What to Do If Pipes Freeze: A Calm, Safe Plan for the First Hour
You turn the faucet handle on a freezing morning. You expect water, but get only a weak trickle or total silence.
Do not panic. A frozen pipe is not always a burst pipe, but the next hour matters. As water freezes, it expands and builds pressure that can crack or split the pipe. Ice often plugs the damage, so a split can stay hidden until the ice melts. Then water can start gushing from the break inside walls or crawl spaces.
This guide delivers three key answers: a safe sequence of actions, a practical breakdown of DIY thawing versus calling a licensed plumber, and a straightforward safety plan if a winter power outage kills your heating.
First Signs Your Pipe Is Frozen (and What to Do Right Now)
A frozen pipe usually gives itself away long before you ever spot physical frost. A sudden dry faucet while your other taps run fine is the classic red flag. Before you run for a hair dryer, pause for two minutes. You must protect your living space from the mess that happens when that ice block lets go.
Plumber inspecting a frozen pipePlumber inspecting a frozen pipe
Clues that point to a frozen line
Plumbing lines freeze where winter cold penetrates deepest. Watch out for these standard trouble signs around your home:
  • Single fixture failure: You get just a trickle, or nothing at all, from one faucet. The line often runs along an exterior wall, uninsulated basement, crawl space, attic, or garage.
  • Visible pipe frost: You see visible white frost, condensation beads, or light ice on exposed metal or plastic pipes.
  • Cold, unheated spaces: Pipes in crawl spaces, attics, garages, and exterior walls face a higher risk.
  • Several affected faucets: Multiple fixtures stop working, suggesting a larger supply-line problem.
If every faucet has stopped working, the freeze might be near your home's main supply line or water meter. Milwaukee Water Works points out that frozen meters happen during deep cold snaps. If you suspect the municipal meter is frozen, call your local water utility right away instead of trying to heat it yourself.
Do these three things before thawing
Take these three practical precautions before applying any heat to your plumbing:
Step
Why it matters
Official source
1. Find the main shutoff valve
A frozen pipe may already have a split. It can flood your floor the moment it warms up.
FEMA "Winterizing Your Home" (DR-4749-IL); Texas A&M AgriLife Extension
2. Open the affected faucet
Flowing water speeds melting. It also gives expanding steam and slush an open exit path.
Texas A&M AgriLife Extension; Maine Emergency Management Agency
3. Clear standing water and wires
Water conducts current fast. Standing water near outlets, switches, or cords creates immediate electrical shock risks.
Oklahoma State University Extension
Oklahoma State University Extension points out that shutting off your main water valve and calling a licensed plumber right away is a completely sound first move. You do not have to try thawing lines yourself if you feel unsafe. Treating professional help as your primary plan is smart homeownership, not a failure.
A frozen water line rarely happens on a clear, sunny afternoon. It usually hits right in the middle of a brutal winter cold front. Knowing what to do during winter storms helps you manage these cold-weather headaches with far less stress.
Once your main valve is located, the area is dry, and the faucet is open, you can safely decide your next move.
How to Thaw a Frozen Pipe Without Making It Worse
Gentle, steady heat is the safest approach to thawing an accessible frozen pipe. Open flames and intense heat can damage plumbing and start a fire. Stay with your heat source throughout the process, and stop if you notice anything unusual.
Safe thawing tools and methods
If the pipe section is fully exposed and clearly visible, use these low-risk heating methods:
  • Standard hair dryers and warm pads: Texas A&M AgriLife Extension and the University of Missouri Extension suggest using an electric hair dryer, a standard heating pad, or towels soaked in hot tap water.
  • Portable space heaters: The University of Missouri Extension notes that a portable space heater can work well. Keep it safely away from all flammable items like drywall, cardboard, and wood framing. Never leave it unattended, and keep it completely clear of wet concrete or damp flooring.
  • Work from the tap backwards: Milwaukee Water Works recommends warming the pipe starting at the open faucet end, gradually working down toward the frozen blockage. This allows melting water to drain freely instead of getting trapped behind an ice dam.
