How Much Gas Does a Fireplace Use? Natural Gas and Propane Per Hour
A gas fireplace is easy to turn on, so you might not think much about how much fuel it burns. Its gas use depends on the Btu rating, how long you run it, and whether it uses natural gas or propane. You can estimate the amount with a simple calculation using the fireplace's input rating and the fuel's heat content. This guide walks through both fuels, shows what an hour of operation might cost, and explains which fireplace features may need electricity during a power outage.
How Much Gas Does a Fireplace Use Per Hour?
You can estimate your fireplace's hourly gas use from its Btu input rating. Divide that number by the fuel's heat content to find how many cubic feet of natural gas or gallons of propane it burns per hour. Check the fireplace label or owner's manual for its input rating. According to the U.S. Energy Information Administration (EIA), natural gas delivered to U.S. consumers averaged about 1,036 Btu per cubic foot in 2025. Propane contains 91,452 Btu per gallon. Using these figures, here's what different fireplace sizes might use:
Fireplace input (example) | Natural gas per hour | Propane per hour |
20,000 Btu/h | about 19 cubic feet | about 0.22 gallons |
30,000 Btu/h | about 29 cubic feet | about 0.33 gallons |
40,000 Btu/h | about 39 cubic feet | about 0.44 gallons |
These are estimates based on each fireplace running at its rated input. Your actual gas use may be lower if you turn down the flame or use a thermostat to cycle the burner. Always use your model's rating for a more accurate estimate. If you're deciding between gas and other heating options, consider the pros and cons of natural gas before choosing what works for your home. Gas provides the heat, but some fireplaces also use electricity for blowers, controls, or lights. That becomes important during a power outage, especially if you want those features to keep working.
Do gas fireplaces need electricity? Optional outage backup
Many gas fireplaces can produce heat without household electricity. However, features such as blowers, remote controls, and accent lights may need power. If your model has a compatible 120V plug-in blower or lights, a power station can keep those accessories running during an outage. It won't reduce the amount of gas the fireplace uses.
Which fireplace features need electricity?
It depends on the model. Some fireplaces use a standing pilot and can operate without household power, while others have electronic ignition systems that may need electricity or battery backup.
Check your owner's manual to see whether these features need an outlet:
Blower: A plug-in blower may need 120V AC power to circulate warm air.
Controls: Some electronic controls require electricity, while others use batteries.
Accent lights: Built-in or plug-in lights may need household power.
Confirm the fireplace's electrical requirements before choosing a backup source. If the flame can keep running without electricity, you may only need backup power for the accessories.
Using a power station for fireplace accessories
If your fireplace has a compatible 120V plug-in blower or accent lights, an EcoFlow power station can keep them running during an outage. The gas still supplies the heat. The power station only runs the electrical accessories.
EcoFlow DELTA 3 Classic for a blower and lights
The EcoFlow DELTA 3 Classic has a 1,024Wh LFP battery and 1,800W AC output. It can power a compatible 120V fireplace blower, controller, or lights, provided the fireplace manufacturer allows battery power for those accessories. Check the manual and the accessories' power requirements before connecting them. A fireplace blower and a lamp are a relatively small electrical load. The EcoFlow DELTA 3 Classic may keep both running for several hours, depending on their combined wattage. The estimate below uses a 100W blower and a 10W lamp as examples.
Estimated runtime for a fireplace blower and lamp
A blower and a lamp can run together on the EcoFlow DELTA 3 Classic, depending on their combined power draw. The estimate below uses a 100W blower and a 10W lamp as example loads.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Fireplace blower (placeholder 100W) + lamp (10W) | about 110W | about 7.9 hours |
Calculation: Usable battery capacity (Wh) ÷ total load (W) = estimated runtime. This estimate uses 870Wh of usable capacity, based on 85% of the battery's rated 1,024Wh. The 100W and 10W figures are placeholders. Check the labels on your actual accessories and recalculate using their combined wattage. Actual runtime may vary. A similar backup question comes up with other gas appliances. See our guide to gas furnaces without electricity to understand which parts may continue working during an outage.
How much does it cost to run a gas fireplace?
To estimate the hourly cost, multiply the amount of gas your fireplace uses by the price you pay for that fuel. Natural gas bills may list a price per therm or per hundred cubic feet. Propane suppliers generally quote a price per gallon.
