AC Alternatives: Fans, Evaporative Coolers, Shade, and Ventilation Compared
Air conditioning works, but it can raise your electric bill, and some homes and rentals don't have it. Several AC alternatives can help you stay comfortable, depending on where you live and how hot it gets. Fans cool people, evaporative coolers can lower air temperatures in dry climates, and shade and ventilation help keep indoor spaces from heating up. Each option has limits, especially during a heat wave. This guide compares common alternatives, explains how to use them during a power outage, and covers when you need a cooler place to stay.
Best AC Alternatives and Where They Work
The right cooling method depends on your local humidity, outdoor temperature, and home layout. Fans work in most homes, while evaporative coolers need dry air to work well. Shading and ventilation can also help reduce indoor heat.
Compare common alternatives to air conditioning
Option | Works best | DOE note |
Ceiling and room fans | Most homes | Create a wind chill effect; turn off when you leave a room |
Window fans | Cool evenings | Exhaust hot air; open windows in distant rooms |
Evaporative cooler | Dry climates | "Only suitable for areas with low humidity" |
Shading and insulation | All homes | Keeps heat out |
Fans: A practical option for most homes
Ceiling fans and portable room fans move air around you. That airflow helps sweat evaporate from your skin, making you feel cooler. Fans don't lower the room's temperature, but they can make a warm room more comfortable. You can use a ceiling fan in bedrooms, living rooms, and other spaces where people spend time. A portable fan works well when you need airflow in one spot, such as beside a desk or bed. Turn fans off when you leave the room because they cool people, not empty spaces. Fan electricity use varies by size and speed. Check how much electricity a fan uses before choosing one for regular use or battery backup.
Window fans: Use cooler outdoor air
A window fan can help when outdoor air is cooler than the air inside your home, often in the evening or early morning. Set one fan to exhaust warm indoor air through a window. Open another window on the opposite side of the home so cooler air can enter. This setup works best when you have windows on different sides of the house. Keep windows closed when outdoor air is hotter than indoor air, or when smoke, poor air quality, or high humidity makes ventilation a bad choice.
Evaporative coolers: Best for dry climates
Evaporative coolers pull warm air through water-soaked pads. As the water evaporates, it cools the air before the unit blows it into the room. The U.S. The Department of Energy (DOE) says these coolers are suitable only for areas with low humidity.
They can use about one-quarter as much energy as central air conditioning and cost about half as much to install, according to the DOE. But they continually use water, and their performance drops when humidity rises. A cooler that works well in a dry part of the Southwest may not be a good choice in a humid coastal area. Before buying one, check:
The humidity levels in your area.
The unit's water supply and refill requirements.
Its electrical load and starting wattage.
Whether you can provide enough ventilation for the added indoor moisture.
Read the DOE Building America Solution Center guide to evaporative cooling systems before choosing a model.
Shade and insulation: Keep heat out
Blocking sunlight can reduce the heat that enters your home. Close blinds or curtains on sun-facing windows during the hottest part of the day. Exterior awnings, shade trees, and properly fitted window coverings can also reduce direct solar heat. Insulation and air sealing help limit heat transfer through the attic, walls, doors, and windows. These changes won't cool a room on their own, but they can slow down how quickly it heats up.
Running AC alternatives during a power outage
When the power goes out during hot weather, close blinds during the day and open windows when outdoor air is cooler. Battery-powered fans can improve airflow, while small evaporative coolers may help in dry climates. EcoFlow portable power stations can run selected cooling equipment: the EcoFlow DELTA 3 Classic suits a personal fan and phone charging, while the EcoFlow DELTA 3 Max offers more capacity for several fans or a compatible evaporative cooler. Check wattage, starting requirements, and runtime before connecting equipment, and move to an air-conditioned location if indoor temperatures become unsafe.
EcoFlow DELTA 3 Classic for a personal fan and phone
A personal fan and phone charger are relatively small loads. With its 1,024Wh battery, the EcoFlow DELTA 3 Classic can power both during an outage. Actual runtime depends on the devices' power use and how long you need them running.
EcoFlow DELTA 3 Max for several fans or a small cooler
For a larger setup, the EcoFlow DELTA 3 Max offers 2,048Wh of battery capacity. It can support several room fans or a compatible plug-in evaporative cooler, provided the combined load stays within its output limits. Check the cooler's starting wattage, water requirements, and suitability for your local humidity before connecting it.