  • Keep moving your heat: Never leave a hot hair dryer blowing on one isolated spot. Salt Lake City Public Utilities advises homeowners to sweep heat steadily along the pipe to prevent thermal shock.
  • Run until pressure returns: Keep applying mild warmth until regular, full water pressure flows steadily from the tap, as advised by Texas A&M AgriLife Extension.
Tools you must never use
Never try to thaw plumbing with a blowtorch, propane heater, kerosene heater, charcoal stove, or another open-flame device. These methods can damage pipes, ignite nearby materials, and create dangerous fumes.
Also, never heat your house with a gas oven. That creates a carbon monoxide poisoning risk.
When to stop and call a licensed plumber
DIY thawing is not always the right choice. Step back and call a licensed professional immediately if you hit any of these warning signs:
  • Hidden lines: The frozen section sits buried behind finished drywall, inside a ceiling cavity, or deep under subflooring. University of Missouri Extension and Summit County, Utah, recommend calling a plumber for inaccessible pipes.
  • Visible pipe damage: You see metal bulging, hairline cracks, seam splits, or sudden drips while warming the line.
  • Electrical contact: Water has trickled into outlets, baseboard heaters, extension cords, or near your main breaker panel. Immediately call a licensed electrician, and call 911 if there is any active arcing or fire danger.
  • No results after steady heating: If heat produces zero water flow after 30 to 45 minutes, stop and contact a licensed plumber.
Plubmber inspecting a frozen pipePlubmber inspecting a frozen pipe
If the furnace quit because the power went out, a quick look at whether a gas furnace can run without electricity explains why the house cools down even with gas service.
Thawing is the easy part when the lights are on. When an outage is the reason the house got cold, a little planning keeps people safe and helps you avoid the same freeze tomorrow.
If the Heat Went Out With the Power: Safe-Zone Basics and Prepared Heating Circuits
A frozen pipe doesn't always involve a power outage. But if winter weather knocks out electricity and stops your heating system, protecting your household and plumbing becomes more complicated.
Start by keeping everyone warm and safe. Close off unused rooms, dress in layers, and use blankets. Never operate a fuel-burning generator inside your home or garage.
The CDC recommends placing generators outdoors at least 20 feet from doors, windows, and vents. Keep working carbon monoxide detectors near sleeping areas.
Backup power can help with essential electrical needs, but lighting and heating equipment require different planning.
Need 1: a lit, connected safe zone (120V)
Your first objective is establishing a central room for safety and communication. You need simple, dedicated 120V power:
  • Essential visibility: LED work lights help you inspect dark crawl spaces, look under kitchen sinks, and monitor baseboards for hidden leaks.
  • Emergency communication: Keep household cellphones charged, and keep your primary home Wi-Fi router and modem powered up so you receive local utility alerts.
  • Safe connection rules: Connect only small, load-matched devices straight into your portable power unit's integrated AC outlets according to the manufacturer manual.
Need 2: an approved heating or well pump circuit
Some properties must run specific home equipment to prevent catastrophic cold-weather damage:
  • Circulation and ignition loads: Forced-air gas furnaces require electrical power for draft inductors, electronic control boards, and blower motors. Hydronic radiant heat systems require power for zone valves and circulator pumps.
  • Rural water setups: Properties on private wells rely on dedicated well pumps to pull domestic water and maintain line pressure.
  • Know your voltage requirements: Furnace controls and blowers typically use standard 120V branch circuits. In contrast, well pumps and electric heat strips frequently require dedicated 240V split-phase wiring.
  • Check the equipment nameplate: Always check the electrical data tag on your equipment or have a licensed electrician confirm the exact running watts, operating voltage, and motor startup surge before designing your backup setup.
To manage these separate outage demands safely, reliable battery backup systems provide clean indoor power without toxic fumes or engine noise. The following EcoFlow systems match these two home outage requirements.
EcoFlow TITAN 5000 Classic
The EcoFlow TITAN 5000 Classic handles vital everyday household plug-in loads cleanly inside your home.
