Winter Preparedness Checklist for the Home
Winter preparedness starts before the first hard freeze. A few hours spent on your home in October or November can help prevent frozen pipes, drafts, heating problems, and costly repairs later in the season. Home heating caused an estimated 27,900 fires and 115 deaths in 2023, according to FEMA’s U.S. Fire Administration. This winter preparedness checklist covers the key jobs to handle before cold weather arrives, including sealing drafts, servicing the furnace, protecting pipes, checking the roof, and planning for backup power.
Weatherproofing the House Before Cold Weather Hits
A warmer, more comfortable house starts with keeping cold air outside. Before winter settles in, walk through the house and look for the spots where heated air can escape, especially around doors, windows, exterior walls, and the attic. Taking care of those leaks now can make it easier to keep rooms comfortable once temperatures start dropping.
Seal Gaps Around Doors and Windows
Check the weather stripping around exterior doors and windows. Look for cracks, gaps, or areas that have come loose. Replacing worn weather stripping is a simple way to reduce drafts without taking on a major home improvement project. Older windows can also benefit from clear plastic window kits. They add another layer of protection against cold air and cost much less than replacing the windows.
Check the Attic Insulation
The attic can be another source of heat loss. Check for insulation that looks thin, uneven, or missing. Pay close attention to the edges and other areas where air can move between the attic and living space. If you're unsure whether you need more insulation, this guide to attic R-value explains how insulation levels affect heat loss.
Seal Cracks and Openings
Small openings around exterior walls can let cold air into the house, particularly where pipes, wiring, and other utilities pass through. Check these areas before the first hard freeze and seal gaps that lead outdoors or into unconditioned spaces. It's a small job compared with dealing with a drafty room all winter, and it also helps keep the heated air you've already paid for inside the house. Once the house is sealed up, turn your attention to the heating system. It needs to be ready for the long hours of work that come with a real winter cold snap.
Getting the Heating System Itself Ready
Your heating system is about to work a lot harder once temperatures drop, so it's better to find problems before the first serious cold snap. A furnace inspection in the fall gives you time to schedule repairs while service is still available. If you use a fireplace, chimney, or wood stove, those need attention too. Creosote can build up inside chimneys and increase the risk of a fire, so cleaning and inspection should be part of your pre-winter routine.
Have the Furnace and Chimney Checked
Schedule a professional furnace inspection before you start relying on the heat every day. At the same time, have chimneys and wood stoves cleaned and inspected if you use them. FEMA identifies home heating as the second leading cause of home fires nationwide, so keep furniture, curtains, boxes, and other flammable materials at least three feet from any heat source. This simple rule matters for fireplaces, wood stoves, furnaces, and portable heaters alike.
Be Careful With Space Heaters
Space heaters can warm up a cold room, but they can use a lot of electricity. Before using one for long periods, check this space heater power guide to understand its power use. Place the heater on a stable surface. Keep it away from bedding, curtains, furniture, and anything else that could catch fire. Your furnace also needs electricity to run. So even if it is working properly, it won't provide heat during a power outage. That's why it's important to have a backup power plan for essential heating equipment.
Backup Power: Standby, Portable, or Battery?
When the power goes out in winter, you have three main backup options. A standby generator starts automatically but costs more upfront and needs professional installation. A portable gas generator costs less, but you'll need to start and refuel it yourself and keep it running outdoors, away from windows and doors. Battery backup skips the fuel, fumes, and engine noise, while still providing power for essentials such as a furnace blower, well pump, or refrigerator. If you're weighing the generator options first, this guide to standby vs. portable generators lays out the differences and makes it easier to see where a battery system fits.
For smaller backup needs, the EcoFlow DELTA 3 Max offers a more portable option. With 2,048Wh of capacity and 2,400W of output, it can keep essential appliances and devices running without the size or installation requirements of a whole-home system.
The DELTA Pro Ultra X can cover a whole home through a longer outage, while the DELTA 3 Max gives you a more portable, lower-cost way to keep essential devices running in one room. With your backup power plan in place, it's time to check the plumbing. A hard freeze can damage pipes, water heaters, and outdoor spigots before you even notice there's a problem.
Pipes, Water Heater, and What's Hiding Behind the Walls
Start with the pipes most exposed to cold air. Check runs through the garage, attic, and crawlspace, and add insulation where needed. These areas can get much colder than the rest of the house, making exposed plumbing more vulnerable when temperatures stay below freezing. Before the first hard freeze, shut off outdoor spigots and disconnect garden hoses, too. A hose left connected can trap water and put pressure on the pipe behind the spigot.
