NYSEG Outage Map Guide: Reporting Steps for Upstate New York
The lights flicker, the furnace fan goes quiet, and your phone shows 30 percent battery. If you live in upstate New York, you've probably been there during an ice storm or a January nor'easter. The first question is always the same: is it just my house, or the whole street? The NYSEG outage map can usually answer that in a minute or two. This guide shows you how to read it, how to report an outage the fast way, how to keep essentials running, and how to stay safe until your power comes back.
How to Check the NYSEG Outage Map
Wondering whether NYSEG already knows your power is out? Start with the map, which you'll find in the Outages section of nyseg.com.
What the NYSEG Power Outage Map Shows
The NYSEG power outage map marks current NYSEG power outages across the company's upstate territory. Click an outage area to see how many customers are affected. Once crews have looked at the damage, you'll often see an estimated restoration time, too.
NYSEG splits its territory into regional divisions. These include Binghamton, Elmira, Ithaca, Mechanicville, and Brewster, and each one covers a group of counties. If you see a cluster of outages near your address, NYSEG most likely knows about it already. But a single dark house won't always show up on its own.
Using the NYSEG Outage List
Not a fan of maps? NYSEG also posts a county-by-county view of current outages. This NYSEG power outage list shows how many customers are out in each county. It's a quick way to see whether a storm hit just your town or half the region.
A NYSEG outages list is also handy when a storm spans several regions and crews get spread thin. If that sounds familiar, our guide to preparing for a long-term outage is good background reading.
The map shows what NYSEG already knows about. A specific address still needs to be reported directly, so the next step is filing your own report.
How to Report a NYSEG Outage
Don't assume your neighbors already called it in. Every report helps NYSEG find the damage. Before you report, check your own home first. Look at your breaker panel for a tripped breaker or a blown fuse. Then check whether your neighbors or the streetlights are also dark. NYSEG notes that if a crew shows up and the problem is your own wiring, you may be billed for the service call. Once you know it's a utility problem, pick one of these ways to reach NYSEG:
Method
How to Use It
Best For
Phone
Call 1-800-572-1131
Downed lines, hazards, or no internet
Online
Use the Report Outage form on nyseg.com
Quick reports with your account number handy
Mobile app
Report through the NYSEG app
Checking status on the go
Text
Text OUT to 697348
Customers already signed up for text alerts
During a big storm, filing a NYSEG outage report online or in the app is often faster than waiting on hold. Have your account number or phone number ready either way. You can also sign up for outage alerts by text, email, or voice. NYSEG will then let you know when it detects an outage, when the restoration time changes, and when your power is back.
Downed lines are different. If you see one, call 911 first, then report it to NYSEG separately. Keep yourself and your pets far back from the wire.
Once your outage is on record, the waiting begins. That's when backup power matters most, especially during NYSEG's bigger winter storm events.
Backup Power While Waiting on NYSEG
What would happen if your power stayed off for two or three days? For many upstate homes, that means no furnace blower, no well pump, and a fridge full of food at risk. Large storms can stretch restoration well past a single night. In NYSEG's March 2026 storm update, the utility reported responding to more than 149,000 outages after high winds swept the state, with over 450 contracted crews helping restore service.
Stay Comfortable During OutagesStay Comfortable During Outages
Before you pick a backup option, list what you truly need. Most families start with the fridge, a few lights, phone chargers, and the Wi-Fi router. Homes with a well pump, sump pump, or medical device may need more. Two numbers matter here. Watts tell you how much power a device draws at once. Watt-hours tell you how long your backup can keep it running. Here's how the common choices compare:
  • Gas generators can run for a long time, but they need fuel, make noise, and must stay outdoors because of carbon monoxide.
  • Portable power stations run quietly indoors and work well for the fridge, lights, and electronics.
  • Whole-home battery systems cover more circuits, including 240V appliances, but they need professional installation.
If you want most of your house covered through a multi-day outage, a whole-home system is worth a look. That's where a setup like the EcoFlow DELTA Pro Ultra X fits, since it's built to keep larger homes running when the grid goes down.
