Time-of-Use Electricity Plans: How They Work and How to Save on Energy Bills
Two homes can use the same amount of electricity in a month and still receive different bills. The difference may be timing. Under a Time-of-Use (TOU) plan, electricity costs more during designated high-demand periods and less when demand is lower. Running a dryer at dinner time, for example, may cost more than running the same cycle later that night.
That pricing structure can reward households with flexible schedules, but it is not automatically cheaper for everyone. The result depends on the utility’s rate windows, the difference between peak and off-peak prices, and when the household normally uses its largest electrical loads. This guide explains how TOU electricity pricing works, how schedules change, and how to evaluate a plan using your own usage rather than a general estimate.
What Is a Time-of-Use Electricity Plan?
A time-of-use tariff electricity plan charges different per-kWh rates depending on when electricity is used. Instead of paying one supply rate around the clock, customers pay according to the period in which each kilowatt-hour is consumed. The utility publishes the schedule in advance, so the rate does not change unexpectedly from one hour to the next.
Time-of-use electricity rates may be grouped into two periods or into peak, shoulder, and off-peak blocks. Some schedules change by season or treat weekends and holidays differently. The details matter more than the TOU label itself. Before enrolling, read the complete rate calendar and compare it with the hours when your home uses the most power.
How Time-of-Use Electricity Pricing Works
Electricity demand changes throughout the day. Late-afternoon and early-evening demand often rises as people return home, prepare meals, adjust heating or air conditioning, and use appliances at the same time. Meeting that demand can be more expensive, so a TOU tariff assigns a higher per-kilowatt-hour (kWh) rate to that window.
Demand is generally lower late at night. Some grids also have periods of strong daytime renewable production, which can create a lower-cost window around midday. A TOU plan reflects those patterns through scheduled rates rather than charging every customer the same price at every hour.
A compatible meter records how much electricity the home uses during each interval. On the bill, those kilowatt-hours are grouped by rate period and multiplied by the applicable price. Delivery charges, fixed customer charges, taxes, and other bill components may be handled separately, depending on the utility. Moving a dishwasher cycle can reduce the TOU supply charge, but it does not necessarily change every line on the statement.
Time-of-Use Rates vs. Fixed-Rate Electricity Plans
A fixed-rate or flat-rate plan charges the same per-kWh price throughout the day. The monthly bill still changes with consumption, but the time at which that electricity is used does not affect the rate. This makes costs easier to estimate for households that cannot rearrange cooking, cooling, laundry, or vehicle charging.
A TOU plan creates more variation. Electricity used during an off-peak window may cost less than the flat rate, while power used during peak hours may cost considerably more. The plan works best when a household can move a meaningful share of its larger loads without creating an impractical routine.
Neither structure is universally cheaper. A home that charges an electric vehicle overnight and runs major appliances outside the evening peak may benefit from TOU pricing. A household that depends heavily on electricity during the most expensive hours may be better served by a flat rate, even if the TOU plan advertises a very low overnight price.
When Are Electricity Rates Highest and Lowest?
Many TOU schedules place their highest prices in the late afternoon and evening, but there is no nationwide schedule for peak and off-peak hours. Local demand, weather, generation resources, and the utility’s rate design all influence the calendar. The schedule printed in the tariff or account portal is the one that controls the bill.
The hour alone is not enough. A period that is off-peak in winter may become peak in summer, and a weekday rate may not apply on Sunday or a listed holiday. Review the complete calendar before setting appliance timers or changing thermostat schedules. Examples of peak and off-peak schedules show why it pays to check weekday, weekend, and seasonal rules before setting timers.
Peak, Off-Peak, and Shoulder Hours Explained
Most plans use two or three pricing tiers. Peak hours carry the highest rate. Off-peak hours carry the lowest. A shoulder or mid-peak period sits between them and may cover the transition into or out of the busiest part of the day.
