Single Pole vs Double Pole Breakers: 120V vs 240V Circuits in Your Panel
In a common North American 120/240V split-phase home, a single-pole breaker typically protects a 120V lighting or receptacle circuit. A double-pole breaker commonly protects a 240V load, such as a compatible electric range or dryer. The number of poles describes how many conductors the breaker can disconnect; actual voltage depends on the supply and connected conductors. A common-trip breaker opens both poles together. This guide explains their differences, common uses, and safety considerations. You'll also learn how to map circuits for backup power.
Single Pole vs Double Pole: What's the Difference?
A single pole breaker uses one bus slot and one hot wire. A double pole breaker uses two slots and connects to two hot wires. Both poles of a properly designed double pole breaker disconnect together when required.
Which circuits a breaker can protect depends on its listing and the supply. Some listed two-pole models also protect 208V loads or compatible circuits with two 120V legs.
Single Pole Breakers
A single pole breaker occupies one space in a standard residential breaker panel. It connects to one hot leg and typically protects a 120V circuit in the split-phase example.
You'll find these breakers throughout most American homes. They protect everyday circuits that don't need 240V.
Common applications include:
Bedroom and living room outlets.
Ceiling lights and light switches.
Bathroom receptacles.
Small kitchen appliances.
Television, router, and computer outlets.
Some gas furnaces and HVAC control circuits.
Single pole breakers commonly come in 15A and 20A ratings. Larger ratings exist for specific applications, depending on the panel and circuit design.
Each breaker protects its connected circuit against overloads and short circuits. If a fault occurs, the breaker opens that circuit.
A double pole breaker occupies two adjacent spaces in a standard residential panel. It connects to both hot legs of the electrical supply.
Each hot leg provides approximately 120V relative to neutral. The voltage between the two hot legs is approximately 240V.
This makes double pole breakers suitable for appliances requiring higher voltage.
Electric ranges and ovens.
Electric clothes dryers.
Electric water heaters rated for 240V.
Central air conditioning systems.
Some well pumps.
Other dedicated 240V equipment.
These breakers commonly come in 20A, 30A, 40A, and 50A ratings. The correct rating depends on the appliance specifications and circuit design.
A key feature is simultaneous disconnection. If either pole trips on a properly designed common-trip breaker, both poles open together.
Single Pole vs Double Pole Breaker Comparison
Here's a quick comparison of their main characteristics.
Feature | Single pole | Double pole |
Panel spaces | 1 | 2 |
Hot legs | 1 | 2 |
Typical circuit voltage in a 120/240V split-phase home | 120V | 240V |
Common loads | Lights, outlets | Ranges, dryers |
Typical ratings | 15A, 20A | 20A–50A |
Disconnection | One leg | Both legs together |
Typical width | One breaker space | Two breaker spaces |
One important detail: Breaker amperage and voltage are different ratings. A 30A double pole breaker doesn't supply 30A to each leg independently as separate circuits. In the split-phase example above, it protects a 30A circuit on the two hot legs. The marked amperage alone does not identify the circuit voltage.
Why Wire Size Matters
The breaker and wiring must work together. A breaker that's too large for its conductors can allow dangerous overheating before it trips.
For example, check the appropriate wire size for a 30-amp breaker. Ten AWG copper is a common starting point, but actual sizing depends on installation conditions.
An electrician should verify:
Conductor material and gauge.
Insulation temperature rating.
Circuit length and voltage drop.
Terminal ratings and installation conditions.
Applicable NEC requirements and local codes.
Never increase a breaker rating simply to stop repeated tripping. Find the underlying problem first.
Knowing which breaker protects each circuit also helps when planning backup power. That's especially useful during storms and unexpected utility outages.
Mapping Breakers for Home Backup
List the 120V and 240V circuits you'd want during an outage. Note each breaker type and size. An electrician checks which fit.
When severe weather knocks out the grid, like a summer hurricane on the Gulf Coast or a winter Nor'easter in New England, you rarely need to run every device in your house. Instead, you want to keep critical circuits alive. Mapping your North American panel ahead of time helps you see which circuits run on single pole 120V breakers and which demand double pole 240V power.