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. •High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
Not every home needs that much. If you mainly want to protect the fridge, run a few lights, and keep phones charged, a portable power station is simpler. You can also recharge it from solar panels once the storm clears. The EcoFlow DELTA 3 Max is one option in that range.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Knowing what usually causes these outages helps you set realistic expectations during a storm. It also helps you judge how long a given outage might last.
NYSEG's Service Area and Common Outage Causes
Ever wonder why one storm knocks out power for hours while another takes days? A lot of it comes down to geography. NYSEG, a subsidiary of Avangrid, serves more than 40 percent of upstate New York. According to NYSEG's service area page, that includes 924,544 electric customers across 44 counties, from the Southern Tier through the Finger Lakes to the Hudson Valley.
When Winter Storms StrikeWhen Winter Storms Strike
That's a lot of wire running through rural roads, hills, and wooded areas. Many power outages NYSEG crews handle in winter start with trees. Heavy, wet snow bends limbs onto lines. Freezing rain coats wires and branches until they snap. And strong wind events, like the March 2026 storm, can bring down poles across several counties at once.
Ice is often the worst of these. Even a thin coating adds real weight to power lines and tree limbs. You can learn more about how ice accumulation causes outages and why these events take so long to repair.
Whatever the cause, the same safety steps apply while your power is out. A few simple habits can prevent common storm injuries.
Staying Safe During a NYSEG Outage
Storm cleanup is where many people get hurt. Branches and debris in your yard may hide a downed wire or damaged equipment, even if you can't see it. Treat every downed wire as live and dangerous. NYSEG asks people to stay at least 30 feet away and report the wire by calling 1-800-572-1131 or 911.
Heating is the next big risk. If you use a gas generator, keep it outdoors. CDC's power outage safety guidance says never to run one inside your home, basement, or garage, or within 20 feet of a window, door, or vent. It also recommends a battery-powered or battery-backup carbon monoxide detector. Never use a gas stove or oven to heat your home.
Food Safety When the Fridge Goes Dark
Keep your fridge and freezer doors closed as much as you can. Per FoodSafety.gov's power outage chart, a closed fridge keeps food safe for up to 4 hours. A full freezer holds a safe temperature for about 48 hours, or about 24 hours if it's half full. When in doubt, throw it out.
Planning ahead makes the next storm easier. If you're weighing quieter, fuel-free options, our guide to solar generator backup walks through sizing and setup. For cold-weather tips, see our advice on surviving a winter storm outage before the next big storm hits.
Checking the NYSEG outage map and reporting your outage by phone, app, text, or online both matter, especially during upstate New York's long winter storm season. The map tells you what NYSEG already knows, and your report fills in the gaps. Save 1-800-572-1131 in your phone now, and check your breakers and your neighbors first, so you don't mistake a tripped breaker for a utility outage. A portable power station like the EcoFlow DELTA 3 Max can cover the basics, while a whole-home system like the EcoFlow DELTA Pro Ultra X can keep more of your house running through NYSEG's longer winter outages.
How do I report a NYSEG outage?
You can call 1-800-572-1131, use the Report Outage form on nyseg.com, or report through the NYSEG mobile app. If you've signed up for text alerts, you can also text OUT to 697348. Check your breakers first, since NYSEG may bill you if the problem is inside your home.
What's the phone number for NYSEG outages?
The number is 1-800-572-1131. It's the same line for outages, downed wires, and other hazards. If anyone's life is in danger, call 911 first.
What areas does NYSEG serve?
NYSEG serves more than 40 percent of upstate New York across 44 counties. Its territory runs from the Southern Tier and the Finger Lakes to the Hudson Valley, with divisions such as Binghamton, Elmira, Ithaca, Mechanicville, and Brewster.
How long do NYSEG outages typically last in winter?
It depends on the storm. A small, local outage may be fixed in a few hours. Major ice or wind storms can take several days, since crews have to clear trees and rebuild lines across many counties. Outage alerts and the map will show your estimated restoration time as crews assess the damage.
Is NYSEG the same company as RG&E?
No, they're separate utilities, but both are subsidiaries of Avangrid. RG&E serves the Rochester area, while NYSEG covers a much larger part of upstate New York. Each company has its own outage map and phone line.
Power Outages
