What Temperature Do Pipes Burst? Why There's No Single Number
Water pipes can freeze when temperatures drop to 32°F, but freezing does not always mean a pipe will burst immediately. A burst occurs when expanding ice creates pressure inside a section of pipe, depending on its location, insulation, and exposure to prolonged cold. A county handout citing University of Illinois research identifies 20°F as an outdoor alert threshold for vulnerable pipes in milder regions. This guide explains the risks across different pipe locations and materials and covers practical prevention steps, including maintaining heat during power outages.
Outdoor temperature alone cannot determine when a pipe will burst because insulation, wind exposure, location, and exposure time all affect the risk. Water freezes at 32°F, but pipes inside heated walls may remain protected while exposed plumbing freezes. According to a Multnomah County handout citing University of Illinois research, 20°F is a useful warning threshold for vulnerable pipes in milder regions. However, pipes can freeze at higher temperatures when cold air enters through gaps or poorly insulated areas.
Why Does a Frozen Pipe Burst?
A pipe does not necessarily break at the exact spot where ice forms. When water freezes, it expands and can create an ice blockage inside the line. As freezing continues, pressure builds between the blockage and a closed faucet. Eventually, that pressure can damage the pipe, sometimes at a location away from the ice itself. This is why a frozen pipe may not show visible damage immediately. Water can begin leaking when the ice melts and flow returns. Start with basic frozen pipe prevention before cold snaps. An outage during freezing weather raises the risk because indoor heating may stop working.
Keeping Heat On Before and During an Outage
Keeping indoor temperatures stable helps protect household plumbing during freezing weather. However, winter power outages can interrupt heating because many systems depend on electricity. Planning backup power ahead of time helps keep compatible heating equipment operating when the grid goes down.
Why Heating Matters to Your Pipes
Most residential heating systems need electricity to operate essential components. Gas furnaces with electric blowers, ignition, or controls need electricity for those parts. Some millivolt wall furnaces operate without external power. A hydronic boiler uses electricity for its circulator if equipped with one. When indoor temperatures drop, pipes inside exterior walls, basements, garages, and other unheated spaces become more vulnerable to freezing. Before an outage, review your winter power outage preparation checklist to identify essential equipment and circuits that need backup power.
Plan Backup Power Around Your Heating Equipment
Before choosing a backup system, check your heating equipment's label and owner's manual for voltage, running wattage, and startup requirements. Furnace blowers may use modest power while operating but require additional electricity when starting. An electrician can evaluate your system and identify compatible circuits for backup. A gas furnace may need its blower, ignition, and control circuits supported, while a boiler may require electricity for its controls and circulator pump. Heat pumps and electric furnaces have different power requirements. Understanding a gas furnace without electricity can help you plan before an outage.
Using EcoFlow TITAN 5000 for Selected Heating Circuits
When a winter outage interrupts heating, a home battery can supply electricity to compatible heating equipment through a properly configured backup system. The EcoFlow TITAN 5000 is a 5kWh home battery that supports selected household circuits when paired with the EcoFlow Smart Home Panel 10 (240V). The panel must be purchased separately when selecting the standalone EcoFlow TITAN 5000. A qualified, licensed electrician must install the panel, verify circuit compatibility, and evaluate the electrical demand for compatible furnace or boiler equipment.
How Long Could a Home Battery Run Heating Equipment?
Runtime depends on the actual electrical load, battery capacity, operating conditions, and other connected appliances. For planning purposes, the following examples use an estimated usable capacity of 4,265Wh. This assumes 85% of the nominal 5,017.6Wh capacity is available for the calculation.
Load (example) | Assumed average load | Estimated runtime |
Gas furnace cycling | 250W | About 17 hours |
Boiler controls and circulator | 150W | About 28 hours |
These are estimates, not guaranteed operating times. Use these wattages as sample averages. For your own estimate, measure an average over a representative heating cycle and have an electrician check rated load and startup demand separately.
The calculation is:
Usable battery capacity (Wh) ÷ Electrical load (W) = Estimated runtime (hours)
For example:
4,265Wh ÷ 250W = 17.06 hours.
Remember that a refrigerator, lights, router, and other connected equipment also consume stored energy. Actual runtime will decrease when multiple loads operate together. Many gas furnaces and heating systems rely on electricity for ignition, fans, or electronic controls, while some millivolt-powered gas heaters can operate without external electricity. Hydronic boilers equipped with circulation pumps also require electricity to operate those pumps. Check your heating equipment's nameplate and installation manual to confirm its electrical requirements. A battery cannot guarantee that pipes won't freeze. It can only provide backup electricity to compatible equipment for a limited time under suitable conditions.
Which Pipes Are Most at Risk?
Southern homes can also experience sudden temperature drops when Arctic air moves farther south, exposing plumbing to freezing conditions. These arctic air outbreaks in the South can put additional pressure on plumbing and heating systems, particularly in homes with poorly insulated attics and crawl spaces. Preparing exposed pipes and checking heating equipment before extreme cold arrives can help reduce the risk of unexpected damage.
Pipe Locations That Need Extra Attention
Pipe location | Risk level | What you can do |
Unheated attic or crawl space | High | Add pipe insulation and approved heat cable where appropriate |
Exterior wall cabinets | Medium to high | Open cabinet doors during freezing weather |
Garage plumbing | High | Insulate exposed lines and keep the garage door closed |
Outdoor hose bibs | High | Disconnect hoses, shut off the supply, and drain the line |
An unheated attic or crawl space is particularly concerning because pipes receive little protection from indoor heating. Garage plumbing can face similar conditions, especially when the garage door is opened frequently. Pipes installed inside exterior walls may also freeze when insulation is inadequate or cold air enters through gaps around the building envelope.
