Wyoming Wildfires: Current Fire Info, Evacuations, and How to Prepare
Wyoming wildfires can spread across grasslands, sagebrush, and forests, and the risk isn't limited to summer. If you're looking for current Wyoming wildfires, start with official incident reports and your county's emergency alerts. Social media posts can be outdated or incomplete. This guide explains where to check active fires and evacuation orders, what state records show about a typical fire year, and how to prepare your home and family. You'll also find practical ways to keep phones and radios charged while staying at a safe location.
Where to Check Current Wyoming Wildfires
For current fire information, check the Wyoming State Forestry Division and InciWeb. Your county's emergency management office and sheriff's department are the best sources for local evacuation instructions. Always check when a report was last updated before relying on it.
Where to Check Current Wyoming WildfiresWhere to Check Current Wyoming Wildfires
Official fire information and alerts
Use these sources to follow wildfire activity across Wyoming:
  • Wyoming State Forestry Division: Check the state's fire management page for incident updates, fire locations, and acreage reports.
  • InciWeb: Find information about reported incidents, including fire size, containment, closures, and updates from incident management teams.
  • National Weather Service: Check for Red Flag Warnings and other weather alerts. Dry conditions, low humidity, and strong winds can increase fire danger.
  • County emergency alerts: Sign up for notifications from the county where you live, work, or plan to travel. Local authorities issue evacuation notices and instructions.
Fire reports can change quickly. Check the incident's update time, especially if you're near the affected area. A report from yesterday may no longer reflect the fire's location or evacuation status.
Where to find Wyoming evacuation orders
County sheriffs and emergency managers issue local evacuation instructions. Follow their directions immediately if they tell you to leave. Don't wait for a fire to become visible or for another update to confirm the danger. Keep a wildfire evacuation checklist ready before fire season. It should cover essential documents, medication, chargers, clothing, pets, and the people you'll contact after leaving. When a fire is nearby, staying informed matters. You'll need charged phones and radios to receive alerts and communicate with family.
Keeping Phones and Radios Charged for Fire Updates
A charged phone helps you receive emergency alerts, check road closures, and contact family. A weather radio can provide another source of information if cell service becomes unreliable. Prepare your charging equipment before fire danger rises, and keep it at a planned safe location.
What to keep charged
Your emergency communication supplies should include:
  • Cell phones and charging cables
  • A battery-powered or hand-crank weather radio
  • Flashlights and spare batteries
  • A power bank for everyday phone charging
  • A portable power station for charging several small devices
Charge your equipment before an evacuation becomes necessary. If officials tell you to leave, go. Don't delay to collect a power station, charger, or other equipment. Never take a power station into an active fire area.
EcoFlow DELTA 3 Classic for communication backup
If you have a safe place to stay during an evacuation, a portable power station can help keep your phones, radio, and flashlights charged. An EcoFlow DELTA 3 Classic has a 1,024Wh battery capacity and can provide backup power for these smaller devices. Charge it ahead of time and keep it with your prepared emergency supplies.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
How long could it power small devices?
Here's an example using a combined 30W load for phone, radio, and flashlight charging. With an estimated 870Wh of usable energy, the EcoFlow DELTA 3 Classic could support that load for about 29 hours.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Phones + radio + flashlight charging (placeholders)
about 30W
about 29 hours
This is an estimate, not a guaranteed runtime. It uses 85% of the battery's rated capacity to account for conversion losses: 1,024Wh × 0.85 ÷ 30W = about 29 hours. Actual use depends on the devices, charging patterns, and power draw. Check each device's label or specifications to estimate your own needs. Keep the station at your planned safe location, such as a relative's home or another place outside the evacuation area. Never stay behind or return to a restricted area to retrieve it. You can also review options for home battery backup during wildfire season as part of your broader emergency plan.
How Many Wildfires Does Wyoming Have?
Wildfire activity changes from year to year. State records provide a useful baseline, but a yearly average can't predict how many fires will occur in the next season. According to Wyoming's Office of State Lands and Investments (OSLI), the state's reported 10-year average from 2015 to 2025 was 997 fires and 202,529 acres burned per year. The figures show how much land wildfire can affect across the state.
