How to Create a Dominion Power Outage Plan for Medically Vulnerable Family Members
For families with medically vulnerable members, electricity powers vital equipment that keeps loved ones healthy and safe. Dominion Power outages happen 2-3 times yearly, putting the 35,000 people in their service area who rely on medical devices at serious risk. When equipment like oxygen machines or medication refrigerators lose power, health can quickly deteriorate. A good plan includes signing up for Dominion's Medical Program, getting reliable backup power, and knowing exactly what to do whether the outage lasts hours or days.
Identify Your Electricity-Dependent Medical Equipment
Medical equipment that requires electricity can be the difference between comfort and crisis during a power outage. Before creating your backup power plan, you need to know exactly what devices your family relies on and how much power they consume.
1. Breathing Support Equipment: Oxygen concentrators typically use 300-600 watts while running and must operate continuously. Ventilators are even more critical, using 50-300 watts depending on the model, and cannot tolerate even brief power interruptions without risking the patient's life.
2. Mobility Equipment: Power wheelchairs and scooters require regular charging, typically needing 6-8 hours to fully charge at 200-500 watts. Without power, mobility-dependent individuals may become stranded or unable to evacuate if necessary.
3. Temperature-Sensitive Medications: Insulin, certain antibiotics, and biologics must be refrigerated between 36-46°F. A standard medication refrigerator uses 100-150 watts and needs to run several hours daily to maintain proper temperature.
4. Sleep Apnea Machines: CPAP and BiPAP machines use 30-90 watts and typically run 7-8 hours nightly. While missing one night might be uncomfortable, multiple nights without treatment can lead to serious health complications for users.5. Home Dialysis Systems: Peritoneal dialysis machines use 300-500 watts and may run for 8-10 hours daily. Patients typically cannot skip treatments without medical consequences, making backup power essential.
Category
Medical Equipment
Power Usage (Watts)
Daily Operation Time
Daily Energy Need (Watt-hours)
Criticality Level
Breathing Support
Oxygen Concentrator
300-600 W
24 hours (continuous)
7,200-14,400 Wh
Critical - No interruption allowed
Ventilator
50-300 W
1,200-7,200 Wh
Mobility Equipment
Power Wheelchair/Scooter (charging)
200-500 W
6-8 hours
1,200-4,000 Wh
High - Daily charging needed
Temperature-Sensitive Storage
Medication Refrigerator
100-150 W
8-10 hours (cycling)
800-1,500 Wh
High - Max 4-6 hours interruption
Sleep Support
CPAP/BiPAP Machine
30-90 W
7-8 hours (nightly)
210-720 Wh
Medium - Brief interruption possible
Dialysis
Peritoneal Dialysis Machine
300-500 W
8-10 hours
2,400-5,000 Wh
Critical - Limited postponement
Set Up Reliable Backup Power for Medical Equipment
When someone in your family depends on powered medical devices, a reliable backup power system isn't optional—it's essential. The right system can keep life-supporting equipment running during outages and give your family peace of mind during storms or grid failures.
Medical-Grade UPS Systems
A medical UPS is plugged between your wall outlet and medical device and supplies instant backup power when the electricity goes out. Medical-grade systems, as opposed to standard computer UPS devices, supply "pure sine wave" output that sensitive medical equipment requires. They typically offer 30 minutes to 4 hours of backup time and range from $200-$600 depending on capacity.
Solar camping setup in mountain landscape.
Portable Power Stations
For moderate backup needs, portable power stations like the EcoFlow DELTA Pro 3 offer reliable power in a convenient rolling package. The main advantage is mobility— you can easily move it wherever power is needed or take it with you during evacuations. These stations come equipped with various outlet types and can be recharged from wall outlets, your car, or solar panels once power returns.
Whole-Home Backup Systems
For households with several medical devices or those that experience frequent outages, whole-home systems offer complete protection. These systems are installed in your home's electrical panel and automatically switch on chosen circuits during a grid failure.
Fast Switchover Technology
The most critical feature of medical equipment backup is switchover speed. The EcoFlow Smart Home Panel 2 provides a 10-millisecond transfer time—fast enough that even highly sensitive equipment like ventilators continue running without a hitch. Standard generators take 10-30 seconds to start, which is too slow for nearly all life-supporting devices.