The table below shows common examples, not a universal utility schedule:
Pricing Tier | Typical Time Window | Grid Demand & Pricing Level | Best Household Activities |
Peak Hours | 4:00 PM – 9:00 PM (or 3:00 PM – 8:00 PM) | Highest: Steepest per-kWh rates due to evening demand surge | Light LED lighting, laptops, TV, low-wattage electronics |
Shoulder (Mid-Peak) Hours | 7:00 AM – 4:00 PM & 9:00 PM – 11:00 PM | Moderate: Balanced grid load with mid-tier rates | General daytime living, remote work equipment, refrigeration |
Off-Peak (Super Off-Peak) Hours | 11:00 PM – 7:00 AM | Lowest: Excess grid capacity and discounted per-kWh rates | EV charging, laundry, dishwasher cycles, water heating |
Note: TOU pricing periods and electricity rates vary by utility, location, season, and rate plan. The time windows shown above are general examples and may not apply to every U.S. household. Check with your local utility for the exact peak, shoulder, and off-peak hours.
How TOU Rate Schedules Change by Season and Utility
Summer schedules often emphasize afternoon and evening demand because air conditioning use remains high as people arrive home. The spread between peak and off-peak rates may also be wider from June through September. Winter schedules can use different time blocks, particularly in regions where electric heating creates a morning rise in demand.
For example, a winter plan may designate a morning peak between 6:00 AM and 9:00 AM, then apply another price later in the day. A utility in Texas or Arizona may focus heavily on summer cooling demand, while a utility in the Pacific Northwest may publish a different seasonal structure. Those regional differences make national “best hours” unreliable.
Check both the effective dates and the time windows. If a summer calendar ends at the close of September, an appliance schedule created in July may no longer match the October rate periods. Review the plan again when the season changes instead of assuming the same timer settings will remain optimal all year.
How Do Weekends and Holidays Affect Time-of-Use Rates?
Some utilities classify weekends as off-peak because commercial and industrial demand is lower. Others retain a peak period but shorten it or charge a different rate. Holiday treatment varies in the same way. Memorial Day, Labor Day, and Thanksgiving may receive off-peak pricing under one plan and ordinary weekday treatment under another.
The utility’s holiday calendar should identify the exact dates and rate rules. Do not assume that every federal holiday qualifies or that the weekend schedule automatically extends to Friday or Monday. When lower weekend rates do apply, they can provide a convenient opportunity for laundry, dishwashing, vehicle charging, and other tasks that are difficult to postpone on weekdays.
Is a Time-of-Use Electricity Plan Right for Your Home?
The answer depends less on total monthly consumption than on the timing of that consumption. A large home with flexible loads may save under TOU pricing, while a smaller household that uses most of its electricity during the evening peak may pay more.
Look at the home’s routine before focusing on the plan’s lowest advertised rate. Work schedules, school hours, climate-control needs, cooking habits, electric vehicles, pool equipment, and water heating can all shape the result.
Households That Can Shift Electricity Use to Off-Peak Hours
TOU pricing is easier to manage when large loads can be scheduled. An electric vehicle that charges overnight is a clear example. Dishwashers, washing machines, dryers, pool pumps, and some water-heating systems may also operate outside the evening peak without disrupting the household.
Remote workers, retirees, and people with flexible schedules may be able to run appliances during lower-cost daytime hours. Families can sometimes pre-cool the house before peak pricing begins, then allow the temperature to rise gradually while rates are higher. The best opportunities are recurring tasks that can be moved consistently, not one-time changes that are difficult to maintain.
Households With High Peak-Hour Electricity Consumption
A TOU plan may be a poor fit when the household’s busiest hours line up with the most expensive rate period. Consider a family that leaves at 7:30 AM and returns at 5:30 PM. Air conditioning, an electric oven, laundry, entertainment devices, and personal-care appliances may all run before 9:00 PM. Shifting that entire routine may not be realistic.
Homes with inefficient cooling, weak insulation, or appliances without scheduling controls can face the same problem. The evening peak may arrive just as the building needs the most cooling or heating. If comfort or essential household activities require sustained peak-hour use, a flat-rate plan may offer more predictable costs. If those loads cannot move, a home battery can shift some grid purchases to lower-priced hours. Compare the potential bill savings with battery losses and system costs.
Do not judge the plan from one unusually mild or busy week. A schedule that looks economical in spring may perform differently during the hottest part of summer. Include months with heavy heating or cooling when reviewing the household’s likely result.
How to Compare TOU Rates With Your Household's Usage
Begin with actual interval data rather than a monthly total. If available, download 6 to 12 months of hourly or 15-minute readings from the utility account. That history shows how much electricity was used during each part of the day and captures seasonal changes that a single bill cannot.
