Servicing a Gas Furnace: What a Tune-Up Includes, How Often to Book One, and What You Can Do Yourself
A gas furnace can run for years without showing obvious signs of trouble. That makes it easy to put off maintenance until something stops working. But a neglected furnace can waste fuel, cycle on and off too often, or develop problems with combustion and venting. ENERGY STAR recommends having a contractor check your heating system every fall, before the heating season begins. This guide covers what servicing a gas furnace involves, how often to schedule it, and which maintenance tasks you can handle yourself.
How Often Should a Gas Furnace Be Serviced?
Schedule a professional gas furnace inspection once a year, ideally in the fall. ENERGY STAR recommends a pre-season checkup by a qualified contractor before you start relying on your heating system. The same schedule applies to propane furnaces. An annual visit gives a technician time to check the system before colder weather puts it under heavier demand. It can also help catch problems that aren't obvious during normal operation. Book a service visit sooner if you notice any of these changes:
The furnace makes new banging, rattling, or unusual operating noises.
It starts and stops more often than usual.
The burner flame looks yellow instead of blue.
Your home doesn't heat evenly, or the furnace struggles to reach the thermostat setting.
You notice water around a high-efficiency furnace.
These signs don't point to one specific fault, so don't try to diagnose the gas or combustion system yourself. Have a qualified technician inspect it.
What about propane furnaces?
A propane furnace also needs an annual inspection before the heating season. The fuel source changes, but the system still relies on burners, gas connections, combustion, and proper venting. Ask your contractor to check the equipment according to the manufacturer's service requirements. Fall maintenance is also a good time to review your backup plan. Knowing what happens to a gas furnace without electricity can help you prepare for a winter storm or utility outage. Even if the furnace runs on natural gas or propane, its electrical components may still need power.
Keeping Lights and Phones On During Furnace Service
A technician may need to shut off the furnace circuit before starting work. If the furnace is in a basement or crawl space, that can leave the work area without enough light. A separate power source can keep a work light, phones, and Wi-Fi running while the furnace is out of service. An EcoFlow portable power station provides indoor backup power without producing exhaust fumes. You can use it to run small devices during the appointment while the technician handles the furnace. Keep the unit in a dry, well-ventilated spot, and make sure the furnace is properly isolated before work begins.
EcoFlow DELTA 3 Classic for work lights and communication
A work light, router, and phone chargers draw relatively little power. The EcoFlow DELTA 3 Classic has a 1,024Wh battery and 1,800W AC output, making it a practical option for these temporary needs. At about 27 lb, it's also manageable to carry down basement stairs. Use the power station only to support devices. Never connect it to a furnace that's being serviced or has a suspected fault. Gas and electrical work should remain with a qualified technician.
Estimated runtime for small devices
The EcoFlow DELTA 3 Classic can run a work light, router, and two phones during a furnace service visit. Using an estimated combined load of 50W, the battery could provide about 17 hours of runtime.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) |
LED work light + router + two phones (placeholders 20W + 10W + 20W) | about 50W | about 17 hours |
This estimate uses 870Wh of usable battery capacity (85% of 1,024Wh) divided by a 50W load. Actual runtime will vary depending on the devices and their power consumption. A furnace service visit is also a good time to review your home's outage plan. See our guide to preparing for a winter power outage before the next storm arrives. With the work area lit, the technician can move on to the furnace inspection. Here's what a standard tune-up covers.
What a Gas Furnace Tune-Up Includes
A professional tune-up checks the parts that affect safe combustion and reliable operation. ENERGY STAR recommends having a contractor inspect gas connections, gas pressure, burner combustion, and the heat exchanger. Ask for a written service checklist so you know what the technician inspected and whether anything needs attention.
Gas connections and pressure
The technician checks the gas connections and makes sure the pressure meets the furnace manufacturer's specifications. Loose or damaged connections can create safety risks. Incorrect gas pressure can also affect burner performance. Don't try to adjust gas pressure or repair a connection yourself. Leave that work to a qualified professional.
Burners, ignition, and flame
The burner and ignition system need to operate as intended for the furnace to heat your home. A technician may inspect the burner assembly, ignition components, and flame sensor, depending on the furnace design. The contractor also checks burner combustion. A yellow or irregular flame can be a reason to investigate further, but its appearance alone doesn't confirm the cause of a problem.
