RI Energy Outage Map Guide: How to Report and Track an Outage Fast
The wind picks up off the bay during a nor'easter, the lights blink twice, and the house goes dark. If you live in Rhode Island, you know the questions that follow: Is it just your house, does the utility know, and when will the power come back? This guide shows you how to check the Rhode Island Energy outage map and report an outage by phone or text, plus how to stay safe and keep the basics running until the lights come back on.
How to Check the Rhode Island Energy Outage Map
Before you pick up the phone, it helps to see what the utility already knows. The moment the power drops, many people search for "r i energy outage map" or "rienergy outage map." Both lead to the same place, and a quick look can save you a call.
The Rhode Island Energy power outage map lives on Rhode Island Energy's outage page at rienergy.com/outage. It works in any phone browser, which matters when the Wi-Fi is down. The utility refreshes the data every 15 minutes, so bookmark the page and check back often.
The map breaks outages down by town. That shows you if you're facing a local problem or a bigger storm event. If whole towns light up, crews are likely working a much larger job. Do you have a family served by another utility? RIEMA's list of outage maps puts the state's utility maps in one spot. It even covers Block Island Power and Clear River Electric & Water District.
For steps that work with any utility, a general outage preparedness guide is a good place to start. Most of that advice applies in Rhode Island, too. The map shows what Rhode Island Energy already knows about. But your specific address still needs to be reported directly.
How to Report a Rhode Island Energy Outage
It's easy to assume the utility already knows your home is out, but that isn't always true. Your report confirms the exact location and helps crews see how far the damage spreads. If you're searching for "power outage ri" from a dark living room, this is the number you want. Call 1-855-743-1101 to report an outage or a downed line, any time of day or night. Save it in your contacts now, so it's ready when you need it.
Texting is often faster when phone lines get jammed after a big storm. Text OUTAGE to 743674 (RIEMSG) to report an outage. Later, text STATUS to the same number to check on the one you already reported.
You can also report an outage on the rienergy.com website, which works well when you'd rather not wait on hold. For updates tied to your account, the company's contact center can help.
Downed Lines Come First
A downed wire is an emergency, not just an outage. Call 911 first, and then report the line to Rhode Island Energy as a separate call. With your outage reported, the waiting begins. That's where backup power helps most, especially in the state's biggest storms.
Backup Power While Waiting on Rhode Island Energy
Most outages are short, but the big storms are a different story. In February 2026, a record blizzard knocked out power to about 50,000 Rhode Island Energy customers. Crews restored more than 99% of them in less than two days. The last homes were expected back a day or so later. Still, two days is a long time without heat or a working fridge.
The national picture looks similar. EIA reports that U.S. customers averaged 11 hours without power in 2024. Major events, such as hurricanes and other big storms, caused 80% of those hours. So how much backup do you really need? It comes down to two questions: what has to stay on, and for how long?
Whole-Home Backup for Multi-Day Outages
Does your home rely on a well pump, a sump pump, or electric heat? If so, a few hours of backup won't go far. A whole-home system can keep those loads running for days and switch over on its own when the grid drops.
If you want that level of coverage, the EcoFlow DELTA Pro Ultra X is one option worth a look at. It's built for longer gaps, when crews are still working through the repair queue.
Portable Backup for Shorter Outages
Not every household needs whole-home coverage. If your outages clear up by dinnertime, a portable power station may be enough. It can keep the fridge cold, the router on, and your phones charged.
There's no installation, and you can move it from room to room as your needs change. That's the gap a smaller unit like the EcoFlow DELTA 3 Max is built to fill.
Backup power buys you time. Knowing what causes these outages helps you guess how much time you'll need.
Rhode Island Energy’s Service Area and Common Outage Causes
What Causes Most Outages in Rhode Island
Most Rhode Island energy power outages start with the weather. Nor'easters and blizzards bring heavy, wet snow and strong winds that pull down limbs and lines across wide areas. Towns along Narragansett Bay and the ocean also take the brunt of high coastal gusts.
Late-summer and fall tropical storms can hit the coast hard, too. Even on a calm day, a single falling branch can cause a smaller, local outage.
Large storms explain why ri power outages can spread across dozens of towns at once. A single tree on a wire may only affect your street. If you live near the shore, preparing for hurricane-related outages is worth doing before the season peaks.
Whatever the cause, the same basic safety steps apply while the power is still out. Most of them take only a minute to learn.
Staying Safe During a Rhode Island Energy Outage
Most outage injuries don't come from the outage itself. They come from downed wires, generators, and cold homes. Each risk is easy to avoid with a little planning.
Downed Lines, Gas Leaks, and Generators
Treat every downed line as live, even if it isn't sparking. Stay far away and call 911 or 1-855-743-1101 right away. If you smell gas, leave the building right away and take everyone with you, pets included. Once you're safely away, call 911 or the gas emergency line at 1-800-640-1595.
Never run a generator inside your home or garage, even with the door open. CDC carbon monoxide guidance says to keep generators outside and more than 20 feet from windows, doors, and vents. A battery-powered carbon monoxide alarm adds cheap protection.
Cold Weather and Medical Needs
Cold snaps add their own challenge. The National Weather Service offers winter outage safety advice for this. It suggests closing off rooms you aren't using and wearing loose layers. A few other habits help, too. Keep the fridge and freezer closed, and charge phones and battery packs before a storm. Check on older neighbors and anyone who relies on powered medical devices.
Does someone in your home use oxygen or a CPAP machine? Build a backup plan for medical equipment before a storm, not during one. It also helps to know how long outages usually last, so your wait feels less like guesswork.
Checking the map and reporting your outage are separate jobs, and both help crews find where the power is out. Save 1-855-743-1101 on your phone today, bookmark the outage map, and learn the OUTAGE and STATUS text codes before the next storm. Then think about how your home would handle a day or two without power in a Rhode Island blizzard. If that is a real hardship, size your backup to your needs with whole-home power like the EcoFlow DELTA Pro Ultra X or a portable EcoFlow DELTA 3 Max.
How do I report a Rhode Island Energy outage?
Call 1-855-743-1101, text OUTAGE to 743674, or report it on the rienergy.com website. Texting is often fastest right after a storm, when phone lines are busy.
What's the phone number for Rhode Island Energy outages?
The number is 1-855-743-1101, and it's available 24/7 for outages and downed lines. For a downed line, call 911 first. For a gas leak, leave the area and call 911 or 1-800-640-1595.
How do I check the status of a reported outage?
Text STATUS to 743674 after you've reported your outage. You can also check the outage map, which refreshes every 15 minutes and shows outages by town.
What areas does Rhode Island Energy serve?
Rhode Island Energy serves more than 770,000 electric and gas customers, including Providence, Kent, Washington, and Newport counties. Block Island and a few other small areas have their own local utilities.
How long do Rhode Island Energy outages typically last?
Most outages are fixed within a few hours, but major storms take longer. After the February 2026 blizzard, the utility restored power to over 99% of affected customers within two days. Homes at the end of long, tree-lined roads are often among the last to come back.