Next, obtain the complete TOU schedule and the current flat-rate alternative. Separate historical use into the applicable peak, shoulder, and off-peak windows, then multiply each group by its corresponding rate. Add any fixed charges that differ between plans. Run the same usage through the flat-rate tariff so the comparison covers the same billing period.
Some utilities provide an online comparison tool that performs this calculation with smart-meter data. Review its assumptions before relying on the result. Confirm which season it uses, how weekends and holidays are classified, and whether taxes or monthly charges appear in both totals.
The difference between peak and off-peak prices is important, but it cannot determine savings by itself. If peak electricity costs 2.5x more than off-peak power, the outcome still depends on the flat rate and the share of consumption in every pricing tier. A 70% to 75% off-peak target may be useful only when it comes from the terms of the particular plan being evaluated; it should not be treated as a universal threshold.
How to Save Money on a Time-of-Use Electricity Plan?
The most effective TOU strategy is usually a short list of repeatable changes. Identify the household’s largest flexible loads, move them away from the peak window, and check the next bill or usage report to see whether the shift produced a meaningful result.
Avoid making the routine so complicated that no one follows it. Appliance timers, charging schedules, and thermostat programs can handle much of the work automatically once you enter the correct rate windows. If you already have rooftop solar panels, a solar battery can store surplus daytime generation for use during the evening peak.
Monitor Your Electricity Usage and Identify Peak-Hour Consumption
The utility’s usage portal is the best place to start. Compare typical weekdays and look for recurring increases during peak periods, such as 4:00 PM to 9:00 PM. Then connect those increases with what was happening at home: cooling, cooking, laundry, vehicle charging, or another large load.
Plug-in monitors can help with individual devices, while a compatible whole-home or circuit-level monitor can show how several loads behave together. The purpose is not to watch every watt throughout the day. It is to find the few appliances responsible for a large share of expensive-hour consumption. For a rough appliance-level estimate, you can calculate kWh usage from running wattage and operating time.
Recheck the data after changing a schedule. If moving the dishwasher produces little difference but delaying EV charging removes a clear evening spike, focus on the change that matters. A month of ordinary use provides a more useful test than a single day arranged only for the experiment.
Use Battery Storage to Reduce Peak-Hour Electricity Costs
Battery storage can move electricity across time. The battery charges when rates are lower, then supplies connected devices or circuits during a more expensive period. A home with solar can also store daytime production for use after solar output falls and the evening peak begins.
For apartment renters or homeowners without rooftop solar, the EcoFlow DELTA 3 Max Plus Portable Power Station offers a plug-and-play way to take advantage of TOU rates without installing permanent home battery hardware. Its TOU Mode lets you schedule charging during off-peak hours and discharging during peak windows to run everyday essentials like a refrigerator, Wi-Fi router, or home office setup. With a 2,048Wh capacity, 3,000W AC output, and expandability up to 10kWh via extra batteries, it can handle a wide range of household devices, depending on their wattage.
For single-family homeowners looking to cover larger whole-home loads, the EcoFlow TITAN 5000 Plus is engineered for residential energy management. The Smart Home Panel 10 requires professional installation and integration with your home’s electrical panel. Paired with the Smart Home Panel 10 and OASIS 3.0, the system automatically coordinates battery charging and circuit-level power delivery around your utility’s TOU schedule and real-time household demand. Its capacity scales from 5kWh up to 30kWh and supports up to 8kW of solar input, making it well suited for households looking to combine off-peak grid charging with rooftop solar generation.
Battery use should follow the same rate analysis as appliance scheduling. Charging during a lower-cost period and discharging during peak hours is most useful when the price difference and household load justify moving that energy. Choose the devices or circuits that matter most rather than assuming every load must be supplied from storage.
Schedule Flexible Appliances During Off-Peak Hours
Dishwashers and washing machines often include a Delay Start setting. Enter the utility’s off-peak start time so the cycle begins after 9:00 PM or 11:00 PM, depending on the plan. Set the schedule deliberately instead of choosing a late hour from a general TOU example.
