What Size Generator Do You Need to Run a Heat Pump?
A heat pump may be one of the largest loads you want to keep running during an outage. Its normal wattage is only part of the calculation. A conventional compressor can require a brief burst of current at startup, the indoor blower draws power of its own, and electric auxiliary heat can add several kilowatts in cold weather.
Tonnage alone is not enough to choose a generator. Two 3-ton systems may have very different electrical demands because one uses a single-stage compressor and the other uses a variable-speed inverter. This guide explains how to read the relevant equipment ratings, estimate continuous and starting demand, account for heat strips, and compare standby, portable fuel-powered, and battery-based backup systems.
How Much Power Does a Heat Pump Need to Run?
How many watts does a heat pump use? A heat pump does not use one fixed amount of electricity throughout every heating cycle. Demand changes when the compressor starts, the fan changes speed, the system enters defrost, or the thermostat calls for supplemental heat. Outdoor temperature matters too: the building needs more heat as the weather gets colder.
For generator planning, separate the load into three parts—the outdoor unit, the indoor air handler or blower, and the compressor’s starting demand. Treat electric heat strips as a separate high-draw load rather than burying them in the compressor estimate.
Typical Running Wattage by Heat Pump Capacity
Heat pump capacity is measured in tons, with 1 ton equal to approximately 12,000 BTU/hr. Tonnage describes heating and cooling capacity, not electrical use. Efficiency, compressor design, fan speed, and operating conditions all affect wattage.
For an early estimate, a conventional residential system may use about 1,000 to 1,500 watts per ton while operating. Inverter-driven equipment can run at a fraction of full output and increase gradually as demand rises, while a single-stage system generally cycles between off and full output. Use the following table as a planning reference, then check the data for the installed model before choosing a generator.
Heat Pump Capacity
Estimated Running Watts
Conventional Startup Surge (LRA)
Recommended Generator Size (Without Soft Start)
Recommended Generator Size (With Soft Start / Inverter)
2-Ton (24,000 BTU)
1,800 – 2,400 W
6,000 – 10,000 VA
10 kW – 12 kW
5 kW – 7 kW
3-Ton (36,000 BTU)
2,800 – 3,600 W
9,000 – 14,000 VA
14 kW – 16 kW
7.5 kW – 10 kW
4-Ton (48,000 BTU)
3,800 – 4,800 W
13,000 – 18,000 VA
18 kW – 20 kW
9.5 kW – 12 kW
5-Ton (60,000 BTU)
4,800 – 6,000 W
16,000 – 22,000+ VA
22 kW – 26 kW (Standby)
12 kW – 15 kW
Note: These figures cover the compressor and blower, not auxiliary electric heat strips, which may add 5 kW to 15 kW. Many variable-speed systems ramp up rather than producing the abrupt inrush associated with a conventional compressor. A properly selected soft starter may also reduce starting current on compatible equipment. Use the specifications for the installed heat pump rather than assuming either condition applies.
Starting Wattage and Startup Surge
A conventional compressor draws extra current as its motor speeds up. The outdoor unit’s rating plate often lists Locked Rotor Amps (LRA), which indicates the maximum current associated with a stalled or starting motor.
Starting demand can be three to five times the running wattage. A 3-ton heat pump drawing about 3,500 watts once it is operating may need more than 12,000 watts of starting support. If the backup source cannot maintain adequate voltage and frequency through that moment, the compressor may stall or a breaker may trip.
LRA is useful, but it does not settle the generator choice by itself. Starting performance also depends on the generator’s alternator or inverter, how long it can sustain its surge output, and other loads already running. A compatible soft starter can reduce inrush on many conventional compressors. Variable-speed heat pumps already use electronic controls to ramp the compressor and should be evaluated from their own technical data.
Power Requirements for Auxiliary Heat Strips
Electric heat strips are often the part of the system that upends a generator plan. Installed in the air handler, these resistance elements may operate when the heat pump cannot satisfy the thermostat, during some defrost cycles, or when emergency heat is selected. Some systems begin using auxiliary heat around 25°F to 30°F, but the actual control point varies by equipment, thermostat settings, and the home’s heating load.