Natural gas cost per hour
The EIA reported an average U.S. residential natural gas price of $13.96 per thousand cubic feet in January 2026. Using that figure, here's an example for a 30,000 Btu/h fireplace.
Estimated gas use: 29 cubic feet per hour.
Convert to thousands of cubic feet: 29 ÷ 1,000 = 0.029.
Multiply by the price: 0.029 × $13.96 = about $0.40 per hour.
So, at the January 2026 national average, running this fireplace at its full input rating would cost roughly 40 cents an hour. Your bill may differ based on your utility's rate, delivery charges, and location. The EIA's residential natural gas price data can help you compare the national figure with recent prices.
Propane cost per hour
Propane prices vary by supplier, delivery area, tank size, and purchase arrangement. Use the price on your latest bill or refill quote. For a 30,000 Btu/h fireplace, the estimated consumption is about 0.33 gallon per hour. Multiply that amount by your local price per gallon to get the hourly fuel cost. For example, if your supplier charges $3 per gallon: 0.33 × $3 = about $0.99 per hour. This is an example, not a national propane price. Your actual cost will depend on what you pay. If you're comparing propane with electric space heating, see our guide to propane vs. electric heater costs. Use your local utility and supplier rates to make the comparison relevant to your home.
How to use less gas with a fireplace
Your fireplace's BTU rating sets its maximum fuel input, but your settings and daily routine affect how much gas it uses. A few adjustments can help reduce unnecessary runtime.
Adjust flame & thermostat
If your fireplace has adjustable flame settings, turn the flame down when you don’t need as much heat. A thermostat will also help by cycling the burner rather than running it all the time. Use the timer, if available, to avoid leaving the fireplace on longer than needed.
Heat the room you're using
A gas fireplace can supply additional heat to the room it is installed in. Close unused rooms and set your central heating to suit your home. Don't block the fireplace vents or alter its installation to direct more heat into the room.
Keep the fireplace serviced
Have a qualified technician inspect and service the fireplace on a schedule recommended by the manufacturer. A service call can determine problems with the burner, pilot, venting, or controls. Follow the manual for cleaning and maintenance rather than attempting repairs yourself.
Keep carbon monoxide alarms working
Gas fireplaces burn fuel, so carbon monoxide safety is important. Install battery-operated or battery backup CO alarms in accordance with local requirements and the manufacturer's instructions. Test them often and replace batteries as directed. Learn more about carbon monoxide risks and the precautions to take around gas appliances. If an alarm sounds, leave the home and contact emergency services from outside.
A fireplace's Btu rating gives you a practical way to estimate fuel use. A 30,000 Btu/h model burns about 29 cubic feet of natural gas or 0.33 gallons of propane per hour at its full input rating. At the EIA's January 2026 average natural gas price, that's roughly $0.40 an hour. Check your fireplace label, use its thermostat or timer, and keep CO alarms working. If an outage stops a compatible plug-in blower or accent lights, the EcoFlow DELTA 3 Classic can power those accessories. It won't supply the fireplace's heat or reduce its gas use.
How much gas does a gas fireplace use per hour?
This is based on the Btu input rating and type of fuel for the fireplace. A 30,000 Btu/h natural gas fireplace uses about 29 cubic feet per hour, based on the EIA's average heat content of 1,036 Btu per cubic foot.
How much propane does a fireplace use?
Divide the fireplace's Btu input rating by 91,452 to estimate gallons per hour. A 30,000 Btu/h propane fireplace uses about 0.33 gallons per hour.
Do gas fireplaces use a lot of gas?
That depends on the fireplace's input rating and how long you run it. A larger unit or longer burn time uses more fuel. Check the BTU rating and compare it with your typical daily use.
Does a gas fireplace work during a power outage?
Many gas fireplaces can produce heat without household electricity, but some ignition systems need power. Blowers, remotes, and accent lights may also stop working. Check your model's manual to see which features need electricity.
The cost depends on the fireplace's Btu rating, fuel type, and local price. At the EIA's January 2026 average natural gas price, a 30,000 Btu/h fireplace costs about $0.40 per hour to run at its full input rating.
