Average Electric Bill for a 2-Bedroom Apartment: How to Lower Your Costs?
When the monthly electric bill for a two-bedroom apartment jumps, it can be difficult to tell whether usage increased or the effective rate changed. There is no single official U.S. average specifically for two-bedroom apartments, according to the U.S. Energy Information Administration (EIA). As an illustrative planning estimate, 500 to 850 kWh at the August 2026 national average residential electricity price of 18.16¢/kWh equals about $91 to $154 before any fixed account charges, based on EIA electricity price data. Heating, cooling, building characteristics, local rates, and household habits can move the actual bill well outside that range. Here’s how to compare a bill and identify practical ways to lower it.
What Is the Average Electric Bill for a 2-Bedroom Apartment?
A monthly bill depends on electricity use, the applicable rate, and fixed or delivery charges. The U.S. Energy Information Administration publishes residential prices and bills, but not a national average limited to two-bedroom apartments. The average electric bill for 2 bedroom apartment households is therefore best estimated from the unit’s actual kWh use and applicable rate.
Average Monthly Electricity Costs in the US
Households in two-bedroom apartments may pay around $95 to $135 per month for electricity, depending on location, apartment size, and energy usage. The amount will depend on whether you have shared walls or have a top floor unit or bottom floor. The season and local weather also matter because a mild spring monthly bill may be much lower than a bill after a hot summer month.
Average Electricity Usage for a 2-Bedroom Apartment
An 850- to 1,100-square-foot apartment may use several hundred kWh of electricity per month, depending on household size and energy needs. Usage will generally be higher if space heating, water heating, and cooking appliances all run on electricity rather than natural gas.
Apartment Setup | Estimated Monthly Usage | Estimated Monthly Cost (at ~$0.165/kWh) |
Gas heat and water heater; electricity for lights, AC, fridge, and electronics | 500–650 kWh | $83–$107 |
All-electric unit with electric heating, water heater, and AC | 750–1,000+ kWh | $124–$165+ |
Note: These figures are illustrative estimates, not fixed averages or official benchmarks. Actual monthly electricity consumption and costs vary depending on apartment size, household occupancy, climate, energy efficiency, appliance usage, and local electricity rates. Costs are calculated using an estimated rate of $0.165/kWh and may differ from your actual utility bill.
How Do Electricity Costs Vary by State?
Where you live can make a big difference in what you pay for the same amount of electricity. At 750 kWh a month, these rate estimates show how bills can vary across the country. To put these state estimates in context, compare them with how much electricity costs per month for U.S. households overall.
Region / State Example | Average Residential Rate ($ per kWh) | Estimated Monthly Bill (at 750 kWh/month) |
Washington / Idaho (hydro-heavy) | ~0.11–0.12 | $83–$90 |
Texas / Florida (moderate rates, high AC demand) | ~0.14–0.15 | $105–$113 |
New York / Massachusetts (higher grid and delivery fees) | ~0.23–0.28 | $173–$210 |
California (tiered and time-of-use rates) | ~0.30–0.35+ | $225–$263+ |
Factors Affecting the Electric Bill for a 2-Bedroom Apartment
The average electric bill for two bedroom apartment units varies with the floor plan, local rate, heating and cooling system, and how many people are home during the day. Two otherwise similar apartments can therefore have very different monthly costs.
Location and Local Electricity Rates
Electricity costs vary by utility and state, and the rate per kWh is only part of the bill. Some providers also charge monthly customer fees, delivery fees, or seasonal rates. In deregulated markets such as Texas and parts of Pennsylvania, your utility company and its contract can make a noticeable difference in the price you pay.
Heating and Cooling Usage
Heating and air conditioning can account for a large share of an apartment’s electricity use. A top-floor unit may need more cooling on hot afternoons. Window AC units and electric baseboard heaters can also use more electricity than efficient heat-pump systems, although actual consumption depends on the equipment, climate, and settings.
Appliance Energy Efficiency
An older refrigerator with worn door seals may use more electricity than a newer efficient model. Electric dryers and water heaters can also add substantially to the total. Several partial loads of laundry or dishes each week may use more electricity than running fewer full loads, when the appliance instructions allow it.
Number of Occupants and Daily Usage Habits
A two-bedroom apartment where two people work from home may use more daytime electricity than a unit that is empty during working hours. Computers, monitors, cooking, electric water heating, and more frequent dishwasher or laundry cycles all add to usage. Equipment charged at home, including an EV or home battery, should also be counted when comparing one month with another.
How Can You Tell If Your 2-Bedroom Apartment Electric Bill Is Too High?
To judge whether the average power bill for a 2 bedroom apartment is a useful comparison, first check the usage and charges on your own statement. A higher bill does not always mean you used more electricity; the rate or fixed charges may have changed. If kWh increased, consider changes in routine, weather, occupancy, or appliance performance.
Compare Your Monthly Electricity Usage
Look beyond the dollar amount at the top of your bill and check how many kilowatt-hours (kWh) you consumed. Most utility statements include a 12-month bar chart comparing your current usage to the previous month and the exact same month last year. Comparing August to August usages is good to allow for seasonal weather variations. If your kWh jumped 25% compared to last year it could be explained if you added a roommate or more appliances. If there have been no major changes in your household, however, the increase could indicate that an appliance or system in your apartment is consuming more electricity than usual.
Review Your Electricity Rate and Bill Charges
Utility companies frequently adjust electricity rates in summer and winter, or apply new infrastructure rate adjustments. Divide your total bill by the total kWh used to find your effective all-in rate. If your kWh stayed flat at 700 kWh but your bill rose by $20, it could likely mean it’s due to higher utility rates, and not your daily habits. Also check whether your account switched from an introductory promotional rate to a higher variable month-to-month plan.
