How to Make Your Home Energy-Efficient and Lower Your Energy Bills
Inefficient heating and cooling, drafts around windows and doors, and inefficient appliances can all raise your energy bills. Next is using appliances that consume more power than they need to. If you’re wondering how to make your home more energy-efficient, start with simple fixes before investing in larger upgrades. Begin by following a practical, step-by-step approach that starts with doing low-cost weatherization. After this, adopt some daily behavioral changes, and eventually consider smart hardware upgrades. If you follow this through, you can make your home feel more comfortable and lower your monthly utility bills.
How Can You Identify and Reduce Energy Waste in Your Home?
Check your utility bills to identify the months with the highest energy consumption. This can help you determine where to start. Then walk through your home and look for drafts, insufficient insulation, and other sources of energy waste. Pay particular attention to windows and doors, as these are often the easiest places to inspect.
Review Your Monthly Energy Bills and Usage Patterns
Most utility companies show a 12-month history on the bill or you can view it on your online account. A rise in summer electricity use may reflect cooling demand. Compare usage with local weather before drawing a conclusion. A sharp rise in electricity use during July and August, for example, usually means your air conditioner is working much more than expected. If you want to isolate a particular appliance, start by learning how to calculate kWh usage from its wattage and run time.
Identify Common Sources of Energy Waste
A careful inspection of your home can help you find some common trouble spots. Check around windows and doors for drafts, and look for gaps near attic hatches or pipes. Take note if you have an old refrigerator in a hot garage and whether you see any damaged HVAC ducts in the attic. Also, ask your utility whether it offers a free or low-cost energy audit.
Add Insulation to Attics, Walls, and Floors
The attic is often a good place to make sure you have enough insulation. Heat escapes through the ceiling in winter and heat radiates from it in summer. EPA estimates that air sealing and adding insulation in attics, floors over crawl spaces, and accessible basement rim joists can save an average of about 15% on heating and cooling costs. If your attic is already well insulated, check if basement rim joists may also need some insulation.
Seal Air Leaks Around Windows, Doors, and Other Openings
Draft openings are a common waste of energy in both hot and cold weather. Fortunately, there are easy fixes. Check and repair weatherstripping around doors, add door sweeps, and caulk around window trim. You can also insert foam gaskets behind outlet plates and spray foam around pipes that go outside to seal smaller openings.
Upgrade to Energy-Efficient Windows and Doors
If you still feel drafts after making repairs, older, single pane windows or doors may be part of the problem. ENERGY STAR-certified double- or triple-pane windows can improve insulation and save energy. Their Low-E coatings help keep summer heat outside and winter warmth inside. They can also reduce UV fading on floors and furniture.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
Which Home Systems and Appliances Should You Make More Energy-Efficient?
Heating and cooling account for a large share of household energy use, making regular HVAC maintenance important for improving efficiency and reducing energy waste. Water heaters, appliances, and lighting are also practical places to look for savings.
Home System / Appliance
Typical Share of Home Energy Use
High-Impact Efficiency Action
Heating & Cooling (HVAC)
~45%–50%
Change duct filters every 1–3 months; upgrade aging units to high-SEER2 heat pumps
Water Heating
~18%
Lower tank thermostat to 120°F; switch to a heat pump water heater
Washer, Dryer & Kitchen
~15%
Choose ENERGY STAR models; wash clothes in cold water
Lighting & Electronics
~10%–15%
Use all LED bulbs; use smart power strips for entertainment centers
Note: Energy-use percentages are approximate estimates and may vary by household, climate, and appliance efficiency. The figures are informed by the U.S. Energy Information Administration’s 2020 Residential Energy Consumption Survey (RECS). The categories in this table are simplified for reference and do not correspond exactly to EIA’s original end-use classifications.
Maintain or Upgrade Your Heating and Cooling System
Since HVAC often uses more energy than any other home system, regular maintenance is necessary. Check and replace filters as directed by the equipment manufacturer, clear leaves from around the outdoor unit, and schedule an annual tune-up. If your equipment is aging or needs repeated repairs, compare repair costs with the expected energy use of a replacement. A heat pump’s energy savings depend on the system it replaces and your climate.
Choose ENERGY STAR-Certified Household Appliances
When an older refrigerator, dishwasher, or washer needs replacing, be sure to compare and use ENERGY STAR-certified models. ENERGY STAR refrigerators use about 9% to 10% less energy than standard models. ENERGY STAR-certified clothes washers can save even more energy, using roughly 20% less electricity and 30% less water. Check the yellow EnergyGuide label as well. This gives you estimated annual operating costs and makes it easier to compare similar appliances. If you’re comparing an older unit with a replacement, knowing how many watts a refrigerator uses helps explain why a single power reading doesn’t tell you its daily energy use.
Improve Water Heating Efficiency
A water heater tank uses energy around the clock to keep water hot. Consider lowering the tank temperature to 120°F, and this will reduce standby heat loss and help prevent scalding. Also insulate an upright older tank and the first six feet of hot- and cold-water pipes. If you’re replacing the unit, a heat pump water heater draws warmth from the surrounding air and can use up to two-thirds less electricity than a conventional electric resistance model
Replace Traditional Lighting With LED Bulbs
Replacing older incandescent bulbs with LEDs is a simple way to reduce energy. LEDs use at least 75% less energy and can last up to 25 times longer. They’re also available in warm color temperatures, very similar to incandescent bulbs, for a softer light around the home.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
What Daily Habits and Technologies Can Help You Save Energy?
You can cut some energy use by adjusting your thermostat. If you have time-of-use pricing, running appliances during lower-priced periods can reduce your bill. Smart thermostats and power strips can make it easier to manage electricity use. If your rate plan makes the price difference worthwhile, a home battery can shift when you draw some electricity from the grid.
