How Much Does an AC Cost to Run All Day? Calculate It in Three Steps
Air conditioning is often the biggest line on a summer electric bill, but the cost of running it all day isn't fixed. It depends on the unit's power draw, how long its compressor runs, and what your utility charges per kilowatt-hour. With those numbers, you can estimate the daily cost in a minute. This guide walks through the math, compares window, portable, and central AC examples, and covers practical ways to lower cooling costs. You'll also find options for keeping fans or a compatible AC running during a summer outage.
To calculate the daily cost, multiply your AC's input watts by its operating hours, divide by 1,000, and multiply the result by your electricity rate. The key is to use the hours the compressor actually runs, not automatically assume it runs at full power for 24 hours. Here's the formula: Daily electricity cost = (Input watts × Operating hours ÷ 1,000) × Price per kWh. For example, a 500-watt window AC running for 12 hours uses: 500 × 12 ÷ 1,000 = 6 kWh. At 18.16 cents per kWh, that works out to about $1.09 for the day.
The U.S. Energy Information Administration (EIA) reported a preliminary U.S. Total average residential electricity price of 18.16 cents per kWh in August 2026 (under the Residential column of EIA's Electric Power Monthly Table 5.6.A). Your actual rate may be higher or lower depending on your utility, location, and electricity plan. Check your latest bill before using the estimate for your home.
How Much Does an AC Cost to Run All Day?How Much Does an AC Cost to Run All Day?
What does it cost to run different AC units?
The table below uses example power draws and assumes each unit runs at that average draw for 24 hours. These are estimates, not typical consumption figures for every model. Your AC's EnergyGuide label or technical specifications will give you a better starting point.
AC type
Example average draw
Energy used in 24 hours
Cost at 18.16¢/kWh
Small window AC
500W
12 kWh
About $2.18
Portable AC
900W
21.6 kWh
About $3.92
Central AC (3-ton example)
2,000W
48 kWh
About $8.72
These examples use average power across the full day, including periods when the compressor cycles off. If you're using the unit's rated input watts instead, calculate the hours the compressor actually runs. Otherwise, you may overestimate its daily consumption. Start by checking how many watts a window AC uses. The unit's size, cooling capacity, and operating conditions all affect its power draw. When the grid goes down, the AC stops along with other appliances. A portable power station can keep fans running and may support a compatible window or portable AC for a limited time.
Staying Cool in an Outage: Fans and Short AC Runs
A power outage during hot weather can make it difficult to keep your home comfortable. A portable power station can keep fans, lights, and phones running for longer periods. A larger unit may also run a compatible 120V window or portable AC for a shorter time, depending on its power requirements and battery capacity.
EcoFlow portable power stations offer two options for these situations. The EcoFlow DELTA 3 Classic can handle everyday essentials such as fans, lights, and communication devices. If you need to run a compatible window or portable AC, the EcoFlow DELTA 3 Max Plus provides higher output and more battery capacity. Check the AC's running wattage and compressor startup requirements before connecting it. Neither unit makes your AC more efficient or guarantees all-day cooling.
EcoFlow DELTA 3 Classic for fans and essentials
During an outage, a fan can make a room more comfortable without drawing as much power as an air conditioner. The EcoFlow DELTA 3 Classic has a 1,024Wh battery, making it suitable for running fans, lights, and phones. It's a practical option when you need basic backup power through a summer evening.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Max Plus for short AC runs
The EcoFlow DELTA 3 Max Plus delivers 3,000W output and 6,000W surge capacity, making it suitable for short runs of a compatible 120V window or portable AC. Its 2,048Wh battery supports five charging methods, reaches 80% in 43 minutes with generator charging, and expands to approximately 10kWh with compatible extra batteries and an adapter.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3,000W Output: 6,000W surge. X-Boost mode can run some appliances up to 3,800W, though results vary by device. •Fast Recharging: 5 ways to charge, reaching 0 to 80% in 43 minutes with generator charging. • Expandable Capacity: 2kWh base, expandable to approximately 10kWh with two DELTA Pro 3 Smart Extra Batteries and the EcoFlow Smart Extra Battery Expansion Adapter (sold separately). Pairing with a compatible EcoFlow Smart Generator adds automatic start and stop for longer runtime.
How the products divide the job
The EcoFlow DELTA 3 Classic is better suited to everyday essentials, such as fans, lights, and phones. The EcoFlow DELTA 3 Max Plus offers more output and battery capacity for short runs of a compatible 120V window or portable AC. The table below shows estimated runtimes using 85% of each battery's rated capacity. Actual results depend on the connected devices and operating conditions.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max Plus (1,741Wh usable est.)
