How to Reduce Your Electricity Bill: 15 Proven Strategies for 2026
Aging grid infrastructure, extreme weather, and rising fossil fuel costs have left many homeowners with skyrocketing electric bills, wondering how to reduce them. Fortunately, you don’t have to sacrifice modern comfort to lower your bills. By targeting the primary drivers of energy consumption and adopting strategic home efficiency habits, you can take control of your rising costs and create a more resilient home in 2026.
Start With the Biggest Drivers of Your Electricity Bill
If you’re wondering why your electrical bill is so high, you’re not alone. Prices have been rising all across the country due to aging infrastructure, severe weather upgrades, and skyrocketing fuel prices.
If you want to lower your energy bill, start by looking at your biggest drivers: heating and cooling, hot water, lighting, and phantom loads. The more you can reduce their energy use, the more you’ll save.
15 Proven Ways to Cut Electricity Use Without Sacrificing Comfort
1. Compare Electrical Providers
Shop around for different electrical providers, and you might find a plan that works better for you.
2. Conduct an Energy Audit
Hire a professional to conduct an energy audit. They’ll use thermal cameras to look for hidden drafts and examine your appliances, providing a list of upgrades to enhance efficiency.
3. HVAC Maintenance
Regular HVAC maintenance, including cleaning filters regularly and scheduling professional annual maintenance, allows it to work more efficiently.
4. Reduce Phantom Loads
Phantom loads occur when electronics are left plugged in when not in use. They use energy to scan for updates or Wi-Fi, or expend energy just to be ready for use. Unplug appliances you don’t use often and put others on power strips on timers so they shut off when not needed.
5. Install Solar and Battery Backup
Battery-operated whole-home generators, like the EcoFlow DELTA Pro Ultra X, let you use battery power during peak electricity rates. And you can save even more by recharging with solar panels.
6. Smart Washing Techniques
Washing clothes in cold water and running full loads saves significant energy.
Also, clean your dryer’s lint filter to ensure proper airflow, or better yet, hang your clothes and dry for free.
7. Seal Leaks
Use weatherstripping, caulking, and door sweeps to seal drafty doors and windows. Also, repair any leaking HVAC ducts.
8. Insulation
Consider upgrading your insulation, especially in your attic, to reduce heating and cooling costs.
9. Upgrade to ENERGY STAR Appliances
Upgrading aging large appliances that aren’t ENERGY STAR rated is an excellent way to save money on electricity.
10. Use Fans
Using fans instead of ACs to stay cool saves energy. And when it gets really hot, use both. Fans help improve AC efficiency in the summer and furnace efficiency in the winter.
11. Turn Lights Off
Turn the lights off when you leave the room, or open the curtains and use natural lighting.
12. Set Hot Water Heater Temperature Lower
Lowering your hot water temperature can save you on electricity or gas bills.
13. Close the Damper in Your Fireplace
Closing the damper when not in use will prevent unnecessary drafts.
14. LED Lighting
LED lights use about 75% less electricity than an incandescent bulb.
15. Install a Heat Pump
Heat pumps are more efficient and can replace air conditioners in any climate and furnaces in all but the most extreme cold. Even if you still need a furnace, heat pumps enhance efficiency.
An installation of an EcoFlow DELTA Pro Ultra X Whole-Home Backup Power System in a garage
Make the Savings Stick With Smart Controls and Home Efficiency
About 52% of energy usage comes from heating and cooling, which is why smart thermostats save significant money.
Set it to lower the temperature at night while you sleep and keep it low or off while you're away. Then, program it to turn back on an hour before you return home to ensure comfort.
Lower Your Bill Further by Using Electricity at the Right Time
If you’re on variable time-of-use electricity rates, avoid using large appliances during peak hours. Then, run dishwashers, washing machines, and dryers at night during off-peak hours.
Cut Costs and Add Resilience With Home Energy Storage and Backup Power
Whole-home backup power solutions make homes more resilient. You can keep essential appliances running during outages and use battery power during peak time-of-use rates to save money. And if you recharge with solar panels, you can use clean, free energy.
The EcoFlow DELTA Pro Ultra X Whole-Home Backup Power starts at 12kWh of expandable capacity (up to 180kWh), which makes it perfect for any-sized home, including large homes with multiple power-hungry appliances. It can help save up to $6,000 a year on electricity in some homes.
An EcoFlow DELTA Pro Ultra X Whole-Home Backup Power Unit
What Are the Most Common Reasons Electricity Bills Are Higher in 2026?
Electricity bills are high in 2026 due to upgrading aging infrastructure and making upgrades to deal with increasingly common severe weather events. Current high fuel prices are further elevating costs.
How Much Can LEDs and Thermostat Changes Realistically Save Each Month?
Since LED lightbulbs use ~75% less energy than incandescent bulbs, and because heating and cooling are your biggest energy users, together these changes can reduce your electrical bill by $15–$40 each month.
What Are Time-of-Use Rates, and How Do I Avoid Peak-Hour Costs?
Time-of-use rates are when utilities charge more during peak demand and less at night when demand is lower. Avoid peak rates by running large appliances late at night or using battery backups during peak hours.
Is a Home Battery Worth It If I’m Mainly Trying to Reduce My Bill?
A home battery alone can be worth it if you take advantage of time-of-use rates or you have poor net metering rates with your solar. Otherwise, you’ll save far more if you recharge using solar instead of grid power.
Save More Each Month While Making Your Home More Comfortable and Reliable
Cutting your electrical bill doesn’t mean sacrificing comfort. From simple habits like using LED lights and managing phantom loads to upgrades like heat pumps and smart thermostats, every change can lead to big savings.
You can save even more money on electricity and time-of-use rates while creating a more resilient home with the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power. Add solar, and you can even achieve true energy independence.
Save Bills