Adjust Heating and Cooling Schedules Around Your Daily Routine
There’s usually no reason to fully heat or cool an empty home. The DOE says setting your thermostat back by 7°F to 10°F for eight hours a day can reduce annual heating and cooling costs by about 10%. Try adjusting temperature when you’re out or asleep, and then return to your usual setting when you’re home and awake.
Use Smart Thermostats to Automate Temperature Control
It’s easiest to use a smart thermostat to help you adjust temperatures according to your schedule. Some models use occupancy sensors or your phone’s location to adjust the temperature when people leave or return. Some also provide energy reports, so you can see how your heating and cooling habits affect use.
Reduce Standby Power From Electronics and Appliances
Some electronics draw a small amount of power even when they’re switched off. Game consoles, cable boxes, desktop computers, and coffee makers are common examples. A smart power strip can automatically turn off power to connected devices when your TV or computer is off.
Shift Electricity Use to Off-Peak Hours When Available
If your utility uses Time-of-Use (TOU) rates, electricity may cost more during late-afternoon and evening peak hours. Run the dishwasher, dryer, or EV charger later at night or in the morning to avoid the high peak rates. Also, consider using a home battery that can store electricity charged during cheaper hours for use during peak periods. For example, the EcoFlow DELTA 3 Max Plus Portable Power Station supports TOU mode, allowing homeowners to schedule charging and discharging cycles around local rate tiers. The system has a 2,048 Wh base capacity and 3,000 W AC output, with expandable storage of up to 10kWh. It gives households the ability to run key circuits on stored energy throughout expensive peak periods.
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
Which Long-Term Energy Investments Can Help Lower Your Bills?
When comparing energy-efficient home improvements, weigh the upfront cost against the savings you expect. In deciding what to do, compare each project’s likely savings and payback period, and be sure to check for any available incentives before you purchase.
Compare Upfront Costs, Potential Savings, and Payback Periods
Smaller projects, such as air sealing and attic insulation, often cost less upfront. How quickly they pay for themselves depends on installation costs and expected savings. To estimate a project’s simple payback period, subtract only rebates and tax credits you’ve confirmed you qualify for, then divide the net cost by the annual energy savings you expect. Start with upgrades that have shorter payback periods and budget for larger projects later. When comparing solar quotes, size a solar battery around how much electricity you expect to use after sunset.
Use Solar Panels and Home Battery Storage to Reduce Grid Electricity Use
If your solar panels produce surplus electricity during the day, the unused portion can be stored in a battery for evening use. The EcoFlow TITAN 5000 Plus works with the Smart Home Panel 10 and OASIS 3.0 to automatically manage solar generation, battery storage, and household energy use throughout the day. This can be particularly beneficial in high-rate markets with large Time-of-Use spreads, such as San Diego under SDG&E’s TOU-DR2 plan. According to EcoFlow’s estimates, a household using approximately 16.5 kWh of electricity per day could save around $3,100 annually with a 15 kWh TITAN 5000 Plus system paired with an 8 kW solar array. Actual savings will vary depending on local electricity rates, solar production, household consumption patterns, and system configuration.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
Take Advantage of Federal, State, and Utility Energy Incentives
State rebates, local utility incentives, and manufacturer promotions can significantly reduce the upfront cost of efficiency upgrades. Federal Section 25C and 25D residential clean energy tax credits expired at the end of 2025. But, many states still administer federally funded Home Energy Rebate programs (HOMES and HEEHRA). Local utilities may offer cash-back awards for heat pumps, insulation, and battery storage. Before buying equipment, check the DSIRE database and your electric utility’s rebate portal. Check which point-of-sale discounts and low-interest financing options are available in your ZIP code.
You don’t have to tackle every upgrade at once. Start with easy but effective steps to seal drafts, check insulation, and adjust your thermostat. Next, look at appliances, solar, or battery storage as your budget and needs allow. An energy-efficient home starts with a few targeted changes that improve comfort and help lower energy costs.
Is $200 a Month Normal for Electricity?
A $200 monthly electric bill is higher than the U.S. national average, which was approximately $142 per month in 2024, according to the U.S. Energy Information Administration (EIA). However, whether a $200 bill is unusually high depends on your state, home size, electricity rates, and heating and cooling needs. In 2024, average monthly residential bills exceeded $200 in Hawaii and approached $200 in Connecticut. Seasonal bills can also rise in regions with high air-conditioning demand during the summer.
How Much Electricity Does a Two-Person Household Use per Month?
A typical two-person household in the United States uses roughly 600 to 800 kilowatt-hours (kWh) of electricity per month, translating to roughly $95 to $145 on an average national rate. Your exact usage will sit toward the lower end if you live in an apartment or use natural gas for heating, cooking, and hot water, and toward the higher end in an all-electric single-family home with central air conditioning.
How Much Does It Cost to Run a TV for 8 Hours?
Running a modern LED or OLED TV for 8 hours typically costs between $0.08 and $0.25 per day, or roughly $2.50 to $7.50 per month. Most 55- to 65-inch LED TVs draw between 60 and 150 watts while turned on; at the U.S. average rate of roughly $0.17 per kWh, an 8-hour binge session consumes around 0.5 to 1.2 kWh of electricity.
Do Phone Chargers Waste Electricity?
Phone chargers draw a tiny amount of electricity when left plugged into the wall without a phone attached, though the actual cost is negligible. A modern smartphone charger idling in an outlet pulls roughly 0.1 to 0.5 watts—adding up to less than $0.50 per year on your electric bill. Unplugging chargers mainly helps declutter outlets rather than dramatically lowering utility costs, whereas unplugging game consoles, desktop setups, and older TV boxes saves noticeably more.
Save Bills