Setting Up Medical Priority Circuits
When you install a backup system, work with your electrician and mark all power circuits powering medical equipment. Smart Home Panel 2 enables you to reserve these as priority circuits that switch on first and last when you go dark. By doing so, you ensure that your medical equipment keeps running while other home systems can be shut down to save the battery.
To determine how much battery capacity you need, add up the watt-hours your medical equipment uses daily. If your equipment uses 2,000 watts and needs to run for 24 hours, you'll need at least 48 kWh of battery storage. It's always wise to add an extra 20% for unexpected situations or system inefficiencies.
Most families can't power everything during long outages, so make a priority list. Put medical equipment at the top, followed by refrigeration for medications, basic lights, and phones or communication devices. With a Smart Home Panel 2, you can easily control which circuits receive power and for how long—ensuring your critical medical needs always take priority over less essential items.
How to Create Your Emergency Contact Network
When you rely on medical equipment, having the right people to call can make all the difference during a power outage. Here's how to prepare before you need help:
1. Make a list of all your important medical contacts
Make sure to write down phone numbers for your doctors, equipment suppliers, pharmacy, and insurance—after-hours numbers and your account numbers. Leave copies in handy places: on your refrigerator, in your wallet, and with your emergency kit.
2. Plan how your family will communicate during outages
In emergency cases, texts also pass through when calls don't. Have an emergency radio that can charge your phone and have backup power sources. Most families also employ simple code words to quickly explain how bad something is without alarming everyone.
3. Get a medical alert system that works during power failures
Services like Lifeline can be a lifesaver during hard times. When you press your button, they'll send the appropriate help—whether it's a neighbor, family member, or ambulance; they'll even call back to confirm that the aid did arrive. MedicAlert offers comparable services that give your vital medical information to emergency responders when seconds count.
4. Connect with neighbors who can check on you quickly
Your other neighbors can get to you before the emergency team will. That's why it is also a good practice to leave your contact information with familiar neighbors and even a spare key. Neighbors with medical experience or who are extremely well acquainted with your equipment can be especially helpful in those first critical hours.
5. Know where to go in your community when power is out
Most neighborhoods also have backup-powered facilities in the event of a blackout. Hospitals typically permit charging medical equipment, and the Red Cross typically opens shelters in the case of extended outages. Your local health department probably has special emergency programs for individuals with medical needs—something to ask about in advance before an emergency arises.
6. Sign up for special help from emergency services
Don't count on just one way to get to medical facilities. Keep phone numbers for medical ride services where you can find them easily, and know which vehicles can fit your equipment. It helps to practice moving your equipment between different vehicles before you're in a rush.
7. Sign up for special help from emergency services
Many cities let people with medical equipment register their addresses so they can get help first during widespread emergencies. Power companies also often have programs that warn you about planned outages and get your power back on faster if you have critical medical equipment. It's best to ask about these helpful services before you actually need them.
How to Protect Medical Equipment During Dominion Power Outages: First Minutes to Extended Blackouts
Having a clear, step-by-step plan for power outages removes guesswork during stressful situations. When someone's health depends on powered medical equipment, knowing exactly what to do at each stage of an outage can prevent panic and ensure continuous care.
The First Critical Hours (0-2 Hours)
1. Verify Your Backup Power Is Working
Your automatic backup system should start automatically when power is initially lost. For the first few minutes, visually check all your medical devices to determine if they are receiving power and running to specification. Don't assume your backup system came online properly on faith—verify with visual inspection that critical devices are running.
2. Check Battery Status and Runtime Estimates
For equipment like the EcoFlow Smart Home Panel 2, check the EcoFlow app or control panel for current power consumption and estimated runtime. For stand-alone UPS units, check their screens for battery life percentage and estimated remaining time. Make immediate adjustments if the runtime appears to be too short.
3. Activate Your Communication Plan
Send a standard text message to your designated support network stating your status and that you're experiencing an outage. If you're a participant in your power company's medical necessity program, call Dominion Power using their priority medical needs number rather than the general outage reporting system.
4. Implement Your Medical Protocol
Follow certain medical procedures you've agreed to with your physician for outages. This could include more intensive monitoring of oxygen levels, the timing of drugs being changed, or alternative treatment plans. Document any changes to standard practice for future sharing with medical personnel.