Your water heater also has more work to do in winter because the incoming water is colder. Keeping it running efficiently can help avoid unnecessary energy use while maintaining the hot water your household needs. If you're checking your home for winter pipe problems, the guide to preventing frozen pipes covers insulation, temperature settings, and what to do if a pipe freezes. Pipes get most of the attention, but the roof is often the part of the house nobody checks until there's a problem.
Roof and Gutters: The Checklist Item Most People Skip
A quick roof check before winter can prevent small maintenance issues from turning into expensive problems once snow and ice arrive.
Clear the Gutters and Check the Roof
Clogged gutters can hold water against the roof and lead to ice dams when temperatures drop. Clear out leaves and debris before winter. While you're up there, check for damaged shingles or other signs of roof damage. Snow adds extra weight to the roof. If the roof is already in poor shape, that weight can cause more problems. Trim any branches hanging over the roof, too. Heavy snow or ice can make them break and damage your home.
Inspect the Roof Without Climbing
You don't have to climb onto a roof or ladder in freezing weather to get a useful view. A drone roof and gutter inspectioncan help you check hard-to-see areas from the ground, including debris buildup, damaged sections, and branches close to the roofline. Spotting those issues before a winter storm gives you time to deal with them while conditions are still manageable. The house isn't the only thing that needs winter prep. Getting stuck on the road is its own kind of emergency.
Winter Driving and Road Safety Prep
Winter driving should be part of your home preparedness checklist, especially if your area gets snow, sleet, or freezing rain. The Federal Highway Administration says 24% of weather-related crashes happen on snowy, slushy, or icy roads. Another 15% happen during snowfall or sleet, leading to more than 1,300 deaths each year. A few basic checks before the first storm can make a big difference once the roads turn slick.
Get the Car Ready for Winter Roads
Keep your gas tank at least half full during winter. That gives you more flexibility if traffic stops or you end up stranded, and it reduces the chance of fuel-related problems in extremely cold conditions. Check your tires before winter arrives, too. Winter tires can improve traction in snow and ice, while all-season tires are still useful when they have adequate tread and are in good condition.
Know What to Do If You Get Stuck
It's easier to deal with a stranded vehicle when you've thought through what you'll do ahead of time. Review car stuck in snow before the first storm, so you're not trying to figure out the safest next step while sitting on a snowy roadside. Knowing when to stay with the vehicle, how to clear the exhaust area, and when to call for help can matter more than trying to force your way back onto the road.
A solid winter preparedness checklist covers more than an emergency kit. A few simple checks can help you avoid bigger problems in winter. Check the furnace, insulate exposed pipes, clean the gutters, and inspect the roof. It also helps to prepare your car for winter driving. Start with the furnace and exposed pipes. These jobs are easier to handle before a cold snap. For backup power, EcoFlow's DELTA Pro Ultra X and DELTA 3 Max can keep essential equipment running without the fuel and exhaust of a gas generator.
What should be on a winter preparedness checklist for a home?
A winter home checklist should cover the areas most likely to cause trouble during freezing weather. Check door and window seals, attic insulation, the furnace and chimney, exposed pipes, outdoor spigots, the water heater, roof, and gutters. You should also decide how you'll handle a power outage and make sure your vehicle is ready for snow, ice, or freezing rain.
When should I get my furnace serviced before winter?
Schedule a furnace inspection before you start relying on your heating system every day. Getting it checked in the fall gives you time to deal with repairs before the first major cold snap. If you use a fireplace, chimney, or wood stove, have those inspected and cleaned at the same time.
Is a battery backup system better than a generator for winter outages?
It depends on what you need to power and how much hands-on work you want during an outage. A standby generator starts automatically and can provide whole-home power, while a portable gas generator costs less but needs fuel, manual operation, and safe outdoor placement. A battery backup avoids fuel and exhaust and can provide quiet power for essentials such as a furnace blower, refrigerator, or well pump.
How do I prevent ice dams on my roof?
Clean the gutters before freezing weather arrives so water can drain freely. Check the roof for damaged areas, too. Make sure the attic has enough insulation and airflow. Heat escaping into the attic can create uneven roof temperatures and contribute to ice buildup. It's best to handle these checks before the first major snowfall.
What winter driving precautions actually make a difference?
Keep your gas tank at least half full and check your tires before winter weather arrives. Winter tires can improve traction in snow and ice, while all-season tires should have adequate tread and be in good condition. It's also worth reviewing what to do if your car gets stuck in snow before you need that information on the side of the road.
