Maryland Solar Incentives: What's Actually Available in 2026
Here's a detail that says a lot about where Maryland stands. In spring 2026, the state launched a brand new "Solar Access Bridge Fund." Why? To help offset the sudden end of the 30% federal solar tax credit. That credit stopped applying to any system installed from January 1, 2026 onward. Maryland didn't just lose an incentive and move on. It built something new to help fill the gap. This post covers that bridge fund, the state's other solar programs, and whether solar still makes sense here.
Why Maryland Built a Bridge Fund
Understanding how federal tax credits work alongside state grants gives Maryland homeowners the clearest path to maximum savings.
The federal Residential Clean Energy Credit (IRC Section 25D) is no longer available for new systems placed in service after December 31, 2025. It does not apply to new homeowner purchases or installations. If you are looking at options for new systems, there is no federal tax credit available, but state programs, SRECs, and local incentives can still help offset costs.
Maryland's answer was the Solar Access Bridge Fund. It launched in spring 2026 as a one-time program. Its goal: cover the sudden financial hole the early credit cutoff left behind. According to the Maryland Energy Administration, grants run up to $1,000 per kilowatt of installed solar, with a $15,000 cap per home. The fund pulls from the state's Strategic Energy Investment Fund, not from general tax dollars. MEA runs it on a first-come, first-served basis. As of this writing, the FY2026 application window is closed while the state works through a backlog of applications. If you think you might qualify down the road, check MEA's site directly for updates.
The fund isn't for everyone, though. It's only open to Maryland residents who applied to the Maryland Solar Access Program between July 1 and November 30, 2025, rather than the general public. Want the full national picture? Why the federal solar credit ended covers what changed and why, well beyond just Maryland.
Maryland's Ongoing Solar Incentive Programs
maryland solar access programmaryland solar access program
Maryland's incentive picture goes well beyond just the new bridge fund. A few programs have been running for years.
  • Maryland Solar Access Program. Grants for income-qualified households installing residential solar, given out through a list of approved contractors while funding lasts.
  • Sales tax exemption. Maryland charges no sales tax on new solar panel systems. That alone saves roughly 6% of your total install cost.
  • Property tax exemption. You won't pay extra property tax on the value solar adds to your home. Several counties, including Anne Arundel, Baltimore, Harford, and Prince George's, stack local credits on top.
  • Storage grants. Maryland's Residential and Commercial Energy Storage Grant Program, run through the Maryland Energy Administration, helps cover the cost of adding a battery alongside solar.
Curious how other states are handling this? How other states are handling it breaks it down state by state.
A lot of Maryland homeowners are pairing solar with a battery these days. It makes sense. Grants and tax breaks help with the upfront cost. But a battery is what actually keeps your fridge and lights running when a storm knocks out the grid. EcoFlow's TITAN lineup is built with exactly that pairing in mind.
EcoFlow TITAN 5000 Plus
If you're planning a smaller array, or your rooftop panels are already in place, the standard EcoFlow TITAN may be the better fit. It delivers the same 7.2kW split-phase output and expandable 5kWh base, with one 4kW solar input instead of two.
EcoFlow TITAN 5000
Grants and tax breaks are one part of the math. Maryland's SREC market is where a system keeps earning money after it's installed.
How Maryland's SREC Market Works
Once your system is up and running, it can keep making money on its own. Here's how: Maryland homeowners earn one Solar Renewable Energy Certificate for every megawatt-hour their system produces. A typical 5kW home system produces around 6 to 7 megawatt-hours a year, so that's roughly 6 or 7 certificates. You then sell those certificates, and recent prices have run around $55 each. Do the math, and that's a few hundred dollars a year, just for owning panels that are already paid for.
The demand for these certificates comes from Maryland's renewable portfolio standard. That's a state rule forcing utilities to buy a certain share of their power from solar. No demand, no market. Maryland set that demand on purpose, which is part of why prices here run higher than in Virginia.
New to how this works? How solar certificates get sold breaks down how they're earned and where the money comes from. SREC income adds up slowly over years. Net metering is what decides how much your system saves you every single month.
Net Metering in Maryland
Net metering is the part of going solar that shows up on your bill right away. Maryland's version is one of the better ones in the country.
Feature
How it works in Maryland
Credit rate
Full retail rate, not a lower wholesale rate
Unused credits
Roll forward indefinitely, they never expire
Utilities covered
BGE, Pepco, Potomac Edison, Delmarva, plus municipal and rural providers
That "credits never expire" detail is bigger than it sounds. In a lot of other states, unused credits reset or get paid out at a lower rate once a year. Maryland just lets them carry forward, month after month, year after year if you want. That matters most for a system sized to cover winter and summer both, since one season often makes more power than the other. Rules like this vary a lot from state to state, and how net metering differs by state is worth a look if you're weighing Maryland against somewhere else.
Is Solar Still Worth It in Maryland?
are solar panels worth it in marylandare solar panels worth it in maryland
Losing the 30% federal credit stings. It's real money off the table. On a typical system, that's thousands of dollars gone. But it doesn't tell the whole story here.
Maryland's grants, tax exemptions, SRECs, and the new bridge fund all still add up. Stack the sales tax exemption, the property tax exemption, and a few years of SREC checks together, and a chunk of that missing federal credit comes back on its own. For income-qualified households, the math actually looks better than in most other states right now. Between the Solar Access Program and the bridge fund, lower- and moderate-income Maryland homeowners have more layered support than almost anywhere else in the country. That won't last forever, since the bridge fund is a one-time program. But it's there right now for the households who need it most.
Want to see if the math works for your own home? Whether solar panels are worth it walks through the numbers for a typical household.
The federal solar tax credit ended for new systems in 2026. Maryland responded fast, adding a new bridge fund on top of its sales tax exemption, property tax exemption, SREC market, and retail-rate net metering. Check your eligibility for the Solar Access Program and bridge fund if you qualify by income. Factor SREC income and tax breaks into your own numbers before you rule out solar. And if you're pairing your system with backup power, EcoFlow's TITAN, and TITAN Plus are all built for exactly that.
Is there still a solar tax credit in Maryland in 2026?
No federal tax credit is available for new solar systems placed in service after December 31, 2025. However, Maryland homeowners can still lower their costs by using state SREC earnings, local property and sales tax exemptions, and eligible grant programs.
What is the Maryland Solar Access Bridge Fund?
It's a one-time state program launched in spring 2026. It helps cover the financial gap left by the early end of the federal tax credit, though it's only open to people already in the Solar Access Program.
How much are Maryland SRECs worth?
Recent prices have run around $55 per certificate. A typical 5kW home system can earn a few hundred dollars a year from selling them.
Does Maryland have net metering?
Yes. Maryland requires utilities to credit your exported solar power at the full retail rate, and unused credits roll forward without expiring.
Are solar panels worth it in Maryland without the federal tax credit?
For most homeowners, yes. The state's grants, tax exemptions, and SREC market help make up some of the difference. Pairing your solar system with a home battery like the EcoFlow TITAN also means your panels keep the lights on during an outage, not just lower the bill.
Save Bills
