How Much Electricity Does a Space Heater Use?
A space heater feels like a small appliance, but it can draw a lot of electricity. Most residential models use between 750 and 1,500 watts. A 1,500-watt heater can add up quickly when it runs for several hours each day. So, how much electricity does a space heater use? It depends on its wattage, runtime, thermostat settings, room size, and electricity rate. Here's how to estimate its energy use and cost, plus practical ways to keep your winter electric bill under control.
How Many Watts Does a Space Heater Use?
To figure out how much electricity a space heater uses, you have to look at wattage. Watts measure the rate at which an electric appliance draws power from your wall.
How many watts does space heater useHow many watts does space heater use
Most residential space heaters draw between 750 and 1,500 watts. On standard American 120-volt circuits, 1,500 watts is the maximum continuous load permitted on a standard 15-amp breaker. Because of safety margins, manufacturers rarely build plug-in portable units that pull more power than that.
However, power draws vary widely depending on the heater style and heat setting:
  • Personal desktop heaters: Small ceramic or fan-forced units pull between 200 and 500 watts. These work well for heating your hands or warming under a work desk.
  • Standard portable room heaters: Typical ceramic, infrared, and oil-filled radiator units run on low (750W to 900W) or high (1,500W).
  • Large space or utility heaters: Heavy-duty garage heaters and workshop units can pull 2,000 to 4,000 watts. These often require dedicated 240-volt circuits.
You can easily find the exact wattage of your unit. Check the rating sticker placed near the power cord or on the base panel. Look for the label marked "W" or "Watts."
Typical Wattage by Heater Size and Type
Different heater technologies deliver warmth in different ways. Some warm the surrounding air quickly with fans. Others radiate warmth into physical objects or circulate hot oil slowly.
Heater Type
Typical Low Setting
Typical High Setting
Best Room Application
Personal / Under-Desk
200W
500W
Cubicles, small work desks, foot warming
Ceramic Fan-Forced
750W
1,500W
Home offices, small bedrooms (100–150 sq ft)
Oil-Filled Radiator
600W
1,500W
Medium bedrooms, home offices (sustained heat)
Infrared Quartz Heater
750W
1,500W
Open living spaces, direct personal heating
Micathermic Panel
750W
1,500W
Wall-mounted bedroom zones, quiet spaces
Heavy-Duty Garage Heater
2,000W
4,000W+
Workshops, uninsulated two-car garages
Wattage explains how much power a heater pulls. What that actually costs is the number most people really want.
How Much Does It Cost to Run a Space Heater?
Wattage explains how much energy a space heater uses per second. What you really want to know, though, is the dollar amount on your utility statement.
Electric utilities bill you in kilowatt-hours (kWh). One kilowatt-hour equals 1,000 watts of power running continuously for 60 minutes.
To calculate your running cost:
  1. Divide your heater's wattage by 1,000 to get kilowatts (kW).
  2. Multiply that kW figure by the hours you run the heater.
  3. Multiply the total kWh by your local electric utility rate.
In 2026, the national average residential electricity rate in the United States sits around $0.18 per kWh. Depending on where you live, that rate can swing drastically. Rates run as low as 11 cents per kWh in states like Idaho or Washington. In places like California, New York, or Massachusetts, rates frequently climb past 30 to 40 cents per kWh.
Cost Per Hour
Let's look at standard running costs per hour using the national average rate of 18 cents per kWh:
Here's the basic calculation:
1,500 watts ÷ 1,000 = 1.5 kW
1.5 kW × 1 hour = 1.5 kWh
1.5 kWh × $0.18 = $0.27
So, a 1,500-watt heater costs about 27 cents per hour at that electricity rate.
Your actual cost can be higher or lower depending on your local utility rate.
Cost Per Month and Per Season
When the temperature drops below freezing, space heaters stay on for extended stretches. Running a standard 1,500-watt unit across a typical winter day adds up fast.
Daily Operating Time
Daily Power Draw (kWh)
Estimated Daily Cost (@ $0.18/kWh)
Estimated Monthly Cost (30 Days)
4 Hours (Evening Chill)
6 kWh
$1.08
$32.40
8 Hours (Workday or Overnight)
12 kWh
$2.16
$64.80
12 Hours (Cold Climate Use)
18 kWh
$3.24
$97.20
24 Hours (Continuous Running)
36 kWh
$6.48
$194.40
That daily cost is easy to justify when the power is reliably on. But a space heater becomes a very different kind of appliance during a winter outage, when staying warm matters more than the electric bill. A portable power station with enough continuous output lets a household run a space heater for at least part of an outage without waiting on the grid to come back.
