Sleet vs. Hail: What’s the Difference?
Sleet and hail are both frozen precipitation, but they are formed differently and bring different risks. Sleet is a small ice particle and usually forms during the winter months. It’s created when falling snow melts and then refreezes before reaching the ground. Hail on the other hand forms inside strong thunderstorms, often in spring or summer, when powerful updrafts build layers of ice around water droplets.
This guide explains how to tell sleet and hail apart and what damage they may cause. It will also explain how to prepare your home if you have severe weather that causes a power outage.
What Is the Difference Between Sleet and Hail?
Sleet and hail may look similar, but they form in very different weather conditions. The main differences in what they are and how they’re formed is due to temperature, storm type, size, and impact.
Feature
Sleet (Ice Pellets)
Hail
How It Forms
Snow melts into rain through a warm pocket of air, then refreezes in a deep sub-freezing layer nearer the ground.
Raindrops get swept high into freezing thunderstorms via updrafts, accumulating frozen layers on each cycle before dropping.
Typical Weather
Cold winter days, freezing nor'easters, or severe transitional winter storms.
Severe thunderstorms in warmer seasons, squall lines, and supercells (spring/summer).
Size
Tiny, uniform translucent pellets (usually under 0.2 inches / 5 mm).
Ranges wildly from pea-sized (0.25") to golf ball (1.75") or even softball-sized (about 4 inches).
Where It Forms
Lower atmosphere, relatively close to the Earth's surface.
High up inside massive cumulonimbus thunderheads (often 20,000–50,000 feet up).
What It Can Affect
Roads, walkways, and travel conditions; mixed winter precipitation can also contribute to outage risks.
Roof shingles, siding, skylights, car tops and windshields, HVAC units, and power grids.
Sleet Forms as Precipitation Refreezes Before Reaching the Ground
Sleet starts high in the clouds as snow. As it falls, it passes through a shallow layer of warmer air above freezing, which causes it to melt and turn into raindrops. Then it continues falling through another layer of freezing air near the ground. By the time it hits the ground, those raindrops have frozen into small ice pellets.
Hail Forms Inside Strong Thunderstorms
Hail, when it occurs, is usually only associated with thunderstorms, and not typically due to winter weather. Hail is formed inside towering cumulonimbus clouds and usually on spring and summer afternoons. To form, it requires intense, churning updrafts. Updraft winds lift the liquid water droplets up through the freezing level, high into the atmosphere. This happens repeatedly, creating layer after layer of ice on the hail stone. Once hailstones become too heavy for the storm’s updraft to keep them aloft, they fall to the ground and can cause damage. Understanding how hail is formed starts with repeated lifting through freezing layers inside a strong thunderstorm.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
How Can You Tell Sleet From Hail?
When you see freezing precipitation outside, it’s straightforward to find out whether it’s hail or sleet. A quick evaluation of three physical clues will give you the answer immediately.
Check the Size and Shape of the Ice
Look closely at a few pieces on the ground or flat surface, or even pick up one. If it looks like a tiny, translucent bead or a smooth, frozen drop of water then it’s sleet. These are usually under a fifth of an inch across. Hailstones, by contrast, are rarely uniform in size. They are often milky or layered like an onion, exhibiting rough ridges, and can range from small pea or marble-sized stones to large chunks as big as a golf ball.
Look at the Weather Conditions Around You
Context is everything when trying to guess what the weather is bringing. If you’re bundled up in a heavy parka watching gray, overcast skies hover around the freezing mark, you’re almost certainly dealing with sleet. But if there’s lightning against a dark charcoal sky, and it’s a muggy spring afternoon, it’s hail making all the noise on your patio roof.
Notice Whether the Ice Bounces or Accumulates
Watch how the ice behaves when it hits the ground like a driveway. Sleet hits with a distinct, light clatter, bouncing very little. As more falls, it accumulates into a crunchy, sugar-like slush that builds up evenly across surfaces. Hail lands with much harder force and bounces more. Large hailstones can break apart on concrete or can even give a one hop bounce on your lawn and usually come in different sizes. In everyday weather reports, sleeting vs. hailing usually points to the storm environment as much as the shape of the ice.
Can Sleet and Hail Cause Power Outages?
When ice starts falling across your region, utility companies start preparing for trouble. Both sleet and hail can cause problems for local electrical distribution systems. However, electrical infrastructure problems can be caused by different mechanisms. A portable power station can help keep compatible communication devices charged if a local outage follows the storm.
Sleet Can Create Road and Power Risks
Although pure sleet doesn’t stick to tree limbs or power lines as much as freezing rain does, it rarely falls by itself. What happens is that winter weather systems often change quickly between sleet, snow, and freezing rain. Heavy, waterlogged slush can accumulate on overhead power lines and overhanging branches, adding excessive weight. Mix that weight with gusty winter winds, and utility poles snap. To make matters worse, slick roads often slow down utility service crews trying to reach downed lines, especially in rural areas. A severe winter weather preparation plan should also account for mixed precipitation, slick roads, and delayed utility access.
Hail Can Damage Outdoor Electrical Equipment and Property
Severe hailstorms can also cause sudden and expensive damage. Giant hailstones falling at 60 to 100 mph can damage electrical service masts on the side of a house, dent outdoor air conditioning compressors, and even shatter solar panel arrays. Large hailstones can crack porcelain insulators on utility transmission lines. They can also rupture transformer seals on roadside utility poles which causes immediate local blackouts.