Does Pipe Material Change the Risk?
Different pipe materials react differently when exposed to freezing temperatures and expanding ice. Rigid materials are more likely to crack under pressure, while flexible options like PEX can handle some expansion. However, no plumbing material is completely protected from freeze-related damage.
Copper pipes: Copper is rigid and can crack or split when freezing water creates enough internal pressure.
PVC and CPVC pipes: These rigid plastic materials can also crack under freezing conditions, particularly when exposed to repeated or prolonged cold.
PEX pipes: PEX is more flexible and can tolerate some expansion better than rigid plumbing materials. However, that doesn't make it freeze-proof. Connections, fittings, valves, and other components can still become damaged.
There isn't one guaranteed pipe material that eliminates freezing risk. Installation quality, exposure, insulation, and the condition of fittings all matter.
Practical Ways to Protect Exposed Pipes
Protecting exposed pipes before freezing weather arrives can reduce the risk of ice buildup and costly damage. A few simple steps, such as adding insulation, sealing gaps, and improving warm-air circulation, can help keep vulnerable plumbing warmer during cold spells.
Insulate exposed plumbing: Use appropriately sized foam pipe insulation in unheated areas.
Seal air leaks: Close gaps around exterior walls, foundation openings, and pipe penetrations.
Protect outdoor faucets: Disconnect garden hoses and drain outdoor water lines according to the plumbing setup.
Improve warm-air circulation: Open kitchen and bathroom cabinet doors when exposed pipes are at risk.
Use approved heat cables: Install only products rated for the pipe material and follow the manufacturer's instructions.
Monitor local weather updates and use National Weather Service alerts when preparing for freeze warnings. These measures work best together. Insulation slows heat loss, while sealing drafts reduces the amount of cold air reaching vulnerable plumbing.
What to Do If a Pipe Freezes or Bursts
Finding a frozen pipe doesn't necessarily mean it has burst, but acting quickly can help limit damage. Watch for reduced water pressure, frost on exposed plumbing, unusual pipe noises, or visible swelling. If you notice water leaking, shut off the main water supply if it's safe and stay away from wet electrical equipment.
Signs That a Pipe May Be Frozen
A frozen pipe may cause reduced water flow, frost around exposed plumbing, unusual cracking sounds, or visible swelling. These signs are common in unheated attics, garages, and crawl spaces. Check accessible pipes carefully, and contact a plumber if you suspect freezing inside a wall.
How to Thaw a Frozen Pipe Safely
If the pipe is frozen and there is no sign of a leak, open the affected faucet and apply gentle heat. Use electric appliances only when the floor, outlet, and equipment are dry and safe. Warm towels provide a non-electric option. Work gradually along the frozen section and check for leaks as the ice melts. The National Weather Service advises against using open flames, blowtorches, or charcoal heaters because they can cause additional damage and fire hazards. For additional guidance, follow what to do if pipes freeze to understand how to identify frozen plumbing and respond safely.
What to Do When a Pipe Bursts
A burst pipe can release large amounts of water quickly, causing damage to walls, floors, furniture, and electrical equipment. Acting promptly can help limit the damage and reduce safety risks. If you discover a burst pipe, follow these steps:
Shut Off the Main Water Supply: Turn off your home's main water valve if you can safely access it. If you cannot safely reach or operate the valve, contact your local water supply authority or a qualified professional.
Avoid Electrical Hazards: Stay away from standing water near electrical outlets, appliances, and wiring. Never touch wet electrical equipment.
Contact a Licensed Plumber: Arrange for a licensed plumber to inspect and repair the damaged pipe.
Document the Damage: Once the area is safe, photograph the damaged pipe and affected property for insurance purposes.
Check for Further Leaks: After repairs, inspect nearby walls, ceilings, and floors for signs of moisture or additional leaks.
What temperature pipes burst at depends on their location, insulation, and exposure time, although research cited by Multnomah County uses 20°F as an alert threshold for vulnerable pipes. Protect your plumbing by insulating exposed lines, disconnecting garden hoses, and sealing cold-air gaps. If a pipe freezes, thaw it gently without using an open flame. For additional outage protection, EcoFlow TITAN 5000 can support compatible heating circuits through a professionally installed backup system, helping maintain indoor heat when the power goes out.
What temperature do pipes burst?
There is no exact temperature at which every pipe bursts. However, 20°F is a common outdoor warning threshold for vulnerable pipes. Exposure time, insulation, and pipe location determine the actual risk.
Do pipes freeze at 32 degrees?
Water freezes at 32°F, but pipes do not necessarily freeze immediately at this temperature. Poor insulation, drafts, and prolonged exposure can increase the risk.
How long does it take pipes to freeze?
There is no fixed freezing time. Exposed pipes may freeze within several hours during severe cold, while insulated pipes surrounded by warmer air may take longer.
Do PEX pipes burst?
PEX pipes are more flexible than rigid plumbing materials and generally tolerate expansion better. However, freezing can still damage PEX fittings, connectors, and other components.
How do I keep pipes from freezing in an outage?
Insulate exposed pipes, seal drafts, open cabinets near exterior walls, and maintain indoor heat. A properly sized home battery backup can help operate compatible heating equipment during an outage.