Start by separating your must-have loads from the luxuries you can live without for a few days:
Identify 120V essentials: Your refrigerator, chest freezer, Wi-Fi router, a few LED lights, and a gas furnace blower all run on standard single pole breakers. Even though a gas furnace uses natural gas or propane for heat, its internal fan and thermostat rely on a 15-amp or 20-amp 120V circuit.
Identify 240V essentials: Depending on your home setup, you might have critical 240V loads. Check each appliance nameplate. A well pump, heat pump, or electric water heater belongs in this 240V list only if the installed model requires 240V. Some well pumps can be configured for either voltage, and some plug-in heat pump water heaters use 120V.
Check leg balance and total draw: In a split-phase system, your 120V single pole circuits are split between Leg A and Leg B. If you put all your heavy 120V loads on one leg, you risk overloading one side of your backup system while the other side sits idle.
A licensed electrician will evaluate your panel's voltage, current ratings, circuit types, and same-leg loads before connecting any backup gear. Never attempt DIY panel rewiring, and never try to bypass double pole rules to squeeze extra circuits onto a backup switch.
EcoFlow TITAN 5000 has 7,200W of 120V/240V split-phase output. A licensed electrician can connect suitable 120V and 240V circuits through Smart Home Panel 10 (240V). In grid-connected operation, No Export limits export to the utility. During an outage, the correctly installed panel switches the backup supply for circuits selected and connected by the electrician.
Because it outputs split-phase power, both breaker types are possible. The electrician checks each circuit's load and leg balance.
Estimate How Long Your Backup Battery Can Last
Once you've identified compatible circuits, estimate how much energy they'll consume.
A simple starting formula is:
Runtime (hours) = Usable battery capacity (Wh) ÷ Combined load (W)
For a preliminary estimate, use 85% of the rated battery capacity as usable energy:
Runtime (hours) = (Battery capacity (Wh) × 0.85) ÷ Combined load (W)
For example, add the running wattage of your refrigerator, furnace blower, lights, and networking equipment. Use their actual equipment labels rather than generic estimates.
Remember that startup surges, inverter losses, temperature, and changing loads affect actual runtime.
Circuit | Breaker Type | Estimated Load / Notes | Backup Fit (Electrician Decides) |
Fridge outlet | Single pole, 120V | ~150W–200W running (higher startup) | Usually essential |
Gas furnace | Single pole, 120V | ~400W–600W for blower fan | Usually essential |
Well pump (240V) | Double pole | ~1,000W–2,000W running (high surge) | Evaluate startup |
Electric range | Double pole, 40A minimum (GE range installation example) | ~3,000W–8,000W+ depending on burners | This 40A minimum circuit exceeds the built-in 20A and 30A double-pole branch ratings of Smart Home Panel 10 (240V). |
See the Smart Home Panel 10 support guide for branch ratings and how connected circuits are supplied in an outage. Have an electrician verify each breaker rating, expected load, and the combined system limit.
Next, the safety rule people break most.
Why Two Single Poles Can't Replace a Double Pole
A 240V load needs both legs to disconnect together. Two separate single poles can leave one leg live. That's a shock and fire hazard.
It is a dangerous myth that you can slap two 120V single pole breakers next to each other and wire them to a 240V appliance. Even if you physically align them across both hot bus bars, independent single pole breakers operate on separate internal trip mechanisms.
Opening one leg interrupts a purely line-to-line 240V load, but the other leg can remain live and leave parts of the equipment energized. A listed common-trip breaker opens both poles together when required. Have a licensed electrician select and service protection for the actual circuit.
Common Trip vs. Handle Ties
True double pole breakers feature an internal common-trip mechanism alongside a molded plastic crossbar connecting both switches. Even if someone holds one side of the switch handle down, the internal mechanism forces both poles to snap open simultaneously during a fault.
Listed breakers only: Have an electrician verify the breaker type listed on the panel label or a classified replacement specifically identified for that panel and application. Check its listing limitations and local requirements. Do not mix brands based only on whether a breaker fits.
