Are Tankless Water Heaters Gas or Electric? How Each Works and What They Need
Are you shopping for a tankless water heater and not sure which kind fits your home? Tankless units come in both gas and electric versions, and the difference matters more than most people expect. Gas models burn natural gas or propane, and many use external electricity for ignition, controls, and a fan. Whole-home electric models need a large 240V supply. That shapes your install cost and what happens in a power outage. This guide answers the question, are tankless water heaters gas or electric, and covers sizing and outage power needs.
The short answer is both. Gas tankless heaters burn natural gas or propane, while electric ones heat water with electric elements. Many gas models require external power, but some generate their own ignition power from flowing water.
How Each Type Heats Water
Both types heat water only when you turn on a tap. In a gas unit, ENERGY STAR explains that a flow sensor activates the burner, which warms a heat exchanger. Cold water passes around that heat exchanger and leaves at your set temperature. The exhaust then exits through a sealed vent. An electric unit skips the flame and the vent. Its elements heat the water directly as it flows through.
How to Tell Which Type You Have
So is a tankless water heater gas or electric in your own home? Look for a gas line and a vent pipe on the unit. Both point to gas, and neither usually means electric. Does a tankless water heater use gas in every case? No. Only gas models do, so people who ask "do tankless water heaters use gas" are really asking which type they have.
Gas tankless
Electric tankless
Heat source
Natural gas or propane burner
Electric elements
Electricity needed
Varies by model. Powered controls and fans need electricity. Hydro-ignition models can operate without an outlet.
Large: heats the water; whole-home units usually 240V
Venting
Required
Not required
Capacity rating
Gallons per minute (GPM)
Works in an outage
Depends on the model. A unit that needs mains power stops without backup. A self-powered unit can operate if gas and water are available.
No
Which Gas Tankless Units Need External Power?
You might wonder, does a gas water heater need electricity if gas does the heating? It depends on the model. The Bosch Therm 520 HN uses water flow to power ignition without an electrical connection or batteries. A. O. Smith says its gas tankless heaters need electricity to run the ignition, control board, safety sensors, and blower motor, but not to heat the water itself. The draw is small, about 100 to 150 watts for a few seconds at startup and 60 to 100 watts while running.
So do gas water heaters require electricity in general? Not all of them. A. O. Smith notes that the outage problem also applies to many newer gas tank models with electronic ignition. People often search "does gas water heater work without electricity" or "will gas water heater work without electricity," and the answer depends on how the heater lights its burner. Some older tank models with a standing pilot can keep heating without power. Most modern units can't.
If you're still weighing which way to go, it helps to read up on the tankless heater pros and cons before you choose. Are tankless water heaters electric or gas in the homes around you? Often it comes down to whether a gas line was already in place.
If your gas tankless unit relies on outside electricity, a power outage leaves you without hot water. Its load is usually small, though, so a modest battery can often cover it.
Powering a Gas Tankless Water Heater in an Outage
A gas tankless unit draws so little power that a portable power station can run it, as long as the maker allows it. You still need gas and water pressure, though. Electric whole-home units are a different story, since they need far too much power at 240V for a portable unit.
Picture a winter storm that knocks out your power overnight. The gas meter still works, but your heater's control board goes dark and the morning shower runs cold. Some people reach for a generator, but the CDC warns against connecting generators to home circuits without approved automatic-interrupt devices.
Check These Things First
Start with your heater's manual. Confirm these details before you plan any backup:
  • Connection type: A. O. Smith says its units plug into a grounded 120V outlet or are hardwired to a dedicated circuit. Only a plug-in unit can connect to a power station. A hardwired unit needs an electrician and a suitable transfer device.
  • Direct connection only: Plug the heater's own three-prong cord straight into the power station's AC outlet. Never feed power back through a wall outlet, junction box, or home circuit. The CDC warns against connecting generators to home circuits without approved automatic-interrupt devices.
  • Maker approval: Rinnai's KCM manual, for example, says its cord should plug directly into a properly grounded three-prong receptacle, with no extension cord or adapter plug. If your manual doesn't cover battery backup, ask the maker before you plug in.
  • Startup and running watts: Use your manual's figures.
  • Gas and water supply: Backup power doesn't replace gas or create water pressure.
  • Unit condition: Never power a heater that's faulty or being serviced.
Where a Portable Power Station Fits
For that small ignition, controls, and fan load, the EcoFlow DELTA 3 Classic can power a maker-approved 120V unit. That can keep hot water flowing for a limited time during an outage, while gas and water pressure last. It isn't meant for electric whole-home tankless heaters.
Estimated firing time for compatible gas tankless heaters at three example electrical loads.Estimated firing time for compatible gas tankless heaters at three example electrical loads.
A gas tankless unit draws well under the EcoFlow DELTA 3 Classic's 1,800W output. Its 1,024Wh battery can cover many hours of on-and-off use for a maker-approved 120V model, based on the estimate below.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
How Long Can a Battery Run It?