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
EcoFlow TITAN 5000
The EcoFlow TITAN 5000 delivers dual-voltage output to handle heavy domestic circuits and essential residential mechanical systems.
EcoFlow TITAN 5000
How the two products divide the job
The right backup system depends on which household essentials you need to keep running during a winter outage. The EcoFlow TITAN 5000 Classic is suited to compatible 120V essentials, while the EcoFlow TITAN 5000 can support approved 120V and 240V circuits with the appropriate setup.
  • EcoFlow TITAN 5000 Classic: Best for a safe zone with 120V work lights, phone chargers, internet equipment, and other compatible devices within its 4,000W output rating. Plug-in devices according to the manufacturer's instructions. It has no 240V output, so it cannot directly power a 240V well pump or heating circuit.
  • EcoFlow TITAN 5000: Better suited to homes that need backup for an approved 240V heating or well pump circuit. This setup requires a compatible Smart Home Panel 10 and installation by a licensed electrician. The electrician should verify voltage, startup and running loads, and usable battery capacity.
  • Important limitations: Neither system repairs a burst pipe or guarantees that plumbing won't freeze. Address leaks, hidden frozen pipes, and electrical hazards with the appropriate licensed professional before focusing on backup power.
  • Placement and charging: Both systems are rated IP20 for indoor use and shouldn't be charged below 32°F. Keep them in a protected indoor location within the manufacturer's operating-temperature limits, not in a freezing garage or crawl space.
  • Solar recharging: A typical grid-tied rooftop solar system shuts down during a grid outage unless it has suitable backup functionality. To recharge an EcoFlow TITAN during an outage, use a compatible solar setup connected to the power station's own solar input, following the manufacturer's instructions.
Example runtime estimates
This runtime table shows realistic power duration for common safe-zone emergency electronics:
Setup
Usable energy (capacity × 0.85)
Example load
Estimated runtime
EcoFlow TITAN 5000 Classic, 1 unit (5,000Wh)
4,250Wh
150W safe-zone load (example value: LED work light, router, modem, phone charging)
4,250 ÷ 150 = about 28 hours
4,250Wh
400W (example value: safe-zone load plus a small load-matched device)
4,250 ÷ 400 = about 10.6 hours
Note: These runtime calculations are engineering estimates, not guaranteed operational figures. Real-world runtimes change based on operating temperatures, system age, and specific device ratings. Always check the electrical rating plates on your own appliances. Dedicated 240V heating blowers and well pumps have high startup surges; consult a licensed electrician to measure exact loads.
If your rural property relies on private water, knowing how many watts a well pump can draw helps you plan for sudden startup surge demands.
Once your backup power strategy is clear, let us look at the question most homeowners ask first when cold weather arrives.
What Temperature Do Pipes Freeze? A Number With Fine Print
Water freezes at 32°F under ordinary conditions. But household pipes don't necessarily freeze the moment outdoor temperatures reach that point.
Insulation, exposure, airflow, and the duration of the cold all affect the risk. That's why 32°F isn't a reliable warning threshold for every home.
What the source says
Source
How to use it
Water pipes have the potential to freeze and burst when the outside temperature reaches 20°F or below
Texas A&M AgriLife Extension, "Winter Storms: Frozen Pipes" (adapted from Red Cross and IBHS material)
Treat 20°F as a planning trigger, not a safe line
Uninsulated pipes can technically freeze at 32°F; insulated pipes can freeze if temperatures drop below 20°F
Summit County, Utah, "FAQs: Frozen Pipes"
Exposed pipes are at risk sooner
Keep the furnace at 55°F or higher so the home stays above freezing
FEMA, "Winterizing Your Home" (DR-4749-IL)
A thermostat floor, especially when you're away
Always treat 20°F as a critical threshold to double-check vulnerable plumbing throughout your property. Keep in mind that wind drafts can freeze an exposed pipe in an open crawl space even when outdoor air temperatures sit comfortably above 25°F.
Preparing your plumbing before freezing weather hits is always the best defense. Taking time to winterize your home for safety gives your water lines strong protection against sudden polar plunges.