Many U.S. homes have 5 kW to 15 kW of electric resistance heat:
  • A 5 kW heat strip draws about 5,000 watts continuously.
  • A 10 kW heat strip draws about 10,000 watts, or more than 41 amps on a 240V circuit.
Unlike a compressor’s momentary startup demand, a heat strip can stay on for minutes. A generator that starts the compressor without difficulty may still overload when one or more resistance stages energize.
Find the heat-kit rating on the air handler and ask how the controls behave on backup power. Some installations allow selected strip stages to be shed or locked out. Any such arrangement should be approved for the equipment and still leave enough heating capacity to protect the home during cold weather.
EcoFlow TITAN 5000EcoFlow TITAN 5000
How Do You Calculate the Generator Size for a Heat Pump?
To determine what size generator to run a heat pump, start with the electrical ratings on your installed equipment. Record the model numbers and electrical ratings for the outdoor unit, air handler, and heat-strip kit. Then list any other circuits that must remain on. A refrigerator, well pump, sump pump, lights, and internet equipment can materially change the total, especially if two motors start together.
The backup source must meet two limits: enough continuous output for the combined operating load and enough short-duration output to start the largest motor while the other selected equipment is still running. For a small generator for home backup, check the largest motor’s startup demand while the other selected loads are already running.
Determine the Total Running Wattage
The outdoor-unit nameplate may list Rated Load Amps (RLA), voltage, Minimum Circuit Ampacity (MCA), and Maximum Overcurrent Protection (MOCP). These ratings do not all describe everyday power use. MCA and MOCP are used for conductor and overcurrent-protection sizing, so they should not be treated as running wattage.
For a rough single-phase estimate, voltage multiplied by current gives apparent power in volt-amps:
Apparent running power (VA) = Volts × RLA
Real power also depends on power factor:
Running watts = Volts × RLA × PF
For example, a compressor rated at 15A RLA and 240V produces an estimate of 3,600 VA. Using a planning power factor of 0.85 to 0.90 gives roughly 3,100 to 3,240 watts. Actual consumption changes with operating conditions, so regard this as a planning figure rather than a field measurement.
Add the outdoor fan and indoor blower. The air handler may use about 400 to 800 watts, but its own label is the better source. Include any controls or pumps that operate with the system, then add the household circuits you intend to support.
Separate essential loads from appliances that can wait. An electric range, water heater, clothes dryer, or EV charger can often remain off while the heat pump runs. Intentional load management may reduce the generator size without sacrificing heat, refrigeration, or basic lighting.
Calculate Required Surge Output
For a conventional compressor, find the Locked Rotor Amps on the outdoor unit. A rough apparent-power calculation is:
Peak starting surge (VA) = Volts × LRA
A compressor rated at 55A LRA and 240V has a theoretical starting demand of about 13,200 VA. This does not mean it will draw 13,200 watts during every start. Starting power factor is lower—often around 0.4 to 0.6—and a healthy motor should accelerate quickly.
The generator still needs to supply the required current without excessive voltage drop. Compare the heat pump’s demand with both the amount and duration of the generator’s surge rating. A high peak output that is available only briefly may not be enough for a compressor that takes longer to start.
Also account for what will already be operating. If the refrigerator or well pump can start at the same time, an electrician may recommend load controls or sequencing rather than sizing the generator for every motor to start at once.
Match Generator Size to the Load
Leave practical headroom instead of planning to operate at the backup source’s limit. One common sizing method is:
Target continuous rating = Total running watts ÷ 0.8
If the heat pump and selected household loads total 6,400 watts, the calculation points to at least 8,000 watts of continuous output. That unit must still have enough surge capacity to start the compressor; an 8,000-watt continuous rating does not guarantee suitable motor-starting performance.
Run the calculation for the coldest conditions you expect the system to cover. Include any heat-strip stages that may remain available. If those stages will be shed, make the operating plan clear so someone does not switch on emergency heat during an outage and overload the system.
What Type of Generator Can Run a Heat Pump?