Handle ties have limits: Approved handle ties physically join two single pole switches so you turn them off together manually. However, handle ties only work where the breaker manufacturer and local electrical codes allow them, such as on multi-wire branch circuits (MWBCs). A simple metal clip does not create an internal common trip for heavy 240V appliances.
Leave Panel Modifications to the Pros
Working inside an open electrical panel exposes you to live service lugs that carry enough amperage to be fatal, even when the main breaker is flipped off. According to the U.S. Fire Administration (USFA), homeowners should always have electrical work done by a qualified electrician to prevent residential electrical fires. A licensed pro ensures your breakers match your panel's bus design, torque specs are met, and grounding stays intact.
Learn how 240V versus 120V power differs for big appliances and why proper voltage isolation keeps your household wiring safe.
Finally, know how to read your panel.
How to Read Your Breaker Panel
Check the directory label. Double pole breakers are twice as wide and have a joined handle. The number printed on the handle indicates the amp rating.
You don't need an electrical license to inspect the outside of your breaker panel. Opening the hinged metal door reveals the breaker switches and the printed directory card inside. Never remove the inner metal deadfront cover. It protects you from live bus bars and exposed wiring.
Follow these quick steps to identify your breakers:
Look at the switch width: Single pole breakers occupy one standard slot, usually about 1 inch wide. A standard tandem can house two independent single-pole breakers in one full pole space. A conventional full-size double-pole breaker takes two adjacent spaces.
Check the handle: Handle shape can be a clue. Read the breaker marking, panel directory, and model instructions. Two linked handles alone do not establish internal common trip.
Read the amp number: Look closely at the breaker handle. You'll typically see a number such as
15,20,30,40, or50. Both handles on a double pole breaker may display30. That indicates a 30A breaker, not 60A. Verify the circuit voltage from the electrical supply and circuit design.Match the numbers to the directory: Compare the numbered breaker positions with the handwritten or printed circuit list inside the panel door.
If your panel directory is blank, faded, or difficult to read, don't guess by randomly flipping breakers. This could interrupt sensitive electronics or essential equipment. Have a licensed electrician trace and label your circuits properly.
Compare 32 versus 12 circuit panels if you're upgrading an older electrical panel or adding 240V appliances, such as an EV charger or heat pump.
In a 120/240V split-phase home, single-pole breakers usually protect 120V circuits, while common-trip double-pole breakers often protect 240V appliances and open both poles together. Confirm actual voltage and the breaker’s approved applications before choosing protection.
Before planning home backup, check your panel directory and identify essential circuits. Never replace a double pole breaker with two independent single pole breakers.
If you want backup for both 120V and 240V circuits, the EcoFlow TITAN 5000 offers 7,200W of split-phase output. Paired with Smart Home Panel 10 (240V), it gives a licensed electrician a way to evaluate and configure compatible essential circuits.
What is the difference between single pole and double pole?
In a common North American split-phase home, a single-pole breaker typically protects a 120V circuit on one hot leg. A double-pole breaker often protects a 240V appliance circuit on both hot legs. Actual voltage and allowable loads depend on the supply and the breaker’s listing.
Can I use two single pole breakers instead of a double pole?
No. Two independent single pole breakers don't provide the same common-trip protection. A 240V circuit needs both hot legs to disconnect together. Use a properly listed double pole breaker designed for your panel.
What uses a double pole breaker?
Models that require a 240V line-to-line circuit often use a double-pole breaker. Examples include compatible ranges, dryers, water heaters, HVAC equipment, well pumps, and Level 2 EV chargers. Check the exact model, since some equipment is designed for 120V.
How do I tell them apart?
You can tell them apart by looking at their size and switch handles inside your panel door. A single pole breaker takes up one narrow slot with a single toggle switch, while a double pole breaker is twice as wide and has a joined handle connecting two switches together.
Can backup batteries power 240V circuits?
Yes. A battery system with compatible 120V/240V split-phase output can potentially power selected 240V circuits. The electrician must verify circuit compatibility, voltage, current, startup demand, and available system capacity.