What Wyoming's fire records show
The state's October 29, 2025 wildfire update reported:
State-reported figure
Total
Wildfires reported as of October 29, 2025
1,560
Acres affected
209,871
Fires on state and private land
About 79%
These figures are from October 29, 2025, not current 2026 totals. Check the Wyoming State Forestry Division or OSLI for the latest numbers. Fire risk varies across Wyoming's grasslands, sagebrush, and forests. Rainfall, dry vegetation, wind, and temperature all play a role. Even counties without active fires can face danger later in the season. Homeowners can reduce some risks by clearing dry vegetation, moving flammable materials away from buildings, and maintaining defensible space. See our guide to home wildfire protection.
How to Prepare for Wildfire in Wyoming
A good wildfire plan gives everyone in your household a clear idea of what to do and where to go. Make it before an evacuation notice arrives. Include your pets, livestock, medications, and anyone who may need help leaving.
How to Prepare for Wildfire in WyomingHow to Prepare for Wildfire in Wyoming
Prepare your home
Start with the area immediately around your house. Remove dry leaves, dead branches, and other flammable debris from roofs, gutters, decks, and outdoor spaces. Keep firewood and fuel containers away from buildings, and follow local guidance on defensible space. Also check local and state fire restrictions. County officials may issue burn bans or limit activities that could start a fire. Follow those rules, especially during dry and windy conditions.
Pack a wildfire go-bag
Keep essential supplies together so you can leave without searching through the house. Your go-bag should include:
  • Identification, insurance papers, and other important documents
  • Prescription medication and basic first-aid supplies
  • Drinking water and nonperishable food
  • Phone chargers, power banks, and spare batteries
  • A flashlight, battery-powered radio, and extra clothing
  • Personal hygiene items and supplies for children or older family members
Store important digital documents securely, but keep paper copies of anything you may need if your phone loses power.
Plan your evacuation routes
Identify at least two routes out of your neighborhood or property. Roads may close without much notice, and smoke can make familiar routes difficult to navigate. Choose a meeting place outside the affected area and make sure everyone knows how to get there.
If you have pets or livestock, plan how you'll move them before fire season. Keep carriers, leashes, trailers, and necessary supplies ready. This guide to pet and livestock evacuation can help you prepare for animals that need extra time or transportation. Follow evacuation instructions as soon as authorities issue them. Don't wait until you see flames or smoke nearby. If officials tell you to leave, take your go-bag and follow the recommended route.
If you're tracking Wyoming wildfires, use the Wyoming State Forestry Division and InciWeb for fire updates, and follow your county sheriff or emergency manager for evacuation orders. State records show an average of 997 fires and 202,529 acres burned per year over the reported 2015 to 2025 period. Prepare your home, pack essential supplies, and plan two routes out before fire danger rises. An EcoFlow DELTA 3 Classic can keep phones and radios charged at a safe location, but never delay an evacuation to retrieve backup equipment.
Where can I see current wildfires in Wyoming?
Check the Wyoming State Forestry Division and InciWeb for incident updates. For evacuation orders, follow your county sheriff's department and emergency management office. Check the timestamp on each report because conditions can change quickly.
How many wildfires does Wyoming have a year?
Wyoming's reported 10-year average from 2015 to 2025 was 997 fires and 202,529 acres burned per year, according to state figures. Annual totals vary with weather and fire conditions.
When is wildfire season in Wyoming?
Wildfires often occur during summer and fall, when vegetation can dry out and conditions become favorable for fires. However, fires can happen in other months too. Check local fire restrictions and weather alerts throughout the year.
Who issues evacuation orders in Wyoming?
County sheriffs and emergency managers issue local evacuation instructions. Follow their official alerts and directions. Don't rely on social media posts as confirmation that an area is safe or that an evacuation order has changed.
What should be in a wildfire go-bag?
Pack identification, important documents, prescription medication, water, nonperishable food, clothing, phone chargers, a power bank, and a flashlight. Add supplies for children, older family members, pets, or anyone with specific needs.
Power Outages