Standby, portable fuel-powered, and battery-based systems can all power certain heat pumps. The practical differences are automatic operation, fuel or stored-energy capacity, motor-starting performance, installation requirements, and cost. A heat pump generator must match the equipment’s voltage and handle both running and startup demand. When sizing a whole-home generator, also count the other circuits that will operate at the same time.
Standby Generators
A standby generator is permanently installed outdoors and connected through an Automatic Transfer Switch (ATS). When utility power fails, the generator starts and the ATS transfers the selected circuits—or, in some systems, the full service—to backup power. Most residential models use natural gas or propane.
Units rated from 14 kW to 26 kW can run many central heat pumps and air handlers if their motor-starting capability is adequate. Some can also carry limited auxiliary heat. Large heat strips and other heavy loads may require a larger unit or automatic load-shedding controls.
The higher initial cost includes more than the generator itself. Site preparation, transfer equipment, fuel work, permits, and professional installation all contribute. The engine also needs regular service. In return, a standby system restores power without requiring someone to move equipment or connect cables during bad weather.
Portable Fuel-Powered Generators
A portable dual-fuel or tri-fuel generator rated for 9,000 to 12,000 running watts may support a small or midsize heat pump, especially when a compatible soft starter reduces compressor inrush. It needs 240V output and a connection sized for the intended load. Check the generator’s continuous rating for the fuel you plan to use; output may differ by fuel type.
A qualified electrician can confirm whether a properly installed transfer switch or an approved panel interlock and inlet are appropriate for the equipment and local requirements. The connection must prevent power from feeding back toward the utility. Never energize household wiring with a double-ended cord.
Follow portable generator and carbon monoxide safety guidance. Operate the generator outdoors at least 20 feet from the home, away from doors, windows and vents, with the exhaust directed away from the home and other buildings. Use working battery-powered or battery-backup CO alarms indoors.
Portable Solar Generators
Battery-based power stations run quietly without burning gasoline or propane. There is no engine exhaust at the unit and no fuel to refill, but the inverter still must provide the required 240V output, continuous power, and compressor-starting support. Battery capacity determines how long the system can sustain the load.
The EcoFlow TITAN 5000 has a 5 kWh base capacity, up to 7.2 kW of inverter output, and native 120V/240V support for compatible heat pumps and transfer switches. Expansion batteries can increase storage to 30 kWh, while solar input of up to 4 kW allows the system to recharge when sunlight is available.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $2,900/year, with ROI in 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, including upfront purchase, installation, and long-term use.
For homes with rooftop solar, the EcoFlow TITAN 5000 Plus accepts up to 8 kW of PV input through dual MPPT controllers. Its X-Fusion 2.0 technology coordinates solar power and battery reserves, with combined output of up to 10 kW. That additional input and output capacity can help support a heat pump alongside essential household circuits and make better use of daytime solar.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
Output and capacity answer different questions. A system may start the heat pump but lack enough stored energy for a cold night. A large battery bank may offer long runtime but still be unsuitable if the inverter cannot handle the compressor or provide the required voltage. Check both sides of the equation.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Do You Choose the Right Generator for a Heat Pump?
Once the wattage estimate is complete, review voltage, connection method, runtime, and total installed cost. A generator is only a workable choice if it can operate the actual heat pump under the conditions in which you expect to use it.
Match the Generator’s Output Voltage to Your Heat Pump
Most central heat pumps in the United States use a 208V or 240V supply. A 120V-only generator cannot run a 240V compressor, regardless of its advertised wattage.
Portable units may provide an L14-30R or 14-50R receptacle, while integrated systems may be hardwired. Check the continuous current available at 240V rather than judging capacity from the plug shape or peak wattage printed on the generator. The backup source must also keep voltage and frequency within the heat pump’s permitted range as the compressor starts and other loads cycle.
Check Transfer Switch and Connection Requirements
A central heat pump is connected to the home’s fixed wiring, so the backup source needs equipment that isolates the house from the utility grid. Depending on the system, that may be a manual transfer switch, an approved panel interlock with an inlet, an ATS, or a compatible home power panel.
A licensed electrician should match the conductors, inlet, breaker, transfer equipment, and grounding arrangement to the generator and selected loads. An HVAC contractor can confirm whether a soft starter or auxiliary-heat control is appropriate for the installed heat pump.
