What Are TDU Delivery Charges? How They Work on Your Electricity Bill
Signing up for a lower electricity rate does not eliminate every charge on a Texas power bill. If you live in a deregulated part of the state, one company sells you electricity while another company delivers it. The cost of that second job appears on your bill as a TDU delivery charge.
These fees help pay for the poles, wires, substations, meters, and repair crews that keep electricity moving through the local grid. Because part of the charge is tied to household usage, it can rise during a hot Texas summer even when the price in your retail plan stays the same. Understanding the line item makes it easier to read an Electricity Facts Label, compare plans on equal terms, and see which parts of the bill you can realistically reduce.
Your retail electricity provider is responsible for the plan you select and the bill you receive. It does not own the neighborhood power lines or send a crew when a transformer fails. Those responsibilities belong to the utility assigned to your address, and TDU delivery charges cover the regulated cost of that local service.
Definition of a Transmission and Distribution Utility (TDU)
A Transmission and Distribution Utility (TDU), also known as a Transmission and Distribution Service Provider (TDSP), owns and maintains the physical grid within a defined service territory. Its equipment includes substations, utility poles, overhead and underground lines, transformers, and smart meters. The TDU also restores service after local outages.
If a thunderstorm drops a tree limb onto a line in Dallas or a transformer fails in Houston, the TDU—not the company that sold the electricity plan—dispatches the repair crew. Customers do not shop for this utility. The TDU serving a home is determined by its location.
Differences Between a TDU and an Electricity Provider
Texas separates electricity delivery from retail electricity sales in deregulated markets. The two businesses may appear on the same bill, but they perform different jobs:
Feature
Retail Electric Provider (REP)
Main Job
Maintains poles, wires, meters, and fixes outages.
Buys wholesale power, sets plan rates, and sends your bill.
Can You Choose?
No—assigned strictly by your street address.
Yes—you can shop and switch providers anytime.
Who Sets Rates?
Regulated and approved by the Public Utility Commission of Texas (PUCT).
Set by the provider based on market competition.
Examples
Oncor, CenterPoint Energy, AEP Texas, TNMP.
TXU Energy, Reliant, Octopus Energy, Rhythm.
The Retail Electric Provider (REP) is the customer’s billing contact. Under most residential plans, it collects the approved TDU fees through the monthly statement and passes the money to the local utility. A bill may show the delivery charge separately, while an advertised plan price may combine delivery and energy costs into one average rate. That difference in presentation is one reason the Electricity Facts Label matters when comparing plans. If you searched for “TDU energy,” look for the delivery charge and the retail energy charge as separate components of the plan price
How Are TDU Delivery Charges Calculated?
Most residential TDU charges have two parts. One is a fixed fee that applies each billing period; the other changes with the number of kilowatt-hours delivered to the home. A low-usage month can reduce the second part, but it generally will not remove the first.
Understand Fixed and Usage-Based TDU Charges
  • Fixed Monthly Charge (Base & Metering): This flat amount supports basic account, metering, and grid-connection costs. It still applies if the home uses little or no electricity during the billing period.
  • Usage-Based Delivery Charge (Per kWh): This charge is stated in cents per kilowatt-hour and increases as grid consumption rises. A central air conditioner running through a 102°F August afternoon can add substantially more delivered energy than the same home uses during mild spring weather.
The variable charge is based on electricity delivered through the grid, not simply the rate the REP charges for the energy itself. That is why reducing consumption can affect both the supply portion of a bill and the usage-based portion of the TDU fee.
Find Your Local TDU Delivery Rates
TDU rates are regulated rather than negotiated between an individual customer and the utility. The Public Utility Commission of Texas (PUCT) reviews and approves changes, including updates that commonly take effect around March 1 and September 1, as well as adjustments associated with other rate proceedings.
Before enrolling in a plan, look at its Electricity Facts Label (EFL). The label identifies the applicable delivery charges used in the plan’s price calculation. The same information may appear in the itemized portion of a monthly statement and in PUCT rate materials. Because approved charges can change, an older bill or saved comparison page may not reflect the rate in effect today.
The following figures provide an illustrative view of common residential fee structures in the major deregulated service territories. They are useful for understanding the format of the charge, not as a substitute for the current EFL:
TDU Service Territory
Major Cities Covered
Typical Monthly Base Charge
Typical Usage Delivery Rate
CenterPoint Energy
Houston, Katy, Sugar Land, The Woodlands
~$4.39
~5.4¢ – 5.9¢ / kWh
Oncor
Dallas, Fort Worth, Arlington, Plano, Waco
~$4.23
~5.2¢ – 5.6¢ / kWh
AEP Texas Central
Corpus Christi, McAllen, Laredo, Victoria
~$3.24
~5.2¢ – 5.6¢ / kWh
AEP Texas North
Abilene, San Angelo, Vernon
~$3.24
~5.1¢ – 5.5¢ / kWh
Texas-New Mexico Power (TNMP)
League City, Texas City, Lewisville, parts of West TX
~$7.85
~6.5¢ – 7.2¢ / kWh
Note: Because PUCT riders, including transmission and distribution cost recovery factors, may be updated in March and September, use these figures only as a general baseline. Confirm the exact cents-per-kWh charge on the current EFL for the plan under consideration.