These runtimes are estimates, not promises. They treat 85 percent of the battery as usable energy and use the top of A. O. Smith's running range.
Example load
Watts used
EcoFlow DELTA 3 Classic (870Wh usable, estimate)
Gas tankless heater running (A. O. Smith: 60 to 100W; 100W used)
about 100W
about 8.7 hours of firing time
The math is 1,024Wh × 0.85 ÷ 100W, which comes to about 8.7 hours. A tankless heater only fires while hot water runs, so the backup can stretch across more of the day. Real runtime still depends on your heater's actual draw and how much hot water you use. Learn more about battery power for tankless heaters.
Backup only helps if the heater fits your daily needs in the first place. So how do you size one?
How to Size a Tankless Water Heater
Tankless heaters are sized by flow rate, not tank gallons. You add up the fixtures that run at the same time. Colder incoming water also needs more heating power to reach the same temperature.
Add Up Your Peak Flow Rate
ENERGY STAR says tankless models are rated in gallons per minute (GPM). It lists these average flow rates:
Fixture
Typical flow rate
Shower and bathtub
2.5 GPM
Clothes washer
3.3 GPM
Kitchen or bathroom sink
2.2 GPM
Dishwasher
1.3 GPM
On a busy morning, one shower plus the dishwasher adds up to 3.8 GPM. Add a load of laundry and you're at 7.1 GPM. Your heater needs to keep up with the busiest stretch of your day, not the average one.
Plan for Cold Winter Water
Incoming water temperature changes the math. In northern states, water entering your home in January is much colder than it is in August. The heater has to raise that water further to reach your set temperature, so the same unit can deliver fewer gallons per minute in winter.
ENERGY STAR recommends you consult an experienced plumber to estimate your home's hot water demand. Your installer should also confirm the right GPM size, check whether your gas line is big enough, and see "whether electricity is available near the water heater (for forced ventilation models)." The same question applies when people ask whether gas water heaters need electricity in tank form.
Once you know your flow rate, the last step is picking the fuel. So which type fits your home?
Gas or Electric Tankless: Which Should You Choose?
Gas usually suits homes that already have a gas line and high hot water demand. Electric suits homes without gas, as long as the electrical panel can support it. Installation can add a large share to the total cost, so get quotes for the full job, not just the unit.
Choose Fuel, Check InstallationChoose Fuel, Check Installation
What Each Type Needs at Install
A gas tankless heater needs proper venting and a gas line sized for its burner. Condensing models also need a condensate drain, with the condensate disposed of as local codes require. Vent direction, material, and end point vary. Rinnai's RU199iN manual, for example, covers both horizontal through-wall and vertical roof terminations, so follow your model's manual and local code. An electric model needs large breakers and heavy wiring, and some homes need a panel upgrade. A. O. Smith says electric tankless units aren't recommended for whole homes because most homes lack the panel capacity. It suggests them for point-of-use spots, such as under a kitchen sink.
Factor
Gas tankless
Electric tankless
Best fit
Homes with a gas line and high demand
Homes without gas, or point-of-use spots
Install needs
Proper venting and gas line sizing. Provide electrical service if the model's manual requires it.
Large breakers, heavy wiring, possible panel upgrade
Whole-home use
Common
Limited by panel capacity
Outage backup
A compatible backup source for a model that requires external power
Too large for a portable unit
Running Costs and Other Options
ENERGY STAR says certified gas tankless heaters "cut water heating expenses" by heating water only when you need it. You can also compare heat pump water heater savings before you decide.
Tankless water heaters come in both gas and electric versions. Gas units that rely on external power for ignition, controls, or fans stop in an outage unless those loads have backup, while whole-home electric models need large 240V circuits. Size your heater by flow rate, check venting or panel capacity, and ask a plumber to confirm the fit. If you choose gas and want hot water during outages, the EcoFlow DELTA 3 Classic can power a maker-approved 120V unit for a limited time, depending on battery capacity and the actual load.
Are tankless water heaters gas or electric?
You can buy either type. Gas models burn natural gas or propane, and electric models heat water with elements. It usually comes down to your gas line and panel capacity.
Does a gas tankless water heater need electricity?
Check the model. A. O. Smith describes units that need external power for ignition, controls, sensors, and the blower. The Bosch Therm 520 HN instead uses flowing water to power its ignition and can operate without an outlet when gas and water are available.
Does a gas water heater work without electricity?
Most gas tankless models don't, and neither do many newer tank models with electronic ignition. Some older tank heaters with a standing pilot light can keep working, so check your manual.
How much power does a gas tankless heater use?
Not much. A. O. Smith lists about 100 to 150 watts for a few seconds at startup and 60 to 100 watts while the burner runs.
Can a power station run an electric tankless water heater?
Not a whole-home model. Those units need large 240V circuits and far more power than a portable power station can supply. A power station is a better match for the small 120V electrical load of a maker-approved gas tankless heater.
Home Solutions
