Heating Swimming Pool Water: Covers, Solar Heaters, Heat Pumps, and Gas Compared
A pool that's too cold doesn't get used, so many owners look for ways to stretch the swimming season. The options range from a simple cover to solar collectors, heat pumps, and gas heaters. Each has a different upfront cost, running cost, and climate fit. The U.S. Department of Energy (DOE) provides useful information about how these options compare. This guide explores heating a swimming pool with different methods, how to retain heat, what heating systems cost to operate, and what to consider when planning backup power for an electric pool heat pump.
Ways of Heating a Swimming Pool
The easiest place to start is with a pool cover, which helps retain existing heat and reduces evaporation. After that, choose a heating system that suits your climate, budget, and swimming schedule. Solar heaters and heat pumps can offer lower running costs in suitable conditions, while gas heaters provide faster heating when you need it.
Comparing Different Pool Heating Methods
Method | How it works (DOE) | Best Fit |
Pool cover | Reduces evaporation and heat loss | Almost every swimming pool |
Solar pool heater | Circulates water through solar collectors | Sunny climates |
Heat pump heater | Transfers heat from outdoor air into pool water | Moderate and warm climates |
Gas heater | Burns natural gas or propane to heat water | Fast, occasional heating |
1. Pool Covers: The Simplest Way to Keep Water Warm
A pool cover is one of the simplest and most practical ways to keep swimming pool water warm without installing a dedicated heating system. It reduces heat loss caused by evaporation and helps retain warmth, especially overnight when temperatures drop and the pool receives no direct sunlight. Homeowners can choose from solar covers that absorb sunlight, thermal covers that reduce overnight heat loss, or automatic covers that make daily pool protection more convenient.
2. Solar Pool Heaters: Use the Sun to Warm Your Pool
Solar pool heaters use sunlight to warm swimming pool water without burning fuel. A pool pump circulates filtered water through solar collectors, where sunlight increases its temperature before the water returns to the pool. Understanding how solar pool heaters work can help homeowners evaluate their installation requirements, available sunlight, and potential energy savings. Obtain a current local quote for the equipment and installation, and assess payback using the heating costs the system would replace.
3. Heat Pump Pool Heaters: Efficient Heating in Suitable Climates
Electric pool heat pumps collect heat from outdoor air and transfer it to circulating pool water rather than generating heat directly. A fan, evaporator, compressor, and heat exchanger work together to move this heat into the pool. The DOE reports that these systems typically achieve a coefficient of performance (COP) between 3.0 and 7.0 under suitable conditions. They offer efficient, consistent heating in warmer climates, although performance decreases when outdoor temperatures fall below approximately 45°F to 50°F.
4. Gas Pool Heaters: Fast Heating When You Need It
Gas pool heaters use natural gas or propane to heat water through a combustion process. Pool water passes through a heat exchanger, absorbs the heat, and returns to the swimming pool at a higher temperature. Unlike solar heaters and heat pumps, gas heaters do not depend on sunshine or warm outdoor air, making them useful for occasional swimming sessions and faster temperature increases. However, fuel consumption can increase operating costs, especially when maintaining a warm pool throughout the season.
Backup Power for a Pool Heat Pump and Pump Circuits
Electric pool heat pumps and circulation pumps depend on electricity to operate. During an outage, both can stop working, interrupting heating and water circulation. If you want these systems available during a blackout, you need a properly designed home backup arrangement. Start by identifying which pool circuits matter and how long you want them to operate. Pool equipment can require substantial electrical power, so backup planning needs more than simply checking a battery's capacity.
What Should You Back Up?
During a power outage, identify which pool equipment needs backup power instead of trying to operate every circuit. Consider whether circulation or heating is the immediate priority, check each appliance's running and starting wattage, and estimate how long it needs to operate. Since pool heat pumps can draw substantial electricity, review their nameplate specifications and plan for essential water-related needs by understanding water security during a power outage. Consult an electrician before selecting a suitable backup system.
EcoFlow TITAN 5000 for Selected Pool Circuits
The EcoFlow TITAN 5000 is a home battery backup option for supporting selected 120V and 240V pool circuits when paired with the Smart Home Panel 10 (SHP10), installed by a licensed electrician. It provides 7,200W of split-phase output with a 5kWh starting capacity, making it worth evaluating for compatible pool heat pumps and circulation pumps. Before installation, have an electrician verify equipment compatibility, running and starting wattage, circuit requirements, and the battery capacity needed for your expected backup duration.
How Long Can EcoFlow TITAN 5000 Run Pool Equipment?
Battery runtime depends on the combined electrical load. For illustration, the following estimates use approximately 4,265Wh of usable energy, calculated as 85% of the unit's 5,017.6Wh battery capacity (nominally 5kWh).
Example equipment | Assumed running load | Estimated runtime |
Pool circulation pump | 1,000W | 4.3 hours |
Pool heat pump | 4,000W | 1.1 hours |
Calculation:
Usable battery capacity (Wh) ÷ Equipment load (W) = Estimated runtime.
5,017.6Wh × 85% = 4,265Wh
These figures are estimates, not guaranteed operating times. The wattages are placeholders rather than verified specifications for a particular pool pump or heat pump. Actual starting demand, conversion losses, operating conditions, and simultaneous loads can change runtime.