Calculate Your Total Monthly TDU Charges
The basic calculation is:
Total TDU Charge = Fixed Monthly Fee + (Monthly Usage in kWh × Per-kWh TDU Rate)
Suppose a household uses 1,200 kWh in a billing period. Using a hypothetical $4.23 monthly fee and a hypothetical rate of 5.40¢ per kWh, the calculation looks like this:
  1. Fixed monthly charge: $4.23
  2. Usage charge: 1,200 kWh × $0.0540 = $64.80 Total TDU delivery cost: $4.23 + $64.80 = $69.03
The cents-per-kWh figure must be converted to dollars before it is multiplied by usage. In this example, 5.40¢ becomes $0.0540. The resulting $69.03 is the delivery portion of the bill. The REP’s energy charge, taxes, and any other applicable plan charges are added separately.
If you lack a usage history, you can calculate kWh usage from appliance wattage and runtime to estimate the usage input.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Do TDU Delivery Charges Affect Your Electricity Bill?
TDU delivery charges help explain why the total due can change even when a customer has a fixed-rate electricity plan. The energy price named in the contract and the regulated delivery rate are separate components. Usage, the local service territory, and an approved TDU adjustment can all change the final amount.
TDU Charges Increase Your Total Electricity Costs
On a typical Texas residential statement, delivery fees may represent 35% to 45% of the entire total. The exact share depends on the plan, the TDU territory, and how much electricity the household used during that billing period.
A 12-month fixed-rate contract generally locks the REP’s energy supply price, not every regulated utility charge that may appear on the bill. When an approved TDU rate changes in March or September, the provider passes the new delivery amount through to customers. As a result, the household’s all-in average price per kilowatt-hour can move even though the contracted energy rate has not changed.
TDU Rates Vary Across Service Areas
Delivery costs are not uniform across Texas. Oncor, CenterPoint Energy, AEP Texas, and TNMP operate different networks, each with its own approved rate structure. The work required to serve a dense Houston suburb is not the same as maintaining long stretches of line across a less populated part of West Texas.
That distinction can produce different delivery costs for homes on opposite sides of a service-territory boundary, even if both customers select the same REP plan. A customer can choose among available retail providers, but cannot select a different TDU for the same address. The location establishes the delivery utility and its approved charges.
TDU Charges Affect Electricity Plan Savings
The lowest advertised energy charge is not always the lowest total price. A plan promoted at 8.5¢ per kWh may be showing only the REP’s energy component, while the TDU charge appears separately. Another plan may present a bundled price that already includes delivery. Comparing those headline figures alone can create a misleading impression of the monthly cost.
Use the Average Price per kWh section of the Electricity Facts Label instead. It shows the calculated average at 500 kWh, 1,000 kWh, and 2,000 kWh and accounts for the plan’s energy rate, TDU charges, and applicable recurring fees. Review all three usage levels, then compare them with the home’s actual consumption over the past year. A plan that looks inexpensive at 1,000 kWh may work differently at the amount the household normally uses in August or January.
You can also reduce the amount of electricity you buy from the grid. A solar battery can store excess rooftop generation for later use, which may reduce the kilowatt-hours you buy from the grid.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
How Can You Reduce Your Household Electricity Costs?
The fixed TDU fee cannot be removed through conservation, and customers cannot negotiate the utility’s approved rates. They can, however, reduce the usage-based delivery charge by drawing fewer kilowatt-hours from the grid. The same reduction can also lower the energy portion of the bill.
Cut Unnecessary Electricity Use
Texas homes often use the most electricity during the cooling season, so routine decisions around air conditioning and major appliances can make a visible difference:
  • Adjust your thermostat by 2–3 degrees: If the household remains comfortable, raising the cooling set point from 73°F to 76°F while everyone is away or asleep can shorten air-conditioner runtime.
  • Shift heavy appliance runs: Running the dishwasher, clothes dryer, or pool pump in the morning or evening limits the extra indoor heat created during the hottest part of the afternoon. Eliminate phantom loads: Smart power strips can disconnect monitors, gaming equipment, and chargers that continue drawing standby electricity when they are not being used.
These steps do not change the TDU’s per-kWh rate. Their value comes from reducing the number of grid-supplied kilowatt-hours to which that rate applies. Managing cooling, cutting standby loads, and improving insulation are other ways to reduce your electricity bill.
