CEMC Outage Map Guide: How to Report an Outage in Middle Tennessee
Cumberland Electric Membership Corporation, or CEMC, serves more than 116,000 members across Middle Tennessee. When the power goes out, a quick check of the CEMC outage map can show whether the utility is already tracking a problem in your area. You can also report the outage by phone, text, or through SmartHub. This guide explains how the map works, how to report an outage, what can cause service interruptions, and how to keep essential appliances running while crews make repairs.
How to Check the CEMC Outage Map
The CEMC outage map at outagemap.cemc.org shows current outages across its service area. You can use it to see whether other members in your area are without power and whether CEMC has already detected the problem. CEMC says most outages are automatically detected by its system. That means crews may already know about an outage before a member reports it.
What the CEMC outage map shows
The map can be useful when a storm moves through Middle Tennessee and several neighborhoods lose power at once. A quick look can tell you whether the outage appears to be limited to your home or affecting a wider area. Still, don't assume the map has every detail. Reporting your own outage gives CEMC another way to confirm the problem and its location. If you want to see how another Tennessee utility handles outage information, this guide to the NES outage map offers a useful regional comparison.
How to Report a CEMC Outage
CEMC gives members several ways to report a power outage. You can call or text the utility, use SmartHub, or submit a trouble ticket online. Even when the CEMC power outage map already shows a nearby outage, reporting your own loss of power can still help. It gives the utility another customer report tied to your location.
Report by phone or text
Call or text OUT to 800-987-2362 to report a power outage. Texting can be a convenient option if phone traffic is heavy after a major storm. CEMC notes that its toll-free line can occasionally have a dial tone during periods of high call volume. If that happens, try texting or using SmartHub instead.
Report through SmartHub
You can also report an outage through the SmartHub app or submit a ticket through trouble.cemc.org. These options let you report the problem without waiting on the phone. Have your account or service information available when you submit the report. If you know when the power went out or noticed damage nearby, include those details when the reporting system gives you a place to add them.
Downed lines need extra caution
A downed power line can still be energized. Stay away from the line and anything touching it, including trees, vehicles, fences, and standing water. Call 911 first if you see a downed power line. After that, report the line to CEMC separately so the cooperative knows where the hazard is located. Once you've reported the outage, the next priority is keeping essential appliances and devices running until CEMC restores service.
Backup Power While Waiting on CEMC
Storms can leave thousands of CEMC members without power at the same time. Downed poles and other storm damage can take time to repair, especially when crews have several areas to cover. A backup battery can keep important household equipment running during that wait, including a refrigerator, lights, phones, Wi-Fi equipment, and other essential devices.
If you don't need to power the whole house, a smaller portable power station can cover the essentials without the larger capacity of a whole-home system.
The right backup setup depends partly on how long an outage lasts. Knowing what can cause a CEMC outage can give you a better idea of what crews may be dealing with and why some repairs take longer than others.
CEMC's Service Area and Common Outage Causes
CEMC serves members across Middle Tennessee, including communities around Clarksville, Dover, Ashland City, Greenbrier, and Gallatin. The area includes suburban neighborhoods, smaller communities, and rural roads. Different parts of the system can also face different outage risks, from storm damage to equipment problems.
Storms and high winds
Severe thunderstorms can bring strong winds, lightning, and heavy rain to Middle Tennessee. Trees and branches can fall onto power lines or damage utility poles. A damaged pole can create a larger repair job than a problem affecting one piece of equipment. Crews may need to replace damaged equipment before they can safely restore the line. A recent outage in the Cumberland Electric service area also showed how unusual the cause of an outage can be. A downed utility pole has caused a large outage affecting CEMC customers in the area. For a broader look at why outages happen, this guide to common outage causes covers problems that affect electric grids across the country.
Equipment and wildlife problems
Not every CEMC outage follows a major storm. Equipment can fail and interrupt service in a smaller area. Wildlife can also cause problems around substations and other electrical equipment. These outages may affect fewer members, but they can still happen without much warning.
Why some repairs take longer
The location of the damage matters. A problem on a larger part of the electrical system can require more work before power reaches individual homes. Crews also need to work safely around damaged poles, lines, transformers, and other equipment. After a major storm, several repairs may be underway at the same time. If you're also comparing different backup options, this guide to home generators covers another approach to keeping essential loads running during an outage.
Staying Safe During a CEMC Outage
An outage can create hazards inside and outside your home. Downed lines, dark rooms, gas-powered equipment, and spoiled food all need extra attention while the electricity is off. Take a few simple precautions to protect your household until power is restored.
Stay away from downed power lines
Treat every downed line as live. Keep away from the line and anything touching it, including trees, fences, vehicles, and standing water. Don't try to move a branch or other object near the line. Keep children and pets away from the area, too. Call 911 first, then report the problem to CEMC so crews know where the hazard is located.
Keep generators outside
Never run a portable generator inside your home, basement, or attached garage. A generator can produce carbon monoxide, which can build up indoors and become dangerous quickly. Place the generator outside and away from doors, windows, and vents. Follow the manufacturer's instructions for setup, operation, and refueling.
Use flashlights after dark
Keep flashlights somewhere you can reach them easily during an outage. It's also smart to keep spare batteries on hand if your flashlights use them. Flashlights can make it easier to move around a dark home without the fire risk that comes with candles. Keep walkways clear, especially if children or older adults are in the house.
Keep the refrigerator and freezer closed
Try to keep your refrigerator and freezer doors closed while the power is out. Opening the doors lets cold air escape and can cause food to warm faster. If an outage lasts for many hours, backup power can help keep a refrigerator or freezer running. Planning ahead can also help reduce the cost of food spoilage and other problems during a longer outage.
The CEMC outage map gives Middle Tennessee members a quick way to check whether an outage is already being tracked. But it's still worth reporting your own outage through CEMC's phone, text, SmartHub, or online options. Save 800-987-2362 in your phone before the next storm. For downed power lines, call 911 first and then report the hazard to CEMC. A backup battery can also give you another option when the grid goes down. The EcoFlow DELTA Pro Ultra X is built for larger whole-home loads, while the EcoFlow DELTA 3 Max can cover a smaller group of essential appliances and devices.
How do I report a CEMC outage?
You can report a CEMC outage by calling or texting OUT to 800-987-2362. You can also report the problem through the SmartHub app or submit a ticket online. If you see a downed power line, call 911 first and stay away from the area.
What's the phone number for CEMC outages?
The CEMC outage phone number is 800-987-2362. You can call or text OUT to this number to report a power outage. If call volume is high, CEMC also provides reporting through SmartHub and its online trouble ticket system.
What areas does CEMC serve?
CEMC serves more than 116,000 members across Middle Tennessee. Its service area includes communities around Clarksville, Dover, Ashland City, Greenbrier, and Gallatin, along with surrounding residential and rural areas.
Does CEMC automatically know when my power is out?
CEMC says most outages are automatically detected by its system. Even so, members should still report an outage rather than assume the utility already knows. A direct report gives CEMC another source of information about the problem and its location.
How long do CEMC outages typically last?
There isn't one restoration time for every CEMC outage. A small equipment problem may require less repair work than a storm-damaged pole or several damaged lines. During a major storm, crews may also have multiple outages to repair across the service area.