Once water flows freely from your taps again, completing a few simple checks keeps a thawed pipe from causing hidden water damage later on.
After the Thaw: Leak Checks and Keeping It From Happening Again
The pipe you just thawed out requires close monitoring over the next few hours. Ice can act like a temporary plug, keeping a split seam sealed until all the ice melts away. Once water starts running normally, take deliberate steps to confirm your plumbing system is sound.
Post-thaw inspection steps
Work through this straightforward checklist once water pressure returns:
Post-thaw inspectionPost-thaw inspection
  1. Reopen valves gradually: Turn supply valves slowly to prevent water hammer, and inspect pipe joints, elbows, and soldered fittings for seeping water (Summit County, Utah).
  2. Watch prolonged freezes closely: The University of Missouri Extension warns that lines frozen solid for several hours carry higher rupture risks. Check these sections repeatedly over the first day.
  3. Inspect nearby building materials: Look closely along finished walls, ceilings, and baseboards for soft drywall, water staining, or damp carpet.
  4. Confirm steady pressure: If pressure drops suddenly when all indoor fixtures are closed, an unnoticed leak may be running under your foundation or inside a crawl space.
Preventing future plumbing freezes
Simple maintenance steps protect your home from dealing with frozen pipes again next winter:
  • Disconnect garden hoses: Salt Lake City Public Utilities reminds homeowners to disconnect outdoor hoses before winter. Water trapped in a hose expands back into the sillcock, splitting the interior wall pipe.
  • Insulate exposed runs: FEMA suggests wrapping vulnerable exterior pipes and unheated runs with quality foam insulation sleeves and thermostatically controlled heat tape.
  • Label the main shutoff: Show everyone in your household where the main water valve sits and how to turn it off during an emergency.
  • Notify your insurance company: Oklahoma State University Extension recommends contacting your homeowner insurance provider right away if pipe breaks cause structural water damage.
Severe winter weather creates multiple hazards beyond frozen water lines. Following practical winter safety tips for the home helps keep your heating systems, travel plans, and loved ones protected throughout the season.
Managing a frozen pipe takes a calm, orderly approach. Locate your main shutoff valve first, open the faucet tap, apply slow and gentle heat, and never use open flames.
Treat outdoor temperatures near 20°F as your trigger to insulate crawl space lines and monitor exposed plumbing. If a pipe is buried inside a wall or shows signs of splitting, turn off your main valve and call a licensed plumber immediately.
If winter storm power outages are a concern where you live, consider your backup options. Look into the EcoFlow TITAN 5000 Classic for clean 120V safe-zone lighting, communication, and basic electronics. For larger setups requiring an electrician-installed Smart Home Panel 10 to power essential heating or well pump circuits, look into the EcoFlow TITAN 5000.
What should I do first if my pipes freeze?
Locate your main water shutoff and open the faucet supplied by the frozen line. Check for leaks and electrical hazards before attempting to thaw the pipe. If you suspect a burst or can't safely reach the frozen section, call a licensed plumber.
Can I use a space heater to thaw a frozen pipe?
The University of Missouri Extension notes that a portable electric space heater can thaw frozen pipes. Place it safely away from drywall, framing lumber, and insulation. Never leave an active space heater unattended, and never place it on damp or wet flooring.
What temperature do pipes freeze?
Water freezes at 32°F under ordinary conditions, but pipes freeze at different rates depending on their exposure and insulation. Texas A&M AgriLife Extension warns that pipes have the potential to freeze and burst when outdoor temperatures reach 20°F or below.
Will a frozen pipe thaw on its own?
A pipe can thaw naturally when outside temperatures rise, but Summit County, Utah, warns that leaving it alone increases your risk of severe pipe bursts. Thawing the line with controlled, gentle heat lets you spot leaks right away and take action before water spreads.
Can a home battery keep my pipes from freezing in an outage?
A home battery cannot guarantee your pipes will never freeze. However, a properly sized system like the EcoFlow TITAN 5000, installed with an approved Smart Home Panel 10 by a licensed electrician, can keep crucial furnace blowers and heating controls running during winter grid outages.
Tips