If you only need to warm a compact area, a lightweight and responsive backup option can be practical. The EcoFlow DELTA 3 Plus can help keep bedrooms or home offices warm during brief power outages.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
During multi-day freezes or deep cold snaps, a standard battery drains quickly under heavy heating loads. The EcoFlow DELTA 3 Max delivers a massive 2,400W continuous output and over 2kWh of onboard capacity. It effortlessly handles full-size space heaters, refrigerators, and other critical appliances until the grid returns.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The DELTA 3 Plus fits shorter bridges or a lower-wattage heater setting. The DELTA 3 Max stretches runtime further for a standard-size heater during a longer cold-weather outage.
Cost estimates assume a heater running at full power, but several factors change how much electricity it actually uses in practice.
Factors That Affect Space Heater Electricity Use
The numbers above assume your heater runs non-stop at full load. In practice, how much power a space heater uses depends on several real-world home variables.
Factors affecting space heater electricty useFactors affecting space heater electricty use
Room Size and Insulation
Room size and insulation can have a major impact on how often your heater needs to run.
  • A larger or poorly insulated room can make a heater run longer and more often to maintain the desired temperature, increasing total electricity use.
  • Drafts around windows and doors allow warm air to escape, making the heater work harder to maintain a comfortable temperature.
Thermostat Settings and Heat Mode
Your thermostat setting and selected heat mode can also affect electricity consumption.
  • Heaters with thermostats can cycle on and off after reaching the target temperature, using less electricity than continuous full-power operation.
  • Eco or low-wattage modes reduce power draw, although they may take longer to warm the room.
Space heaters aren't the only way to heat a room, and the comparison matters for anyone deciding how to warm a home overall.
Space Heater vs. Other Heating Methods
A space heater is generally cheaper to run than heating an entire home with a central system just to warm one occupied room. However, heating an entire house with electric resistance heat costs considerably more than targeted space heating in a single room.
Comparing how a heat pump stacks up against a traditional furnace on cost and efficiency provides useful context for anyone deciding between whole-home heating and a room-by-room approach with space heaters:
Heating Method
Energy Efficiency
Running Cost Profile
Best Use Case
Space heater (single room)
100% (Direct heat)
Low for one room; expensive for whole-home
Warming an occupied bedroom or home office
Central electric resistance heat
100% (Direct heat)
Very high across the entire home
Homes without gas access; costly during winter
Heat pump
250%–400% (Moves heat)
Low to moderate for whole-home heating
Primary year-round heating in moderate to cold climates
Gas furnace
80%–98% AFUE
Moderate fuel costs overall
Heating large, multi-room houses quickly in freezes
Whichever heating method a household relies on, a few habits make a real dent in space heater electricity use.
Tips to Reduce Space Heater Electricity Use
Small daily adjustments can significantly lower running costs. Use these straightforward habits to keep your home warm while trimming unnecessary power draw from your utility bill.
  • Heat only occupied rooms: Run your unit where you spend time rather than warming the whole house.
  • Close room door: Trap warm air inside to stop heat escaping down empty hallways.
  • Rely on built-in thermostats: Let your heater cycle off automatically instead of running continuously at full blast.
  • Lower the heat setting: Run the heater on a low or medium setting instead of high to draw fewer watts.
Pairing these spot-heating habits with proven ways to reduce your winter electric bill keeps your overall household energy costs under control all season long.
Most space heaters draw 750 to 1,500 watts, costing roughly 15 to 30 cents per hour. That expense adds up fast across a cold winter. To keep utility bills low, match heater size to your space. Always choose a model with a built-in thermostat, and close doors to trap heat inside.
When winter storms knock out the power grid, reliable backup matters. The EcoFlow DELTA 3 Plus and DELTA 3 Max provide the continuous output needed to run space heaters safely indoors.
How many watts does a typical space heater use?
Most space heaters draw between 750 and 1,500 watts, with 1,500 watts being the most common setting on standard room heaters. Small personal models use as little as 200 watts.
How much does it cost to run a space heater for 8 hours?
Running a 1,500-watt heater on high for eight hours uses 12 kWh of electricity. At national average utility rates, that comes out to about $2.16 per day.
Do space heaters use more electricity than central heating?
It depends on how much space you're heating. A space heater can use less electricity when heating one occupied room than a central system heating the entire house.
Can a portable power station run a space heater during an outage?
Yes, if its continuous output matches the heater's draw. High-output units like the EcoFlow DELTA 3 series reliably supply the 1,500 watts needed to run space heaters during blackouts.
Does a lower thermostat setting actually reduce a space heater's electricity use?
Yes. A lower target temperature can reduce how long the heater needs to operate. A thermostat can also cycle the heater off after reaching the selected temperature, reducing continuous full-power operation.
Save Bills
