How to Keep an Apartment Cool: Shade, Fans, AC, and Outage Tips for Renters
Apartments can heat up fast. Top floors catch rising heat from downstairs units. West-facing windows bake in the afternoon sun. Many leases limit what you can actually install. Still, there is plenty you can do without breaking lease rules. Blocking direct sunlight helps tremendously. Moving indoor air the right way makes a huge difference. Using a window or portable AC unit wisely keeps costs down. This guide covers how to keep an apartment cool using renter-friendly steps backed by DOE and CDC guidance. You will also learn how to stay cool safely when a summer blackout cuts grid power completely.
How to Keep an Apartment Cool Without Major Changes
The best way to keep an apartment cool starts with keeping heat outside. Then, focus on moving air through your living space. A few inexpensive changes can make hot afternoons much more comfortable.
Block Direct Sunlight Before It Heats Your Apartment
Windows let natural light in, but they also bring unwanted heat. This becomes especially noticeable in west-facing apartments during summer afternoons.
Try these simple changes:
  • Close blinds early: Shut blinds and curtains before direct sunlight reaches your windows. Don't wait until the room feels hot.
  • Choose lighter window coverings: Light-colored curtains and reflective shades help reduce solar heat gain. Check your lease before installing window film or other coverings.
  • Use removable window film: Static-cling films can reduce glare and sunlight without permanent changes. Choose products suitable for your window type.
  • Keep unused rooms shaded: Close curtains in rooms that receive direct sunlight, even when nobody is using them.
Blackout curtains can also help bedrooms stay darker and more comfortable. They work especially well on windows that receive strong afternoon sunlight.
Block sunlightBlock sunlight
Reduce Heat From Everyday Appliances
Your apartment's appliances can add more heat than you might expect. Cooking, laundry, and electronics all contribute to indoor temperatures.
A few changes can help:
  • Use a microwave, slow cooker, or air fryer instead of your oven during hot afternoons.
  • Run the dishwasher and dryer later in the evening.
  • Switch frequently used bulbs to energy-efficient LEDs.
  • Turn off televisions, gaming systems, and computers when nobody needs them.
  • Avoid running several heat-producing appliances together.
If your apartment has a balcony, consider drying clothes outside when building rules allow it.
Renters can also save electricity without changing their apartments. Try these no-renovation apartment electricity hacks to reduce unnecessary energy use during summer.
Use Ceiling Fans and Window Fans Correctly
Fans help you feel cooler by moving air across your skin. They create a wind-chill effect, but they don't actually lower the room's temperature.
The U.S. Department of Energy recommends using ceiling fans to improve comfort. You can raise your thermostat about 4°F without reducing comfort.
Here's how to use different fans effectively:
Ceiling fans
  • Set the blades to rotate counterclockwise during summer.
  • Use a comfortable speed to move air downward.
  • Turn fans off when you leave the room.
  • Raise your AC thermostat slightly when using a ceiling fan.
Window fans
Window fans can help remove hot indoor air, especially during cooler evenings.
  1. Place one fan in a window facing outward.
  2. Close nearby windows in the same room.
  3. Open windows in distant rooms to provide replacement air.
  4. Let the fan exhaust warm indoor air outside.
This arrangement helps create a path for cooler outdoor air to enter your apartment.
However, check outdoor conditions before opening windows. Avoid bringing in smoke, excessive humidity, or polluted air.
Take Advantage of Cooler Evening Air
Outdoor temperatures often drop after sunset. Use those cooler hours to release heat trapped inside your apartment.
  • Open suitable windows when outdoor air becomes cooler than indoor air.
  • Use window fans to move warm air outside.
  • Keep interior doors open to improve airflow.
  • Close windows again when outdoor temperatures begin rising.
This simple routine can make a noticeable difference without adding another appliance to your electricity bill.
When a sudden summer outage hits, your AC and fans stop instantly. Having a basic backup cooling plan is essential.
Staying Cool During a Summer Outage
A power outage on a sweltering afternoon can turn a brick apartment into an oven within hours. A portable power station can run fans and phones to maintain airflow and communication. A larger backup unit can even run a verified window or portable AC for a short time.
Heat safety always comes first during a blackout. Focus on shading windows and cross-ventilation before relying on battery reserves. Reserve battery power for fans, personal hydration setups, and essential medical gear. If you plan to power an air conditioner, check compressor startup surge and lease restrictions beforehand.
In a summer outage, an apartment can heat up within hours. EcoFlow portable power stations keep fans and phones going, and a larger unit can run a verified window AC for a short stretch. They don't cool anything themselves, and heat safety still comes first.