Box fan (placeholder 60W) + phones (10W)
about 70W
about 12 hours
about 25 hours
Window AC, cycling (placeholder 500W average)
about 500W
about 1.7 hours
about 3.5 hours
Runtime estimates use 870Wh and 1,741Wh of usable capacity, respectively. The 60W fan, 10W phone load, and 500W AC draw are examples. Check your devices' actual power requirements before connecting them. If you live in an area with frequent heat-related outages, have a heat wave outage plan ready before extreme temperatures arrive. With backup power covered, let's look at a few ways to lower your everyday AC costs.
How to Lower the Cost of Running AC
A few changes to your cooling routine can reduce electricity use without making your home uncomfortable. Start with the thermostat, check whether your AC is sized correctly, and keep up with basic maintenance.
Set the thermostat a little higher
ENERGY STAR recommends setting your thermostat as high as is comfortable, typically around 78°F when you're home. A higher setting can reduce how often the AC runs. Use ceiling or portable fans to help circulate air, but turn them off when nobody is in the room. Fans use much less electricity than air conditioners. Compare how much electricity a fan uses when deciding whether a fan can handle some of your cooling needs.
Choose the right AC size
An oversized room AC can cost more to buy and waste energy. It may also cool the room too quickly without removing enough humidity. ENERGY STAR provides room-size recommendations to help match cooling capacity to the space. For example:
Room size
Suggested cooling capacity
150–250 sq. ft.
6,000 BTU/hr
450–550 sq. ft.
12,000 BTU/hr
Use the sizing guidance as a starting point. Room layout, ceiling height, sunlight, insulation, and the number of people in the space can affect the cooling capacity you need.
Keep the unit clean and properly installed
Clean or replace the filter as recommended by the manufacturer. Check the window seals around a window AC and make sure the unit sits securely. ENERGY STAR notes that an improperly installed room AC can leak as much air as a 6-square-inch hole. That means cooled air can escape while warm air enters.
Window vs. portable vs. central AC running costs
Window vs. portable vs. central AC running costsWindow vs. portable vs. central AC running costs
Choosing the cheapest AC to run depends on the space you need to cool and how much cooling you require. Window units are usually more energy efficient than comparable portable units. Central AC uses more total electricity because it cools multiple rooms or an entire house, but it may make more sense for larger homes.
AC type
Best suited for
What to consider
Window AC
One room or a small apartment
Usually efficient for room cooling, but needs a suitable window
Portable AC
Rooms where window installation isn't practical
Uses floor space and needs an exhaust hose
Central AC
Multiple rooms or an entire home
Higher total energy use, but cools a larger area
Compare the EnergyGuide labels when shopping. They provide estimated annual energy costs, which can help you compare models under a consistent set of assumptions. Also check the cooling capacity in BTU/hr and make sure it matches the room. If you're deciding between two room units, compare portable AC vs. window AC before buying. Installation, noise, room size, and energy use all matter.
The cost of running an AC all day depends on its power consumption, how long it's on, and the price you pay for electricity. At the EIA’s August 2026 average of 18.16 cents per kWh, a 500W window AC running 24 hours a day costs about $2.18. For a more accurate estimate, use the figures and utility rate of your own unit. If you like it at about 78 degrees Fahrenheit, you can adjust the thermostat to that. Make sure you have the right size air conditioner for your space and keep the filters and seals in good condition. If summer outages are a concern, the EcoFlow DELTA 3 Classic can cover fans and essentials, while the EcoFlow DELTA 3 Max Plus can support a compatible 120V window or portable AC for a limited time.
How much does it cost to run an AC all day?
It depends on the AC's average power draw, how long it runs, and your electricity rate. For example, a window AC averaging 500 W over 24 hours uses 12kWh. At 18.16 cents per kWh, that costs about $2.18 for the day.
How much does a window AC cost to run per month?
Multiply the estimated daily cost by the number of days you use it. A window AC would cost $2.18 a day or $65.40 for 30 days to run. Your actual bill will depend on its operating hours, cycling, and electricity rate.
Does running AC all day cost more than turning it off?
Usually, turning the thermostat up when you don't need as much cooling saves energy. You don't have to keep the house at the same temperature all day. ENERGY STAR recommends setting it around 78°F when you're home and comfortable.
What is the average price of electricity in the US?
The EIA reported an average residential electricity price of 18.16 cents per kWh in August 2026. That figure was preliminary. Electricity rates vary by state, utility, and plan, so use the rate on your own bill for a more accurate calculation.
Can a power station run an air conditioner?
A power station with enough output and battery capacity may run a compatible 120V window or portable AC for a limited time. Check the AC's running wattage and compressor startup requirement against the power station's specifications. A portable power station in this comparison isn't designed to run a 240V central AC system.
Save Bills
