Incandescent Christmas Lights Versus LED: Watts, Cost, Heat, and Which to Buy
Picture two boxes of C9 Christmas lights on a store shelf. Each has 25 bulbs, but one uses 175 watts while the other uses just 2.4 watts. Both can light up your roofline, yet they put very different demands on your electric bill and power setup. This guide compares incandescent Christmas lights versus LED using Northlight's package ratings. You'll see how the wattage affects seasonal costs, how many sets you can connect, and what to know about heat and fire safety. We'll also look at battery runtime and the warm glow some people still prefer.
Incandescent Christmas Lights Versus LED: Key Differences at a Glance
Both types light up a tree, porch, or roofline, but they work differently. An incandescent bulb heats a filament until it glows. An LED uses a semiconductor and releases far less energy as heat. That difference affects electricity use, bulb temperature, and how many sets you can run together.
Incandescent Christmas Lights Versus LEDIncandescent Christmas Lights Versus LED
Compare the package ratings
The table below uses Northlight light-string ratings checked on October 14, 2026. The C9 sets each have 25 bulbs, but their spacing and overall length differ. Compare watts per bulb rather than assuming each set covers the same distance.
Set (Northlight)
Bulb type
Rated watts per set
Rated amps
Sets you can connect end to end (maker)
Lighted length
25-count C9, opaque red, 12 in. spacing (SKU C4BG8511)
Incandescent
175W
1.46A
Connected total "not to exceed 210 watts," so effectively one set per run
24 ft
25-count C9, warm white, 8 in. spacing (SKU NL02604)
LED
2.4W
0.02A
Up to 87 sets (210W limit)
16 ft
100-count mini, green, 2.5 in. spacing (SKU NL02345)
Incandescent
40.8W
0.34A
Up to 5 sets (210W limit)
20.25 ft
100-count mini, warm white, 4 in. spacing (SKU NL02497)
LED
7.2W
0.06A
Up to 29 sets (210W limit)
33 ft
The C9 figures come straight from the package ratings: 175W divided by 25 bulbs equals 7W per bulb. For the LED set, 2.4W divided by 25 is about 0.1W per bulb. These numbers apply to the listed Northlight sets, not every Christmas light on the market. Read the label on your own lights before calculating energy use. All four Northlight sets were listed as 120V, 60Hz, UL certified, and approved for indoor or outdoor use. Some incandescent listings showed as out of stock when checked, so availability may change.
What else differs?
Feature
Incandescent lights
LED lights
Energy use
Higher wattage on the listed C9 set
Much lower wattage on the listed C9 set
Heat
Filaments release substantial heat
Run much cooler
Breakage
Traditional glass bulbs can break
DOE says LED lights use epoxy lenses rather than glass
Lifespan
Usually shorter
ENERGY STAR says certified LED strings can last up to 10 times longer
Connecting sets
Higher wattage reaches connection limits faster
Lower wattage can allow more sets, within package limits
Upfront price
Usually costs less
May cost more, depending on the set
Appearance
Familiar filament glow
Available in warm white and other colors
The U.S. Department of Energy says incandescent bulbs release 90% of their energy as heat, while LEDs emit very little heat. LEDs also use much less electricity for decorative lighting. If you're comparing bulbs for other fixtures around the house, this guide to bulb wattage can help explain why watts measure energy use, not brightness. The wattage difference matters most when lights stay on for hours each night. That's where the electric bill starts to tell the story.
Energy Use and Cost: What a Season of Each Type Adds to Your Bill
A light string's watt rating tells you how quickly it uses electricity while it's on. Multiply watts by hours, then divide by 1,000 to get kilowatt-hours (kWh). Your utility uses kWh to calculate the energy portion of your bill.
A 40-night cost example
The U.S. Energy Information Administration reported an average residential electricity price of 17.3 cents per kWh for 2025. Your rate may be higher or lower, so treat the figures below as examples, not a prediction of your bill. Assume the lights run six hours a night for 40 nights, or 240 hours total.
Display (4 sets of each)
Total watts
kWh for the season (watts × 240 ÷ 1,000)
Example cost at 17.3¢/kWh
100 incandescent C9 bulbs (4 × 175W)
700W
168 kWh
About $29.06
100 LED C9 bulbs (4 × 2.4W)
9.6W
About 2.3 kWh
About $0.40
400 incandescent mini bulbs (4 × 40.8W)
163.2W
About 39.2 kWh
About $6.78
400 LED mini bulbs (4 × 7.2W)
28.8W
About 6.9 kWh
About $1.20
These estimates use Northlight's listed wattages and the 2025 national average electricity rate, excluding other utility charges. Four incandescent C9 sets draw 700W, compared with just 9.6W for four LED sets. ENERGY STAR certified decorative light strings use 92% less energy than conventional incandescent strands, though this does not apply to every LED product. A timer can further reduce costs by switching lights off when not needed. For a personal estimate, use each set's wattage and your current rate, or follow this Christmas light cost guide. LEDs also use less battery power, making them a practical choice for displays far from an outlet. A portable power station, such as the EcoFlow DELTA 3 Classic or EcoFlow DELTA 3 Max, can power these lights without a long extension cord.