Electric vehicles can usually be scheduled through the vehicle or Level 2 charger. An overnight start prevents charging from beginning as soon as the car is plugged in during the evening peak. Pool pumps and compatible electric water-heating controls may offer similar scheduling options.
Not every appliance should run unattended. Follow the manufacturer’s operating instructions and consider noise, building rules, and the household’s normal routine. The goal is a workable schedule that can be repeated, not a one-night attempt to move every load.
Use a Smart Thermostat to Manage Heating and Cooling
Heating and cooling are often among a home’s largest electrical loads, so thermostat timing can strongly affect a TOU bill. During warm weather, a smart thermostat can pre-cool the house by 2°F to 3°F during a less expensive period, such as 1:00 PM to 4:00 PM. The setting can then rise slightly during a 4:00 PM to 9:00 PM peak window.
The house does not need to become uncomfortably cold before peak pricing begins. A modest adjustment may reduce compressor operation during expensive hours while keeping indoor conditions reasonable. Results depend on insulation, outdoor temperature, equipment capacity, and how quickly the home gains heat.
Use smaller changes if a large setback causes uncomfortable temperatures or an aggressive recovery cycle later. In winter, pay attention to how the heating system responds; a schedule that calls for rapid recovery may use more electricity than expected. Review the usage data after several comparable days and adjust the program based on the home’s actual behavior.
A Time-of-Use electricity plan can reduce energy costs when a household can consistently move substantial consumption away from expensive periods. The lowest off-peak rate is only part of the decision. Peak pricing, seasonal schedules, weekend rules, fixed charges, and the household’s own interval data all affect the final bill.
Before switching, compare several months of actual usage under both the TOU and flat-rate options. If the plan fits, begin with a few manageable changes: schedule vehicle charging and major appliances, adjust climate control before the peak window, or use stored energy when rates are highest. Then review a complete billing cycle. The best TOU strategy is the one that lowers costs without making the household’s daily routine unnecessarily difficult.
Can I Participate in the Time-of-Use Rate Without a Smart Meter?
No, almost all U.S. utilities require an interval-capable smart meter (AMI meter) to enroll in a Time-of-Use rate plan. Traditional analog meters only track total cumulative kWh used between monthly readings, whereas TOU billing needs timestamped data showing exact consumption during peak, shoulder, and off-peak windows. If your home still has a legacy meter, your utility will typically upgrade it at no extra charge when you request a TOU tariff.
Does Time-of-Use Not Make Sense for Solar Users?
Time-of-Use plans can work particularly well for solar homeowners, especially when paired with battery storage or under modern net-billing programs such as California’s NEM 3.0. Solar panels typically generate the most electricity between 10:00 AM and 3:00 PM, when rates are often lower. By storing excess midday solar energy in a home battery, homeowners can use it during higher-priced evening hours, typically between 4:00 PM and 9:00 PM, reducing the need to purchase electricity from the grid when rates are higher.
What Wastes the Most Electricity in a House?
Heating and cooling account for approximately 52% of total household energy consumption in the U.S., making them the largest combined energy end uses in a typical home, according to the EIA. Other significant electricity users include water heaters, clothes dryers, and refrigerators. Hidden “vampire” or standby loads from always-on electronics and other plugged-in devices can also account for approximately 5% to 10% of residential electricity use, according to Lawrence Berkeley National Laboratory.
What Does TOU-D-4-9pm Mean?
TOU-D-4-9pm is a specific residential Time-of-Use rate schedule offered by Southern California Edison (SCE) where peak electricity rates apply every day from 4:00 PM to 9:00 PM. The “D” stands for Domestic (residential service), and the 4-9pm designates the five-hour daily window when per-kWh prices are highest year-round, while all other hours fall under lower off-peak or super off-peak pricing depending on the season.
How Much Would It Cost to Run My AC for One Hour?
Running a standard 3-ton central air conditioner (which draws roughly 3,000 to 3,500 watts, or 3 to 3.5 kWh per hour) costs about $0.45 to $0.63 per hour at an off-peak rate of $0.15–$0.18/kWh, but jumps to $1.35 to $1.93 per hour during a $0.45–$0.55/kWh peak window. A smaller 10,000 BTU window AC unit uses around 900 to 1,000 watts (1 kWh per hour), costing roughly $0.15 to $0.55 per hour depending on your current TOU tier.
