When Does Prime Day 2026 End? Shop EcoFlow at Record-Low Prices
Amazon’s 2026 Prime Big Deal Days runs from October 6 to 7, with Prime Day deals on selected EcoFlow products. If backup power is on your shopping list, now is a good time to compare power stations and solar bundles. Here’s when the sale closes, which models to consider, and what to check before you buy.
When Does Prime Day End in 2026?
Amazon Prime Big Deal Days runs on October 6 and 7, 2026. If the US event follows a Pacific Time cutoff at 11:59 p.m. PDT on October 7, that would be 2:59 a.m. EDT on October 8. Check Amazon’s event page and the countdown on the product listing for the confirmed deadline. Individual deals may expire or sell out earlier.
What Happens When a Prime Day Deal Ends?
Prime Day sales can include deals that end before the two-day event does. Check the countdown on the listing and complete checkout while the price you want is still available.
Limited-Time Deals May Expire
Promotional pricing doesn’t last long once the Prime Day clock starts. Lightning deals, clipped digital coupons, and member-exclusive rate cuts disappear the moment the event finishes. If you’re still comparing EcoFlow Prime Day deals, you can review available power stations and solar bundles before checking out. More importantly, just putting a power station in your Amazon cart won’t guarantee you snagged that deal. You must fully finish checking out and purchase it before the deadline. Otherwise, the item(s) in your cart recalculates back to standard MSRP automatically.
Some Offers May Sell Out Early
High-capacity batteries and solar bundles will be available in limited quantities. Thousands of homeowners will be scrambling to prepare for windstorms and winter freezes, so key bundles often hit “100% Claimed” hours before the official cutoff. When these are all taken, items revert to listings by third-party merchants or go completely out of stock.
Which EcoFlow Deals Can You Shop Before the Sale Ends?
EcoFlow is advertising up to 57% off selected products from September 20 to October 5. The three options below cover different home backup needs, from essential appliances to longer outages. Check each listing for its actual discount, accessories included and availability. Explore the EcoFlow Prime Day Fall Sale for more offers before the sale ends.
Model / Bundle | Key Specifications | Best Application | Prime Day Savings |
EcoFlow DELTA 3 Ultra Plus + 500W Solar Panels | 500W Solar Input, Smart Output Priority via App | Whole-room backup & essential appliance triage | Substantial bundle package discount |
EcoFlow DELTA 3 Max | 2400W AC Output, 10ms UPS switchover | Home offices, sensitive electronics & RV trips | Record-low standalone price cut |
EcoFlow DELTA Pro + 2× 220W Solar Panels | 3.6kWh base (expandable to 25kWh), 440W solar input | Multi-day winter blackouts, cabins & whole-home systems | Major seasonal markdown + panel bonus |
Note: Prices, discounts, bundle contents, and product availability may change during the sale. Check the official EcoFlow listing for the latest offer and final price before purchasing.
The EcoFlow DELTA 3 Ultra Plus Portable Power Station has a 3,072Wh base capacity and 3,600W rated output. Its Smart Output Priority feature lets you choose which connected circuits receive power as the battery runs low. The included solar panels have a combined rated output of 500W. The actual charging power will depend on sunlight, panel placement and connection conditions. Check the sale listing that includes the solar panels and compare its price with the power station alone.
EcoFlow DELTA 3 Max
The EcoFlow DELTA 3 Max Portable Power Station (2048Wh) offers 2,048Wh of capacity, 2,400W rated AC output and a 10ms UPS transfer time if power goes out. It may suit a home office, a refrigerator or an RV setup, depending on each device’s power usage and the runtime you need. Things to check before buying are the wattage of your appliances, and confirm that the UPS transfer time meets the requirements of equipment you plan to connect.
EcoFlow DELTA Pro + 2 × 220W Solar Panels
The EcoFlow DELTA Pro + 2 x 220W Portable Solar Panel bundle starts with 3,600Wh of capacity and includes solar panels with a combined rated output of 440W. Extra batteries can increase storage, but they are separate from this base bundle. If you need 240V output for larger appliances, this setup requires additional compatible equipment, including a second DELTA Pro. Check the exact configuration carefully if you plan to power 240V appliances. For any backup power system, always compare the battery capacity with the daily energy use of the devices you need to keep running.
What Should You Check Before the Prime Day Deadline?