Lighting a Display Without an Outlet Nearby: EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max
A front-yard tree, mailbox, or porch railing may be too far from an outdoor outlet. The EcoFlow DELTA 3 Classic can power a group of lights within its 1,800W output limit, while the EcoFlow DELTA 3 Max supports up to 2,400W for larger displays. Both supply power, but your lights' wattage determines how long they run.
Check compatibility before connecting
  • Check total wattage. Add the watts listed on each light set. Keep the total within the power station's rated output and follow each set's connection limits. Don't rely on X-Boost for extra capacity with lights.
  • Keep the power station dry. Neither model lists an IP or water-resistance rating on its US product page. Keep it in a dry, sheltered area and use outdoor-rated extension cords for the lights.
  • Check cold-weather limits. The EcoFlow DELTA 3 Max has a listed discharge range of 14°F to 113°F. For the EcoFlow DELTA 3 Classic, check the user manual for its operating limits.
Estimated runtime for Christmas lights
These estimates assume 85% of the battery capacity is usable after conversion losses. Actual runtime may be shorter, especially with low-wattage LED lights, because the power station also uses energy to operate.
Group of lights (Northlight ratings)
Total watts
EcoFlow DELTA 3 Classic (870 ÷ W)
EcoFlow DELTA 3 Max (1,741 ÷ W)
4 incandescent C9 sets
700W
About 1.2 hours
About 2.5 hours
4 incandescent mini sets
163.2W
About 5.3 hours
About 10.7 hours
4 LED mini sets
28.8W
About 30 hours
About 60 hours
Four LED C9 sets draw just 9.6W, but actual runtime will be lower than a simple battery calculation suggests. At six hours per night, four LED mini sets can run for one evening on either power station, while four incandescent C9 sets would drain the EcoFlow DELTA 3 Classic in a little over an hour. Recharge the power station indoors during the day. EcoFlow lists a 0% to 80% recharge time of 45 minutes for the EcoFlow DELTA 3 Classic and 68 minutes for the EcoFlow DELTA 3 Max using wall power. Here are the two power stations side by side.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For larger displays or longer runtimes, the EcoFlow DELTA 3 Max offers double the battery capacity and higher output than the EcoFlow DELTA 3 Classic.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Classic suits a single group of lights, such as a tree or porch railing, especially when using LEDs. The EcoFlow DELTA 3 Max offers more battery capacity for larger displays or longer runtimes, including some incandescent setups. Neither power station reduces the lights' energy use, so switching to LEDs helps the battery last longer. If your yard tree is too far from an outlet, this guide to powering Christmas trees without electricity explains your options, including battery-powered lights and portable power stations. Runtime depends on the total wattage, which also affects how many light sets you can safely connect. Incandescent strings use more power, so their connection limits matter.
How Many Sets You Can Connect, and What That Means for Your Outlets
Every light set has a maximum connection limit printed on its box or tag. Incandescent lights use more power, so they reach that limit faster than LEDs. This affects how many strings you can connect without overloading the setup. Northlight's listed limits show the difference. You can connect up to five sets of incandescent mini lights, 29 sets of LED mini lights, or 87 sets of LED C9 lights, according to the package ratings. One 175W incandescent C9 set already comes close to the 210W connector limit.
The CPSC advises against connecting more than three sets of incandescent lights. Follow whichever limit is lower: the CPSC's guidance or the limit printed on your box. Because LED lights draw significantly fewer watts, you can often connect more LED strings end to end, but your specific product's package instructions and wattage limits still take absolute priority. Keep LED and incandescent lights on separate runs unless the manufacturer explicitly allows mixing them.
Why wattage matters when sharing outlets
Holiday lights often share circuits with other household appliances. Based on Northlight's ratings, four incandescent C9 sets draw about 5.8 amps, while four LED C9 sets draw about 0.08 amps. LEDs use much less power, which can help when other devices are running, too. If you're hosting guests, avoiding tripped breakers starts with checking what you're plugging in and how much power it uses. Lower wattage also means less heat from the lights. That makes heat, fire safety, and lifespan worth looking at before you choose a set.