Managing Through the Day (2-24 Hours)
1. Conserve Power Strategically
Turn on your power-saving plan by turning off unnecessary equipment and lights. For medical equipment with programmable settings, consult your emergency guidelines to see if lower power settings are safe for short-term use. For example, some oxygen concentrators have economy modes that optimize battery life.
2. Rotate Portable Batteries
If you have over one battery of medical devices, have a rotation plan. Exhaust one battery when it has a 30% capacity, then switch to the next while you recharge the first using your power backup. Designate each battery with numbers in order to remember the rotation sequence.
3. Monitor Power Restoration Progress
Monitor Dominion Power's outage map or call their automated system every 4-6 hours for revised restoration estimates. Modify your power conservation plan based on these estimates—becoming more aggressive with conservation if the outage is likely to last longer than originally reported.
4. Maintain Temperature Control
For temperature-sensitive drugs or equipment, implement your temperature control strategy. This might be using ice packs in refrigerators for cold drugs or moving equipment to the coolest or warmest room in your home depending on the season.
Power station at outdoor cooking event
Handling Extended Outages (Beyond 24 Hours)
1. Activate Community Resources
If the outage is expected to continue for more than 24 hours, contact your pre-identified community resources. This could be going to a medical shelter, community charging station, or a friend's home that has electricity. Don't wait until your backup power is nearly fully depleted—act while you still have enough battery life to relocate all of the equipment you require.
2. Implement Alternative Power Sources
For prolonged outages, utilize secondary power sources like solar panels to charge your backup batteries. If a portable generator is present, adhere to your pre-established safety procedure for installation to prevent proper ventilation and the house itself.
3. Evaluate Relocation Thresholds
Check your pre-defined "decision points" for evacuation to a medical facility. They should be pre-defined conditions that you have set ahead of time—e.g., "If standby power falls below 20% with no recovery expected," or "If the interior temperature rises above 80°F for longer than 2 hours." Having these decision points set ahead of time takes the pressure off making difficult decisions in the heat of a stressful event.
4. Coordinate with Medical Providers
Contact your medical providers to coordinate any necessary adjustments to treatment regimens during the extended outages. They can recommend temporary medication schedules, alternative therapies, or, in some cases, preventive hospitalization until power is restored.
How to Test and Update Your Outage Plan Regularly
Even the best emergency plan becomes risky if outdated or untested. For those depending on medical equipment, regular practice isn't optional—it's essential for when you need it most.
Testing Your Emergency Response
  • Schedule full outage simulations quarterly with brief equipment checks in between. Instead of just imagining an outage, actually disconnect from utility power using your main breaker; this creates realistic conditions that test both your equipment and your family's readiness.
  • When testing backup systems, be thorough by connecting all medical devices you'd normally use during an outage. Let them run for 2-3 hours to confirm your system handles the combined load and to get a realistic picture of your runtime expectations.
  • Each powered device should have a manual backup that everyone in your household knows how to use. It's worth timing how these manual methods compare to their powered counterparts so you can plan accordingly during real emergencies.
  • During drills, a stopwatch becomes your friend. Measuring how long critical tasks take—from switching to backup power to relocating if necessary—helps you identify bottlenecks and improve with each practice session.
Keeping Your Plan Updated
  • Every three months, take time to review all medical conditions and equipment requirements. After medical appointments, immediately update your emergency plan if there are any changes to care needs.
  • At least twice yearly, verify that all emergency phone numbers still work. When changes occur, be sure to update both digital and printed copies of your contact information right away.
  • Monthly checks of expiration dates on batteries, distilled water, and backup medications should be part of your routine. Having a system to replace items before they expire ensures you're never caught unprepared.
  • Your power company's medical necessity registration should be reviewed annually; however, if your equipment needs to change significantly, contact them immediately rather than waiting for your yearly update.
  • Maintaining a record of when you update each part of your plan creates accountability and helps ensure nothing important gets overlooked during your regular reviews.
Power Up Your Medical Safety Plan Today
When your health depends on medical equipment, a good power outage plan isn't optional—it's a lifeline. By understanding your needs, getting the right backup equipment, creating simple step-by-step protocols, and practicing regularly, you turn potential crises into manageable events. Don't wait for the next storm warning. Start today by listing your power requirements and exploring financial help options. Talk to your doctor, power company, and local emergency office about available resources. Remember that preparation is ongoing—update your plan as your health needs change.
Solar Panels