Take a minute to carefully go through everything in your cart before completing payment. This can prevent costly post-purchase headaches. Reviewing what to know before buying power stations can also help you compare capacity, output, charging options, and ports before the deadline.
Confirm the Final Sale Price
“Up to 57% off from September 20 to October 5” is the maximum advertised discount on selected products, not the discount on every EcoFlow model. You can confirm the discount before paying by checking the price after any coupon is applied and comparing it to the exact model and bundle on EcoFlow’s official website. Price only matters if the unit fits the intended load. Before comparing prices, make sure the power station you’re considering can handle the devices you need to run.
Check Bundle Contents and Savings
Check all the contents carefully once your purchase arrives. Also note that manufacturer deals often bundle portable solar panels, weatherproof extension cables, and protective covers together. This almost always saves you more money than purchasing accessories separately.
Review Shipping and Delivery Details
Large, heavy-capacity lithium iron phosphate (LiFePO4) battery packs travel via designated ground transport and are handled as hazardous materials. Sometimes this requires a longer time to arrive. Check the projected delivery window at checkout, particularly if you are trying to beat some extreme weather or planning an upcoming RV trip.
Confirm the Deal’s End Time
Pay attention to flash-deal countdown timers displayed directly below the “Add to Cart” button. Certain vendor lightning promos run on 6- or 12-hour schedules that stop well ahead of Amazon’s October 7 midnight deadline.
Missed the Deadline? How to Still Save on EcoFlow Products
If you didn’t finalize your order before the clock struck midnight, don’t worry. Power station deals may still be available through ongoing promotions, refurbished inventory, or rewards offers.
Check Ongoing EcoFlow Promotions
EcoFlow frequently extends price matching and post-event discounts on their official brand web store. Visiting the direct site often yields exclusive accessory giveaways, extended customer service perks, or free shipping bundles that match Amazon’s holiday rates.
Explore Certified Refurbished Products
You can purchase certified refurbished units directly from EcoFlow’s web outlet or verified manufacturer eBay store. Every unit undergoes rigorous factory diagnostic checks making sure it meets original capacity specs, and comes with official brand warranty coverage.
Check Trade-In and Rewards Offers
If you have an older, lead-acid type battery or legacy portable unit, consider EcoFlow’s trade-in program. This program allows you to send in older devices for store credit vouchers. You can also join the brand’s EcoCredit rewards club to earn points on every dollar spent. These can be converted into instant coupon codes for future expansion batteries.
Prime Big Deal Days runs on October 6–7, so use the time before the sale to figure out what you need to power and for how long. The EcoFlow DELTA 3 Max suits smaller backup needs, while the EcoFlow DELTA 3 Ultra Plus and EcoFlow DELTA Pro offer more capacity or room to expand. Once the deals go live, check each EcoFlow listing for its actual discount, bundle contents and when the offer ends. Then simply choose the setup that fits your needs.
How Much Do Prices Drop on Prime Day?
EcoFlow offers up to 57% off selected products during the September 20–October 5, 2026 sale period. Discounts vary by model and bundle, so check each product listing for the final price and any available coupon.
Does Prime Day Give Deals on Everything?
Prime Day does not include discounts on every item across Amazon’s entire catalog. Sellers must review and select specific products from the Prime-exclusive deals. Legacy components, newly released flagship items, and niche gear often remain at standard retail rates throughout the event.
What Size Portable Power Station Do I Need?
Your ideal battery capacity depends entirely on the combined wattage of your gear and how many hours of continuous runtime you require. For weekend outdoor recreation and device recharging, 500Wh to 1,000Wh is usually sufficient. For household emergency outages, where refrigerators and Wi-Fi networks need to run, plan on 2,000Wh to 3,600Wh, or modular units like the EcoFlow DELTA Pro.
Is It Okay to Leave EcoFlow Plugged in All the Time?
Some EcoFlow models support use while connected to a wall outlet, but operating guidance varies by model. Check the manual for your unit, follow its charging and storage recommendations. Also, make sure the connected devices don’t use more power than the system’s rated output.
Can I Plug Any Solar Panel into EcoFlow?
Not necessarily. A third-party panel must meet your specific EcoFlow model’s solar input limits. This includes open-circuit voltage, current and connector requirements. Check the power station’s specifications and the panel’s ratings before connecting them.