Heat, Fire Safety, Durability, and Lifespan
LED strings run much cooler than incandescent lights. Lower operating temperatures help reduce the risk of combustion and burnt fingers. Compared to traditional glass bulbs, LEDs are also generally far less prone to breakage. Still, a damaged light string shouldn't go back on the tree or roofline.
Heat, Fire Safety, Durability, and LifespanHeat, Fire Safety, Durability, and Lifespan
Check every set before hanging it
The CPSC recommends checking new and old lights for cracked sockets, frayed wires, bare wires, and loose connections. Throw out damaged sets. Don't use electric lights on a metallic tree. For outdoor displays powered by household grid electricity, ensure lights are labeled for outdoor use, use outdoor-rated extension cords, and plug into a GFCI-protected outlet.() When powering displays off-grid with portable power stations like the EcoFlow DELTA 3 Classic or DELTA 3 Max, place the power station in a dry, covered area, follow the manufacturer's outdoor cord guidance, and adhere to official grounding/adapter instructions provided in the product manual.
How long do LED Christmas lights last?
ENERGY STAR says certified LED light strings can last up to 10 times longer than traditional incandescent strands. Certified strings also come with a manufacturer's warranty of at least three years. Actual lifespan varies, so check the packaging for certification and warranty details. LEDs can be a practical choice for holiday displays, but the look matters, too. If you decorate a tree or mantel with a Christmas village, keeping the display lit during a power outage is easier when the lights use less energy. Lower-wattage LEDs can help stretch your available power.
Warm Glow vs Crisp Color: Incandescent Christmas Tree Lights, LED, and Which to Buy
Incandescent lights have a familiar filament glow that many people associate with old-fashioned holiday decorations. LEDs come in a range of colors, including warm white options that create a similar look. Your choice may come down to the style of your tree or roofline, how long the lights stay on, and how much power the display uses.
When incandescent lights still make sense
Incandescent lights can be a reasonable choice for a small indoor display that runs for a short time, especially if you're matching an existing set or vintage C9 roofline. They usually cost less upfront, although prices vary by maker and set. The trade-off is higher energy use and more heat. That may matter less for a small display used briefly, but it adds up on a long roofline or a set that runs every evening.
When LEDs are the practical choice
LEDs make more sense for large outdoor displays, long rooflines, or lights that stay on for hours. They use less electricity and run cooler, which can be helpful around kids and pets. Their lower power draw also makes them a better fit for battery-powered displays. You can use both types in different parts of your home. Try incandescent lights on a small indoor tree and LEDs outside, but keep them on separate runs. Only use replacement bulbs that match the string's specifications. For a warm, welcoming look, drape warm-white lights around a window or mantel before hosting a cozy Christmas Eve. Either type can create that familiar holiday glow, so choose the set that fits your style and energy needs.
Incandescent C9 lights use far more power than LED versions, affecting running costs, heat, and connection limits. LEDs are usually the better choice for larger displays and longer hours, while incandescent lights offer a familiar glow. Before decorating, check each set's wattage and connection limits, inspect cords, and use outdoor-rated equipment outside. Follow the stricter connection limit from the package or CPSC guidance, and use a timer to avoid running lights all night. For displays far from an outlet, consider the EcoFlow DELTA 3 Classic for smaller setups or the EcoFlow DELTA 3 Max for larger ones. LEDs also provide longer battery runtime.
Are LED Christmas lights cheaper to run than incandescent lights?
Yes, based on the Northlight package ratings used here. In the example, 100 LED C9 bulbs cost about $0.40 to run for 240 hours at the 2025 U.S. average electricity rate. The same number of incandescent C9 bulbs costs about $29.
Do LED Christmas lights get hot?
LED Christmas lights produce much less heat than incandescent lights. The U.S. Department of Energy says they reduce the risk of burns and combustion because they stay cooler. But they still need a quick inspection before use. Replace any string with cracked sockets, damaged insulation, or loose connections.
Can you mix LED and incandescent Christmas lights?
Yes, you can use both types in the same display, such as LEDs outdoors and incandescent lights on an indoor tree. Keep them on separate runs, though. Don't connect the two types directly unless the manufacturer's instructions allow it.
How many incandescent Christmas light sets can I connect?
The CPSC advises against connecting more than three sets of incandescent lights together. Your light set may have a lower limit, so follow whichever rule is stricter. Check the package before connecting multiple strings, and avoid overloading outlets.
Do LED Christmas lights last longer than incandescent lights?
They can. ENERGY STAR says certified LED light strings can last up to 10 times longer than traditional incandescent strands. Certified strings must also have a manufacturer's warranty of at least three years. Check the packaging for the ENERGY STAR label, since these claims apply to certified products.
Save Bills
