a home, basement, garage, or other enclosed or partially enclosed space because of the risk of carbon monoxide poisoning. Follow the U.S. Consumer Product Safety Commission's generator safety guidance for additional precautions.
EcoFlow DELTA 3 Max: Portable Power for One Burner
After confirming that the cooktop's wattage and voltage are compatible, a portable power station can help provide temporary cooking power during a blackout or at a location without a suitable wall outlet.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
Explore the EcoFlow DELTA 3 Max portable power station for its specifications and compatibility details before using it for short cooking sessions with a compatible 120V induction burner. If you live in an apartment, following an apartment blackout preparedness guide can help you plan backup power, choose essential appliances, and prepare simple meals during an outage. Remember that this setup cannot power a fixed 240V range, and the power station itself does not improve cooktop efficiency. Choosing induction and adjusting the cooking settings can help reduce energy use.
What "Energy Efficient" Means on Paper: ENERGY STAR Criteria and DOE's Cooking Top Standard
ENERGY STAR and the U.S. Department of Energy (DOE) address appliance efficiency in different ways. ENERGY STAR is a voluntary certification program, while DOE sets mandatory minimum standards for covered products.
ENERGY STAR (voluntary label)
ENERGY STAR outlines efficiency requirements for qualifying residential electric cooking units by capping their allowable annual power usage. Its program-wide estimates also highlight potential energy and cost savings compared with standard models.
  • Annual energy consumption: Covered electric cooking products must use 195 kWh per year or less to meet the specified criterion.
  • Oven low-power energy use: Qualifying electric ranges must use 7 kWh per year or less in oven low-power mode.
  • Product coverage: Eligible standalone and portable cooktops, as well as ranges, fall within the criteria, although portable models did not appear on the certified list checked for this article.
  • Efficiency and savings: ENERGY STAR reports that certified electric cooking products are 18% more efficient on average than standard models, with estimated lifetime savings of about $385. These are program-wide estimates, not guaranteed savings for every buyer.
DOE's 2024 Cooking Products Rule: Original Requirements and Current Legal Status
DOE and ENERGY STAR take different approaches to appliance efficiency. ENERGY STAR provides voluntary certification, while DOE establishes mandatory minimum energy-efficiency standards for covered products. Understanding LEED vs. ENERGY STAR green certifications can help clarify how these programs differ.
In 2024, DOE issued a rule that included a 207 kWh/year energy-use limit for certain smooth-element cooktops, with an original compliance date of January 31, 2028. However, on August 11, 2026, the U.S. Court of Appeals for the Fifth Circuit set aside the challenged rule and remanded it to DOE for further proceedings. Therefore, the 207 kWh/year limit and the 2028 date should be understood as historical details of the original rule, not as current mandatory obligations. Read the original 2024 DOE rule and the Fifth Circuit's August 11, 2026 ruling for details.
Feature
ENERGY STAR
DOE's 2024 rule
Purpose
Voluntary efficiency certification
Federal energy-conservation rule issued in 2024
Annual energy figure
195 kWh/year for covered residential electric cooking products
207 kWh/year for certain smooth-element cooktops under the original rule
Coil cooktop limit
Certification criteria apply to qualifying products
The 2024 rule did not establish the same energy-use limit for coil cooktops
Timing
Certification criteria introduced in 2023; check current criteria for updates
Original compliance date: January 31, 2028. The Fifth Circuit set aside the challenged rule on August 11, 2026, and remanded it to DOE
Everyday Ways to Keep an Electric Cooktop's Consumption Low
Even an energy efficient electric cooktop can waste energy when the pan, setting, or cooking method is poorly matched to the task. These simple habits help you use the heat more effectively without replacing your appliance.
Electric Cooktop's Consumption LowElectric Cooktop's Consumption Low
  • Check cookware compatibility: For induction, place a magnet against the bottom of a pan. If it sticks, the pan is generally suitable for induction cooking.
  • Match the pan to the cooking zone: Use cookware that meets the manufacturer's minimum diameter and sits properly on the heating area.
  • Choose the lowest effective setting: A gentle simmer usually does not require the same power as bringing water to a boil. Reduce the setting once the food reaches the desired temperature.
  • Prepare one-pot meals: Combining ingredients in one pan can reduce the number of burners and total cooking time needed.
  • Keep the surface clean: Remove food residue according to the manufacturer's care instructions. Avoid abrasive materials that can damage glass cooktops.
  • Measure rather than guess: A compatible plug-in energy meter can help measure the consumption of portable 120V burners. Fixed or hardwired cooktops need an appropriate measurement method.
Renters who cannot replace their appliances can also explore ways to reduce apartment electricity use without renovations, including measuring plug-in devices and changing everyday energy habits.
A low-consumption electric stove is primarily about efficient heat transfer. ENERGY STAR rates induction at approximately 85% efficiency, compared with 75–80% for conventional electric resistance cooktops. Check certified product listings, use compatible cookware, and select the lowest setting that cooks your food properly. For outages or locations without a wall outlet, EcoFlow DELTA 3 Max can power one compatible 120V induction burner for short cooking sessions, subject to its rated output and usable battery capacity. It offers a practical backup option without replacing the need for an efficient cooktop.
What type of electric stove uses the least electricity?
Induction generally transfers the most energy to cookware. ENERGY STAR estimates approximately 85% efficiency for induction, compared with 75–80% for coil and radiant resistance cooktops.
Are ENERGY STAR certified electric stoves available?
Yes. The ENERGY STAR certified list includes residential induction, radiant, and coil ranges and cooktops that meet the program's applicable energy criteria. Check the current listing for specific models.
Is a portable induction cooktop more energy efficient than a full-size stove?
Induction uses the same basic heating method in either format. A portable burner lets you heat one pan at a time and control its power setting, which may be convenient for smaller meals.
Will a new federal rule ban my electric coil stove?
No. The 2024 DOE rule did not establish the same energy-use limit for open-coil cooktops as it did for certain smooth-element cooktops. On August 11, 2026, the U.S. Court of Appeals for the Fifth Circuit set aside the challenged 2024 rule and remanded it to DOE for further proceedings. The original 2028 compliance date should therefore not be presented as a current mandatory requirement. Check DOE's official cooking products guidance and the Fifth Circuit's ruling for updates.
Can a portable power station run an electric stove?
It can run a compatible 120V single-burner cooktop if the appliance's power requirements fall within the station's rated output. A 1,500W burner could run for about 1.2 hours on the DELTA 3 Max under the stated planning assumptions. It cannot directly power a fixed 240V range.
Save Bills