Heat exchanger and venting
The heat exchanger separates the combustion gases from the air circulated through your home. The technician checks it for signs of damage or deterioration and inspects the venting system to make sure combustion gases can leave the house as intended. These checks matter for carbon monoxide safety. The hidden dangers of carbon monoxide are worth understanding because CO has no smell or color. Install working battery-operated or battery-backup CO detectors near sleeping areas and on every level of your home. Test them regularly and follow the detector manufacturer's replacement guidance.
Blower, thermostat, and drainage
A tune-up may also include checks of the blower motor, belts, thermostat, and condensate drain. The exact checks depend on your furnace model. High-efficiency furnaces produce condensate as they run. A clogged or damaged drain can cause water to collect around the unit. Before approving extra work, ask the technician to explain any worn parts, unusual readings, or recommended repairs.
DIY gas furnace maintenance: What homeowners can do
Homeowners can take care of a few basic maintenance tasks between professional visits. Keep your attention on the air side of the system. Leave gas connections, burners, combustion, and venting work to a qualified technician.
Check the air filter monthly
ENERGY STAR recommends checking, cleaning, or changing your furnace filter monthly during periods of heavy use. Before removing or replacing a filter, switch the system off and follow the furnace manufacturer’s safety and access instructions. Replace it when it's dirty, and follow the filter size and type specified for your system. A clogged filter restricts airflow and makes the furnace work harder to move air through the house. Check the filter more often if you have pets, dusty rooms, or frequent furnace use.
Keep vents and the furnace area clear
Make sure supply vents and return-air grilles aren't blocked by rugs, furniture, boxes, or curtains. Keep the space around the furnace clear too, following the clearance requirements in the owner's manual. Good airflow helps the system operate as designed and gives a technician room to work during service.
Watch for water around the unit
If you have a high-efficiency furnace, look around the base of the unit for signs of water or a blocked condensate drain. Don't take apart the drain assembly or open the furnace cabinet to investigate internal components. Contact a technician if you see a leak or recurring moisture.
Leave gas repairs to a professional
Never open burner compartments, adjust gas pressure, or attempt to repair a gas leak. If you smell gas, leave the house and call 911 from a safe location well away from the leak, then notify your gas utility. Don't operate switches or use anything that could create a spark while inside. Regular maintenance helps your heating system run properly. But it doesn't tell you which heating option makes the most sense for your home. Read our guide to gas furnace and solar heating costs to compare the two options.
Schedule a professional gas furnace tune-up every fall, before the heating season begins. The technician should check the gas connections, pressure, burner combustion, and heat exchanger. They may also inspect other components based on your furnace model. Between visits, check the air filter monthly during heavy use. Keep vents clear and test your carbon monoxide (CO) detectors regularly. If the technician needs to shut off power during service, the EcoFlow DELTA 3 Classic can keep a work light, router, and phones running. It provides temporary power for these small essentials while the furnace stays safely shut down.
How often should a gas furnace be serviced?
A gas furnace should be inspected by a qualified contractor once a year, preferably in the fall before the heating season. ENERGY STAR recommends an annual pre-season checkup for heating systems.
What does a gas furnace service include?
A professional tune-up covers the gas connections, gas pressure, burner combustion, and heat exchanger. The technician may also check the ignition system, blower, and venting. Other checks can include the thermostat and condensate drain, depending on your furnace model.
Can I service my own gas furnace?
You can handle basic tasks such as checking the air filter, replacing it when dirty, and keeping vents clear. Switch the system off before removing or replacing the filter, and follow the furnace manufacturer’s safety instructions. A qualified technician should handle gas connections, burners, combustion, venting, and repairs.
How often should I change my furnace filter?
Check the filter monthly during periods of heavy use. Replace it when dirty, following the filter type and replacement guidance for your furnace. Switch the system off before removing or replacing the filter, and follow the furnace manufacturer’s safety instructions.
Does a propane furnace need yearly service too?
Yes. A propane furnace should receive a professional inspection once a year, preferably before the heating season. The technician should follow the furnace manufacturer's maintenance requirements.
