Gas vs Wood Fireplace: Which Is Better for Heat, Cost, and Convenience?
A gas fireplace and a wood-burning fireplace can both make your home feel warm and inviting. But they offer very different experiences. Wood fireplaces require hauling, stacking, and storing firewood. They also need regular chimney cleaning. Gas fireplaces are easier to operate and generally produce fewer indoor and outdoor pollutants. However, some models depend on electricity for ignition, fans, or electronic controls. This guide compares gas vs wood fireplaces across installation, fuel costs, heating efficiency, maintenance, and air quality. You'll also learn which fireplaces work during a power outage.
Gas vs Wood Fireplace: Side-by-Side Comparison
The right choice depends on how you plan to use it. Wood suits people who love the ritual and have seasoned firewood ready. Gas suits those who want instant heat at the push of a button.
Factor | Gas Fireplace | Wood Fireplace |
Primary Fuel | Natural gas or liquid propane | Cured, seasoned firewood |
Start-Up Method | Wall switch, remote, or thermostat | Kindling, fire starters, and manual tending |
Heat Efficiency | Varies by model; compare tested overall heating efficiency | Low for open masonry fireplaces; much heat escapes up the chimney |
Routine Upkeep | Annual checkup and glass cleaning | Routine ash cleanout; annual chimney sweep |
Venting Needs | Direct vent pipe or vent-free | Traditional masonry or class-A metal chimney |
Electricity Use | Depends on model (blowers, IPI ignition) | None required for standard open models |
Indoor Air Quality | Low particulate emissions | High particulate emissions if draft is weak |
Everyday Operation and Convenience
Lighting a fire should not feel like an unwanted chore after work.
Gas setups: Turn on via a wall switch or handheld remote. Flames appear right away. You can adjust the flame height instantly. Turning it off takes a single click. There is no waiting for embers to cool before bed.
Wood setups: You have to carry split logs into the house. Next, you stack kindling and light the fire manually. You must adjust dampers and poke logs to keep it burning. You cannot walk away until the embers burn out cold.
Fuel Storage and Sourcing
Your fuel choice changes how you use your living space and yard.
Natural gas: Runs directly through underground utility pipes into your house. You get a steady supply without manual hauling.
Propane: Relies on an outdoor tank in your yard. A local delivery company refills it on a set schedule.
Firewood: Demands dedicated, dry outdoor storage. Stacks must sit off the damp ground. Wood needs six to twelve months of drying time to season properly.
The Environmental Protection Agency (EPA) points out big performance gaps through its Burn Wise program. Traditional open wood fireplaces are largely inefficient heaters. In fact, they create about 20 times the amount of air pollution of EPA-certified wood heaters. Most warm air gets pulled right up the open flue.
If you are weighing inserts, read about powering pellet stoves versus wood stoves in outages.
Whether your fireplace keeps working in an outage depends on the model. That is worth checking before winter storms hit your neighborhood.
Fireplaces in a Power Outage: Which Ones Need Electricity?
Most wood fireplaces need no power to provide basic heat. Gas fireplaces vary quite a bit across brands and designs. Millivolt models with a standing pilot light can run without power. Models with electronic ignitions or electric blowers will not work fully without outside power. You should always check your specific model before an emergency happens.
How Different Ignition Systems Behave
Fireplaces handle blackouts differently depending on how they ignite the flame.
Standing Pilot (Millivolt Systems): These use a tiny pilot flame that burns continuously. The pilot heats a small thermopile generator. This creates enough tiny millivolts to open the main gas valve. They need zero grid power to produce heat.
Intermittent Pilot Ignition (IPI): These save energy by sparking only when turned on. They need 120V household electricity or a dedicated backup battery pack. Without power, the electronic spark will not light the burner.
Electric Distribution Blowers: A fireplace blower needs a suitable electrical supply to move heated air into the room. The burner’s ability to operate without the blower depends on the model. For example, the Heat & Glo SL-5, SL-7 and SL-9 manual explains that battery backup can operate the ignition system while the fan and other 110–120V accessories remain unavailable. Follow your own model’s manual for backup-power options.
If your gas fireplace has a plug-in blower or electronic controls, it may sit cold or lose its fan when the power goes out. EcoFlow portable power stations can run a maker-approved 120V blower or controller during an outage. Many fireplaces need no power at all, so check your model before buying anything.
A fireplace blower or a small controller draws modest power. A 1kWh unit can bridge a short outage for a verified 120V plug-in accessory.
Longer outages call for more stored energy. If the same fireplace accessories need to operate for additional hours, a 2kWh power station provides more capacity.
How the two products divide the job
EcoFlow DELTA 3 Classic (1024 Wh): This unit can run a maker-approved 120V fireplace blower or electronic controller for a limited period. The 100W example below estimates about 8.7 hours; check the actual accessory load before planning.
EcoFlow DELTA 3 Max (2048 Wh): This station provides more stored energy for the same maker-approved 120V accessories. The 100W example below estimates about 17 hours. Outages that exceed the battery reserve require a practical recharging plan.
Estimated Runtime for Fireplace Accessories
The following examples show how battery capacity affects runtime. These are estimates, not guaranteed operating times.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3 Max (1,741Wh usable est.) |
Fireplace blower | about 100W | about 8.7 hours | about 17 hours |
Blower, lamp, and phone | about 130W | about 6.7 hours | about 13 hours |
Calculation method:
Usable battery capacity ÷ device wattage = estimated runtime.
For these examples, usable capacity assumes 85% of the rated battery capacity:
EcoFlow DELTA 3 Classic: 1,024Wh × 0.85 = approximately 870Wh.
EcoFlow DELTA 3 Max: 2,048Wh × 0.85 = approximately 1,741Wh.