Severe Weather Can Lead to Temporary Power Interruptions
Even if power lines and equipment aren’t severely damaged, modern grid protection systems intentionally trip circuits to prevent cascading overloads during extreme weather. An intense line of thunderstorms dropping hail can suddenly knock out power across many communities. Unfortunately, this will leave many homeowners sitting in darkness while the storm rumbles through. For longer disruptions, home backup power can support selected compatible circuits when properly installed.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
How Can You Prepare Your Home for a Weather-Related Power Outage?
A little preparation before a winter storm or hail warning is issued will help you manage through an outage and reduce damage around the home. Here are some steps to take to fortify your household.
Secure Outdoor Items Before Severe Weather
Strong winds accompany almost every hailstorm and winter squall. Patio umbrellas, lightweight deck chairs, hanging planters, and trash bins can easily be blown around and overturned. Move things into the garage if you can, or tie them up securely to a support before the front rolls in.
Reduce Risks From Broken Glass During Hail
When a hail warning is issued, pull your vehicles straight into the garage or beneath a sturdy carport. Close interior blinds, shades, and heavy drapes throughout the house. If a large hailstone or flying tree branch cracks a window pane, closed curtains help minimize the extent of the glass and damage.
Keep Emergency Supplies Easily Accessible
To avoid having to search in a dark home for emergency use items, have these gathered well before a storm. Learning how to prepare for a winter power outage in advance can help your household stay safer and better prepared through severe cold snaps. Keep a dedicated storm tote stocked with essentials somewhere where everyone knows. Include items like LED flashlights, extra alkaline batteries, a hand-crank NOAA weather radio, first-aid basics, blankets, and a supply of bottled drinking water.
Keep a Portable Power Station Ready for Short Outages
Extreme weather events can trigger a sudden, short-term power outage. When this happens, your immediate priority is keeping core essentials running. These would include your smartphones, Wi-Fi router, emergency lights, and maybe the kitchen refrigerator to save groceries from spoiling.
The EcoFlow DELTA 3 Max Portable Power Station, equipped with a 2,048Wh capacity and a 2,400W output, can power a range of common household appliances and critical electronics, provided their combined load stays within the unit’s output limits. The unit is conveniently portable so you can roll or carry it between the living room and home office, or whenever you need to shift your power focus.
Built for durability and performance, this system features automotive-grade LFP cells and an EV-grade structure, providing 10 years of reliable power with 24/7 BMS protection. It ensures seamless continuity for critical devices with a 10ms auto-switch and operates at a whisper-quiet ≤25dB.
Consider Larger Backup Power for Longer Outages
Ice storms and even violent summer hail storms can sometimes damage regional transmission towers. This impacts a large area, and can leave neighborhoods stranded without power for days. If you need to keep more than just a couple of appliances running, a whole-home back up power system is needed.
The EcoFlow DELTA Pro Ultra Whole-Home Backup Power offers expandable power storage starting at 6kWh and scaling all the way up to 90kWh. It can be configured to match with as much of your home’s total electrical footprint as needed. It is built specifically for scenarios where you need to run central heating/AC, well pumps, major refrigeration, and lighting circuits during longer outages. You determine the size you want.
The EcoFlow DELTA Pro Ultra is the only portable power station certified to both UL1973 and UL9540. It delivers 7.2-21.6kW, powerful enough to run your whole home even with a central AC. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
Sleet and hail may both hit the ground as ice, however they come from very different weather systems. Sleet is mainly a winter travel hazard, while hail is more likely to damage roofs, cars, windows, and outdoor equipment during severe thunderstorms.
The safest approach is to watch local alerts, protect exposed property when warnings are issued, and keep basic emergency supplies ready. If your area often sees winter storms or severe thunderstorms, a backup power plan can also help keep phones, lights, routers, and key appliances running until the power is restored.
At What Temperature Does It Start to Sleet?
Sleet typically occurs when surface temperatures hover near or just below freezing, usually between 28°F and 34°F. For sleet to form, a warmer layer of air above freezing must sit higher in the atmosphere, melting falling snow into rain before it refreezes near the ground.
Is Sleet Dangerous to Drive In?
Yes, sleet is exceptionally hazardous to drive on because it quickly compacts into a slick, deceptive sheet of ice that drastically reduces tire traction. Braking distances multiply, and vehicles can easily slide off roadways or spin out on highway overpasses, which freeze well before standard road surfaces.
Does Hail Hurt if It Hits You?
Yes, hail can cause real physical injury, especially stones larger than marble-sized (around 0.5 inches) falling at high speeds. Large hailstones can fall at speeds exceeding 70 mph, which is more than enough momentum to cause concussions, bruising, or severe cuts if you get caught outside without cover.
What to Do During a Hailstorm?
Move indoors immediately and stay far away from windows, skylights, and glass doors. If you are driving, stay in the vehicle and, when it is safe to do so, pull off the roadway in a location away from traffic. If possible, seek a sturdy covered structure such as a parking garage. Keep your face and head away from windows and protect yourself from broken glass.
Which Causes More Damage, Sleet or Freezing Rain?
Freezing rain causes significantly more damage than sleet because it remains liquid until it makes contact with trees, poles, and power lines, coating them in thick, heavy glaze that tears down infrastructure. Sleet bounces off objects and settles into manageable pellets, creating slick roads without adding the same immense, structural-snapping ice weight to power lines.
Home Backup