A high-power electric resistance pool heater should not be assumed compatible with this arrangement. Similarly, this system should not be treated as a promise of all-day pool heating. If you are preparing for an outage, plan ahead for essential household equipment and decide which circuits deserve backup priority. For additional guidance on selecting a suitable system, EcoFlow explains how home battery backup systems work. You can also review how to estimate home battery backup runtime before deciding how much storage you need.
Pool Heating Costs: What Affects Your Bill
The cost of heating a swimming pool depends on several factors, including your local climate, desired water temperature, heater type, and how often you use the pool. A pool cover can make a noticeable difference because it reduces the amount of heat your system needs to replace.
How Much Can a Pool Cover Save?
The Florida Solar Energy Center at the University of Central Florida explains that pool covers reduce heat loss and can reduce the solar collector area needed to maintain swimming temperatures. The comparison below describes heat retention rather than quoting a fixed annual bill.
Heating Setup | Effect on Heat Retention |
Without a pool cover | More heat escapes through evaporation |
With a pool cover | Less heat escapes through evaporation |
Actual heating costs and savings vary with pool size, weather, energy prices, and usage. Reducing heat loss should come before upgrading your heater. Even an efficient heating system has to work harder when warm water continually loses heat.
Heat Pump Efficiency Compared With Other Systems
Separate equipment efficiency from operating cost. AHRI explains coefficient of performance (COP) as the ratio of heat output to energy input. For illustration, a heat pump operating at a COP of 5 delivers five units of heat for each unit of electricity consumed. This does not establish a fixed dollar saving against a gas heater. Actual savings depend on local electricity and fuel prices, outdoor temperatures, and equipment performance.
Solar Heating and Long-Term Costs
Solar pool heating involves a higher upfront investment than a simple pool cover, but uses sunlight to supply heat. Compare current installed quotes and include pumping costs and maintenance when estimating payback. Homeowners planning how to open a swimming pool after winter can consider solar heating when deciding how to extend their swimming season and manage long-term heating expenses.
How to Size a Pool Heater
Choosing a heater with the right capacity is just as important as choosing the heating method. An undersized unit may struggle to reach your preferred temperature, while an oversized system can increase your initial installation costs. The DOE recommends sizing a pool heater according to the pool's surface area and the difference between the desired water temperature and the surrounding air temperature.
Factors That Affect Heater Size
Choosing the right pool heater size depends on several factors that influence how quickly and efficiently the water reaches your desired temperature. Consider your pool's dimensions, local weather conditions, heat loss, and heating preferences before selecting a suitable system.
Pool surface area: Larger pools have more water exposed to the surrounding air and generally require greater heating capacity to maintain the desired temperature.
Desired temperature: The greater the difference between the current water temperature and your target temperature, the more heating capacity you may need.
Outdoor temperature: Cooler outdoor conditions increase heating demand, particularly for heat pump systems that rely on warmth from the surrounding air.
Wind exposure: Strong winds increase evaporation from the pool surface, causing faster heat loss and requiring more energy to maintain water temperature.
Pool cover: Using a pool cover consistently helps reduce evaporation and heat loss, lowering the amount of heating capacity needed to maintain comfortable water temperatures.
Sizing Solar Pool Collectors
Solar pool heating systems need appropriately sized collectors. University of Central Florida guidance sizes collectors using pool surface area, location, swimming season, and whether the pool is screened and covered. A single percentage is not suitable for every installation, so ask a pool professional to calculate the collector area for your conditions. Homeowners exploring how to build a DIY small pool on a budget should also consider available installation space and future heating requirements.
Before choosing a system:
Measure the pool's surface area to estimate how much solar collector space you may need.
Decide your preferred swimming temperature to determine the amount of heat the system must provide.
Consider local sunlight and nighttime temperatures because both affect solar heat collection and overnight heat loss.
Account for wind exposure and available installation space when planning where to position the collectors.
Ask a pool professional to calculate the required heating capacity and recommend a suitable collector size.
Heating a swimming pool efficiently starts with reducing heat loss through a pool cover and choosing the right heater for your needs. Solar heaters, heat pumps, and gas heaters offer different benefits depending on climate, budget, and usage. Check your pool's surface area and get professional sizing advice before purchasing. If you need backup power for compatible heat pumps and circulation pump circuits, consider the EcoFlow TITAN 5000 with an electrician-installed Smart Home Panel 10.
What is the cheapest way to heat a pool?
Using a pool cover is generally the cheapest first step because it reduces heat loss and evaporation. Solar pool heaters are another cost-effective option in sunny climates because they have low operating expenses.
How efficient are pool heat pumps?
According to the DOE, pool heat pumps typically have COP ratings between 3.0 and 7.0. This means they can deliver three to seven units of heat for each unit of electricity consumed under the relevant operating conditions.
Do pool heat pumps work in cold weather?
Pool heat pumps generally work efficiently when outdoor temperatures remain above approximately 45°F to 50°F. Their heating performance decreases as temperatures fall, so check the manufacturer's operating specifications.
How much does a solar pool heater cost?
Get current local quotes for the collectors, controls, plumbing, and installation. Costs and payback vary with the required collector area, installation conditions, local energy prices, and the heating system being replaced.
Can a home battery run a pool heater?
A properly configured home battery system may support a compatible electric pool heat pump and circulation pump. However, the electrician must verify running watts, starting watts, voltage, and total load. High-power resistance heaters should not be assumed compatible.