Fans and phones are relatively light electrical loads. A 1kWh portable power station can support these essentials for extended periods, depending on actual consumption. The EcoFlow DELTA 3 Classic offers 1024Wh battery capacity. It provides a practical backup option for apartment renters who mainly need to power smaller devices.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
A window AC compressor is a much bigger load. A 2kWh unit can start and run a verified 120V window AC for a limited time. Check the label first.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3,000W Output: 6,000W surge. X-Boost mode can run some appliances up to 3,800W, though results vary by device. • Fast Recharging: 5 ways to charge, reaching 0 to 80% in 43 minutes with generator charging. • 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
How the products divide the job
Choosing the right power station depends directly on what cooling equipment you need during an emergency.
  • EcoFlow DELTA 3 Classic: Best for running circulating fans, box fans, bedside clip fans, smartphones, and emergency LED lights.
  • EcoFlow DELTA 3 Max Plus: Best for short runs of a verified 120V window or portable AC to pull peak heat out of a bedroom.
Estimated Runtime for Common Apartment Devices
The following examples use estimated usable battery capacities. Actual results will vary with device consumption and operating conditions.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max Plus (1,741Wh usable est.)
Box fan and phone charging
70W
About 12 hours
About 25 hours
Window AC, cycling
500W average
About 1.7 hours
About 3.5 hours
Calculation method: Usable battery capacity (Wh) ÷ appliance load (W) = estimated runtime.
These estimates assume 870Wh of usable capacity for the EcoFlow DELTA 3 Classic and 1,741Wh for the EcoFlow DELTA 3 Max Plus.
Critical Power Station Safety Guidelines
Portable power stations store electricity safely in lithium battery cells. However, you must handle them responsibly:
  • No direct central AC connection with these two models: The EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max Plus models recommended here provide 120V AC output and cannot directly power a 240V central air-conditioning system.
  • No backfeeding: Never connect a power station to a wall outlet with a double-male cord. The CPSC warns that male-to-male cords can expose live prongs and cause electrocution or fire. For the loads described here, use the power station’s AC outlets directly and follow both manufacturers’ instructions.
  • Direct connection only: Plug your fan or verified 120V air conditioner directly into the power station's AC faceplate.
  • No all-night AC promises: Do not count on running an air conditioner continuously overnight on battery power alone. Use AC power in short bursts to drop the room temperature before sleeping.
  • Mind the heat exhaust: Portable and window AC units exhaust massive amounts of heat outdoors. Make sure window foam seals remain tight so heat cannot re-enter.
Plan ahead for staying safe in a heat wave outage by keeping your power stations charged before storms arrive.
Back to everyday cooling: here is how to pick and use AC wisely in rental units.
Renter-Friendly AC Options
Window units usually cool better and use less power than portable ACs. Portable floor units do not hang outside, but they still require a dedicated window exhaust vent. Check your lease agreement thoroughly before buying either style.
Renter-friendly AC optionsRenter-friendly AC options
Window Air Conditioners
Window AC units are popular for cooling individual rooms.
They remove heat from indoor air and release it outside. This makes them effective for bedrooms, living rooms, and other enclosed spaces.
Advantages:
  • Generally efficient for their cooling capacity.
  • Often cost less than comparable portable units.
  • Don't take up floor space.
  • Can cool a room relatively quickly when properly sized.
Disadvantages:
  • Require suitable window installation.
  • May need landlord approval.
  • Can block natural light.
  • Need proper support and secure installation.
Before purchasing one, check your lease and building requirements. Some apartment buildings prohibit window-mounted equipment.
Portable Air Conditioners
Portable AC units sit inside your apartment and release hot air through an exhaust hose.
Most models use a window kit to direct hot air outside. This makes them useful when traditional window units aren't permitted.
Advantages:
  • Easier to move between rooms.
  • No permanent window installation.
  • Suitable for apartments with certain window restrictions.
  • Can be stored when summer ends.
Disadvantages:
  • Take up valuable floor space.
  • Need a suitable exhaust opening.
  • Can be noisier than window units.
  • May use more electricity than comparable window models.
Optimize Your AC Settings and Airflow
Getting the most cooling out of your air conditioner comes down to air circulation and proper thermostat targets:
  1. Pair AC with a ceiling fan: The DOE reports you can raise your thermostat setting about 4°F with zero loss in personal comfort when running a ceiling fan simultaneously.
