SMECO Outage Map Guide: How to Report an Outage in Southern Maryland
SMECO serves more than 180,000 members across Charles, Calvert, and St. Mary's counties. When the power goes out, knowing where to check the SMECO outage map and how to report the problem can save time. It can also help you understand whether the outage is already being tracked and what to do next. This guide covers outage reporting, storm preparation, backup power, and basic safety steps to help you stay prepared until service is restored.
How to Check the SMECO Outage Map
The SMECO Power Outage Map gives members a way to check outages across the cooperative's Southern Maryland service area. You can reach the map from the SMECO homepage after logging into your online account with your account number and address. The map provides real-time outage information, so it can help you see whether an issue has already been reported in your area. That can be useful after a storm, when several neighborhoods may lose power at once.
How to Check the SMECO Outage MapHow to Check the SMECO Outage Map
What the SMECO outage map shows
If your neighborhood has lost power, check the map before assuming you're the only one affected. The information can give you a better idea of whether SMECO already has an outage on its radar. Still, don't rely on the map alone. A specific address may need to be reported directly, even when you can see a nearby outage. For ideas on preparing a home for an outage, this guide to smart home backup covers backup approaches that can also apply to Southern Maryland households.
How to Report a SMECO Outage
If your electricity goes out, SMECO provides several ways to report the problem. You can call the outage line, report it online, or use SMECO's mobile and messaging options. It's a good idea to report the outage even if you can already see a nearby problem on the SMECO power outage map. SMECO says most members have smart meters, but customers should still report an outage rather than assume the system has already picked it up.
Report by phone
Call 1-877-74-SMECO (1-877-747-6326) to report a power outage. The number is available for outage reports and gives you a direct way to tell SMECO that your home has lost power. Have your service address ready when you call. If you know roughly when the power went out or whether nearby homes are also without electricity, that information can help describe what's happening in your area.
Report online or through the app
You can also report an outage through smeco.coop, SMECO's 24/7 mobile app, or its texting service. These options can be useful when a major storm has caused widespread outages and phone lines are busy. Before you submit a report, double-check your service information. If you noticed a damaged pole, fallen tree, or other visible problem, include those details when the reporting option gives you a place to add them.
Report downed lines separately
A downed power line needs extra caution. Stay away from the line and anything touching it, including trees, fences, vehicles, and standing water. For a downed line or a tree on a power line, call 1-888-440-3311. Treat every fallen line as energized and keep children and pets away from the area until the hazard has been handled. Once you've reported the outage, you'll need to keep essential parts of your home running while you wait for power to return.
Backup Power While Waiting on SMECO
Southern Maryland can see storm conditions that leave large numbers of customers without electricity. SMECO has reported more than 1,000 separate outage incidents during a single major storm, with some of the hardest-hit areas needing repairs into the following days. A charged power station can cover essential household needs while crews work through those repairs. Depending on the system and the appliances you need to run, backup power can keep a refrigerator, lights, communication devices, heating equipment, and other essentials operating.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If you don't need whole-home coverage, the EcoFlow DELTA 3 Max can handle a smaller set of essential appliances and devices. It has 2,048Wh of capacity and 2,400W of output. Its portable design also makes it easier to move and recharge between outages.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Knowing what causes SMECO outages can also give you a better sense of what crews may be dealing with and why some repairs take longer than others.
SMECO's Service Area and Common Outage Causes
SMECO is a nonprofit electric cooperative serving Charles, Calvert, and St. Mary's counties in Southern Maryland. Its service area covers a mix of suburban neighborhoods, smaller communities, rural roads, and coastal areas. The cause of an outage often affects the repair process. A fallen tree can damage several sections of the electrical system, while a localized equipment problem may affect a much smaller area.
Severe weather, trees, and flooding
Southern Maryland can see strong storms, high winds, and heavy rain. These conditions can lead to power outages across the area. SMECO cites falling trees and flooding from saturated ground as some causes of weather-related outages. A fallen tree can damage power lines, poles, transformers, and other equipment. That can leave crews with several repairs to handle. Hurricanes can also cause outages in multiple communities at once. If you're preparing for a longer outage, this guide to long-term power outages covers supplies and backup power to keep ready.
How SMECO prioritizes restoration
SMECO's restoration process starts with the larger parts of the electrical system and works toward individual homes. Transmission lines and substations are repaired first. Distribution lines come next, followed by individual service lines. That means your neighborhood may not get power back as soon as a nearby repair is finished. Crews may need to restore another part of the system before they can safely work on the line serving your home. For a broader look at outage causes and preparation, this power outage guide covers common problems and ways to prepare before the next storm.
Staying Safe During a SMECO Outage
An outage can create hazards inside and outside your home. Downed lines, dark rooms, gas-powered equipment, and spoiled food all need some extra attention while the electricity is off.
Staying Safe During a SMECO OutageStaying Safe During a SMECO Outage
Keep generators and grills outside
Never use a portable generator, gas grill, or charcoal grill inside your home, basement, or garage. These devices can produce carbon monoxide, an odorless gas that can build up quickly in enclosed spaces. Place generators outside and away from doors, windows, and vents. Follow the manufacturer's instructions for safe operation and keep the equipment dry.
Use flashlights instead of candles
A flashlight is a safer choice for moving around your home after dark. Keep a few charged flashlights where you can reach them easily, along with spare batteries if the lights use them. If you have young children or pets at home, keeping walkways clear can also reduce the chance of trips and falls during a nighttime outage.
Keep your refrigerator and freezer closed
Try to keep the refrigerator and freezer doors closed while the power is out. Every time you open the door, cold air escapes and the food warms faster. If you're planning backup power for a refrigerator or freezer, consider the potential costs of food spoilage and other expenses during an extended outage.
The SMECO outage map can help you check current outage information, but it shouldn't replace a direct report when your power goes out. You can report a power outage at 1-877-74-SMECO (1-877-747-6326) and use 1-888-440-3311 for a downed line or tree on a power line. Save both numbers before the next storm. For longer outages, having backup power ready can also keep key appliances and household devices running while SMECO crews work through repairs.
How do I report a SMECO outage?
You can report a SMECO outage by calling 1-877-74-SMECO (1-877-747-6326), using the SMECO website, or using its 24/7 mobile app and texting service. Have your service address ready when you report the problem. If you see a downed line or a tree on a power line, use 1-888-440-3311 and stay away from the area.
What's the phone number for SMECO outages?
The SMECO outage phone number is 1-877-74-SMECO (1-877-747-6326). Use this number to report a power outage and provide your service address and any useful details about the problem. For a downed line or tree on a power line, call 1-888-440-3311 instead.
What counties does SMECO serve?
SMECO serves Charles, Calvert, and St. Mary's counties in Southern Maryland. The cooperative provides electric service to more than 180,000 members across these counties. Its service area includes residential communities as well as more rural areas.
How long do SMECO outages typically last after a storm?
Restoration time depends on the cause and extent of the damage. SMECO prioritizes transmission lines and substations first. Distribution lines and individual service lines are repaired next. This means larger system repairs may need to be finished before power can return to your home.
Does SMECO have smart meters that report outages automatically?
SMECO has smart meters covering most of its members. Even so, the cooperative asks customers to report outages instead of assuming the problem was detected automatically. Your report gives SMECO more information about the outage at your address.
Power Outages