Improve Household Energy Efficiency
Efficiency improvements reduce the amount of work required to keep the home comfortable. In a climate where cooling equipment may run for much of the year, addressing the building itself can matter as much as changing daily habits:
  • Seal air leaks and attic hatches: Weatherstripping around exterior doors and adequate attic insulation help keep conditioned air inside instead of losing it to a Texas attic that can reach 130°F.
  • Service your HVAC system every spring: Check filters monthly and replace dirty ones as needed. Keeping the outdoor condenser coils clean also helps the system move heat without unnecessary strain.
  • Switch to heat pump appliances: High-efficiency heat pump water heaters and variable-speed HVAC equipment can use substantially less electricity than older resistance-based systems.
Start with the parts of the home that drive the largest loads. Cutting a small standby draw can help, but reducing unnecessary HVAC runtime usually has a much larger effect on both the energy charge and the usage-based TDU charge.
Store Solar Energy for Peak Hours
Solar panels can reduce grid purchases while they are producing, and battery storage can save some of that daytime production for later. Instead of exporting every unused kilowatt-hour at midday and buying electricity back after sunset, a household can use stored solar energy for selected evening loads.
A portable power station can supply a few plug-in devices from stored solar. A system connected to the home’s electrical panel can serve selected household circuits.
For a Texas plan with a per-kWh TDU charge, each kilowatt-hour supplied from on-site solar or stored solar rather than the grid can reduce the usage-based delivery portion of the bill. The fixed monthly TDU fee remains in place. The financial result also depends on the retail plan’s rules for imported and exported electricity, so storage should be evaluated as part of the home’s overall usage pattern.
For a household that wants to use solar energy through a portable power station, the EcoFlow DELTA 3 Max Plus Portable Power Station offers a flexible option. It has a 2,048Wh base battery capacity, charges from compatible solar panels, and can power selected essentials, including a refrigerator or Wi-Fi router, through its AC outlets. Self-Powered mode gives stored energy priority over grid power, and extra batteries can expand total capacity to 10kWh.
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
Homes with larger rooftop arrays and more midday surplus can pair the EcoFlow TITAN 5000 Plus with the EcoFlow Smart Home Panel 10 for a more complete home energy storage setup. Its dual-MPPT design supports up to 8kW of solar input for larger solar systems. The 5kWh base battery capacity expands to 30kWh, providing storage for daytime surplus that can be used at night or through cloudy periods. With the Smart Home Panel 10, the system supports both 120V and 240V household circuits and can provide backup power to up to 10 selected circuits, including everyday loads such as lighting and a microwave. The Smart Home Panel 10 requires professional installation by a qualified electrician and must be wired into the home’s existing electrical panel.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
TDU delivery charges are a standard part of residential electricity bills in deregulated areas of Texas. The fixed portion remains due regardless of usage, while the per-kWh portion rises and falls with the amount of electricity delivered from the grid. The utility serving the address and any approved rate changes also affect the final cost.
When comparing plans, read the Electricity Facts Label rather than relying on a promotional rate by itself. Check the average price at the usage level that most closely matches the household’s history, and confirm which TDU charges are included in that calculation. Once a plan is in place, conservation, home-efficiency improvements, and greater use of on-site solar energy can reduce grid consumption—and, with it, the usage-based part of the delivery charge.
Can You Avoid TDU Delivery Charges in Texas?
No, you cannot avoid TDU delivery charges if your home is connected to the ERCOT power grid in a deregulated area of Texas. All REPs serving the same TDU territory generally pass through the applicable PUCT-approved delivery charges. However, you can reduce the usage-based (per-kWh) portion of those charges by lowering your grid consumption through energy efficiency or rooftop solar with battery storage.
Are TDU Delivery Charges the Same Across Texas?
No, TDU delivery charges vary depending on which utility service territory your home is located in. For example, customers in CenterPoint Energy (Houston) or AEP Texas pay different monthly base fees and per-kWh delivery rates than homeowners in Oncor (Dallas–Fort Worth) or TNMP. Rates are determined by each utility’s infrastructure maintenance costs and customer density.
Does Your TDU Handle Power Outages in Texas?
Yes, your local TDU—not your Retail Electric Provider—is responsible for fixing power outages, downed power lines, and damaged transformers. Even though you pay your monthly bill to a company like TXU or Reliant, you should contact your TDU directly (such as Oncor or CenterPoint) to report an outage or check restoration updates in your neighborhood.
Do Smart Meters Affect TDU Delivery Charges?
No, having a smart meter does not increase your TDU delivery rate or add extra surcharges to your bill. The cost of operating and maintaining digital meters is already built into your TDU’s standard monthly metering and customer charge. In fact, smart meters help you track 15-minute usage data on Smart Meter Texas, making it easier to spot energy spikes and lower your per-kWh delivery charges.
Save Bills