Note: All runtimes shown above are estimates. Always check the electrical data label on your blower motor before planning emergency usage.
Plan backup power around your fireplace’s maker-approved accessories and their actual wattage. Now let us look closer at heat delivery, efficiency, and household air quality.
Heat, Efficiency, and Air Quality
Open wood fireplaces lose a lot of heat up the chimney. Inserts and certified stoves do far better. Gas units are cleaner to burn inside the home.
Heat Loss and Heating Efficiency
How much heat stays in the room varies sharply by fireplace design.
Open masonry fireplaces: These draw warm room air up the chimney, while outdoor air can enter elsewhere in the house. The EPA describes open fireplaces as inefficient home heaters.
Direct-vent gas units: These use sealed combustion, taking combustion air from outdoors and venting exhaust outdoors. Heating efficiency varies by model and test method, so ask the manufacturer for the specific unit’s tested overall heating efficiency before comparing it with another appliance.
EPA-certified wood inserts and stoves: Inserts enclose an existing open hearth. For wood stoves, EPA reports that newer certified models can be up to 50% more efficient and use one-third less wood for the same heat when replacing older wood stoves.
Indoor Air Quality and Emissions
Smoke particles and fuel byproducts can harm sensitive lungs.
Wood combustion smoke: Wood smoke contains tiny particulate matter ($$PM_{2.5$$). It carries benzene, formaldehyde, and other hydrocarbons. A drafting chimney reduces indoor smoke, but opening the screen lets fine ash into living areas.
Gas combustion byproducts: Natural gas burns much cleaner than cordwood. Direct-vent gas systems exhaust all combustion byproducts directly outdoors through sealed pipes.
Vent-free gas considerations: Vent-free fireplaces release all exhaust into your living space. They emit water vapor and trace nitrogen dioxide ($$NO_2$$). Many municipalities ban vent-free units outright. Always check local mechanical codes before buying one.
Any fireplace makes monitoring carbon monoxide indoors important for family safety. The Centers for Disease Control and Prevention (CDC) advises homeowners to install battery-operated or battery backup carbon monoxide detectors. Place them on every floor and outside all sleeping areas.
So which fireplace style should you pick for your home?
Which Fireplace Is Right for You?
Choose wood if you enjoy the traditional experience and want a heating option that doesn't depend on household electricity. Choose gas if convenience, adjustable heat, and easier maintenance matter more. Your home's existing setup should also influence the decision.
Choose a Wood Fireplace If...
A wood fireplace makes sense when you enjoy the process of building and maintaining a fire.
It's worth considering if:
You have affordable access to seasoned firewood.
Your home already has a suitable chimney.
You enjoy natural flames and crackling sounds.
You want a heat source that doesn't require electricity.
You're comfortable with ash removal and chimney maintenance.
Wood can also be useful during winter storms when the power stays out for several hours or days. However, you'll still need a safe, properly maintained fireplace and enough dry firewood.
Choose a Gas Fireplace If...
A gas fireplace is a better fit for homeowners who prefer simple operation.
Consider gas if:
You want heat without preparing firewood.
Your home already has a natural gas connection.
You prefer adjustable flame settings.
You don't want frequent ash cleanup.
You want a cleaner-burning alternative to an open wood fireplace.
Remember that gas fireplaces aren't all identical. Some operate without electricity, while others need power for ignition or accessories.
Questions to Ask Before Buying
Before choosing either option, think about how you'll actually use your fireplace.
How often will you use it? Occasional ambiance may not justify an expensive installation.
Is fuel readily available? Compare local natural gas, propane, and firewood availability.
Is your chimney in good condition? Repairs can change your installation budget.
Are local burn restrictions in place? Some areas restrict wood burning during poor air-quality conditions.
Will you need backup power? Check ignition and blower requirements before purchasing accessories.
Is it your primary heat source? Make sure the appliance is appropriately rated for the room.
A fireplace can be one of several budget ways to stay warm in winter when heating bills rise.
A gas vs wood fireplace choice comes down to fuel, convenience, upkeep, and air quality. Open wood fireplaces create classic ambiance, but EPA data shows they are inefficient and polluting compared with sealed units. Gas units give you instant heat and clean burning with very little daily maintenance.
Before winter arrives, check whether your fireplace model needs outside electricity to run. Always install working carbon monoxide alarms near your living spaces, and schedule yearly safety inspections.
If your gas fireplace has a maker-approved 120V plug-in blower or electronic controller, plan backup power around its actual wattage. The EcoFlow DELTA 3 Classic provides a smaller reserve, while the EcoFlow DELTA 3 Max provides more stored energy. Estimate runtime for your load and arrange recharging if an outage lasts longer than that reserve.
Is a gas or wood fireplace better?
Gas is generally better for convenience, easier maintenance, and cleaner combustion. Wood is better for homeowners who enjoy traditional fires and want a heating option that doesn't usually require electricity. Your heating needs and existing installation also matter.
Does a gas fireplace work without electricity?
Many millivolt models with a standing pilot light work without grid power. Units with electronic ignition or electric room blowers often need outside power. Always consult your owner's manual.
Which gives more heat, gas or wood?
It depends on the fireplace design and efficiency. Open wood fireplaces lose significant heat through the chimney. Gas fireplaces often provide more controllable heat. EPA-certified wood stoves and inserts can also deliver much better heating performance than traditional open fireplaces.
Is a wood fireplace bad for air quality?
Traditional wood fireplaces release smoke and fine particles that affect indoor and outdoor air quality. The EPA reports that open fireplaces produce significantly more pollution than EPA-certified wood heaters. Burning dry, seasoned wood and maintaining your chimney can help reduce emissions.
Do I need a power station for my fireplace?
You only need a power station if your fireplace has a 120V plug-in blower or electronic control module. Units with manual pilot lights need no electricity at all.