How the products divide the job
The EcoFlow DELTA 3 Classic suits a smaller setup with a personal fan and phone charging. The EcoFlow DELTA 3 Max has more capacity for several room fans or a compatible plug-in evaporative cooler in a dry climate. The table below estimates how long each unit could run common cooling loads. It uses example wattages, so check your equipment labels before relying on these figures.
Estimated runtimes using hypothetical loads:
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3 Max (1,741Wh usable est.) |
Personal fan (assumed 40W) + phone charging (assumed 10W) | about 50W | about 17 hours | about 35 hours |
Three room fans (assumed 150W total) | about 150W | about 5.8 hours | about 12 hours |
Small evaporative cooler (assumed 200W) | about 200W | about 4.3 hours | about 8.7 hours |
These are estimates based on 85% usable battery capacity. Actual runtime depends on the equipment's power draw, settings, and battery conditions. The wattages are examples and should be replaced with the figures on your devices' labels. Runtime is only one part of outage planning. Consider how long the power may be out and when you can recharge your battery. Follow a homeowner's heat wave outage plan so you have other ways to stay safe if indoor temperatures become dangerous. Once you've planned for an outage, a few everyday habits can help you get more from these cooling options.
Tips to Get More From AC Alternatives
A few changes around the house can make fans and other cooling methods more useful. Focus on blocking direct sunlight, moving air at the right time, and keeping cooling equipment in good condition.
Combine shade and ventilation
Close blinds or curtains on sunny windows during the day. If outdoor temperatures drop below indoor temperatures at night, open windows to let cooler air in. Window fans can help move warm air out, but avoid bringing in smoke or polluted air. If you use a ceiling fan, set it to create a downward airflow during warm weather. You can also raise your thermostat by about 4°F without reducing comfort when you use ceiling fans alongside air conditioning, according to the DOE. For more details, see whether ceiling fans use much electricity.
Maintain evaporative coolers
Dust and mineral buildup can affect an evaporative cooler's performance. The DOE recommends checking the pads, filters, water reservoir, and pump regularly during hot weather. In hot climates, replace the pads at least twice during the cooling season. Disconnect the unit from power before servicing it. Follow the manufacturer's instructions for cleaning and replacing parts.
When AC Alternatives Aren't Enough
Fans, shade, and ventilation can help you stay comfortable, but they have limits during extreme heat. The CDC advises using fans only when indoor temperatures are below 90°F. Above that, a fan may not protect you from heat-related illness. Watch for signs of heat exhaustion, such as heavy sweating, weakness, dizziness, nausea, and headaches.
If your home gets too hot, go to a cool place with air conditioning or a local cooling center. Check on older neighbors and those with health conditions who might need help staying cool. Don't have fans or battery-powered coolers as your only heat safety plan. Review heat safety guidance and follow advice from your local health department.
The best AC alternatives vary by climate and how hot your home gets. Fans work in most settings; evaporative coolers work in dry areas; and shade and ventilation can reduce indoor heat. When conditions are right, combine these methods. And use CDC's guidance on the use of fans indoors when it's less than 90°F. The EcoFlow DELTA 3 Classic can power a personal fan and charge a phone during an outage. The EcoFlow DELTA 3 Max can power a few fans or a compatible evaporative cooler. Check your equipment's wattage and plan for recharging before an outage.
What is the best alternative to air conditioning?
The best choice depends on your local climate, humidity, and home layout. Ceiling and room fans help move air across your skin in most homes. Evaporative coolers work better in dry climates. You can also close blinds during sunny hours and improve ventilation when outdoor air is cooler.
Do evaporative coolers work in humid areas?
Evaporative coolers work best in low humidity areas. They draw incoming air through pads soaked in water to cool the air and add moisture. When humidity is already high, evaporation slows down, and the cooler becomes less effective.
How much energy does an evaporative cooler use?
The U.S. Department of Energy says evaporative coolers use about one-fourth of the energy of central air conditioning. This may make them a consideration for households in dry climates who want to reduce cooling energy use. Actual consumption depends on the unit's size, settings, and operating time.
Do fans cool a room?
Fans don't reduce the temperature of the air in a room. Instead, they blow air across your skin to help sweat evaporate and make you feel cooler. Turn them off when you leave because they don't provide a cooling benefit in an empty room.
When should I stop relying on fans?
The CDC advises using fans only when indoor temperatures are below 90°F. Above that temperature, fans may not protect you from heat-related illness. Move to an air-conditioned location if your home gets too hot, and check on older adults and others who may be more vulnerable to extreme heat.