  2. Size the AC correctly: Match the unit's British Thermal Units (BTU) rating to your exact square footage. An undersized unit runs nonstop without cooling. An oversized unit cools too fast without removing sticky humidity.
  3. Insulate window installation gaps: Use high-density foam strips around sliding window panels. Air leaks let humid outdoor heat seep straight back into your living room.
  4. Clean mesh filters bi-weekly: Clogged, dusty filters choke airflow across the evaporator coil. Clean filters increase airflow and lower monthly utility bills.
  5. Review lease guidelines: Some property managers prohibit window-mounted units due to building exterior rules or liability concerns. Always ask your property manager in writing first.
Before buying, compare portable AC versus window AC to ensure you pick the right model for your apartment's layout.
Finally, know when indoor heat reaches dangerous levels.
Heat Safety in Apartments
Electric fans alone cannot protect your body against extreme, prolonged heat. Learn the physical warning signs of heat exhaustion and heat stroke. Relocate to an air-conditioned public facility if indoor living conditions become unsafe.
The Centers for Disease Control and Prevention (CDC) provides clear safety rules for indoor fan use:
"Use fans, but only if indoor temperatures are less than 90°F."
Follow the CDC’s indoor-temperature limit above. If your apartment is becoming unsafe, move to an air-conditioned location instead of relying on fans alone.
Heat safety in apartmentsHeat safety in apartments
Recognize Heat-Related Illnesses
Keep a watchful eye on family members, roommates, and indoor pets when temperatures soar.
  • Heat Exhaustion symptoms: Heavy sweating, cold or clammy skin, fast weak pulse, muscle cramps, dizziness, nausea, and headache. Move the person to a cooler room immediately, apply wet clothes, and sip water.
  • Heat Stroke symptoms: High body temperature above 103°F, hot red dry skin, rapid strong pulse, confusion, dizziness, and loss of consciousness. Heat stroke is a medical emergency. Call 911 right away and take immediate action to cool the person down.
Community Safety Steps
  • Check on vulnerable neighbors: Knock on doors to check on elderly neighbors and residents with limited mobility living on upper floors.
  • Find designated cooling centers: Cities and county health departments open air-conditioned libraries, recreation centers, and community halls during severe heat alerts. Call 211 or visit your local municipal website to locate your nearest public cooling site.
  • Hydrate frequently: Drink plenty of cool water throughout the day. Avoid sugary soda, energy drinks, and alcohol because they accelerate fluid loss.
Read up on protecting loved ones in a heat wave to stay prepared when temperatures spike.
Keeping an apartment cool requires a smart, multi-layered approach. Block direct sunlight using light-colored curtains and reflective films. Use ceiling fans while rooms are occupied, and place window fans to exhaust hot air. Size your window or portable AC correctly, and follow the CDC guideline to stop using electric fans when indoor temperatures reach 90°F or higher. Take simple steps today: close your blinds, clear window vents, check your lease rules, and know where local cooling shelters operate.
For unexpected summer power outages, portable backup power can keep basic cooling gear running for a limited time. The EcoFlow DELTA 3 Classic can power box fans and phones, while the EcoFlow DELTA 3 Max Plus can support a short run of a verified 120V window AC. Use the actual load to estimate runtime; the 500W example above is about 3.5 hours for the Max Plus.
How can I keep my apartment cool without AC?
Block direct sunshine using thermal curtains or reflective window film. Set up box fans facing outward in windows to exhaust hot air during the evening. Open distant windows to pull cooler outside air across your home. Run ceiling fans counterclockwise while you are in the room, and avoid using your oven during peak afternoon hours.
Do fans cool a room?
No, fans do not lower ambient room temperatures. Fans create a wind-chill effect across exposed skin, which helps your body evaporate sweat more efficiently. Because fans cool people rather than spaces, you should always switch them off when leaving a room to conserve energy.
When are fans not enough?
The CDC advises using fans only when indoor temperatures are below 90°F. At 90°F or higher, do not rely on fans alone. Take a cool shower, drink water, and seek an air-conditioned location if your home is unsafe.
Can I put a window AC in my apartment?
Always check your lease agreement and building association bylaws first. Some landlords ban window-mounted air conditioners due to exterior facade aesthetics or falling hazards. If window units are prohibited, a portable floor air conditioner with an adjustable sliding window exhaust kit is usually permitted.
Can a power station run an air conditioner?
A suitable portable power station can run a verified 120V window or portable air conditioner for a limited time. Check that both running wattage and compressor startup surge fit its rated output. The two 120V models recommended here cannot directly power a 240V central air-conditioning system.
Home Solutions