After installation, test the system under controlled conditions. Start the heat pump while the expected essential loads are connected and confirm that it completes a normal heating cycle without a trip. If heat strips are supposed to be shed, verify that the controls actually keep them off while backup power is in use.
Evaluate How Long the Generator Can Run
Output determines whether the heat pump can operate; fuel or stored energy determines for how long. Estimate daily use in kilowatt-hours rather than multiplying full-load wattage by 24. Heat pumps cycle or modulate, and their duty cycle changes with outdoor temperature, insulation, thermostat settings, and the condition of the house.
For an engine generator, use the manufacturer’s runtime information for the intended fuel and load. For a battery system, divide usable capacity by average connected load, then account for conversion losses and colder periods. Estimating battery generator size for a two-story house uses the same daily energy calculation.
Solar input can extend runtime for a solar generator, but winter production varies with daylight, cloud cover, array size, orientation, and snow. Treat it as a variable source rather than guaranteed daily energy.
Compare Purchase, Installation, and Operating Costs
Portable fuel generators generally cost less at the outset, but the project may also require an inlet, transfer equipment, a soft starter, suitable cabling, fuel storage, and maintenance. Standby systems add site preparation, fuel piping or tank work, permits, installation, and scheduled service.
Battery systems may need additional storage for long winter outages, plus compatible transfer equipment and solar components if recharging is part of the plan. They avoid engine fuel and engine maintenance, but storage capacity is a significant part of the purchase price.
Compare quotes on the same basis. Each should identify continuous output, surge capability, included circuits, auxiliary-heat management, runtime assumptions, connection equipment, labor, and maintenance. Check current eligibility before including tax credits or local incentives in the cost comparison.
There is no dependable generator size for a heat pump based on tonnage alone. The backup system must carry the outdoor unit and air handler, start the compressor without an excessive voltage drop, and account for any auxiliary heat that may operate during an outage. Other essential household circuits belong in the calculation as well.
Start with the condenser’s RLA and LRA, the air handler’s electrical data, and the installed heat-strip rating. Decide which loads can be shed, confirm the 240V connection method, and estimate runtime for realistic winter conditions. A qualified electrician and HVAC contractor can then verify the plan against the equipment requirements and test the completed installation.
Can a Soft Starter Help a Generator Run a Heat Pump?
Yes, installing an aftermarket soft starter can significantly reduce your heat pump’s startup surge, potentially by around 50% or more, depending on the equipment and soft starter model. By gradually ramping up compressor voltage rather than slamming it with full inrush current, a soft starter lowers the required peak wattage. This modification may allow some homeowners to use a smaller generator than would otherwise be needed for a 3-ton to 4-ton heat pump, which could otherwise exceed the generator’s startup capacity.
Can You Use a Heat Pump During a Winter Power Outage?
Yes, you can run a heat pump during an outage as long as your generator provides 240V split-phase power and meets both running and surge wattage needs. To avoid overloading the backup system, turn down the thermostat slightly to prevent auxiliary electric heat strips from engaging, or lock out emergency heating mode entirely at your control panel.
Can You Run a Generator Overnight to Power a Heat Pump?
Yes, generators can run overnight, but safety and fuel capacity are paramount. Fuel-powered generators must be situated at least 20 feet away from windows and doors with active carbon monoxide alarms inside, and they must have enough fuel capacity to run through the night. Battery-based solar generators are inherently quiet and emit zero fumes, making them ideal for uninterrupted overnight heating
Does Defrost Mode Increase a Heat Pump's Power Consumption?
Yes. In freezing weather, the heat pump may reverse its refrigerant flow to warm the outdoor coil and melt frost. During this cycle, the control board may also activate auxiliary heat strips to keep indoor air warm, potentially adding around 5 kW to 15 kW to the load, depending on the installed heat strip capacity. Lowering the thermostat may not prevent this because the defrost control board can call for the strips directly. If your generator can’t handle the combined load, ask an HVAC technician whether the heat strips can be safely locked out at the air handler or control board before using backup power.
Solar Generators