Check for Unusual Changes in Energy Consumption
When kWh usage spikes unexpectedly, this could mean there is a mechanical issue, such as one of the following:
Clogged HVAC filters: Dust buildup restricts airflow, forcing your blower motor and compressor to run nonstop.
Deteriorated refrigerator seals: A simple dollar-bill test on the fridge door reveals if cold air is leaking out. Close the door with a bill in the seal. If the bill slides out easily, the gasket needs replacement.
Faulty water heater thermostat: An electric water heater stuck in a continuous heating cycle can unknowingly add around $40 to $60 a month to your statement.
How Can You Lower Your Electric Bill in a 2-Bedroom Apartment?
You may not be able to replace the heating system or major appliances, but a few everyday changes can still make a difference. Start with temperature settings and the appliances you use most.
Adjust Your Thermostat to Reduce Heating and Cooling Costs
Small temperature adjustments can help reduce your utility bills. Setting your thermostat to 78°F in summer when you’re home and raising it to around 85°F while away can help lower cooling costs. Adjusting your thermostat by 7–10°F for about eight hours a day can reduce annual heating and cooling costs by up to 10%, according to the U.S. Department of Energy (DOE).
During winter, try setting your thermostat to 68°F while you’re home and awake, then lowering it by 7–10°F at night. For conventional heating systems, reducing the temperature by 10–15°F over an eight-hour period can save approximately 5%–15% on annual heating costs under certain conditions, according to NREL research. Using extra blankets at night can help you stay comfortable at lower temperatures.
In summer, ceiling fans can make you feel more comfortable while allowing you to raise your thermostat setting by about 4°F. Turn fans off when you leave the room, since they cool people rather than the space itself. See the DOE Energy Saver Guide for more energy-saving tips.
Use Energy-Efficient Appliances and Lighting
Replacing older incandescent bulbs with LEDs will cut lighting energy use by up to 75%. Using cold water detergent for laundry will save on electricity needed to heat the water tank. Cleaning the dryer’s lint trap before every single load shortens drying times. Running the dishwasher and washing machine only with full loads maximizes the value of every cycle.
Use Portable Solar Generators to Power Essential Devices
If your lease and building rules allow it, a portable power station can run smaller devices such as a Wi-Fi router, laptop or desk lamp. Combine an EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) system with a 160W solar panel if you’re able to mount panels on a balcony or patio with sufficient sunlight. The system can also be charged from a wall outlet during cheaper off-peak hours on some time-of-use plans. For a fridge or other larger appliance, you’ll need to match the appliance’s starting and running power against the power station’s limits.
The EcoFlow DELTA 3 Max Plus Portable Power Station has a 2,048Wh base capacity and 3,000W AC output which can be expanded with extra batteries. Combine the unit with two 160W solar panels, and you’ll be able to recharge it during the daytime. Use solar power to lower your bill. Actual savings will depend on your rates, appliance use and effective solar panel use.
Reduce Standby Power and Unnecessary Electricity Use
Standby or “vampire” loads from gaming consoles, smart TVs, soundbars, and other electronics can add to annual electricity use. Smart power strips can disconnect selected idle devices, but equipment that needs continuous connectivity, updates, clocks, or safety functions should remain powered as directed by its manufacturer. Broader energy-saving tips can help renters prioritize changes that fit the lease and their daily routine.
Choose a More Cost-Effective Electricity Plan
If you live in a retail-choice market, compare current offers through the applicable state or utility resource before the existing contract expires. Even in regulated markets, some utilities offer optional time-of-use or off-peak plans. A portable power station can be charged during a lower-priced period where the plan and equipment support that strategy, but savings depend on the rate spread, conversion losses, and how much stored energy is later used. Do not assume that off-peak hours begin at the same time for every utility.
If your utility bill is unexpectedly high, compare kWh use, the effective rate, and fixed charges with the same period last year. This helps show whether the increase came from weather, a price change, occupancy, or inefficient equipment. Thermostat adjustments, full laundry loads, and reduced standby use can lower consumption. Renters considering battery or solar equipment should compare the purchase cost, permitted placement, available sunlight, conversion losses, and the value of the electricity displaced rather than assuming the equipment will lower every monthly bill.
Does Leaving Things Plugged in but off Use Electricity?
Yes, many electronics and appliances continue drawing small amounts of “standby” or phantom power even when turned off. Devices with digital clocks, remote-control sensors, or constant Wi-Fi connectivity—like smart TVs, game consoles, cable boxes, and desktop computers—account for roughly 5% to 10% of a typical household’s annual electricity usage.
Is It Cheaper to Turn Off AC or Keep It On?
Turning your AC off or raising the thermostat by 7 to 10 degrees while you are away is cheaper than maintaining a cool temperature all day. Air conditioners operate most efficiently at full capacity rather than cycling on and off repeatedly to hold a low setpoint against afternoon heat, so letting the apartment warm up while empty reduces total runtime.
Is Electricity Cheaper in an Apartment or House?
Electricity is generally cheaper in an apartment because smaller square footage and shared walls reduce heating and cooling losses. Unlike detached houses exposed to outdoor temperatures on all four sides plus the roof, apartments benefit from thermal insulation provided by neighboring units, resulting in lower average kWh consumption.
Can I Use a Portable Generator in My Apartment?
You cannot use a gas-powered generator inside an apartment or on a balcony due to lethal carbon monoxide exhaust and fire codes, but battery-powered portable power stations are safe for indoor use. Battery units produce zero fumes and operate quietly, making them suitable for indoor apartment backup and daily energy management, though you should always check your lease terms before hanging or placing solar panels on a balcony railing.
